Amphetamine Radio
Were you looking for fishnet stockings radio beacons?
Amphetamine Radio has not been heard for quite some time (as of February 2025). The op has indicated that he is currently unable to put up a proper antenna and will attempt to resume broadcasts once that situation changes.
