Signal Identification
Revision as of 15:08, 5 December 2014 by Token (Talk | contribs)
Why is this Guide here?
With the advent and proliferation of SDRs to the hobby of shortwave listening, and the often associated wideband waterfall / spectrum displays, hobbyist are now more likely to notice short duration, transient, signals. Signals are now visually presented that in the past would not have been noticed at all unless the listener just happened to be tuned to the right random frequency when the short duration signal occurred. This has had the affect of raising the probability of reception of any given signal type, regardless of duration. Further, these waterfalls and spectrum images can be used to ID specific modes of operation, as different techniques often have very different visual signatures.
Today's online receiver nodes (from services like Globaltuner.com, SDR-Radio.com, and websdr.org) mean that more people than ever potentially have access to monitor the HF spectrum. Often people with no prior exposure to HF radio or shortwave listening first gravitate to these kinds of services, as they take no investment in equipment to start using.
Go to the HFUnderground HF Mystery Signal board and follow the guidelines presented there for posting. Assuming the signal is IDed there, and it is not already on the list here, it will likely be added to this list.
If you look at each segment of the guide you will see it is divided into two types of signals, "Non DATA Signals" and "DATA Signals". Each section is further broken down into sub categories.
Basic information shown
"Spectrum Image" is a 200 pixel wide expandable thumbnail image of the signal, typically either the spectrum or a waterfall / histogram of some kind. Typically the full size version of this images is at least 640 x 480.
Signals
Non DATA Signals
Communications Modes
Mode Frequency Range (kHz) Bandwidth (kHz) Shift (Hz) Number of Tones Key Features Sources Recording Spectrum Image
AM All Frequencies in the HF Range Typically 2.6 to 10.0 kHz, can be wider or narrower Not Applicable Not Applicable Carrier present in center of signal, audio typically mirrored left and right of the carrier World wide AM recording link here AM SWBC 7520.jpg
CW
(Morse Code)
All Frequencies in the HF Range Very narrow, potentially less than 50 Hz Not Applicable Not Applicable Line or broken line on the waterfall, no sidebands, may show wider "key clicks" at the start and stop of each dot and dash World wide CW recording link here CW ham 7030.jpg
LSB All Frequencies in the HF Range Typically 2.4 to 3.0 kHz, can be wider or narrower Not Applicable Not Applicable No carrier present in Spectrum, audio typically bunched to towards the right (low audio frequency) World wide LSB recording link here LSB ham 7155.jpg
USB All Frequencies in the HF Range Typically 2.4 to 3.0 kHz, can be wider or narrower Not Applicable Not Applicable No carrier present in Spectrum, audio typically bunched to towards the left (low audio frequency) World wide USB recording link here USB ham 14185.jpg
Non Communications Modes
16 x 64 Sounder (nickname, official name or designation not known) Below 4000 to above 30000 observed 2.5 kHz Not Applicable Not Applicable FMCW transmission, changes sweep rates in 16 steps, resulting in 16 different sounds per transmission, a pilot tone may precede each rate change but is not always present Unknown Media:16x64_sounder.mp3
16 x 64 sounder recording
PLUTO radar (possible offical name, PLUTO II, suggested by open source documents) 8000 to 38000 3 to 40 kHz, depending on specific operating conditions Not Applicable Not Applicable FMCW transmission, presenting a wide signal equal to the swept (chirped) width, sweep rate creates a pulsed sound affect British Sovereing base of Akrotiri, Island of Cyprus PLUTO recording link here LSB-signal.png
Need to put some kind of break here, a line or something, to sep out the Non DATA from DATA
Probably need to put a desription of what is meant by DATA Signals in this area.
DATA Signals
FSK Modes
CIS 36-50, BEE, T-600 All Frequencies in the HF Range 0.085 to 0.500 kHz (85 to 500 Hz depending on mode) 85, 125, 250, or 500, only one shift used at a time 2 Appears as two lines on waterfall, seperated by the shift, normally encrypted Used by Russian or Russian supplied forces, a mode of the T-600 modem CIS 36-50 recording link here USB-signal.png
STANAG 4481 FSK All Frequencies in the HF Range 0.85 kHz (850 Hz) 850 Hz 2 Appears as two lines on waterfall, seperated by the shift, normally encrypted Used by NATO forces world wide 4481 FSK recording link here LSB-signal.png
MFSK Modes
PSK Modes
SELCAL Modes
Image Modes
