Part 15 Beacons
Revision as of 18:52, 20 February 2019 by Double Zepp (Talk | contribs)
Overview
  • 160 - 190 kHz
  • 13.553 - 13.567 kHz (often referred to as 13560 kHz, 13.56 MHz or 22 neters)
  • 26960 - 27280 kHz
160-190 kHz Part 15 Beacons
  • 167.180 LC Sacramento CA
  • 181.818 JH Florence SC
  • 182.448 R Keeler CA
  • 183.500 WD2XFJ Burbank CA
  • 185.100 22A Baraga MI
  • 185.185 SIW Oswego IL
  • 185.290 KT Oswego KS
  • 185.297 TAG Raymond ME
  • 185.299 SIW Oswego IL
  • 185.303 SJ East Haven CT
  • 185.650 WE2XEB Penn Yan NY
  • 186.204 MLS Massilon OH
  • 187.015 J La Crescenta CA
  • 187.507 WI Aiken SC
  • 188.830 EAR Saltford, ON
13560 kHz Part 15 Beacons
  • 13554.000 AZ Oro Valley AZ
  • 13555.414 TAG Holden MA
  • 13555.420 JIM Dallas TX
  • 13555.430 SIW Elgin IL
  • 13555.440 SIW Elgin IL
  • 13555.450 MP London ON
  • 13555.462 EH East Haven CT
  • 13555.472 7P Ajo AZ
  • 13555.500 NC Stanfield NC
  • 13555.528 EDJ Monroe GA
  • 13555.920 WV Richwood, WV
  • 13555.98 TSN
  • 13556.200 HHH CT/MA Border (testing, may not be 24/7)
  • 13556.600 OH Findlay OH
  • 13557.50 PBJ Tracey City TN
  • 13557.800 PLM [UNKNOWN]
  • 13558.2 PVC
  • 13558.510 AJO Ajo AZ
  • 13562.080 NDB
  • 13562.950 SZX Macomb IL
  • 13563.000 RR
  • 13563.55 PCO Colorado
  • 13564.280 T Sun City CA
  • 13562.80 GNK Madison WI
  • 13564.20 RF Grid EM96 NC
  • 13565.04 K6FRC Patterson CA
  • 13566.20 AMA Hamilton ON
Pending beacons:
  • Freq TBD VVV CT/MA Border (Vertical dipole, solar powered)
  • Freq TBD WOO Worcester, MA (Solar powered)
None reported
22 meter band beacon kit
FCC Regulations
160 - 190 kHz
  emissions.
13560 kHz
  meters.
  meters.
  limits in §  15.209.
  device.
26960 - 27280 kHz
