HF pagers
Frequency List
| Frequency | Remarks |
| 26.145 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.150 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.150 MHz | Hospital pagers (Holland) FM mode |
| 26.155 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.160 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.165 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.170 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.175 MHz | Marine Instruments Radio Buoys Telemetry |
| 26.250 MHz | Hospital pagers (Holland) FM mode |
| 26.300 MHz | Hospital pagers (Holland) FM mode |
| 26.350 MHz | Hospital pagers (Holland) FM mode |
| 26.400 MHz | Hospital pagers (Holland) FM mode |
| 26.450 MHz | Hospital pagers (Holland) FM mode |
| 26.500 MHz | Paging, heard in Europe, noted use in Holland |
| 27.070 MHz | POGSAG Pager FM - Russian origin - Russia paging frequency |
| 27.255 MHz | Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode |
| 27.510 MHz | Paging, voice and data - possibly offset 27.5125 MHz |
| 27.650 MHz | Data link/Carrier signal, FM/FSK, possibly military - confirmed active again March 2019 |
Keywords:
26 MHz pager 27MHz paging 27.255 MHz data link 27 MHz data transmitter 27007 kHz 27255 kHz FCC Part 15 Part 95 POCSAG 26.995MHz 27.045MHz 27.095MHz 27.145MHz 27.195MHz 27.225MHz 27.235MHz 27.245MHz 27.255MHz 27.270MHz 27.12 MHz ISM 27MHz band paging Long Range Systems 467.750 MHz RCRS Remote Control Radio Service 25 watt 27.255 data 27MHz data link 100mw low power data link IOT low frequency 900 MHz 151.820 MHz 151.880 MHz 151.940 MHz 154.570 MHz 154.600 MHz MURS data datalink 154MHz 151MHz license free long range 10 watt FSK signal Linear Systems WAVE lightning detector remote monitoring link 27MHz CB radio frequency list HFUnderground Community Audio Distribution Service CADS Wireless Public Address System WPAS 27.995 MHz 26.000 MHz 26MHz paging pager EU harmonized radio bands allocation 27.5 MHz 27500 kHz 27.905 MHz 10mw 1w 1 watt 27.915 MHz 27.965MHz 27.975 MHz 27.985 MHz 27.555 MHz international fixed service 26955 26.955 26,955 26,995 27,045 27,095 27,145 27,195, 27,225, 27,255 11_meter freeband 11 meter band 30 MHz band 29 MHz band 26 MHz band are 10 meter radios illegal freeband frequencies how do I use a CB radio police frequencies driftnet fishnet beacon radiobuoy buoy transmitter 1.6-4 MHz 26-28 MHz 26-30 MHz radio beacon 11m CB repeater 11 meter repeater MURS repeater 151.880 151.820 151.940 156.7 167.9 173.8 154.57 154.600 MHz crossband repeater
