VHF LADD
VHF LADD (Logging Administration Dispatch), LD (Loading Channels) RR (Resource Road or Road Resource) channels, standardized for trucking, logging and use in remote areas for truck-to-truck, truck-to-base and emergency services communications with trucks, loading channels, etc. These frequencies are known by several names, including the Ice Road Channels, Loading Channels, LD channels LAD channels, LADD channels, Resource Road channels, Logging common, VHF trucking channels, Canadian trucking channels and several other combinations of these. In remote areas of Canada, specific sections of roads are assigned specific channels.
While these frequencies were originally intended only for use by logging companies, remote dispatch (think Ice Road Truckers) and other specialized use, the proliferation of inexpensive VHF-FM equipment means their usage has become more widespread and these frequencies have become de facto "interoperability" frequencies in remote areas of Canada. The LADD channels in particular are used by natural resources officers to communicate with logging companies as well as for truck-to-truck, handheld radios for flaggers at loading sites and for other specialized purposes.
The LADD and RR frequencies are used as an adjunct to CB radio (called General Radio Service in Canada - same frequencies and modes as the USA) in some places, and in others, CB radio is used as an adjunct to the VHF LADD and VHF RR and LD channels. Note that the similar MURS VHF CB frequencies are not permitted in Canada for these purposes. VHF LADD does not replace regular CB. Trucks should still retain regular 27 MHz AM CB radios in addition to a VHF radio with LADD/LD/RR channels programmed into memory.
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
| Channel | Frequency | Remarks/Usage |
| LADD 1 | 154.1000 MHz | LADD channel 1 - trucking and logging companies, natural resource agencies |
| LADD 2 | 158.9400 MHz | LADD channel 2 - trucking and logging companies, natural resource agencies |
| LADD 3 | 154.3250 MHz | LADD channel 3 - trucking and logging companies, natural resource agencies |
| LADD 4 | 173.3700 MHz | LADD channel 4 - trucking and logging companies, natural resource agencies |
| LD 1 | 151.7000 MHz | Loading channel 1 |
| LD-2 | 151.7450 MHz | Loading channel 2 |
| LD-3 | 151.7900 MHz | Loading channel 3 |
| LD-4 | 151.8050 MHz | Loading channel 4 |
| LD-5 | 151.8500 MHz | Loading channel 5 |
| RR-01 | 150.0800 MHz | Resource Road channel 1 |
| RR-02 | 150.1100 MHz | Resource Road channel 2 |
| RR-03 | 150.1400 MHz | Resource Road channel 3 |
| RR-04 | 150.1850 MHz | Resource Road channel 4 |
| RR-05 | 150.2000 MHz | Resource Road channel 5 |
| RR-06 | 150.2450 MHz | Resource Road channel 6 |
| RR-07 | 150.2600 MHz | Resource Road channel 7 |
| RR-08 | 150.3200 MHz | Resource Road channel 8 |
| RR-09 | 150.3650 MHz | Resource Road channel 9 |
| RR-10 | 150.4100 MHz | Resource Road channel 10 |
| RR-11 | 150.4400 MHz | Resource Road channel 11 |
| RR-12 | 150.5000 MHz | Resource Road channel 12 |
| RR-13 | 150.5300 MHz | Resource Road channel 13 |
| RR-14 | 150.5450 MHz | Resource Road channel 14 |
| RR-15 | 150.5600 MHz | Resource Road channel 15 |
| RR-16 | 150.5900 MHz | Resource Road channel 16 |
| RR-17 | 150.6800 MHz | Resource Road channel 17 |
| RR-18 | 150.7100 MHz | Resource Road channel 18 |
| RR-19 | 150.7700 MHz | Resource Road channel 19 |
| RR-20 | 150.8300 MHz | Resource Road channel 20 |
| RR-21 | 151.0100 MHz | Resource Road channel 21 |
| RR-22 | 151.1300 MHz | Resource Road channel 22 |
| RR-23 | 151.1900 MHz | Resource Road channel 23 |
| RR-24 | 151.2200 MHz | Resource Road channel 24 |
| RR-25 | 151.3100 MHz | Resource Road channel 25 |
| RR-26 | 151.3400 MHz | Resource Road channel 26 |
| RR-27 | 151.3700 MHz | Resource Road channel 27 |
| RR-28 | 151.4300 MHz | Resource Road channel 28 |
| RR-29 | 151.4600 MHz | Resource Road channel 29 |
| RR-30 | 151.4900 MHz | Resource Road channel 30 |
| RR-31 | 151.5200 MHz | Resource Road channel 31 |
| RR-32 | 151.5800 MHz | Resource Road channel 32 |
| RR-33 | 151.6100 MHz | Resource Road channel 33 |
| RR-34 | 151.6400 MHz | Resource Road channel 34 |
| RR-35 | 151.6700 MHz | Resource Road channel 35 |
