245 MHz VHF CB
Revision as of 11:43, 22 April 2020 by R4002 (Talk | contribs)
Thailand only...known as "245 VHF" "245 CB" "CB 245" or other similar names. Extremely popular in Thailand, especially in urban areas. Popular with taxi and car services in Bangkok.
Radios must have red cases per Thai law. 80 channels, straight channel numbering sequence. 245-245.9875 MHz, 245.0000 MHz to 245.9875 MHz. CTCSS, DCS and other selective calling or squelch systems are legal and heavily used. Narrow band FM mode, 12.5 kHz channel steps.
Heavily used by taxi companies, delivery services, hobbyists, security companies, etc.  Given the proliferation of these radios, there are also indications that they are used by criminal elements and organized gangs for drug dealer lookouts and similar purposes (FRS is reportedly used for these purposes in the United States and elsewhere).
Thailand apparently has 26-27MHz CB - popular with fishing fleets, freebanders, ham operators and DXers, a mid-band VHF 78 MHz band service from 78.0000 MHz to 78.9875 MHz (12.5 kHz steps, 10 watt power limit and radios must be yellow) as well. Estimates of users above one million, especially in larger urban areas. Use of CTCSS, DCS and other squelch and selective calling systems is widespread due to heavy channel congestion and interference/QRM. According to reports, 27 MHz HF CB and 78 MHz VHF CB are niche services and 245 MHz VHF CB is by far the most commonly used personal radio service in Thailand and neighboring areas.
245 MHz VHF CB Thai Frequencies
Channel Frequency
Channel 1 245.0000 MHz
Channel 2 245.0125 MHz
Channel 3 245.0250 MHz
Channel 4 245.0375 MHz
Channel 5 245.0500 MHz
Channel 6 245.0625 MHz
Channel 7 245.0750 MHz
Channel 8 245.0875 MHz
Channel 9 245.1000 MHz
Channel 10 245.1125 MHz
Channel 11 245.1250 MHz
Channel 12 245.1375 MHz
Channel 13 245.1500 MHz
Channel 14 245.1625 MHz
Channel 15 245.1750 MHz
Channel 16 245.1875 MHz
Channel 17 245.2000 MHz
Channel 18 245.2125 MHz
Channel 19 245.2250 MHz
Channel 20 245.2375 MHz
Channel 21 245.2500 MHz
Channel 22 245.2625 MHz
Channel 23 245.2750 MHz
Channel 24 245.2875 MHz
Channel 25 245.3000 MHz
Channel 26 245.3125 MHz
Channel 27 245.3250 MHz
Channel 28 245.3375 MHz
Channel 29 245.3500 MHz
Channel 30 245.3625 MHz
Channel 31 245.3750 MHz
Channel 32 245.3875 MHz
Channel 33 245.4000 MHz
Channel 34 245.4125 MHz
Channel 35 245.4250 MHz
Channel 36 245.4375 MHz
Channel 37 245.4500 MHz
Channel 38 245.4625 MHz
Channel 39 245.4750 MHz
Channel 40 245.4875 MHz
Channel 41 245.5000 MHz
Channel 42 245.5125 MHz
Channel 43 245.5250 MHz
Channel 44 245.5375 MHz
Channel 45 245.5500 MHz
Channel 46 245.5625 MHz
Channel 47 245.5750 MHz
Channel 48 245.5875 MHz
Channel 49 245.6000 MHz
Channel 50 245.6125 MHz
Channel 51 245.6250 MHz
Channel 52 245.6375 MHz
Channel 53 245.6500 MHz
Channel 54 245.6625 MHz
Channel 55 245.6750 MHz
Channel 56 245.6875 MHz
Channel 57 245.7000 MHz
Channel 58 245.7125 MHz
Channel 59 245.7250 MHz
Channel 60 245.7375 MHz
Channel 61 245.7500 MHz
Channel 62 245.7625 MHz
Channel 63 245.7750 MHz
Channel 64 245.7875 MHz
Channel 65 245.8000 MHz
Channel 66 245.8125 MHz
Channel 67 245.8250 MHz
Channel 68 245.8375 MHz
Channel 69 245.8500 MHz
Channel 70 245.8625 MHz
Channel 71 245.8750 MHz
Channel 72 245.8875 MHz
Channel 73 245.9000 MHz
Channel 74 245.9125 MHz
Channel 75 245.9250 MHz
Channel 76 245.9375 MHz
Channel 77 245.9500 MHz
Channel 78 245.9625 MHz
Channel 79 245.9750 MHz
Channel 80 245.9875 MHz
Reports indicate that significant amounts of simplex and duplex repeater systems exist on these frequencies, in addition to fixed base stations with high gain base station antennas. The majority of users appear to use portable handheld radios and mobile radios mounted in vehicles for simplex purposes.
80 channels 245.0000 to 245.9875 MHz 12.5 kHz steps. FM mode only (narrowband FM, aka NBFM or NFM, likely 11K0F3E, 11K2F3E or similar emission). Many radios can easily be modified to cover 240-270 MHz or similar frequency ranges. Most 245 MHz CB radios include a channel display and frequency display, or offer the end user the option of switching from channel display, frequency display or dual channel/frequency display.
As of the late 2010s (2018-2019, into 2020), entry level dual band VHF/UHF equipment such as the Baofeng UV-5R series are available in tri-band or three-band models, generally covering 220-225 MHz, switchable to 220 MHz - 260 MHz, 220 MHz - 270 MHz or similar ranges. Others are explicitly sold as tri-band radios that cover 245 MHz in addition to the standard 136-174 MHz VHF and 400-470 MHz or 400-520 MHz UHF bands. Quad-band radios are available that cover the 350-390 MHz UHF band of the 350-400 MHz UHF band as well.
