HF pagers
Frequency List
| Frequency | Remarks |
| 26.145 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.150 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.150 MHz | Hospital pagers (Holland) FM mode - confirmed active May 2020 |
| 26.155 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.160 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.165 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.170 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.175 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.250 MHz | Hospital pagers (Holland) FM mode - confirmed active May 2020 |
| 26.300 MHz | Hospital pagers (Holland) FM mode - confirmed active May 2020 |
| 26.350 MHz | Hospital pagers (Holland) FM mode - confirmed active May 2020 |
| 26.400 MHz | Hospital pagers (Holland) FM mode |
| 26.450 MHz | Hospital pagers (Holland) FM mode |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland |
| 26.995 MHz | Remote Control Technology Long Range Wireless Switch System LRWSS model # 01217 4-watt FSK (FM) 27MHz transmitter |
| 27.070 MHz | POGSAG Pager FM - Russian origin - Russia paging frequency |
| 27.255 MHz | Linear Controls XT-1 "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.510 MHz | Paging, voice and data - possibly offset 27.5125 MHz |
| 27.650 MHz | Data link/Carrier signal, FM/FSK, possibly military - confirmed active again March 2019 |
Keywords:
