HF pagers
Revision as of 19:23, 7 May 2020 by R4002 (Talk | contribs)
Frequency List
Frequency Remarks
26.100 MHz Hospital pagers (Holland) FM mode
26.145 MHz Marine Instruments Radio Buoys Telemetry
26.150 MHz Marine Instruments Radio Buoys Telemetry
26.150 MHz Hospital pagers (Holland) FM mode
26.155 MHz Marine Instruments Radio Buoys Telemetry
26.160 MHz Marine Instruments Radio Buoys Telemetry
26.165 MHz Marine Instruments Radio Buoys Telemetry
26.170 MHz Marine Instruments Radio Buoys Telemetry
26.175 MHz Marine Instruments Radio Buoys Telemetry
26.300 MHz Hospital pagers (Holland) FM mode
26.350 MHz Hospital pagers (Holland) FM mode
26.400 MHz Hospital pagers (Holland) FM mode
26.450 MHz Hospital pagers (Holland) FM mode
26.850 MHz Hospital pagers (Holland) FM mode
27.095 MHz European standardized Eurobalise train telemetry system (27.090 MHz - 27.100 MHz)
27.255 MHz RadioShack 7-watt FSK paging transmitter on-site system frequency (legal under Part 95 of FCC rules)
27.255 MHz Linear Controls XT-1 "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode
27.650 MHz Data link/Carrier signal, FM/FSK, possibly military - confirmed active again March 2019
Keywords:
