HF marine
Revision as of 14:41, 17 July 2019 by R4002 (Talk | contribs)
See also: VHF marine band
Band Frequency Range
2450-2850 kHz MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-3 MHz)
16460-17360 kHz HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz
25070-25121 kHz HF 25 MHz marine band
26145-26175 kHz HF 26 MHz marine band
26175-30000 kHz Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz)
  • 2003.0 kHz
  • 2065.0 kHz
  • 2079.0 kHz
  • 2082.5 kHz
  • 2086.0 kHz
  • 2093.0 kHz
  • 2096.5 kHz
  • 2142.0 kHz
  • 2203.0 kHz
  • 2214.0 kHz
  • 2635.0 kHz
  • 2638.0 kHz
  • 2670.0 kHz - this frequency is also used for maritime weather forecasts
  • 2738.0 kHz
  • 2782.0 kHz
  • 2830.0 kHz
  • 4146.0 kHz
  • 4149.0 kHz
  • 4417.0 kHz
  • 6224.0 kHz
  • 6227.0 kHz
  • 6230.0 kHz
  • 6516.0 kHz
  • 8294.0 kHz
  • 8297.0 kHz
  • 12353.0 kHz
  • 12356.0 kHz
  • 12359.0 kHz
  • 12362.0 kHz
  • 12365.0 kHz
  • 16528.0 kHz
  • 16531.0 kHz
  • 16534.0 kHz
  • 16537.0 kHz
  • 16540.0 kHz
  • 16543.0 kHz
  • 16546.0 kHz
  • 18825.0 kHz
  • 18828.0 kHz
  • 18831.0 kHz
  • 18834.0 kHz
  • 18837.0 kHz
  • 18840.0 kHz
  • 18843.0 kHz
  • 22159.0 kHz
  • 22162.0 kHz
  • 22165.0 kHz
  • 22168.0 kHz
  • 22171.0 kHz
  • 22174.0 kHz
  • 22177.0 kHz
  • 25100.0 kHz
  • 25103.0 kHz
  • 25106.0 kHz
  • 25109.0 kHz
  • 25112.0 kHz
  • 25115.0 kHz
  • 25118.0 kHz
401 4065 kHz 4357 kHz
402 4068 kHz 4360 kHz
403 4065 kHz 4357 kHz
404 4065 kHz 4357 kHz
405 4065 kHz 4357 kHz
406 4065 kHz 4357 kHz
407 4065 kHz 4357 kHz
408 4065 kHz 4357 kHz
409 4065 kHz 4357 kHz
410 4065 kHz 4357 kHz
411 4065 kHz 4357 kHz
412 4065 kHz 4357 kHz
413 4065 kHz 4357 kHz
414 4065 kHz 4357 kHz
415 4065 kHz 4357 kHz
416 4065 kHz 4357 kHz
417 4065 kHz 4357 kHz
418 4065 kHz 4357 kHz
419 4065 kHz 4357 kHz
420 4065 kHz 4357 kHz
421 4065 kHz 4357 kHz
422 4065 kHz 4357 kHz
423 4065 kHz 4357 kHz
424 4065 kHz 4357 kHz
425 4065 kHz 4357 kHz
426 4065 kHz 4357 kHz
427 4065 kHz 4357 kHz
428 4065 kHz 4357 kHz
429 4065 kHz 4357 kHz
601 6200 kHz 6501 kHz
602 6203 kHz 6504 kHz
603 6206 kHz 6507 kHz
604 6209 kHz 6510 kHz
605 6212 kHz 6513 kHz
606 6215 kHz 6516 kHz
607 6218 kHz 6519 kHz
608 6221 kHz 6522 kHz
801 4065 kHz 4357 kHz
802 4068 kHz 4360 kHz
803 4065 kHz 4357 kHz
804 4065 kHz 4357 kHz
805 4065 kHz 4357 kHz
806 4065 kHz 4357 kHz
807 4065 kHz 4357 kHz
808 4065 kHz 4357 kHz
809 4065 kHz 4357 kHz
810 4065 kHz 4357 kHz
811 4065 kHz 4357 kHz
812 4065 kHz 4357 kHz
813 4065 kHz 4357 kHz
814 4065 kHz 4357 kHz
815 4065 kHz 4357 kHz
816 4065 kHz 4357 kHz
817 4065 kHz 4357 kHz
818 4065 kHz 4357 kHz
819 4065 kHz 4357 kHz
820 4065 kHz 4357 kHz
821 4065 kHz 4357 kHz
822 4065 kHz 4357 kHz
823 4065 kHz 4357 kHz
824 4065 kHz 4357 kHz
825 4065 kHz 4357 kHz
826 4065 kHz 4357 kHz
827 4065 kHz 4357 kHz
828 4065 kHz 4357 kHz
829 4065 kHz 4357 kHz
830 4065 kHz 4357 kHz
831 4065 kHz 4357 kHz
832 4065 kHz 4357 kHz
833 4065 kHz 4357 kHz
1201 4065 kHz 4357 kHz
1202 4068 kHz 4360 kHz
1203 4065 kHz 4357 kHz
1204 4065 kHz 4357 kHz
1205 4065 kHz 4357 kHz
1206 4065 kHz 4357 kHz
1207 4065 kHz 4357 kHz
1208 4065 kHz 4357 kHz
1209 4065 kHz 4357 kHz
1210 4065 kHz 4357 kHz
1211 4065 kHz 4357 kHz
1212 4065 kHz 4357 kHz
1213 4065 kHz 4357 kHz
1214 4065 kHz 4357 kHz
1215 4065 kHz 4357 kHz
1216 4065 kHz 4357 kHz
1217 4065 kHz 4357 kHz
1218 4065 kHz 4357 kHz
1219 4065 kHz 4357 kHz
1220 4065 kHz 4357 kHz
1221 4065 kHz 4357 kHz
1222 4065 kHz 4357 kHz
1223 4065 kHz 4357 kHz
1224 4065 kHz 4357 kHz
1225 4065 kHz 4357 kHz
1226 4065 kHz 4357 kHz
1227 4065 kHz 4357 kHz
1228 4065 kHz 4357 kHz
1229 4065 kHz 4357 kHz
1230 4065 kHz 4357 kHz
1231 4065 kHz 4357 kHz
1232 4065 kHz 4357 kHz
1233 4065 kHz 4357 kHz
1234 4065 kHz 4357 kHz
1235 4065 kHz 4357 kHz
1236 4065 kHz 4357 kHz
1237 4065 kHz 4357 kHz
1238 4065 kHz 4357 kHz
1239 4065 kHz 4357 kHz
1240 4065 kHz 4357 kHz
1241 4065 kHz 4357 kHz
1601 4065 kHz 4357 kHz
1602 4068 kHz 4360 kHz
1603 4065 kHz 4357 kHz
1604 4065 kHz 4357 kHz
1605 4065 kHz 4357 kHz
1606 4065 kHz 4357 kHz
1607 4065 kHz 4357 kHz
1608 4065 kHz 4357 kHz
1609 4065 kHz 4357 kHz
1610 4065 kHz 4357 kHz
1611 4065 kHz 4357 kHz
1612 4065 kHz 4357 kHz
1613 4065 kHz 4357 kHz
1614 4065 kHz 4357 kHz
1615 4065 kHz 4357 kHz
1616 4065 kHz 4357 kHz
1617 4065 kHz 4357 kHz
1618 4065 kHz 4357 kHz
1619 4065 kHz 4357 kHz
1620 4065 kHz 4357 kHz
1621 4065 kHz 4357 kHz
1622 4065 kHz 4357 kHz
1623 4065 kHz 4357 kHz
1624 4065 kHz 4357 kHz
1625 4065 kHz 4357 kHz
1626 4065 kHz 4357 kHz
1627 4065 kHz 4357 kHz
1628 4065 kHz 4357 kHz
1629 4065 kHz 4357 kHz
1630 4065 kHz 4357 kHz
1631 4065 kHz 4357 kHz
1632 4065 kHz 4357 kHz
1633 4065 kHz 4357 kHz
1634 4065 kHz 4357 kHz
1635 4065 kHz 4357 kHz
1636 4065 kHz 4357 kHz
1637 4065 kHz 4357 kHz
1639 4065 kHz 4357 kHz
1640 4065 kHz 4357 kHz
1641 4065 kHz 4357 kHz
1642 4065 kHz 4357 kHz
1643 4065 kHz 4357 kHz
1644 4065 kHz 4357 kHz
1645 4065 kHz 4357 kHz
1646 4065 kHz 4357 kHz
1647 4065 kHz 4357 kHz
1648 4065 kHz 4357 kHz
1649 4065 kHz 4357 kHz
1650 4065 kHz 4357 kHz
1651 4065 kHz 4357 kHz
1652 4065 kHz 4357 kHz
1653 4065 kHz 4357 kHz
1654 4065 kHz 4357 kHz
1655 4065 kHz 4357 kHz
1656 4065 kHz 4357 kHz
See also:
