VHF UHF logs
Revision as of 21:14, 27 May 2021 by R4002 (Talk | contribs)
THIS IS A PLACEHOLDER
CSQ is carrier squelch (no tone or code). Most radios default to CSQ or 67.0 Hz, Some radios, in particular pre-programmed FRS handhelds, have specific CTCSS or DCS tones/codes associated with a specific channel/frequency "Most ""job site"" handheld radios default to 67.0 Hz, 88.5 Hz or 023 DCS but there are numerous exceptions " "FRS units are most likely to use CSQ, although a significant number default to ""code 1"" (67.0 Hz)" SIGNAL STRENGTH/QUALITY Signal QUALITY: Date Frequency Tone/Code Channel ID Remarks - User(s) - presumed or confirmed, signal strength, time of day, association with other logs, etc. LOUD GOOD FAIR - signal strength still strong enough to copy message POOR - parts of message unreadable UNREADABLE 2/25/2021 151.5125 136.5 Hz Tower crane control (very busy) 151.8050 71.9 Hz Dominion Energy drone pilot - inspecting power lines 462.7625 88.5 Hz Night shift tower crane control Signal READABILITY 462.7875 88.5 Hz Night shift tower crane control CLEAR (or CRYSTAL) 462.8125 88.5 Hz Night shift tower crane control READABLE 462.8375 88.5 Hz Night shift tower crane control DISTORTED or GARBLED 467.6375 CSQ FRS 11 Local school, active during weekdays only "FADING - also called ""picket fencing"" - signal strength rapidly changing - generally occurs when two mobile stations are " 462.7250 432 DCS FRS 22 Spanish, lots of music and alert/alarm tones on channel 462.7250 136.5 Hz FRS 22 Construction crew, weaker than the 432 DCS guys 462.6750 606 DCS FRS 20 Hardware store in-store communications 462.6125 127.3 Hz FRS 03 School 151.9400 74.4 Hz MURS 3 Truckers, truck to truck CB-like chatter (radios appear to be on wideband mode, receivable on 151.9450 MHz as well) 462.7125 159.8 Hz FRS 07 Downtown parking garage or security force 462.5875 118.8 Hz FRS 02 Local COVID testing or vaccine testing site 462.6625 79.7 Hz FRS 05 UNID users 2/26/2021 467.5625 CSQ FRS 08 UNID users 464.5000 88.5 Hz Brown Dot IT networking crew checking network and WiFi coverage at VCU Children's Hospital 464.5000 179.9 Hz Brown Dot Hotel staff 467.9250 218.1 Hz Blue Star Tower crane crew 467.6625 67.0 Hz FRS 12 Service elevator requests - construction site downtown 154.4900 67.0 Hz Highway sign/infrastructure maintenance crews 151.6260 167.9 Hz Red Dot Crane Master - truck to truck 151.8200 131.8 Hz MURS 1 Water/sewer pipe inspection/repair crew 151.8800 131.8 Hz MURS 2 Water/sewer pipe inspection/repair crew 461.1125 162 DCS Construction 462.9125 192.8 Hz Construction 462.8125 136.5 Hz Construction 462.8375 136.5 Hz Construction 461.1125 67.0 Hz Hotel 154.5700 371 DCS MURS 4 Utility crews, portables 154.6000 371 DCS MURS 5 Utility crews, portables 469.5000 114.8 Hz Tower crane control (also active on 469.550 [114.8 Hz]) 469.5500 114.8 Hz Tower crane control 461.1625 67.0 Hz Hotel 451.8000 712 DCS Tower crane control 151.8200 67.0 Hz MURS 1 Hotel/hospitality 462.7250 136.5 Hz FRS 22 Catering company - active downtown 3/2/2021 466.3375 156.7 Hz Spanish language 464.5000 67.0 Hz Brown Dot """Large amount of trash here""" 151.5950 85.4 Hz Construction or maybe heavy materials hauling or other similar activity (simplex, portables?) - no local other licensed users 464.5000 712 DCS Brown Dot Tower crane control 467.8750 229.1 Hz Gold Star Tower crane control 152.4425 445 DCS Henrico County Public Schools - Repeater (confirmed user) 152.3000 023 DCS Yellow Cab Dispatch only (taxis transmit on 157.5600 MHz) 461.3625 97.4 Hz Construction 464.8250 026 DCS Tower crane control, mixing with repeater using 179.9 Hz on same frequency 467.7125 226 DCS FRS 14 FRS call tones heard, weak 464.8250 179.9 Hz Philip Morris - Chesterfield area (repeater - confirmed user) 462.5625 CSQ FRS 01 UNID - possibly children playing with radios 467.9000 82.5 Hz Red Star Construction crew, weak 467.6375 CSQ FRS 11 School 457.5250 315 DCS School - confirmed user 462.5875 100.0 Hz FRS 02 Sporadic activity, possible school or similar organization 464.5500 67.0 Hz Yellow Dot Window installation crew? 152.3000 445 DCS Henrico County Public Schools - Repeater (confirmed user) 469.5625 464 DCS Spanish 451.8125 703 DCS Construction crew 462.6250 127.3 Hz FRS 18 School, weak 467.7125 131 DCS FRS 14 Security 466.1625 506 DCS Construction 466.2625 506 DCS Construction 466.0875 506 DCS Crane control/construction 466.3125 156.7 Hz """check to make sure the kids aren't over by the..."" ""10-4"" " 462.5875 118.8 Hz FRS 02 """we need another wheelchair""" 464.5500 131.8 Hz Yellow Dot """The DEC guys want..."" " 464.5500 114 DCS Yellow Dot UNID 466.3625 506 DCS Crane control 462.7250 431 DCS FRS 22 Spanish 469.5000 506 DCS Spanish 469.5500 506 DCS Spanish 464.4875 82.5 Hz Weak 151.7000 67.0 Hz Portables, poor signal 464.5000 67.0 Hz Brown Dot Crane control 154.5050 072 DCS Henrico County Public Schools - Repeater (confirmed user) 462.9125 192.8 Hz Strong, possibly crane control 462.8125 627 DCS """Want to request one now"" ""pull up to the corner"" " 462.7625 026 DCS """Jacket"" " 467.7125 107.2 Hz FRS 14 Weak signal, 464.4875 136.5 Hz """814"" ""T K U"" ""copy that"" " 464.5500 67.0 Hz Yellow Dot Crane control 462.6875 CSQ FRS 06 """Just call me if you need me"" ""they're playing tennis and they are really bad"" ""okay buddy"" " 464.5500 627 DCS Yellow Dot """3/4 bolt needs to be snapped"" ""the bolt is missing"" ""somebody didn't tell them that the bolts need to be snapped"" ""cable walk"" " 469.5625 123.0 Hz """okay 10-4"" ""level gauge"" ""yes sir""" 464.5125 115 DCS """stop there"" (weak) " 154.4825 152 DCS Henrico County Public Schools - Repeater (confirmed user) 469.5500 114.8 Hz Related to 462.9125 [192.8 Hz] Crane operator chatter, English/Spanish 469.5125 136.5 Hz """came back to get you guys motivated"" " 462.6250 127.3 Hz FRS 18 School, possibly multiple users on same frequency/tone 462.7125 146.2 Hz FRS 07 Weak, maybe retail or security? 462.7125 159.8 Hz FRS 07 Downtown security or parking garage 451.8000 023 DCS Construction or concrete contractor 3/5/2021 462.7125 023 DCS FRS 07 """polarization"" ""coming your way""" 154.5700 371 DCS MURS 4 Utility or road repair crew (portables) 462.6750 606 DCS FRS 20 """brown couch at the front display, he's gonna pick it up tomorrow""" 3/10/2021 462.7250 146.2 Hz FRS 22 "two mobile units having a long casual conversation, mention of ""Hanover County""" 154.5700 162.2 Hz MURS 4 Weak, Spanish language chatter 154.5700 371 DCS MURS 4 Construction/utility work 462.7125 159.8 Hz FRS 07 """bring it up to 12"" - downtown parking garage or security " 462.8625 88.5 Hz Tower crane control chatter 464.5000 612 DCS Brown Dot Construction 464.5500 271 DCS Yellow Dot Construction 462.5875 118.8 Hz FRS 02 """classroom"" ""wheelchair"" " 464.5500 627 DCS Construction, likely same group logged on 3/2/2021 151.5125 136.5 Hz Crane control 151.6250 97.4 Hz Red Dot Possibly cemetery or funeral home? portables or mobiles 467.6625 67.0 Hz FRS 12 Elevator floor requests, similar to traffic heard on FRS 12 and FRS 7 previously 457.5250 315 DCS Local school 467.6375 CSQ FRS 11 Local school 469.5000 047 DCS Tower crane control 462.6875 023 DCS FRS 06 Telecom installation team secondary 462.7125 023 DCS FRS 07 Telecom installation team (also heard on FRS 06 and FRS 03) 462.6125 023 DCS FRS 03 Telecom installation team secondary 467.6125 CSQ FRS 10 """it already dropped"" ""the end of it""" 462.5625 023 DCS FRS 01 "Telecom installation team - ""get that other side of the antenna"" (strong) " 462.6000 023 DCS FRS 17 Local school, switched from 467.6375 to this freq 462.5875 025 DCS FRS 02 Window installation or repair crew? 462.6125 67.0 Hz FRS 03 Weak chatter 154.4900 67.0 Hz Highway maintenance or lighting/sign repair crew (numerous previous logging on this frequency/tone) 3/11/2021 462.6625 136.5 Hz FRS 05 COVID testing or vaccination coordination? possibly 462.6750 606 DCS FRS 20 Local hardware or furniture store 462.6875 141.3 Hz FRS 06 "Weak, mention of ""waiting room"" " 462.6750 136.5 Hz FRS 20 Local school, previously was on [023 DCS], some minor interference from 462.6750 [606 DCS] 464.5500 627 DCS Yellow Dot Construction, strong signals 467.6625 67.0 Hz FRS 12 Service elevator requests (floors being called out) 466.0875 506 DCS Crane control 464.5000 67.0 Hz Brown Dot Spanish language 462.6875 85.4 Hz FRS 06 Construction, heard lengths (of something) being read (with Roger beeps) 3/12/2021 467.5625 67.0 Hz FRS 08 """my cousin gave me something to wash my car with"" ""okay cool"" " 464.5000 627 DCS Brown Dot Spanish/English - likely construction 464.5500 627 DCS Yellow Dot Spanish/English - likely construction 469.5500 506 DCS Spanish chatter 154.5700 371 DCS MURS 4 Construction crew, talking about supplies being delivered today 462.6250 136.5 Hz FRS 20 Local school, with Roger beeps 462.6125 77.0 Hz FRS 03 weak 467.5625 243 DCS FRS 08 """his answers in the form responses are all green so I guess he's in the clear?"" " 457.5250 315 DCS Local school, strong signals 462.8125 88.5 Hz Crane control or construction 462.9125 192.8 Hz Construction 462.7125 023 DCS FRS 07 Telecom install/antenna installation 151.6250 065 DCS Red Dot AIRCARE EAGLE Medevac Dispatch 462.6625 136.5 Hz FRS 05 UNID user, only caught tail end of transmission 467.8750 218.1 Hz Gold Star Construction 151.5125 136.5 Hz Crane control, strong signals as usual 151.7000 141.3 Hz Utility or sewer repair crew? 462.7250 67.0 Hz FRS 22 """come in, testing..."" ""okay"" " 466.2625 445 DCS construction chatter 464.8250 026 DCS Crane control 464.8250 179.9 Hz Philip Morris repeater 462.7125 94.8 Hz FRS 07 """Did you get that, Marjorie?"" ""that class up here"" ""so what are you saying, you don't want to take the day off?""" 462.6000 023 DCS FRS 17 Local school, possibly primary (see also 462.6750 [136.5 Hz]) 462.6625 136.5 Hz FRS 05 Construction, possibly a different group from the earlier log on same frequency/tone 462.7125 146.2 Hz FRS 07 UNID user, weaker than group using 94.8 Hz 469.5000 114.8 Hz Crane control 469.5625 043 DCS Weak signal, presumably construction related 151.8800 114 DCS MURS 2 "Heard mention of ""classroom"" " 467.8125 97.4 Hz """K"" Dot" Talking about trash cans? 462.7125 159.8 Hz FRS 07 Same group as previously logged on this frequency/tone 151.8200 67.0 Hz MURS 1 Hotel or hospitality operations 154.5150 67.0 Hz "Mention of ""Mayo Bridge"" (weak) " 466.0875 506 DCS Crane control 462.6125 127.3 Hz FRS 03 """three"" ""okay three more"" " 467.8500 627 DCS Silver Star Spanish language chatter 3/14/2021 462.5750 654 DCS FRS 16 Construction? weak/sporadic 462.6000 118.8 Hz FRS 17 Unknown language chatter 151.6250 67.0 Hz Red Dot Portables, possibly flagmen directing traffic 462.6625 79.7 Hz FRS 05 Talking about exit numbers, likely people caravanning on I-95 or I-64 467.5875 97.4 Hz FRS 09 Spanish 154.5700 123.0 Hz MURS 4 UNID user 462.6000 455 DCS FRS 17 Construction chatter 3/15/2021 462.7625 026 DCS Talking about camera setups (portables) 462.7250 136.5 Hz FRS 22 """that's it"" ""okay, 32, thanks"" " 469.5500 114.8 Hz Tower crane coordination (very active at times) 154.5700 127.3 Hz MURS 4 Radio checks, likely local radio op, possibly militia or paramilitary user 466.0875 506 DCS Crane control 462.7125 159.8 Hz FRS 07 """pickup on 9"" ""when you get to 10 can you...."" " 3/16/2021 462.7250 431 DCS FRS 22 Spanish language, very active at times 462.6250 127.3 Hz FRS 18 """Mrs. Williams"" ""chair"" " 462.6500 351 DCS FRS 19 Local school 462.6875 85.4 Hz FRS 06 Talking about cars? weak chatter 461.1625 67.0 Hz Hotel/hospitality 467.9250 67.0 Hz Blue Star Catering company? 451.8125 466 DCS Construction, background noises heard 464.5000 179.9 Hz Brown Dot Engineering/maintenance coordination 464.5500 346 DCS Yellow Dot Crane control or other construction activity, strong signals 151.5125 136.5 Hz Crane control 462.7250 136.5 Hz FRS 22 Weak, mixing with other users using [431 DCS] 464.5500 627 DCS Yellow Dot """Is that pipe down there?"" ""Can we take that apart?"" ""The thing is gonna hook...up here..."" " 464.5500 179.9 Hz Yellow Dot Weak, may be related to 464.5000 [179.9 Hz] 467.8750 79.7 Hz Gold Star Unknown user 154.5700 371 DCS MURS 4 Construction or road repair crew (portable radios) 467.9000 074 DCS Red Star """so that's gonna be...."" ""Roger"" (weak) " 467.7125 131 DCS FRS 14 Weak, was able to decode DCS but UNID traffic 462.5875 025 DCS FRS 02 talking about ductwork 456.8125 85.4 Hz Construction 462.6625 136.5 Hz FRS 05 Parking lot coordination? 151.9550 94.8 Hz Purple Dot Coordinating vehicles 151.6250 67.0 Hz Red Dot Talking about lighting? possibly film or camera crew (portables) 462.5625 67.0 Hz FRS 01 Sounds like kids playing with radios 462.5625 250.3 Hz FRS 01 Heard right after the group using 67.0 Hz, different end of transmission tone (Roger Beep) - likely different groups 462.6250 127.3 Hz FRS 18 """Yolanda Barr - what's her number?"" ""get her a radio?"" ""incoming 1040"" " 462.6125 127.3 Hz FRS 03 """Scott Lee, please call 227"" ""I need a sharps container at table 19"" " 462.5250 114.8 Hz """towels"" ""bring them back around""" 462.5875 71.9 Hz FRS 02 """nurse station"" ""number 2"" " 469.5000 205 DCS """how's that looking now?""" 469.5000 192.8 Hz """the panel"" " 462.7125 159.8 Hz FRS 07 Same group heard on this frequency/tone almost daily 466.0875 506 DCS Very active crane control/construction chatter 464.5000 179.9 Hz Brown Dot Active with very strong signals, testing smoke or heat detectors 154.4900 67.0 Hz Highway maintenance or similar work crew contractor 151.6250 77.0 Hz Red Dot Radio checks, very weak 3/17/2021 462.6375 210.7 Hz FRS 04 """hello?"" - Roger beeps heard, weak signals around 8:00 AM" 462.8625 88.5 Hz Construction, good signals 464.5500 627 DCS Yellow Dot Construction, very active 462.8375 88.5 Hz Spanish 467.5625 77.0 Hz FRS 08 """he's pulling up now"" ""okay thank you"" " 467.6625 67.0 Hz FRS 12 Elevator floor requests 467.7625 131.8 Hz """J"" Dot" """adjust the..."" ""5 feet"" " 462.6750 136.5 Hz FRS 20 School 151.8200 103.5 Hz MURS 1 Coordinating delivery of materials (weak) 467.5625 CSQ FRS 08 """back about one-third..."" ""okay"" (weak)" 464.5500 243 DCS Yellow Dot Weak 464.5000 179.9 Hz Brown Dot Engineering? mixing with another user on frequency 151.6250 167.9 Hz Red Dot Crane Master Truck to Truck - confirmed licensed user 158.4000 167.9 Hz Crane Master Alternate - confirmed licensed user 467.5625 CSQ FRS 08 There appear to be 2 or 3 different groups using same frequency 464.8250 026 DCS Crane control - same group as previously monitored 469.5625 712 DCS IT or systems engineers, weak 457.5250 315 DCS School - portables 462.7000 131.8 Hz FRS 21 Spanish 462.7250 431 DCS FRS 22 Spanish, same group that was previously monitored 151.5125 136.5 Hz The usual crane control traffic 462.5875 CSQ FRS 02 Stuck mic (dead air) for 20-30 seconds around 8:30 AM, no CTCSS or DCS 464.5000 172 DCS Brown Dot Crane control mixing with IT or HVAC testing crew or engineering crew using 179.9 Hz 462.7250 252 DCS FRS 22 """Michael Wilson will be coming down also"" " 467.8750 206.5 Hz Gold Star Likely tower crane control or construction traffic 456.8125 023 DCS Concrete construction contractor - portable radios 464.5500 88.5 Hz Yellow Dot Window installation crew? 462.7250 136.5 Hz FRS 22 """at 2:00"" ""Ellie has a 1:30 appointment so she's coming on in""" 462.6000 77.0 Hz FRS 17 """that's Susan, right?"" ""yes ma'am"" " 154.5150 67.0 Hz """another trailer"" ""okay Johnny"" " 462.6625 79.7 Hz FRS 05 """right there at 1636..."" " 462.6250 127.3 Hz FRS 18 Requesting assistance at table 3 3/18/2021 467.7625 065 DCS """J"" Dot" """attention associates: new order"" (automated voice)" 464.5500 165 DCS Yellow Dot Spanish language 467.8375 263 DCS Retail 467.7500 115 DCS Target Store operations (active) 154.6000 CSQ MURS 5 Retail store, possibly WalMart - note complete lack of CTCSS tone or DCS code usage on a very popular (and license free!) channel / frequency 154.5700 CSQ MURS 4 Retail store, possibly WalMart - note complete lack of CTCSS tone or DCS code usage on a very popular (and license free!) channel / frequency 461.2625 023 DCS RMC Events 462.6125 103.5 Hz FRS 03 Possible retail store user 467.8750 85.4 Hz Gold Star """associate"" " 467.7625 97.4 Hz """J"" Dot" possible retail user as well 462.6625 203.5 Hz FRS 05 """Channel 25"" ""copy that"" " 461.3625 023 DCS RMC Events (simplex - portable radios) 467.8750 413 DCS Gold Star """attention associated...curbside pickup...attention assocaties...curbside pickup..""" 467.8500 331 DCS Silver Star Retail 467.9250 67.0 Hz Blue Star """ring back"" ""price check"" " 467.8750 411 DCS Gold Star Retail, weaker than group using 413DCS 467.9000 88.5 Hz Red Star weak 467.6375 CSQ FRS 11 Local school (switched frequencies again) 464.3250 546 DCS RMC Events (simplex - portable radios) 3/19/2021 462.6250 127.3 Hz FRS 18 """17"" ""can you get them?"" ""she might have an appointment at another time"" ""no, 1980"" - active " 151.6250 167.9 Hz Red Dot Crane Master Truck to Truck - confirmed licensed user 464.5000 179.9 Hz Brown Dot Network or IT engineers testing smoke or heat sensors 151.5125 136.5 Hz Crane control, usual users of this frequency/tone 462.6750 606 DCS FRS 20 Retail store (portables) 462.5875 CSQ FRS 02 Weak, FRS call tones heard 467.6125 073 DCS FRS 10 "FRS ""Roger Beeps"" heard" 469.5000 205 DCS """come in, Travis""" 469.5000 151.4 Hz Weak, construction (Spanish/English) 154.5700 88.5 Hz """got you on the top"" (??) " 464.5500 67.0 Hz Yellow Dot """306"" ""alright"" " 462.6625 88.5 Hz FRS 05 Tail end of a transmission 462.7250 67.0 Hz FRS 22 """what's up pal?"" ""my stomach...can't...fill....up...."" " 3/22/2021 464.5000 025 DCS Brown Dot Spanish 462.5625 67.0 Hz FRS 01 "Weak, heard YL talking w/""roger beeps""" 154.5700 371 DCS MURS 4 Same group previously monitored on this frequency/tone 462.7125 159.8 Hz FRS 07 """position good"" ""okay you got it on lock"" - presumed same previous user of frequency/tone " 464.5500 627 DCS Yellow Dot """1010 to base"" ""yeah I got crane time"" ""that's gotta go on level 7"" - very active " 467.7875 132 DCS Voice inversion scrambling with FSK/ANI burst at the end of transmissions 469.5500 114.8 Hz """just so you know I'm working right next to your counterweight on your right side"" " 469.5000 205 DCS """hey Lizzie have you seen them pallets?"" " 469.5500 506 DCS Spanish 151.5125 136.5 Hz Same group previously monitored on this frequency/tone 466.0875 506 DCS Crane control, possibly related to 469.5500 [506 DCS] 469.5500 205 DCS Weak, possible construction 462.6250 127.3 Hz FRS 18 """told her that her brother can't be here if he's symptomatic...she's going to call their mom"" (strong signal) " 159.5625 074 DCS Henrico County Public Schools - Repeater (confirmed user) 462.7250 136.5 Hz FRS 22 """right, Portland"" (very strong/local signal) " 466.1875 506 DCS """Bring it back up""" 462.6750 136.5 Hz FRS 20 Local school or daycare 467.6375 CSQ FRS 11 Local school 464.8250 026 DCS Crane control (simplex, very active) 467.9250 100.0 Hz Blue Star """Mikey are you on here or are you on 2?""" 464.8250 179.9 Hz Philip Morris (confirmed user with 179.9 Hz tone - wide area repeater) 462.7625 365 DCS """11th Street"" ""direction"" (weak, likely portable radios) " 457.5250 315 DCS """I'm outside of Virginia Hall"" ""okay I'll let Julia know"" ""okay thanks"" " 462.6375 131.8 Hz FRS 04 """220"" ""okay Mrs. Nelson"" ""another appointment"" " 467.8500 179.9 Hz Silver Star Hotel/hospitality 467.8500 67.0 Hz Silver Star Weak, probably construction related 154.4900 67.0 Hz Highway maintenance or repair crew 464.5000 173.8 Hz Brown Dot Spanish, heard several two-digit numbers being read 464.5500 94.8 Hz Yellow Dot """level 13"" ""check"" ""pick up"" (weak) " 467.6625 67.0 Hz FRS 12 Elevator floor requests 462.6875 141.3 Hz FRS 06 Weak chatter, UNID users 462.8125 612 DCS """copy"" " 464.5000 205 DCS Brown Dot Construction, possibly alternate channel 154.5400 023 DCS Portables, presumed construction comms 462.9125 192.8 Hz """coming in"" ""okay stop"" " 467.8750 229.1 Hz Gold Star """Roberto you got me on here?"" ""yeah"" ""is it okay if I come up?"" ""yep you're good""" 462.5625 77.0 Hz FRS 01 """swing it to the left...to the left...""" 462.6125 127.3 Hz FRS 03 """Juanita?"" ""okay""" 467.5625 85.4 Hz FRS 08 """number 3...two of them"" ""okay I think they're number 3s"" ""the reducers fit no. 3" 3/23/2021 464.5500 627 DCS Yellow Dot Crane operations - primary channel very active 154.6000 67.0 Hz MURS 5 "Driver training control - ""next driver please"" ""30 percent brake"" ""no ABS this time"" ""remember this is a..."" ""okay nice easy stop"" etc. (portables, very active around 9:00-9:15am) " 469.5000 205 DCS Same group/users monitored using frequency/code previously 3/24/2021 461.0875 179.9 Hz """6 more inches...okay tie it off"" ""Beth has joined the party I'm gonna hand you off to her"" " 464.5500 627 DCS Yellow Dot Crane operations - primary channel very active 457.5750 315 DCS """let her know that somebody is stopping for a temperature check"" " 469.5125 165 DCS """1004"" ""another beam"" ""okay that's good"" ""truck"" " 467.7875 132 DCS Scrambled transmissions (similar to previously logged activity on this frequency and tone) 462.5250 114.8 Hz """bring the....students..."" (weak, simplex)" 462.5500 123.0 Hz FRS 15 """total..."" " 151.8050 136.5 Hz Henrico County Public Schools - Repeater (confirmed user) 462.6875 146.2 Hz FRS 06 """Mr. Baskerville"" " 467.7625 94.8 Hz """J"" Dot" Weak, heard construction noises in background 151.7450 74.4 Hz Henrico County Public Schools - Repeater (confirmed user) 151.7825 162 DCS Henrico County Public Schools - Repeater (confirmed user) 462.6750 606 DCS FRS 20 Retail store, variable signal strength 464.5000 67.0 Hz Brown Dot """ten and five...ten and five"" ""okay right...more to the right...""" 456.8125 732 DCS """back down to the second girder"" " 467.7125 131 DCS FRS 14 Security or similar group 151.9100 565 DCS Henrico County Public Schools - Repeater (confirmed user) 450.2250 023 DCS Hotel or hospitality use, portables/simplex 462.6125 97.4 Hz FRS 03 Heard FRS call tones 467.8125 103.5 Hz """K"" Dot" Hotel operations, possibly valet parking operations 464.5375 85.4 Hz Hotel/hospitality (weak) 159.6450 162.2 Hz Trucking company yard operations/security 464.5500 103.5 Hz Yellow Dot """Room 611"" ""main trunk"" " 469.5500 506 DCS Spanish 461.2125 67.0 Hz "Mention of ""service elevator"" " 451.8125 023 DCS Concrete construction contractor - portable radios 462.7250 67.0 Hz FRS 22 "Kids playing around on the radio - ""hello!!!"" ""heyyy hello!!!!"" etc. (heard around 4:10-4:15pm)" 467.6375 CSQ FRS 11 Local school, same user previously monitored using FRS 11 without any CTCSS or DCS 467.8750 79.7 Hz Gold Star Weak, Spanish language chatter 469.5500 023 DCS Concrete construction contractor - portable radios 3/25/2021 467.6625 67.0 Hz FRS 12 """Pick up level 12....pick up on 12 please""" 151.5125 136.5 Hz Crane control (busy) 151.5125 411 DCS Another user mixing in (weaker than the strong 136.5 Hz signals) 462.7250 218.1 Hz FRS 22 Weak, bits and pieces heard breaking squelch 151.8200 186.2 Hz MURS 1 "Building maintenance or engineering, heard mention of ""panel 3"" " 462.6875 146.2 Hz FRS 06 Likely same user logged yesterday using same frequency/tone 462.9375 703 DCS Retail? 467.7625 065 DCS """J"" Dot" Retail operations 466.3375 743 DCS "Talking about tubing, ""when will the delivery truck be here?""" 464.5500 627 DCS Yellow Dot "English/Spanish ""open the gate...Northside"" ""yeah give me a second " 467.5625 85.4 Hz FRS 08 """no, hold the thing like 2 inches from your mouth"" ""okay can you hear me now!?"" ""yes that's like...perfect.."" ""yeah the damn thing is like 6 inches from my mouth now"" ""okay you're good right there then"" ""I guess my tutor isn't going to be able to...I have like no wifi at all, even the mobile hotspot isn't working""" 467.5625 67.0 Hz FRS 08 """what about Jamar?"" ""I guess he's not coming in today"" " 154.5050 072 DCS Henrico County Public Schools - Repeater (confirmed user) 462.6250 127.3 Hz FRS 18 School? more than likely two or three different groups on same frequency/tone 152.9000 205 DCS Maggie Walker Governor's School (Repeater - confirmed user - note that Richmond Schools use 152.9075 and Henrico Public Schools use 152.8850) 462.5875 71.9 Hz FRS 02 """113"" ""okay you're good 112...."" ""got it"" " 462.7125 159.8 Hz FRS 07 """pick up on 14!"" ""can you hear that?"" ""14 okay"" ""the valves are shut"" ""did you confirm that all our stuff is gone"" ""he's on the other side of the building"" " 466.3625 156.7 Hz """bring that crane back up..."" " 467.8500 100.0 Hz Silver Star Weak signal 151.7000 141.3 Hz Utility contractor or similar? Sounds like truck to truck comms 461.3625 025 DCS Construction or crane control ) 462.5625 77.0 Hz FRS 01 Crane control, possibly mixing with another group/user on same channel 466.0875 205 DCS Construction 462.6000 455 DCS FRS 17 """Madison is inside"" ""I can't go all the way down to the teacher's lounge"" ""she'll be alright"" ""facilities""" 154.4900 162.2 Hz Luck Stone Statewide (confirmed user - also on 151.550, 154.625 and 160.125...also use CB radios extensively) 464.5500 67.0 Hz Yellow Dot "Possibly retail user - ""Did he get that last one...?"" " 469.5500 114.8 Hz """Did Roberto show you that shit?"" ""man, you gotta send it to me"" " 462.6875 85.4 Hz FRS 06 """Kayla Wilson, right?"" ""okay thank you"" ""confused, don't really know what to do""" 151.8200 103.5 Hz MURS 1 """Aurturo"" ""dole""" 462.5500 123.0 Hz FRS 15 """Lynette"" ""she's back up""" 464.5500 506 DCS Yellow Dot """OK"" (English/Spanish) ""15"" ""okay, good"" " 462.6375 77.0 Hz FRS 04 """thank you Tony"" ""copy that, two more cars""" 467.9250 206.5 Hz Blue Star Spanish language, probably construction based on traffic and signal strength 154.5700 371 DCS MURS 4 Previously logged users using same code/frequency 152.8850 85.4 Hz Crushed stone or quarry operations 151.5800 026 DCS AdvanSix Resins and Chemicals (repeater - also use 150.8300 [131.8 Hz], 150.8600 [023 DCS], 150.9650 [025 DCS], 152.3075 [074 DCS], 152.9225 [74.4 Hz], 153.2300 [071 DCS] and numerous others 467.8125 88.5 Hz """K"" Dot" Construction or materials delivery coordination 469.5500 023 DCS Miguel and another UNID station, probably construction-related 154.5700 88.5 Hz MURS 4 """okay I got you on channel 15"" " 467.5625 065 DCS FRS 08 Weak, presumed construction use 466.3125 156.7 Hz """B-2!"" ""B-2!"" " 3/26/2021 467.8500 627 DCS Silver Star Spanish language, strong signals at 8:20am 467.6625 67.0 Hz FRS 12 Elevator requests, as previously logged 466.1625 156.7 Hz """Should be here any second...""" 151.8800 103.5 Hz MURS 2 Caught tail end of transmission, UNID user but same CTCSS as previously logged on other MURS channels 462.6625 79.7 Hz FRS 05 """they have one scheduled for 9:00 I think""" 466.3125 156.7 Hz Likely same users monitored on this frequency/tone before 462.5250 114.8 Hz """Ms. Lee"" " 469.5500 506 DCS """did you copy that?"" (Spanish language)" 469.5500 205 DCS Crane control/construction 464.5000 103.5 Hz Brown Dot Portables 462.5625 67.0 Hz FRS 01 """yes, number 2"" ""at the right time"" ""okay"" (Spanish language)" 154.5700 371 DCS MURS 4 Active, Spanish and English 462.5625 67.0 Hz FRS 01 """I have Kirby Wilson...they have an 8:30...in the parking lot"" (different user)" 462.5750 165.5 Hz FRS 16 """okay go ahead"" (strong signal)" 469.5000 205 DCS """going down"" ""I got 'em Troy""" 462.7125 159.8 Hz FRS 07 """back down...back down"" (likely same user previously logged on frequency/tone)" 464.5500 627 DCS Yellow Dot """do we have the plans? I need a copy of those files"" " 151.6250 67.0 Hz Red Dot """back down towards...""" 462.6750 136.5 Hz FRS 20 "School, FRS ""Roger Beeps"" heard, sporadic signal " 151.8200 103.5 Hz MURS 1 """full up"" ""day or night...obviously day or night"" ""that one over there"" " 462.6875 141.3 Hz FRS 06 """back by the other cones""" 467.5625 85.4 Hz FRS 08 "Weak, FRS ""Roger Beeps"" heard, previously monitored frequency/tone" 466.0625 032 DCS Construction 462.7875 162 DCS Weak chatter, with interference from paging/data on 462.8000 462.6125 77.0 Hz FRS 04 "Spanish language chatter (with FRS ""Roger Beeps"")" 3/27/2021 466.0625 023 DCS Construction 466.2875 606 DCS Construction 466.3125 156.7 Hz Same group previously monitored using the 466.xxxx freqs with 156.7 Hz 461.2875 192.8 Hz Construction/crane control 462.6125 127.3 Hz FRS 03 """Can you hear me on the walkie talkie?"" - kids playing with radios? " 151.7600 136.5 Hz Construction or crane control, alternate channel? 450.2250 023 DCS """that's at 10:30"" ""right, table 14"" " 462.5875 CSQ FRS 02 """he got his money can do anything he want with it!"" " 469.5500 205 DCS """Wake up, man!""" 154.4900 67.0 Hz "Talking about signs, heard mention of ""exit 78"" " 151.8200 103.5 Hz MURS 1 Weak, likely same users as previously logged on MURS using 103.5 Hz CTCSS 466.0875 506 DCS Crane control, strong signals 461.1625 506 DCS Construction 462.6500 143 DCS FRS 19 """right there"" ""okay"" (FRS ""Roger Beeps"" heard) " 464.5500 627 DCS Yellow Dot Construction/crane control 462.6250 127.3 Hz FRS 18 Construction noises heard in background 151.6250 77.0 Hz Red Dot """Back it down"" " 469.5500 114.8 Hz Heard other radio chatter in background, appears to be coordination for multiple cranes 462.7875 025 DCS "Mention of ""fixture"" " 464.8250 026 DCS Crane control, very busy 154.5700 131.8 Hz MURS 4 Utility or sewer contractor? 154.5150 82.5 Hz Portables 469.5000 205 DCS Construction 462.5625 CSQ FRS 01 Spanish chatter, possibly tower crane related (no tone/code in use) 467.8750 229.1 Hz Gold Star Crane control and related chatter 464.5000 627 DCS Brown Dot Appears to be secondary to 464.5500 [627 DCS] 461.1625 67.0 Hz """service request"" (strong signal) " 151.6250 065 DCS Red Dot AIRCARE EAGLE working FLIGHTCOM 462.5625 67.0 Hz FRS 01 """Brock"" ""okay"" " 467.6625 67.0 Hz FRS 12 """Pickup on 14, pickup on 14 please"" - elevator requests " 462.7250 67.0 Hz FRS 22 Kids playing on radios, call/alert tones heard at 1:45pm 151.5125 136.5 Hz Crane control 462.6750 606 DCS FRS 20 Retail store 154.5275 136.5 Hz Crane control, probably alternate frequency 461.2125 67.0 Hz """down...the brake!"" " 464.5500 179.9 Hz Yellow Dot Engineers, testing alarm or sensors 467.8750 69.3 Hz Gold Star Tail end of transmission 464.5500 047 DCS Yellow Dot """number 3 crane"" ""try channel 4""" 462.6875 141.3 Hz FRS 06 Talking about appointment times - rapidly fading in and out 151.9550 82.5 Hz Purple Dot Weak signal, likely portables 462.6250 127.3 Hz FRS 18 Spanish language, sporadic signals 3/28/2021 464.5500 67.0 Hz Yellow Dot Tail-end of transmission, UNID user 462.7000 118.8 Hz FRS 21 """Did you want some hot sauce?"" ""We're making some uh...chips sauce"" ""okay"" " 469.5500 114.8 Hz Tower crane coordination 462.6750 172 DCS FRS 20 "FRS ""Roger Beep"" heard, weak but readable " 151.5125 136.5 Hz Same users previously monitored - crane control 462.6125 127.3 Hz FRS 03 """Mikey"" (unsure if this is same group as previously monitored - this is a very popular frequency/tone combination) " 467.9250 67.0 Hz Blue Star Security or facilities maintenance? 151.8200 67.0 Hz MURS 1 """We have some...up here"" possibly hotel/hospitality users" 467.6875 67.0 Hz FRS 13 """she isn't ready yet""" 462.5625 183.5 Hz FRS 01 """Patrick...for his second shot...get him ready to come over""" 464.5500 162.2 Hz Yellow Dot """in the next couple hours""" 462.6125 97.4 Hz FRS 03 radio checks 467.7500 115 DCS Retail (Target store frequency/code combination) 467.7625 67.0 Hz """J"" Dot" Retail, unknown user 451.8000 506 DCS Gas station? 462.5625 71.9 Hz FRS 01 """Juan, did you copy that?"" " 467.8750 100.0 Hz Gold Star Retail - Kroger (confirmed user of frequency/tone) 467.9250 100.0 Hz Blue Star Retail - Kroger (confirmed user of frequency/tone) 3/29/2021 466.0875 506 DCS Construction 466.3125 156.7 Hz Construction, English/Spanish 467.5875 032 DCS FRS 09 Spanish language 462.6625 67.0 Hz FRS 05 """He back over there!"" ""I see you!"" (kids on FRS radios)" 451.8125 162.2 Hz """Base to Rover 2"" " 151.5125 136.5 Hz Crane control (usual users on this frequency/tone) 464.8250 026 DCS Crane control, mixing with 179.9 Hz users 467.6625 67.0 Hz FRS 12 "Elevator requests ""pick up 13 please? going down"" etc." 464.5500 627 DCS Yellow Dot Busy - construction/crane operator 151.6250 67.0 Hz Red Dot """Excellent, thank you""" 467.5625 CSQ FRS 08 """two more cars coming in"" ""okay"" (no CTCSS or DCS decoded)" 466.1375 156.7 Hz Construction? 469.5500 114.8 Hz Crane coordination, busy 462.6875 85.4 Hz FRS 06 """Mike 8"" ""one eight"" (several different stations heard, poor to unreadable signal) " 466.3125 023 DCS Extreme interference from 156.7 Hz group on same frequency 462.5500 123.0 Hz FRS 15 """Johnson"" " 462.4250 103.5 Hz """I'm right here..."" (weak, YL voices)" 462.8125 627 DCS """bring the cones"" ""no, second cone...""" 462.5625 67.0 Hz FRS 01 "Strong signal, no ""Roger Beep""" 154.5275 136.5 Hz Crane control 462.6750 136.5 Hz FRS 20 Local(ish) school 154.5700 371 DCS MURS 4 Likely same user previously logged using frequency/code combo 467.8500 94.8 Hz Silver Star Construction or maybe building maintenance crew 467.9000 131 DCS Red Star """Parking lot is getting full....we have COVID cars lining in....""" 462.5875 118.8 Hz FRS 02 """anyone working with..."" ""need to notify...""" 469.2625 186.2 Hz Retail store 462.8625 88.5 Hz Spanish language, construction noises in background 151.9400 77.0 Hz MURS 3 Retail, weak signal (portables) 462.7125 159.8 Hz FRS 07 Previously heard user of this frequency/tone 154.4900 67.0 Hz Highway maintenance crew (sign work) 462.6250 127.3 Hz FRS 18 """Hey Maria"" and ""Hey Linda"" heard around 9:45 AM" 467.6125 100.0 Hz FRS 10 Radio checks, no response heard 462.6375 131.8 Hz FRS 04 """Ms. Jenkins can you hear me?"" " 467.8500 131 DCS """attention associates"" " 462.9125 192.8 Hz """drink Red Bull and then they did it!"" - general chatter (construction workers, very similar to traffic heard on 469.5500 [114.8 Hz])" 154.6000 023 DCS MURS 5 """156 is 6-D"" ""and 155 is at 10-D"" ""twenty more feet"" (fair-weak but readable) - active around 12:00 noon/12:15pm" 151.6250 025 DCS Red Dot """I don't know if we just wanna wait on those""" 464.5500 67.0 Hz Yellow Dot """push it a little more...a little more Mike""" 456.8125 712 DCS Construction or crane operations 469.9500 203.5 Hz Retail ops (simplex) 464.5625 165.5 Hz """back...200"" ""10-4"" " 461.1125 67.0 Hz """room 502"" ""request order"" " 462.6125 97.4 Hz FRS 03 "Spanish, sporadic signal w/ FRS ""Roger Beeps""" 466.0625 506 DCS Construction 462.8125 123.0 Hz """101 to base"" " 462.7250 136.5 Hz FRS 22 School, or day care? coordinating lunch schedules 462.7125 146.2 Hz FRS 07 Presumed construction comms, mixing in with 159.8 Hz CTCSS user on frequency 467.9250 67.0 Hz Blue Star Security 461.1625 67.0 Hz Security or facilities maintenance 462.5625 250.3 Hz FRS 01 "Mic key ups, FRS ""Roger Beep"" heard" 464.5000 103.5 Hz Brown Dot Hotel/hospitality 462.6500 131.8 Hz FRS 19 Sounds like kids talking to parents on FRS units 462.8250 162.2 Hz Security or engineering 151.9550 94.8 Hz Purple Dot Film crew? 467.7125 131 DCS FRS 14 Security 461.0875 023 DCS Cement contractor? 462.1250 69.3 Hz Spanish language, probably construction related 467.8500 179.9 Hz Silver Star Hotel/hospitality 457.5250 315 DCS Local school (simplex/legit 457.xxxx Business Radio Service frequency) 462.6875 141.3 Hz FRS 06 """We have an extra long line"" ""okay"" " 467.6625 CSQ FRS 11 "Local school - coordinating students being picked up, etc. - ""checking in Channel 11""" 469.5500 77.0 Hz Weak 151.8200 103.5 Hz MURS 1 Utility contractor or similar 461.0375 91.5 Hz Hotel or hospitality 461.3625 243 DCS """stop for a minute""" 464.5000 627 DCS Brown Dot """Miguel"" - possibly alternate channel for 464.5500 and others " 467.5875 127.3 Hz FRS 09 "Mention of ""circuit 3"" " 462.8875 88.5 Hz Tower crane control or coordination 467.9000 047 DCS Red Star Dan and Miles, UNID 462.7875 025 DCS Seems to be same group as previously monitored 3/30/2021 464.5000 179.9 Hz Brown Dot """my man...bring the boom back there...back there...""" 466.0875 506 DCS Crane control/construction (very active at times) 462.7250 431 DCS FRS 22 "Spanish language chatter with ""Roger Beeps"", call tones, etc. " 464.8250 026 DCS Crane control, also very active at points 462.6625 136.5 Hz FRS 05 """Hello?"" ""the line is...."" " 464.5500 79.7 Hz Yellow Dot Weak/poor readability 151.8200 103.5 Hz MURS 1 Likely same users previously monitored using MURS with 103.5 Hz 457.5250 315 DCS """Yellow cone"" " 462.7125 159.8 Hz FRS 07 Building security, parking deck security or similer 469.5500 179.9 Hz Construction, sporadic signal 467.9250 67.0 Hz Blue Star Spanish language, fair/weak signal 462.7250 146.2 Hz FRS 22 """The only time you would use TAC 3 is when you want to avoid interruption of transfer of the encryption key"" - likely GMRS repeater (heard at 7:48 AM)" 464.5500 627 DCS Yellow Dot Likely same users previously monitored using same tone 462.5875 67.0 Hz FRS 02 """ahhhh!""" 461.0875 67.0 Hz Building maintenance or facilities management - fair signal 464.5000 146.2 Hz Brown Dot Spanish language chatter 462.5625 167.9 Hz FRS 01 Caught tail end of transmission 151.6250 223 DCS Red Dot Heard what sounded like alarms going off in background, weak/poor readability signal 462.7125 023 DCS FRS 07 RF engineering crew? 151.5125 136.5 Hz Crane control, usual users of frequency/tone 467.5625 CSQ FRS 08 """Copy you on 8"" ""okay channel 8"" " 462.6750 606 DCS FRS 20 Retail store, poor signal 462.6125 127.3 Hz FRS 03 """next car, blue car...""" 461.0625 179.9 Hz Weak, poor to unreadable (voice traffic) 467.8875 025 DCS """lighting"" ""checks"" ""404"" " 469.5500 114.8 Hz Usual users (see previous logs for this frequency/tone) 467.6625 67.0 Hz FRS 12 Elevator floor/pickup requests - same as logged numerous times on this frequency/tone 462.7625 192.8 Hz Construction or similar chatter 462.6750 136.5 Hz FRS 20 Local (sort of) school - sometimes suffering from interference from the retail users using 462.6750 [606 DCS] 159.5025 156 DCS Richmond City Public Schools (confirmed user) 462.5625 CSQ FRS 01 """Mom?"" ""yes I can hear you"" (kids playing on the radio, including singing, etc)" 462.6875 141.3 Hz FRS 06 """311, 233"" " 464.5000 346 DCS Brown Dot """can you pull forward?"" ""okay keep pulling""" 462.5875 77.0 Hz FRS 02 Different group, mixing with group using 97.4 Hz CTCSS 462.6125 023 DCS FRS 03 """okay, back 3"" ""they're just like tap-welded right on the inside of the leg of the apex.....yeah they get in the way and shit""" 462.5875 97.4 Hz FRS 02 Crane control (monitored around 4:15/4:20pm) 462.5250 114.8 Hz """have them come to the back door now""" 462.5625 67.0 Hz FRS 01 Different group (not kids playing on the radio) 3/31/2021 467.9000 131 DCS Red Star """there's a gentleman in...."" ""can you help him?""" 467.8500 331 DCS Silver Star """new order"" ""attention associates""" 467.9000 205 DCS Red Star """Loss prevention"" ""manager""" 467.7625 107.2 Hz """J"" Dot" """meet the manager..."" ""number 8122"" " 467.7500 115 DCS """back of house""" 467.9250 67.0 Hz Blue Star """leave away"" (in English), then Spanish language " 467.9250 155 DCS Blue Star Retail? heavy interference from other users on frequency 462.5875 118.8 Hz FRS 02 """Tom, did you copy that?"" " 467.7750 072 DCS Retail, Target confirmed use of frequency/tone combination 469.5500 114.8 Hz Same group previously monitored on this frequency/tone 467.5625 026 DCS FRS 08 """1310"" ""how did you measure that?"" " 467.5875 91.5 Hz FRS 09 """did you get that?"" ""thank you!"" ( ""can somebody bring Aiden's tablet outside please?"" - sounds like a school (fair signal, with FRS ""Roger Beeps"")" 462.6375 131.8 Hz FRS 04 tail-end of a transmission heard, just enough to decode CTCSS/PL tone 131.8 Hz 464.5500 627 DCS Yellow Dot """Mark it...based off our base grid line...""" 152.9075 743 DCS Richmond City Public Schools (confirmed user) 462.6875 141.3 Hz FRS 06 """ticket for Moreno..."" " 466.3125 156.7 Hz """back to...""" 462.6750 606 DCS FRS 20 """Roger Roger!"" ""oh yeah, it is"" (unknown if same group usually heard on this frequency/code)" 151.5125 136.5 Hz Crane control - busy (usual users heard here) 467.8500 627 DCS Silver Star Alternate channel for guys usually using 464.550 / 464.500 with 627 DCS 462.7125 159.8 Hz FRS 07 """I'm working on the one down in the basement!"" - same group usually heard using 159.8 Hz CTCSS on FRS 7/462.7125 MHz " 469.5500 205 DCS Crane control or other construction 462.6125 127.3 Hz FRS 03 """hold it...hold it....you got it""" 153.0125 743 DCS Richmond City Public Schools (confirmed user) 469.5000 205 DCS """I'm on my way down to the platform, coming from 17..."" (loud signal at 11:40 AM)" 151.6250 67.0 Hz Red Dot """Channel 2"" ""baking"" " 467.6625 67.0 Hz FRS 12 Elevator requests - same as previously monitored, very active at points 466.3375 023 DCS """walking on this...""" 461.2875 131.8 Hz Spanish, poor/weak signal 159.8700 127.3 Hz Trucking company, yard control/dispatch (heard CB chatter in background) 462.5625 114.8 Hz FRS 01 School or day care facility 154.4900 67.0 Hz """I think the rain is gonna start soon...""" 466.2625 205 DCS Tail end of signal heard just after 12:00 noon 151.8200 103.5 Hz MURS 1 Likely same group previously monitored using 103.5 Hz on MURS 467.5625 243 DCS FRS 08 Talking about questionnaires 152.9075 074 DCS Richmond City Public Schools (confirmed user) 450.2250 023 DCS UNID users heard 158.4000 123.0 Hz """124 South..."" (sounded like an address) - heard around 7:30pm" 467.6625 CSQ FRS 12 """maybe it's something happening over at campus or something I'm not sure what though"" (NOT the usual elevator request traffic, no CTCSS or DCS tone/code)" 467.8875 110.9 Hz "Mention of ""Brook Road"" - portables (likely)" 456.8125 423 DCS Possibly retail? 4/1/2021 151.6250 065 DCS Red Dot AIRCARE EAGLE doing radio checks at 8:04 AM with FLIGHTCOM (again at 8:14 AM for a dispatched call) 467.5625 91.5 Hz FRS 08 """...truck..."" (FRS ""Roger Beeps"") heard - poor copy at 8:06 AM" 462.7250 146.2 Hz FRS 22 Repeater (GMRS operators) 151.6250 167.9 Hz Red Dot Crane Master Truck-to-Truck primary coordination (confirmed user frequency/tone) 464.5500 627 DCS Yellow Dot Crane control/construction 462.6375 67.0 Hz FRS 04 """car..."" ""sedan coming your way"" " 464.5000 103.5 Hz Brown Dot Weak signal, presumed hotel/hospitality user based on previous logs 151.5125 136.5 Hz Crane control 451.8000 023 DCS Construction work site coordination - concrete contractor 467.6625 67.0 Hz FRS 12 Usual daytime user of frequency/tone (elevator call/floor requests) 466.2625 023 DCS """Chookie...just FYI...we're starting our last one...""" 462.5500 123.0 Hz FRS 15 "Poor copy, presumed portables (no ""Roger Beeps"" heard)" 154.5275 136.5 Hz Crane control - possibly alternate to 151.5125 [136.5 Hz] 457.5250 315 DCS Local school, strong signals 462.6875 141.3 Hz FRS 06 "COVID vaccination site coordination """"""9:30"""" """"370172"""" """"Smith, 9:20"""" - active ""here for his second shot"" " 462.6875 85.4 Hz FRS 06 """he's coming back in now"" (similar signal strength to group using 141.3 Hz - frequency very active this morning with both groups)" 158.4075 065 DCS FLIGHTCOM working AIRCARE EAGLE radio checks, test alert tones and other tests - alternate channel? 462.6625 136.5 Hz FRS 05 """Juan"" and another UNID station " 462.4250 103.5 Hz School? (weak, portables) 462.7125 159.8 Hz FRS 07 Usual user of this frequency/tone 151.8200 103.5 Hz MURS 1 Active around 9:20AM-9:25AM (presumed same users as before) 464.5000 627 DCS Brown Dot Same users monitored using 627 DCS on this and other frequencies 462.6500 632 DCS FRS 19 """How do you copy me?"" (at 9:31AM with FRS Roger Beep) " 154.5700 151.4 Hz MURS 4 Weak to fair signals - crane control communications 464.8250 026 DCS Usual activity, sometimes with interference from Philip Morris repeater (using 179.9 Hz CTCSS) 464.5000 179.9 Hz Brown Dot """I gotta bring it back up here"" " 469.2625 67.0 Hz UNID users, presumed simplex 451.8125 423 DCS Weak signal, was able to decode DCS 158.4000 167.9 Hz Likely Crane Master (alternate channel, primary is 151.625 [167.9 Hz]) 466.3625 156.7 Hz """main..."" and some Spanish language heard (around 10:45AM)" 462.6125 97.4 Hz FRS 03 Presumed school or day care, fair/weak 466.3125 156.7 Hz Construction chatter 461.0375 023 DCS Spanish, poor signal, poor copy 462.9125 192.8 Hz Crane control, active at/around 12:10-12:12PM 462.6625 67.0 Hz FRS 05 """9 foot"" ""okay"" " 461.1875 67.0 Hz Spanish language, fair to poor signals 462.5625 67.0 Hz FRS 01 "Chatter regarding cars, talking about schedules (no ""Roger Beeps"")" 462.7875 88.5 Hz Tail end of a signal, no voice heard...but CTCSS tone decodes 464.5000 67.0 Hz Brown Dot """get close to the..."" ""it's not coming up there so good""" 462.8875 612 DCS Voice inversion scrambling 152.3975 503 DCS Repeater, distant...presumably school system 469.9500 203.5 Hz Hotel or hospitality (portables/simplex) 462.7250 136.5 Hz FRS 22 Local school, fair to poor signal 462.6250 156 DCS FRS 18 """channel..."" ""no, go all the way to the bottom"" " 466.0875 506 DCS Construction, likely tower crane control 464.5500 67.0 Hz Yellow Dot Crane control or similar construction comms 462.8125 192.8 Hz Spanish language, weak signal 466.3125 023 DCS Mixing with users using 156.7 Hz 462.7625 025 DCS """It's starting to rain!"" " 467.8500 627 DCS Silver Star Construction, alternate channel (previously logged) 462.6625 136.5 Hz FRS 05 Weak signal heard at 2:52PM 467.8875 110.9 Hz Weak voice activity mid-afternoon 469.5000 205 DCS """come back up here"" " 462.7000 155 DCS FRS 21 Tail end of a fair-to-strong signal 469.5500 114.8 Hz General informal chatter about cranes, other companies, very active at points 467.6375 CSQ FRS 11 Local school with FRS Roger Beeps...no CTCSS/DCS tone, previously monitored same user on this frequency 462.5625 67.0 Hz FRS 01 "Different group than previously monitored this morning on same frequency/tone (using FRS ""Roger Beeps"")" 467.6375 073 DCS FRS 10 """Wait...uh...hold on a second""" 462.6125 023 DCS FRS 03 RF installation crew, previously heard on other FRS channels with 023 DCS 464.5500 179.9 Hz Yellow Dot Active early evening with what sounded like engineering or maintenance workers 451.8125 023 DCS Construction work site coordination - concrete contractor 469.5625 225.7 Hz """James, do you copy?""" 151.6250 047 DCS Red Dot """slow down, you're talking way too fast""" 462.6250 127.3 Hz FRS 18 """Shannon"" and another YL, weak signal " 467.8625 612 DCS """back it up a bit"" (poor copy)" 4/2/2021 466.3375 023 DCS Spanish language - construction comms (monitored around 6:45-7:30AM) 464.5000 179.9 Hz Brown Dot """4:30, okay?"" ""yes sir"" (in Spanish, heard at 7:02AM) - active early morning " 462.9125 192.8 Hz """Jesus Christ..."" ""we're about the same spot as yesterday, a little bit closer to the west on level 6"" - chatter/construction comms " 462.7125 159.8 Hz FRS 07 Usual users of this frequency/tone combination - first heard around 7:15AM 464.8250 026 DCS Crane control - usual users of this frequency/code 466.3125 156.7 Hz Spanish language - construction comms (monitored around 6:45-7:30AM) 462.6000 146.2 Hz FRS 17 Crane control, presumed 464.5500 627 DCS """He just came back up here"" - usual users " 462.4250 103.5 Hz """I said how the hell did you measure it like that?!!"" (portables, sounds like typical construction site chatter)" 462.7250 136.5 Hz FRS 22 Local school 462.8625 88.5 Hz Spanish language, presumed construction users - very active this morning 462.5250 114.8 Hz School or daycare user 462.6750 67.0 Hz FRS 20 "FRS ""Roger Beeps"" heard, children talking in background - presumed school or daycare " 469.5000 205 DCS """what floor are you on?"" ""11"" ""alright we're coming down now"" " 151.8200 103.5 Hz MURS 1 """behind the uh...behind the generators"" (8:27 AM)" 464.5500 627 DCS Yellow Dot """we're gonna do everything and then we're gonna shit up"" " 469.5500 114.8 Hz Usual users as heard on this frequency/tone 462.6750 77.0 Hz FRS 20 """that's inappropriate!"" - different style ""Roger Beep"" heard (compared to the one heard on 462.6750 users using 67.0 Hz CTCSS)" 462.6875 141.3 Hz FRS 06 COVID vaccination center coordination - fair to good signal strength 462.6375 114.8 Hz FRS 04 Spanish language chatter, presumed construction-related 151.5125 136.5 Hz Crane control 462.5750 165.5 Hz FRS 16 """I'm down here on the ground...behind you"" (heard at 1:25/1:26PM)" 464.5500 67.0 Hz Yellow Dot Weak signal, caught a second (enough to decode CTCSS and that's about it) 154.5700 88.5 Hz MURS 4 Spanish language, poor copy 462.6125 127.3 Hz FRS 03 """this is logistics, does somebody need something at table 16?"" ""yes, can I get some large gloves please?"" " 462.9250 025 DCS Hotel or hospitality - possibly catering company 462.5875 025 DCS FRS 02 """suggestion"" ""section 3"" ""call back"" (poor/fair signal) " 151.6250 065 DCS Red Dot AIRCARE EAGLE being dispatched by FLIGHTCOM at 3:35 (flight number 222) 462.6875 073 DCS FRS 06 """hello you..."" ""hello Judy??!!"" (kids playing on radios - 5-10 seconds of dead air, heard at 4:41/4:42PM)" 469.5375 196.6 Hz """4.6"" ""tank 2"" " 151.8200 186.2 Hz MURS 1 " ""Operations to floor wardens"" (weak/fair signal) " 462.6750 606 DCS FRS 20 """manager"" ""floor manager"" (presumed retail users, previously monitored)" 154.5700 043 DCS MURS 4 Crane control 451.8000 023 DCS Construction work site coordination - concrete contractor 467.6375 CSQ FRS 11 Local school with FRS Roger Beeps...no CTCSS/DCS tone, previously monitored same user on this frequency 462.5625 94.8 Hz FRS 01 """I've been working a lot harder than that"" (no ""Roger Beeps"") " 4/3/2021 462.6875 67.0 Hz FRS 06 """I'm bringing it back up now"" ""thank you"" (with FRS ""Roger Beeps"")" 466.2625 023 DCS """pull on 3!"" ""pull on 3"" " 154.4900 67.0 Hz Sign or road maintenance crew 151.9550 127.3 Hz Purple Dot Very weak signal, presumed portables 462.6125 CSQ FRS 03 Crane control (weak signal - no CTCSS or DCS decoded) 154.5700 043 DCS MURS 4 Crane control 462.6250 127.3 Hz FRS 18 """going..."" ""man..."" (very poor copy)" 462.6750 606 DCS FRS 20 Retail (likely same user previously monitored using 606 DCS on 462.6750 MHz) 154.5700 67.0 Hz MURS 4 """with several"" ""dollars"" " 4/4/2021 154.6000 88.5 Hz MURS 5 """TAC13"" - ambulance service using MURS as a chat / ""back channel"" - informal CB-like banter about various topics - heard reference to ""Battalion 403"" and another 3-digit unit ID" 464.5500 627 DCS Yellow Dot Same users normally heard with 627 DCS 4/5/2021 151.6250 065 DCS Red Dot FLIGHTCOM working AIRCARE EAGLE with radio checks, alternating tone alarm tests at 7:48 AM 464.5500 627 DCS Yellow Dot Usual users of this frequency/code combination 467.7125 67.0 Hz FRS 14 "Spanish language chatter with FRS ""Roger Beeps""" 462.9125 192.8 Hz Crane control and informal chatter 462.6000 241.8 Hz FRS 17 "Tail-end of FRS transmission heard with FRS-style ""Roger Beep""" 151.5125 136.5 Hz Crane operators saying good morning and checking in at 7:51 AM 467.5625 88.5 Hz FRS 08 "Weak/poor signal, heard FRS ""Roger Beeps"" " 469.5500 114.8 Hz "Crane control and general chatter, heard reference to ""El Guapo""" 151.8200 103.5 Hz MURS 1 """well...I ain't worried about all that!"" (at 10:43AM) good copy, presumed same users as previously logged using 103.5 Hz on MURS " 462.7000 155 DCS FRS 21 COVID vaccination or similar site coordination (previously monitored on numerous other FRS frequencies) 462.7125 159.8 Hz FRS 07 Same users as previously monitored (downtown) 467.6625 67.0 Hz FRS 12 Elevator requests, previously logged on 467.6625 67.0 Hz like nearly daily use 466.0875 506 DCS Poor copy, presumed construction users based on previous logs 464.5000 82.5 Hz Brown Dot Local school? Weak/poor copy 457.5250 315 DCS Local school (confirmed user via numerous leggings) 467.8750 229.1 Hz Gold Star Construction - Spanish and English heard, good copy at 10:57 AM - mix of informal chat, similar to 469.5500 [114.8 Hz], 462.9125 [192.8 Hz], etc. 151.6250 167.9 Hz Red Dot Crane Master truck to truck (confirmed user) - coordinating trucks, directions, loud signal at 11:00 AM with CB-like truck-to-truck comms 462.6750 606 DCS FRS 20 Retail use - see other logs for 462.6750 [606 DCS] 462.5625 CSQ FRS 01 """hey Mike?"" ""yeah, go ahead"" (distinctive FRS Roger Beeps heard, no CTCSS or DCS tone/code) " 466.3125 156.7 Hz """whoa!"" ""okay back..."" ""back...""" 151.8800 026 DCS MURS 2 Very weak, unreadable voice but was able to decode DCS at 11:36 AM 466.2375 506 DCS Construction chatter, heard construction noises in background 467.5875 CSQ FRS 09 "Informal chatter, kids playing on radios (with FRS ""Roger Beep"", no CTCSS or DCS decoded) " 158.4075 065 DCS LIFE EVAC 1 working AIRCARE EAGLE and FLIGHTCOM (control station) at 11:41AM 462.6250 127.3 Hz FRS 18 Local school or day care - poor/fair signal 4/6/2021 467.8500 627 DCS Silver Star Secondary channel for users normally using 464.550 [627 DCS] or 464.500 [627 DCS] 457.5250 315 DCS Local school 464.8250 026 DCS Crane control (simplex) 462.5250 114.8 Hz Local school, poor copy 464.5500 627 DCS Yellow Dot Construction/crane control (appears to be primary) 154.4900 67.0 Hz Road repair/maintenance 462.6250 127.3 Hz FRS 18 Local school or daycare 151.8200 103.5 Hz MURS 1 Contractors - active during morning and throughout the day (sporadically) 467.6375 CSQ FRS 11 Local school - same user previously monitored using this and other FRS channels 462.7250 136.5 Hz FRS 22 """bring back"" sounded like ""catheter"" - poor copy" 464.5000 263 DCS Brown Dot Spanish language, presumed construction 462.6875 071 DCS FRS 06 """Baltimore is about five and a half hours away"" ""okay so we're gonna stop..."" (group caravanning up I-95)" 151.5125 136.5 Hz Usual users heard on this frequency/tone 462.5625 CSQ FRS 01 Kids playing on walkie-talkies 466.0625 79.7 Hz Tower crane control 154.5700 371 DCS MURS 4 Road construction - usual users previously heard using this DCS code 151.6250 065 DCS Red Dot AIRCARE EAGLE working FLIGHTCOM COMMUNICATIONS 462.9125 192.8 Hz Crane control, usual users heard on this frequency/tone 154.5700 67.0 Hz MURS 4 Poor copy, unable to ID users 158.4075 065 DCS FLIGHTCOM working AIRCARE EAGLE on alternate channel (primary is 151.6250 [065 DCS]) 451.8125 632 DCS """Lane 3"" ""the second car"" ""check that ticket"" " 4/7/2021 466.3125 156.7 Hz Tower crane control/construction 462.1250 69.3 Hz Hospitality or catering, heavy interference from Jefferson Hotel DMR system on same frequency 464.8250 032 DCS Tower crane control/construction 457.5250 315 DCS Local school, strong signals 467.6625 67.0 Hz FRS 12 Usual users - service elevator floor requests 154.5700 88.5 Hz MURS 4 Tail-end of a strong transmission, no voice traffic heard....UNID user at 7:47AM 462.9125 192.8 Hz Tower crane control/construction 462.5750 654 DCS FRS 16 """Operations to Command"" ""table 6"" - possibly COVID vaccination site operations" 467.8500 627 DCS Silver Star Spanish language - active early morning starting around 7:50AM 464.5500 627 DCS Yellow Dot """We got 3..."" ""base to unit 3"" ""okay level 15"" - likely previously monitored users" 151.5125 136.5 Hz Tower crane control/construction - the usual users of 151.5125 [136.5 Hz] and 154.5275 [136.5 Hz] 462.6750 243 DCS FRS 20 """channel 3"" ""bring Johnny back up"" ""basket to the right"" " 469.5500 114.8 Hz Crane coordination mixed with informal CB-like chatter...can hear other channels active in the background 462.7125 159.8 Hz FRS 07 """go slower a little bit"" (at 7:55AM) - same users monitored basically daily on this frequency/tone " 151.6250 065 DCS Red Dot FLIGHTCOM doing test tones/radio check at 8:02AM - working AIRCARE EAGLE 467.5875 91.5 Hz FRS 09 """...Broad Street..."" (poor signal) " 462.8375 88.5 Hz Tower crane/construction chatter (English/Spanish) 464.5000 627 DCS Brown Dot Construction users 466.0875 506 DCS """ahh, yes"" (in Spanish)" 462.5500 123.0 Hz FRS 15 """Mrs. Johnson"" ""main room"" - presumed school or similar facility " 461.0875 023 DCS Construction 451.8125 506 DCS Retail operations? - portables 456.8125 205 DCS Construction 154.5275 136.5 Hz Tower crane control/construction - the usual users of 151.5125 [136.5 Hz] and 154.5275 [136.5 Hz] 467.8125 103.5 Hz """K"" Dot" Hotel/hospitality 469.5500 506 DCS Spanish - talking about measurements, interference from other users on frequency 158.4000 167.9 Hz Crane Master alternate/tactical channel (primary is 151.6250 [167.9 Hz]) 467.6375 CSQ FRS 11 "Local school, FRS portables (with ""Roger Beeps"") - confirmed use of carrier squelch / CSQ [no tone or code] - heard ""Channel 11"" ID over the air clearly " 461.1625 67.0 Hz Hotel or hospitality user 462.8250 162.2 Hz Security or building maintenance? Poor signal 151.9550 127.3 Hz Purple Dot Weak/poor signal, presumed portables 469.5500 712 DCS Spanish language, heavy interference from 114.8 Hz and 506 DCS activity on same frequency 469.5000 506 DCS Tower crane control/construction 151.8200 131.8 Hz MURS 1 Utility contractor? 464.5625 85.4 Hz Hotel/hospitality 154.5700 371 DCS MURS 4 Road repair or similar? varying signal strengths at 8:30-8:35 AM 456.8125 506 DCS """order 44"" ""pump 5"" - portables (weak signal)" 450.2250 023 DCS School or day care - sporadic signals 464.5500 82.5 Hz Yellow Dot """...opinion..."" ""186.22"" ""tank"" - very sporadic signals with heavy interference from group using 627 DCS" 466.3625 192.8 Hz """level 9"" ""cage"" ""drop...down 10 feet"" - sounds like crane control " 462.5625 114.8 Hz FRS 01 """Logistics"" ""okay that's doable"" " 158.4000 123.0 Hz """Regional""" 462.6750 606 DCS FRS 20 Retail store or similar user - presumed to be same users previously monitored using this frequency/DCS code combination 464.5000 103.5 Hz Brown Dot "Heard mention of ""bread"" at 12:42PM, could be related to 467.8125 [103.5 Hz]" 464.5000 192.8 Hz Brown Dot """get your counts right!"" ""right there!"" (poor copy) " 467.8750 229.1 Hz Gold Star Tower crane control/construction 467.8500 192.8 Hz Silver Star Tower crane control/construction 462.8625 88.5 Hz Crane control 4/8/2021 151.5125 136.5 Hz Crane control - usual users heard on this frequency/tone 462.8625 88.5 Hz Tower crane coordination - very active at points, same group heard on other active crane control frequencies 154.4900 67.0 Hz Early morning chatter - coordinating where to get breakfast, etc. 462.7125 159.8 Hz FRS 07 Usual group heard on this frequency/tone combination 469.5500 343 DCS Weak/poor signal heard around 7:50AM/7:51AM 464.5000 432 DCS Brown Dot Coordination deliveries, truck arrival times, general construction chatter 469.5000 315 DCS """87"" other two-digit numbers (in Spanish)" 469.5000 506 DCS Spanish language, much stronger than group using 343 DCS 467.6625 67.0 Hz FRS 12 "Elevator floor requests - ""pickup on 7, going down"" ""pickup on 12, going down..."" etc " 466.3125 156.7 Hz Tower crane control/construction 464.5500 67.0 Hz Yellow Dot Caught last few seconds of a transmission 464.5500 432 DCS Yellow Dot Tower crane control/construction 461.2125 67.0 Hz Hotel room cleaning or maintenance 467.9000 229.1 Hz Red Star Construction, fair signal 469.5500 114.8 Hz Tower crane coordination - very active at points, same group heard on other active crane control frequencies 151.6250 167.9 Hz Red Dot Crane Master truck to truck (confirmed user) 462.5875 118.8 Hz FRS 02 Weak, active just after 8:00AM 464.5500 627 DCS Yellow Dot Tower crane control/construction - very active at points 154.5275 136.5 Hz Tower crane control/construction 469.5000 205 DCS Tower crane control/construction 461.0375 023 DCS Weak, likely construction comms 467.8750 229.1 Hz Gold Star Tower crane control/construction 464.5000 627 DCS Brown Dot Construction 462.7125 179.9 Hz FRS 07 "Construction chatter, with FRS ""Roger Beeps""" 464.5375 85.4 Hz Hotel/hospitality (weak) 462.9125 192.8 Hz Tower crane coordination - very active at points, same group heard on other active crane control frequencies 467.6625 115 DCS FRS 12 Security or maintenance? poor copy 158.4000 123.0 Hz """didn't get that, repeat"" " 466.0875 506 DCS Tower crane control/construction 462.6625 79.7 Hz FRS 05 Weak, possibly group caravanning up/down I-95 152.3000 023 DCS Yellow Cab - Dispatcher (taxis transmit on 157.5600 [023 DCS]) 457.5250 315 DCS Local school 462.5625 CSQ FRS 01 """right..."" ""back it up...back...okay you're good"" ""hang onto the..."" (with FRS ""Roger Beeps"") " 456.8125 445 DCS Construction 464.8250 026 DCS Tower crane control/construction 467.6375 CSQ FRS 11 Local school, same as previously logged 464.5500 205 DCS Yellow Dot Construction, sporadic signal 158.4075 065 DCS LIFE EVAC 4 working FLIGHTCOM at 11:45AM 462.6875 141.3 Hz FRS 06 """copy"" - ""second dose"" - COVID vaccination site operations " 467.7625 229.1 Hz """J"" Dot" Informal chatter, sounded like same guys from 467.8750 [229.1 Hz] 467.7125 131 DCS FRS 14 Weak/poor signal - possibly security 462.5625 67.0 Hz FRS 01 Spanish language at 11:50AM 462.6125 127.3 Hz FRS 03 """this is Mary, how can I help you?""" 456.5125 632 DCS """cycle set"" ""copy that"" (portables, simplex)" 467.8500 94.8 Hz Silver Star Spanish, heard construction noises in background 462.7250 136.5 Hz FRS 22 Spanish language chatter, fair/poor signal 462.6375 032 DCS FRS 04 "Heard a couple FRS-style ""Roger Beeps"" " 152.3000 445 DCS Henrico County Public Schools - Repeater (confirmed user) 462.6125 67.0 Hz FRS 03 """the line..."" ""they're all tangled up in the peg""" 462.6625 79.7 Hz FRS 05 """yellow""" 464.5625 85.4 Hz Weak signal, presumed related to 464.5375 [85.4 Hz] 462.7125 146.2 Hz FRS 07 Possibly also related to COVID vaccination site 154.5700 371 DCS MURS 4 Repair crew, likely same users previously monitored on MURS with 371 DCS code 462.6750 606 DCS FRS 20 Local store, presumed same group previously monitored using this frequency/DCS code combination 4/9/2021 464.8250 026 DCS Tower crane control/construction 154.5700 371 DCS MURS 4 """man, the fucking HVAC pipe is right there..."" ""this is the only one that has it..."" at 8:08 AM" 464.5500 627 DCS Yellow Dot Tower crane control/construction - very active at points 469.5500 315 DCS Tower crane control/construction 151.5125 136.5 Hz Crane control (usual users heard on 151.5125 and 154.5275 with 136.5 Hz CTCSS) 462.6250 127.3 Hz FRS 18 Local school or daycare 467.8750 67.0 Hz Gold Star """on.."" (weak signal, poor copy) " 469.5000 315 DCS """pipe...right there"" ""okay you're good...yeah I think you're all clear"" (construction noises heard in background " 469.5500 506 DCS """okay it's good"" ""to the right"" (in Spanish) " 462.7250 136.5 Hz FRS 22 Poor signal, possible school or daycare type group/user 462.5625 77.0 Hz FRS 01 """okay come on!"" (in Spanish) with unique ""Roger Beeps"" " 469.5500 114.8 Hz Tower crane coordination and informal chatter, very active at points 464.5000 506 DCS Brown Dot English/Spanish, presumed construction use 464.5000 432 DCS Brown Dot """we're only...we're only going to the 3rd floor so I don't think it will be a problem"" " 154.5150 67.0 Hz """900 pounds"" ""aluminum"" ""712.5"" - portables" 462.5875 025 DCS FRS 02 "Construction users, FRS ""Roger Beeps""" 461.0375 67.0 Hz Weak, suffering extreme interference from GRTC DMR system on 461.0250 MHz 466.0875 506 DCS Tower crane control/construction 462.6875 85.4 Hz FRS 06 """we already went there"" ""before"" (FRS ""Roger Beeps"") - first heard around 8:30AM" 457.7625 136.5 Hz """it's supposed to be on the ticket"" ""oh okay"" " 466.3375 025 DCS Construction 467.6625 67.0 Hz FRS 12 Elevator requests, usual traffic heard on 467.6625 with 67.0 Hz CTCSS (FRS channel 12) 462.6875 141.3 Hz FRS 06 COVID-19 vaccination site operations 464.5500 67.0 Hz Yellow Dot "Radio checks at 8:35 AM - ""can anybody hear me?"" ""hello?"" " 466.1875 156.7 Hz Tower crane control/construction 462.5750 243 DCS FRS 16 """okay that's gonna be exit 76..."" - discussion about driving, presumed to be a group driving up or down 95" 151.8200 103.5 Hz MURS 1 Presumed same users as previously monitored (general construction or contractor chatter) 464.5500 77.0 Hz Yellow Dot """I don't want to fire them...I just want them to know to get off the fucking phone""" 462.6750 606 DCS FRS 20 Local store/retail (portables, same user previously monitored) 464.5500 743 DCS Yellow Dot """lunch truck"" " 151.9550 67.0 Hz Purple Dot """level 6""" 462.6625 136.5 Hz FRS 05 """check table 2"" (sporadic signals)" 158.4075 065 DCS LIFE EVAC 4 working FLIGHTCOM at 12:11PM 462.5875 97.4 Hz FRS 02 """can we take a lunch break now?"" ""yeah, yeah I'm good with that"" " 464.5000 131.8 Hz Brown Dot Weak signal around noon/12:15PM 151.6250 065 DCS Red Dot AIRCARE EAGLE dispatched by FLIGHTCOM 461.1875 023 DCS Concrete construction contractor - portable radios 462.7250 67.0 Hz FRS 22 Sounds like kids playing on the radio, fair to poor signal strength 466.0625 023 DCS Weak signal, likely construction chatter 467.6375 CSQ FRS 11 Local school, same as previously logged 464.5000 179.9 Hz Brown Dot Maintenance or engineering 457.5250 315 DCS Local school 456.8125 141.3 Hz Road repair or utility company? portables 456.8125 023 DCS Concrete construction contractor - portable radios 462.6625 67.0 Hz FRS 05 """back up...keep going..."" (construction sounds heard in background)" 154.5275 136.5 Hz Crane control (usual users heard on 151.5125 and 154.5275 with 136.5 Hz CTCSS) 466.2625 506 DCS Construction 154.6000 67.0 Hz MURS 5 """rebar"" ""piping"" (fair to weak signal) " 461.0875 023 DCS Talking about cement trucks and delivery times 151.8200 114 DCS MURS 1 """Ms. Jones, do you have your walkie talkie on?"" " 464.5000 88.5 Hz Brown Dot """once you get to that point...go ahead and bag it""" 462.7125 159.8 Hz FRS 07 Same users usually heard on this frequency/tons 151.8200 67.0 Hz MURS 1 """32"" ""U2"" ""okay 32"" (YL speaker, heard at 4:48PM)" 462.5500 123.0 Hz FRS 15 """four o'clock!"" ""come up here early you know what I mean?"" " 469.5500 023 DCS Concrete construction contractor - portable radios 151.6250 167.9 Hz Red Dot """you said it does shift better or it doesn't?"" ""well, it's had a rough life"" ""let's try it again"" - Crane Master confirmed user " 4/10/2021 154.5700 88.5 Hz MURS 4 """channel 15"" ""copy you loud and clear"" " 469.5000 205 DCS Tower crane control/construction 469.5500 114.8 Hz Tower crane coordination and informal chatter, very active at points 466.3125 156.7 Hz """yeah we're up here"" ""the only chargers we have for the radios are on B-3, there ain't nothing on B-4 is there?"" " 154.4900 67.0 Hz """yeah we're gonna get coffee first"" ""no at Wawa"" " 151.6250 065 DCS Red Dot FLIGHTCOM doing radio checks and test tones at 7:15AM 462.7250 141.3 Hz FRS 22 """do you copy?"" ""yeah I got you"" - not the usual 136.5 Hz tone, strong signal with 141.3 Hz" 464.5500 627 DCS Yellow Dot """hey Justin!"" - usual users on this frequency/tone" 462.6750 606 DCS FRS 20 Retail store, very active at points 154.5700 151.4 Hz MURS 4 Tail end of a transmission caught, nothing else heard 467.8750 229.1 Hz Gold Star Tower crane control/construction 462.9125 192.8 Hz Tower crane control/construction 151.5050 167.9 Hz Crane Master secondary or backup use 462.5875 97.4 Hz FRS 02 """cable up...cable up..."" - crane control/tower crane control " 467.6625 67.0 Hz FRS 12 Elevator floor requests, typical users heard basically daily 462.8625 88.5 Hz Tower crane control/construction 462.6250 127.3 Hz FRS 18 Daycare? Poor signal 467.5625 186.2 Hz FRS 08 Very weak signal, unable to make out any voice 4/11/2021 469.5000 205 DCS Tower crane control/construction 462.5875 97.4 Hz FRS 02 Tower crane control/construction - active mid-morning 464.8250 026 DCS Crane control - same users usually heard...interference from Philip Morris repeater using 179.9 Hz CTCSS tone on same frequency noted 462.6625 225 DCS FRS 05 "Unmodulated carrier (""dead air"") for 2-3 seconds " 469.5125 464 DCS """Shuttle"" (weak to fair signal)" 467.6125 97.4 Hz FRS 10 Tower crane control, possibly same group monitored using 97.4 Hz on 462.5875 MHz/FRS 02 462.9125 192.8 Hz Tower crane control/construction 158.4075 065 DCS LIFE EVAC 4 working FLIGHTCOM Medevac dispatch at 2:04PM 4/16/2021 464.5500 94.8 Hz Yellow Dot Spanish language chatter, presumed construction 462.5875 118.8 Hz FRS 02 Familiar traffic with this frequency and CTCSS tone combination, sporadic signals 462.6250 127.3 Hz FRS 18 Dead air for 3-4 seconds 464.5500 627 DCS Yellow Dot Same group normally heard on this frequency/code combination 467.5625 306 DCS FRS 08 "Poor signal, FRS call tones or ""alert tones"" heard " 467.9000 612 DCS Red Star Construction 151.6250 167.9 Hz Red Dot Crane Master truck to truck (primary channel - confirmed user) 469.5500 205 DCS Tower crane control/construction 467.6125 CSQ FRS 10 Truck to truck chatter, sounds like a chase car talking to a truck or similar type traffic 466.3125 156.7 Hz "Construction, Spanish with some English words, including ""playbook"" and ""cradle"" " 464.5000 88.5 Hz Brown Dot """Contact"" ""close 14"" ""copy that"" " 462.7000 100.0 Hz FRS 21 Construction or similar, fair signal 462.8125 627 DCS """236"" ""238"" - presumed construction, same signal strength as the group heard using 627 DCS on 464.550 and other frequencies " 467.5875 67.0 Hz FRS 09 Kids playing with FRS radios, FRS-style Roger Beeps heard...fair to weak signals 457.5250 315 DCS Local school 462.5750 632 DCS FRS 16 """not available right now...."" (female speaker)" 151.5125 136.5 Hz Crane control - usual users heard on this frequency/tone 462.5875 97.4 Hz FRS 02 Crane control, same users previously heard using 97.4 Hz CTCSS tone on FRS Ch.2 462.5875 467.8875 110.9 Hz """rebar""""truckload"" " 464.4875 79.7 Hz """Basket"" ""B-1"" ""main floor""" 467.6375 CSQ FRS 11 Local school - strong signals 462.7250 223 DCS FRS 22 Weak UNID chatter, likely kids playing with FRS walkie talkies 154.5700 67.0 Hz MURS 4 Luis and Juanito, presumed construction or utility contractor 462.9125 192.8 Hz Tower crane coordination 151.5050 167.9 Hz Crane control - presumed Crane Master based on CTCSS tone 462.6500 351 DCS FRS 19 """okay I got you on channel 13, can you hear me?"" ""10-4"" " 469.5500 114.8 Hz Tower crane coordination 158.4075 065 DCS LIFE EVAC 3 and LIFE EVAC 4 (Medevac helicopters) heard 462.5750 654 DCS FRS 16 """brake!"" ""okay next exit is gonna be...""" 461.3625 74.4 Hz Hotel or hospitality 4/17/2021 151.8200 103.5 Hz MURS 1 Construction or utility contractor 467.8500 100.0 Hz Silver Star Retail of some sort, portables (weak) 462.5625 CSQ FRS 01 """it's not in the refrigerator"" - no CTCSS or DCS tone/code used " 469.5625 712 DCS Poor copy, unable to ID voice 464.5500 243 DCS Yellow Dot Construction or possible tower crane control use 462.7250 141.3 Hz FRS 22 """yeah I got you"" " 456.8125 074 DCS """pump 2"" ""customer request"" " 464.5500 346 DCS Yellow Dot Parking or security - Temporary Repeater - very strong 462.7125 97.4 Hz FRS 07 """back"" ""three"" ""check the tray"" " 464.5000 67.0 Hz Brown Dot Very active 467.6375 CSQ FRS 11 """look at his dumbass struggling"" ""right there"" - very informal chatter " 462.6375 114.8 Hz FRS 04 """I'm sorry bro"" ""sector 2"" ""copy that"" " 462.8250 162.2 Hz Parking lot attendants or traffic control 464.5500 67.0 Hz Yellow Dot Weak, simplex 154.5700 162.2 Hz MURS 4 Coordination parking, directing traffic, similar to chatter heard on FRS 11 - 467.6375 CSQ 467.6625 115 DCS FRS 12 Parking coordination 469.5125 411 DCS """On Location Van 2 to Base"" ""two more pickups"" " 462.7125 77.0 Hz FRS 07 Kids playing on radios, FRS call tones and Roger beeps heard 462.9125 192.8 Hz Tower crane coordination 467.5625 243 DCS FRS 08 """over here....we dry...."" (strong signal at 6:34PM, no ""Roger Beeps"" heard) " 462.8625 88.5 Hz Tower crane coordination 462.5875 025 DCS FRS 02 """that red truck"" ""blue car"" - presumed parking coordination chatter " 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 3 462.6375 74.4 Hz FRS 04 Traffic control / flaggers or flag men 462.5875 67.0 Hz FRS 02 """do not get going until I tell you to - please confirm!"" " 461.1875 023 DCS Concrete construction contractor - portable radios 462.7250 250.3 Hz FRS 22 "Tail end of a transmission heard with FRS style ""Roger Beep"" " 467.8750 229.1 Hz Gold Star Tower crane coordination 151.5125 136.5 Hz Crane control 462.6375 127.3 Hz FRS 03 """good job today thank you"" " 467.9250 131.8 Hz Blue Star Poor copy, unable to ID voice 467.8875 162 DCS """lot B"" ""number of spots left after the trailers"" " 462.6500 241.8 Hz FRS 19 Similar to FRS traffic monitored earlier today - parking lot attendants 450.2250 023 DCS Parking lot attendants or traffic control 4/18/2021 467.6875 CSQ FRS 13 Parking lot comms, likely associated with RIR NASCAR race (see logs from 04/17/21 as well) 466.2625 205 DCS Construction 466.3125 156.7 Hz Crane control/construction 467.8125 107.2 Hz """K"" Dot" """check"" ""unit 2, radio check..."" (at 8:13AM)" 462.5500 123.0 Hz FRS 15 """back in a second!"" ""do you have your radio on?"" ""okay second vehicle"" " 464.4875 026 DCS """level 2"" " 462.6625 67.0 Hz FRS 05 General informal chatter, sporadic weak to fair signal w/FRS call tones 469.5500 114.8 Hz Tower crane coordination 462.5500 67.0 Hz FRS 15 """okay you're good...go to the next one"" " 158.4075 065 DCS FLIGHTCOM dispatch (bleeding over onto 158.4000) 464.5500 346 DCS Yellow Dot Parking or security - Temporary Repeater - very strong 462.6250 127.3 Hz FRS 18 """cart"" ""take it to the back section"" ""Linda""" 450.2250 023 DCS Security? portables, weak 467.7625 464 DCS """J"" Dot" Construction 467.9250 67.0 Hz Blue Star Weak, only able to decode CTCSS tone 469.5125 114 DCS """shuttle van"" ""back by the cones"" (portables, fair to poor signal)" 154.5700 67.0 Hz MURS 4 """okay I have you loud and clear"" " 461.1875 67.0 Hz """okay"" (fair signal)" 462.6000 118.8 Hz FRS 17 """car 3 to car 1"" ""okay we're looking for 78"" - presumed car to car comms on I-95 " 461.2125 67.0 Hz """I'll go check the [unreadable] right now"" - possibly related to traffic heard on 461.1875 MHz 67.0 Hz " 462.5625 136.5 Hz FRS 01 FRS call tones heard, verified correct CTCSS 151.9550 179.9 Hz Purple Dot Construction-related chatter 467.8375 346 DCS """gate 3"" ""Laburnum Ave"" " 158.4000 023 DCS "Radio checks, reference to ""Channel 16"" - sounds like portables " 467.8750 67.0 Hz Gold Star Spanish language 462.6125 74.4 Hz FRS 03 Traffic control, parking lot attendants or flaggers? 462.5750 023 DCS FRS 16 """section 2"" ""link 4"" - talking about ""dish angles"" and antenna mounting - likely RF engineers " 451.8125 346 DCS """do you copy Echo 3 on direct?"" ""negative copy switching back to 1"" (presumed alternate channel for RIR event with the 464.550 [346 DCS] repeater being primary)" 469.9500 203.5 Hz Parking lot attendants - simplex 462.5875 67.0 Hz FRS 02 """cars"" - sounds like more traffic control type chatter " 154.5150 67.0 Hz Spanish language chatter 467.7750 072 DCS Retail - portables - likely Target (Target channel 2, radio plan A) 464.5500 162.2 Hz Yellow Dot Likely retail 467.7500 115 DCS Retail - portables - likely Target (Target channel 1, radio plan A) 451.8125 203.5 Hz Camera direction, TV production chatter 467.9000 174 DCS Red Star Weak, portables 461.3625 172 DCS Retail, possibly a grocery store 462.9125 065 DCS "heard reference to ""loss prevention""" 467.9000 94.8 Hz Red Star Likely also retail 462.5875 118.8 Hz FRS 02 """they have a 1:45 appointment for an oil change I believe""" 456.8125 023 DCS Construction materials contractor or similar 467.7625 107.2 Hz """J"" Dot" Weak, suffering from strong interference from data/voice on 467.750 MHz and voice on 467.775 MHz 467.8500 100.0 Hz Silver Star Retail/security 467.9000 225.7 Hz Red Star """50 pound bag"" ""customer""" 464.8250 516 DCS Presumed also related to NASCAR race (temporary repeater) - possibly RMC Events 462.5750 251 DCS FRS 16 UNID business user 461.3625 546 DCS Parking/traffic control 467.9000 131 DCS Red Star Retail/security or loss prevention 154.5700 CSQ MURS 4 Retail/security - likely WalMart or Sam's Club going by the fact that they're using carrier squelch (CSQ) on MURS 461.2625 023 DCS Parking/traffic control - likely RMC Events 452.1125 315 DCS Parking or security operations (simplex) 461.3125 023 DCS Parking/traffic control - likely RMC Events 462.7125 CSQ FRS 07 """yeah he's worried about being late for work"" ""yeah well...."" - informal CB-like chatter, faded in and then out very quickly " 154.6000 CSQ MURS 5 Retail/security - likely WalMart or Sam's Club going by the fact that they're using carrier squelch (CSQ) on MURS 467.7625 065 DCS """J"" Dot" Retail - weak/fair signal 466.1875 023 DCS Concrete construction contractor - portable radios 4/19/2021 158.4075 065 DCS FLIGHTCOM dispatch at 9:48AM 464.5625 85.4 Hz Hotel or hospitality 154.4900 67.0 Hz Road repair crew or contractor 467.7875 464 DCS """Level 10"" ""back it up 5 feet...""" 462.9125 192.8 Hz Tower crane coordination 464.5500 205 DCS Yellow Dot Tower crane control/construction 469.5500 114.8 Hz Tower crane coordination 151.5125 136.5 Hz Crane control (usual users of this frequency/tone - have also been heard using 154.5275 with 136.5 Hz tone) 462.8625 88.5 Hz Tower crane control/construction - English/Spanish - likely related to activity on 469.5500 [114.8 Hz], 462.9125 [192.8 Hz] and others 462.6750 606 DCS FRS 20 Retail, same group previously monitored using 606 DCS code on this channel 457.5250 315 DCS Local school 456.8000 074 DCS Poor signal, presumably portables 467.5625 CSQ FRS 08 """okay we don't need to have that conversation now"" ""alright you're good"" - YL and OM speakers, fair to poor signals at 10:00-10:02 AM" 464.5000 179.9 Hz Brown Dot Poor signal, difficult to ID user 462.6000 67.0 Hz FRS 17 """Mike..."" (female speaker) - very poor copy " 462.6875 67.0 Hz FRS 06 Weak 469.5000 205 DCS Tower crane coordination 462.5625 CSQ FRS 01 """I don't think he even knows where we are"" (poor signal, FRS Roger Beeps heard)" 462.7125 167.9 Hz FRS 07 """back..."" (also very weak) " 464.5375 223 DCS Construction 462.7125 159.8 Hz FRS 07 Same group usually heard using this CTCSS tone and channel combination 464.5000 88.5 Hz Brown Dot Weak, interference from other user(s) on frequency 467.6625 67.0 Hz FRS 12 Elevator floor requests - same users as previously monitored, good signals 154.4900 162.2 Hz Luck Stone - base to truck (dispatch) 451.8000 031 DCS "Mention of ""field maintenance"" and discussion regarding weather / raining " 467.6375 CSQ FRS 11 "Local school - previously logged using this channel - no CTCSS or DCS tone/code used, carrier squelch with FRS ""Roger Beeps"" as usual" 462.6625 88.5 Hz FRS 05 Heard YL speaking, poor copy, UNID users 466.1875 023 DCS Concrete construction contractor - portable radios 462.5750 243 DCS FRS 16 Spanish language chatter - presumably construction or similar 151.8200 131.8 Hz MURS 1 Utility marking or inspection company (portable radios) 451.8125 023 DCS Concrete construction contractor - portable radios 464.5500 127.3 Hz Yellow Dot Crane control? presumed 462.5625 67.0 Hz FRS 01 "Group caravanning up 95, good signals at points, FRS style ""Roger Beeps"" heard " 467.7125 107.2 Hz FRS 14 FRS call tones heard...no audio (voice) heard... 4/20/2021 469.5500 114.8 Hz Tower crane coordination 462.6375 131.8 Hz FRS 04 """lot B"" ""okay let the dark blue truck go through"" " 464.5500 627 DCS Yellow Dot """level 9 has been inspected first, he wants to meet you on level 8"" ""okay he will call you back on the radio"" - very active around 8:40-8:45 AM" 467.6625 053 DCS FRS 12 "Coordinating planting, mention of greenhouse, ""Jamie"" - talking about eggplants...good strong signal " 464.8250 026 DCS Crane control 467.6625 67.0 Hz FRS 12 Elevator floor requests, weaker than 053 DCS users on same frequency 151.5125 136.5 Hz Crane control 462.8875 88.5 Hz Crane coordination (other radio chatter heard in background) 151.8200 103.5 Hz MURS 1 Contractor or utility repair crew....sporadic activity 466.3125 156.7 Hz Tower crane control or construction 462.6875 85.4 Hz FRS 06 Short transmission, presumed same group or user previously monitored using this tone on this channel 461.1625 67.0 Hz Hotel/hospitality - repair or maintenance crews 462.5625 CSQ FRS 01 Spanish language, very weak 467.6125 CSQ FRS 10 Kids playing with radios, FRS call tones heard 151.6250 167.9 Hz Red Dot Crane Master truck to truck primary 467.5875 67.0 Hz FRS 09 FRS call tone, a radio check....nothing else heard? 469.5500 506 DCS Spanish language, heard several mentions of floor or level numbers 467.6875 67.0 Hz FRS 13 Local school or daycare? fair to poor copy 151.8200 141.3 Hz MURS 1 Weak, UNID users 466.3625 156.7 Hz Construction 464.5000 179.9 Hz Brown Dot Facilities management 462.6750 606 DCS FRS 20 """price check"" - likely the same retail group previously monitored " 469.5500 732 DCS Weak, UNID user...caught 1 second transmission 467.9250 67.0 Hz Blue Star Security 462.6375 67.0 Hz FRS 04 FRS call tones 462.5625 67.0 Hz FRS 01 Spanish language - different group (not the same guys running carrier squelch on frequency) 464.5500 732 DCS Yellow Dot Construction - weaker than guys running 627 DCS 457.5250 315 DCS Local school 154.5700 023 DCS MURS 4 Two OMs chatting, poor copy 462.6625 79.7 Hz FRS 05 """yeah we got it"" ""okay cool""" 154.5275 136.5 Hz Crane control 154.5700 371 DCS MURS 4 Same group previously monitored using this DCS code 467.6375 CSQ FRS 11 Local school - **switched to channel 12 during afternoon due to interference** 461.2125 67.0 Hz Hotel/hospitality 456.8125 732 DCS Construction (simplex) 464.5000 103.5 Hz Brown Dot Security or building maintenance / facilities management 464.5500 67.0 Hz Yellow Dot Very weak signals, heard at 2:01pm 467.8750 229.1 Hz Gold Star Crane control/coordination 467.6375 97.4 Hz FRS 11 UNID users, causing interference to local school users using carrier squelch 467.6625 CSQ FRS 12 Local school - switched from FRS Ch. 11 due to interference on channel 4/21/2021 457.5750 315 DCS Local school, presumably alternate frequency to 457.525 462.9125 192.8 Hz Crane control/coordination 457.5250 315 DCS Local school - primary frequency 464.5500 271 DCS Yellow Dot """inspection on Friday"" ""clear 12"" " 158.4075 065 DCS LIFE EVAC 1 working FLIGHTCOM at 8:01AM 467.9250 155 DCS Blue Star """there's something wrong with the cable...on the trailer...it's broken and won't close"" " 467.7500 115 DCS Target Store operations (active) 154.6000 77.0 Hz MURS 5 Probably retail, portables 462.6625 136.5 Hz FRS 05 Likely a car repair shop or similar 462.7875 131 DCS Spanish language, fair signals 462.5250 114.8 Hz Daycare 462.5875 118.8 Hz FRS 02 "Retail or similar - heard mention of ""waiting area"" and ""customer service""" 151.5125 136.5 Hz Crane control 462.5750 CSQ FRS 16 """okay thank you"" (weak) " 464.5000 162.2 Hz Brown Dot Retail store, portables 462.6750 606 DCS FRS 20 Retail store 469.5500 703 DCS HVAC engineers? talking about ductwork 464.5500 162.2 Hz Yellow Dot Retail store, portables 467.9000 225.7 Hz Red Star Retail, good signals near Willow Lawn 154.5700 371 DCS MURS 4 Same group previously monitored using this DCS code 466.3125 156.7 Hz Crane control/construction 462.5500 123.0 Hz FRS 15 Spanish language chatter, poor to fair signals 467.8500 67.0 Hz Silver Star """Floor 3"" ""inspector 1"" ""copy that base"" " 462.8125 627 DCS Several transmissions heard around 7:33pm...no voice traffic heard but likely construction related 151.6250 654 DCS Red Dot Lane 3, order numbers....portables, weak signals 462.5875 67.0 Hz FRS 02 Vehicles caravanning up or down I-95 462.8625 88.5 Hz Crane control/construction 469.5500 114.8 Hz Crane coordination, very active at points 464.5500 156 DCS Yellow Dot Construction sounds heard in background, weak signal 451.8000 612 DCS """Base calling Mike...do you copy me on level D?""" 4/22/2021 464.5000 77.0 Hz Brown Dot Spanish 466.3125 156.7 Hz """no toilet paper on the 8th floor...""" 467.6625 67.0 Hz FRS 12 "Elevator floor requests, very active at points (with FRS ""Roger Beeps"")" 467.7875 156 DCS """check out that request"" ""10-4""" 466.1375 103.5 Hz Directing supply delivery trucks, fair to good signal (portables) 469.5500 226 DCS """level 2"" ""check the adjustment"" ""major"" " 462.6250 67.0 Hz FRS 18 Car to car chatter - likely a group caravanning 151.5125 136.5 Hz Crane control 464.5500 627 DCS Yellow Dot Usual users of this frequency and code combination - very active at points 466.0875 506 DCS Construction 462.7125 159.8 Hz FRS 07 Same users usually heard on this frequency/tone combination 466.3625 205 DCS Spanish and English mixed, likely crane control or construction 467.7625 627 DCS """J"" Dot" Construction/crane control chatter 464.8250 026 DCS Crane control 461.3375 023 DCS """inspection on the first levels on Friday"" ""okay"" ""ducting"" - possibly inspection crew or quality assurance crew " 462.7250 136.5 Hz FRS 22 parking lot attendants and traffic direction coordination (portables) 158.4075 065 DCS FLIGHTCOM dispatch loud and clear signals 151.6250 97.4 Hz Red Dot "Car to car comms...heard mention of ""Lombardy Street"" " 467.9125 032 DCS """Tower 2"" " 462.6250 127.3 Hz FRS 18 School or daycare, fair to poor signals 462.5500 67.0 Hz FRS 15 """did you guys want to stop for lunch or wait another hour? - presumably vehicles caravanning " 464.5000 192.8 Hz Brown Dot Microphone keyed down...hearing sirens in background at 11:58AM 462.6625 67.0 Hz FRS 05 Parking lot control 457.5250 315 DCS Local school 467.5875 91.5 Hz FRS 09 Spanish language, poor signal 151.8200 103.5 Hz MURS 1 Contractor/construction crew (portables) 462.5875 023 DCS FRS 02 RF engineering crew, testing radio or data / telemetry links 469.5500 114.8 Hz Crane coordination chatter - can hear other radios active in background 462.5875 97.4 Hz FRS 02 "Crane control, good signal with FRS ""Roger Beeps"" - first heard around 12:15PM" 469.5000 205 DCS Crane control/construction 462.6625 023 DCS FRS 05 """Mick"" ""hold on one sec"" ""shine it now"" - possibly related to the guys monitored using this DCS code on other channels" 467.6125 CSQ FRS 10 "Kids playing on radios (FRS tones heard) - ""can you bring my phone so we can listen to music?"" ""okay also can we bring the together book so we can read it in the car?""" 467.9250 67.0 Hz Blue Star Security? 462.6125 127.3 Hz FRS 03 """Black Suzuki in the handicap spot"" ""10-4"" - very strong signals at 1:45PM" 462.5250 114.8 Hz Local school or daycare - fair signal (portables, simplex) 462.5625 67.0 Hz FRS 01 """ease a little to the right you're almost right next to the building"" " 464.5000 67.0 Hz Brown Dot Crane control 461.1875 67.0 Hz Crane control, fair signal 467.6625 CSQ FRS 12 Local school (have used other FRS channels previously, always with carrier squelch / CSQ) - switched from 12 to 13 at 4:40PM 469.4875 110.9 Hz Spanish, presumed construction 467.6875 CSQ FRS 13 Local school, switched from channel 12 to 13 at 4:40PM...continuing to use carrier squelch 151.7000 141.3 Hz Contractor - possibly utilities or water/sewer? 467.6375 CSQ FRS 11 "Heard mention of ""Casey"" ""oil"" and ""pump"" - likely the reason the school switched off channel 11 to channel 12 (which has construction chatter on it) and then to channel 13)" 462.9125 192.8 Hz Crane coordination 462.7250 252 DCS FRS 22 """sandbox station"" " 4/23/2021 469.5500 114.8 Hz "Crane coordination - informal chatter as well as ""official"" comms - can hear multiple radios in background " 462.4250 103.5 Hz Local school or daycare - fair signal with interference from digital signal on same frequency 451.8125 205 DCS Construction - talking about supply, heard discussion about beams and concrete 464.5500 79.7 Hz Yellow Dot Weak/sporadic signal...was able to decode CTCSS tone but not much else 154.4900 67.0 Hz Highway maintenance or repair contractor 467.6625 67.0 Hz FRS 12 Elevator floor requests - same users usually heard 466.3125 156.7 Hz Spanish and English - construction chatter...very busy at points 462.6625 88.5 Hz FRS 05 """get..."" ""right there""" 154.5700 67.0 Hz MURS 4 Open microphone, heard phone ringing in background 158.4075 065 DCS "FLIGHTCOM - ""that's affirmative - you were giving me your flight plan and they were on the other frequency canceling"" " 467.6125 67.0 Hz FRS 10 Crane control - first heard around 8:45AM 151.5125 136.5 Hz Crane control - the usual user of this frequency and tone combination 159.5100 351 DCS """okay we'll have a look over there"" - possibly repeater " 462.5875 97.4 Hz FRS 02 "Crane control - good signal with FRS ""Roger Beep"" " 464.5000 047 DCS Brown Dot Construction, poor to fair signal 462.6375 131.8 Hz FRS 04 """back it up now"" ""next vehicle go"" " 462.5250 114.8 Hz """yes, I can hear you fine on here now"" " 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency and tone combination (active somewhere downtown) 464.8250 026 DCS Crane control - as usual with sporadic interference from Philip Morris repeater on same frequency 462.6250 127.3 Hz FRS 18 """okay you can bring it down now"" ""copy"" (all female voices)" 457.5250 315 DCS Local school - portables 462.5875 74.4 Hz FRS 02 """she uh...she actually just went out"" - different ""Roger Beep"" than the other group on frequency - roughly same signal strength " 464.5500 627 DCS Yellow Dot Usual users of this frequency and code combination - very active at points 154.5700 371 DCS MURS 4 Same group previously monitored using this DCS code 462.6750 606 DCS FRS 20 Retail user - monitored numerous times using this frequency and DCS code combination (portable radios) 462.1250 69.3 Hz Hotel or hospitality - portables/simplex - heavy interference from digital signal on frequency (note: the Jefferson Hotel is licensed to operate a digital voice repeater system on this frequency) 462.5625 77.0 Hz FRS 01 Spanish language 151.6250 065 DCS Red Dot FLIGHTCOM dispatch 462.5875 67.0 Hz FRS 02 Crane control (third group monitored using this frequency so far today - each using a different CTCSS tone though) 466.0875 506 DCS Construction 462.6500 CSQ FRS 19 Sounds like car to car chatter - likely a group going up or down I-95 or I-64 151.8200 103.5 Hz MURS 1 Contractor or construction - presumably the same group previously monitored using this tone on MURS 469.5500 732 DCS Elevator floor requests - very similar to the traffic normally heard on FRS-12 with 67.0 Hz 462.7250 67.0 Hz FRS 22 Sounds like two kids talking on FRS walkie talkies (monitored around 12:43-12:44PM) 467.5625 CSQ FRS 08 """I'm looking into the sun! I can't see fucking anything!"" " 466.0625 732 DCS Construction 462.6125 127.3 Hz FRS 03 """Bring it back...towards me...."" (weak/poor signal)" 464.5500 67.0 Hz Yellow Dot """Check that level again"" (good signal)" 462.6875 141.3 Hz FRS 06 """Cliff...I need you to dial 223...Cliff...dial 223"" " 154.5275 136.5 Hz Crane control - the usual user of this frequency and tone combination 462.7250 136.5 Hz FRS 22 Caught tail end of a weak signal 456.8125 743 DCS Construction - sporadic signal, portables/simplex 467.8750 67.0 Hz Gold Star Talking about fences? installation crew? 461.2625 67.0 Hz Hotel or hospitality - customer service and room cleaning/repair crew and engineering 462.6125 165.5 Hz FRS 03 Open mic, weak signal but 100% copy on the CTCSS tone... 151.5050 179.9 Hz Crane control, unknown company (likely not Crane Master) 467.6875 CSQ FRS 13 Local school - see log from 04/22/21 regarding frequency/channel changes 462.5875 118.8 Hz FRS 02 Spanish language, weak/fair signal - sometimes 2-3 signals on frequency at once.... 467.6125 073 DCS FRS 10 UNID net - suffering heavy interference from the other group (crane control) on frequency 462.7250 218.1 Hz FRS 22 """Level 14"" ""copy that"" ""check that second load"" " 461.3125 023 DCS RMC Events - likely active at Richmond Flying Squirrels game at The Diamond 461.2625 023 DCS RMC Events - likely active at Richmond Flying Squirrels game at The Diamond 467.8750 229.1 Hz Gold Star Crane coordination channel 467.6125 94.8 Hz FRS 10 """blue sedan coming at you now"" " 4/24/2021 464.5500 627 DCS Yellow Dot Crane control and construction use - very active at points with strong signals 158.4075 065 DCS FLIGHTCOM working various medevac helicopters 467.7625 205 DCS """J"" Dot" Construction 469.5000 114.8 Hz """yeah man and it's interfering with everyone else's radio"" " 462.5500 67.0 Hz FRS 15 "Weak, heard FRS ""Roger Beeps"" and call tones and alert tones " 464.8250 026 DCS Crane control 469.5500 114.8 Hz Crane coordination 464.5000 023 DCS Brown Dot """link 2 check signal strength""" 151.5125 136.5 Hz Crane control - the usual user of this frequency and tone combination 467.7125 343 DCS FRS 14 FRS call tones - fair to weak signal 462.8250 162.2 Hz Weak signals, Spanish language 462.5875 97.4 Hz FRS 02 Crane control, good signals mixed English and Spanish 154.4900 67.0 Hz Contractor or repair crew (portables) 462.6250 127.3 Hz FRS 18 Spanish language 462.8625 88.5 Hz Crane coordination 464.5500 205 DCS Brown Dot Construction 462.9125 192.8 Hz Crane coordination 462.6125 67.0 Hz FRS 03 Traffic control, flaggers or maybe parking lot coordination 462.4250 103.5 Hz Local daycare - portables with some interference from digital signals on same frequency 462.6750 606 DCS FRS 20 Retail store - various signal strengths, portables 4/25/2021 464.5000 432 DCS Brown Dot Construction 462.5875 97.4 Hz FRS 02 "Crane control - good signals with FRS ""Roger Beeps"" " 464.8250 026 DCS Crane control 456.8000 506 DCS Construction (simplex, portables) 469.5500 114.8 Hz Crane control/coordination 462.7125 67.0 Hz FRS 07 "Sounds like kids playing with FRS walkie talkies...""Roger Beeps"" heard - no CTCSS or DCS tones/codes in use " 464.5500 627 DCS Yellow Dot Crane control and construction use - very active at points with strong signals 462.5625 CSQ FRS 01 two kids talking on the radio, very weak...no tone or code in use 4/26/2021 462.8125 627 DCS Crane control and construction operations, active early in the morning on 26 April 464.5500 67.0 Hz Yellow Dot """call him back and let him know that the keys are not up here"" (fair signal at 7:07AM)" 464.8250 026 DCS Crane control, some interference from Philip Morris repeater on frequency 158.4075 065 DCS "FLIGHTCOM dispatch working medevac helicopter - ""what's your ETA to VCU?"" - loud and clear at 7:09AM" 469.5500 114.8 Hz Crane coordination, usual traffic for this frequency and tone 151.6250 065 DCS Red Dot "AIRCARE EAGLE working FLIGHTCOM ""12 minutes en route to Hanover, risk is 1100"" - base station is loud and clear, aircraft is fair and readable at 7:15AM / 7:16AM" 462.5875 97.4 Hz FRS 02 Crane control 467.5875 91.5 Hz FRS 09 """I've got 3 more for you"" ""okay 3...I've got room for 3...."" ""that's quite the line..."" ""copy that"" " 462.7875 021 DCS """why don't we..."" [faded out] weak at 9:31AM" 462.5875 118.8 Hz FRS 02 """truck"" ""okay copy"" " 457.5250 315 DCS Local school 462.8125 021 DCS """no, you can't go down that...it's a one-way"" (very heavy interference with other group using same frequency) " 467.6625 77.0 Hz FRS 12 """Yes, yes, two...."" - weak signal " 466.0875 506 DCS Crane control 462.5750 654 DCS FRS 16 """Tammy Davis said the parking lot is empty""" 151.5125 136.5 Hz Crane control - the usual user of this frequency and tone combination 467.6625 67.0 Hz FRS 12 Elevator floor requests 469.5000 315 DCS Crane control - fair signal - likely some distance away compared to most tower crane activity heard 464.5500 627 DCS Yellow Dot Construction and crane control 462.8375 021 DCS Talking about directions - probably also related to the TV or film crews using the same non-standard DCS code 151.7000 141.3 Hz Contractor - possibly utilities or water/sewer? 462.5625 67.0 Hz FRS 01 Crane control or construction (with interference from another group on channel using a different CTCSS tone) 464.4875 021 DCS """back on the..."" - other fair to poor signals " 151.8800 244 DCS MURS 2 """start to back...slow..."" - possibly construction " 469.5500 165 DCS """hold onto your straps a little bit longer"" (weak, poor copy)" 462.5625 77.0 Hz FRS 01 Spanish language, heavy interference at points 469.5500 506 DCS Spanish language, presumed construction based on DCS code 462.7125 159.8 Hz FRS 07 Usual user of this frequency and tone 462.8625 021 DCS TV or film crew? 151.6250 026 DCS Red Dot Weak, UNID users 469.5125 315 DCS Construction, weak signals 461.2375 165 DCS Construction, sporadic signals 151.9550 127.3 Hz Purple Dot Weak, talking about trucks and deliveries 462.6750 606 DCS FRS 20 Retail store 466.3125 156.7 Hz Crane control 467.5875 165.5 Hz FRS 09 """cage"" ""basket 2"" ""okay bring it back down...""" 154.5700 371 DCS MURS 4 Construction or contractor 462.7250 136.5 Hz FRS 22 Weak signal, presumed portables (low power considering the frequency and tone) 469.4875 021 DCS TV or film crew 467.6125 67.0 Hz FRS 10 Spanish language, very weak 467.5625 CSQ FRS 08 "Local school - dismissal - heard mention of ""6th grade"" ""7th grade"" and ""8th grade"" - no CTCSS tone or DCS code received " 461.1875 136.5 Hz Construction, sporadic signals 464.5000 432 DCS Brown Dot """Hey Jack...do you wanna turn around?"" " 462.6750 136.5 Hz FRS 20 "Local school with FRS ""Roger Beeps"" (some interference from retail store on same frequency) " 466.0375 91.5 Hz Facilities maintenance or engineering crew 462.6250 127.3 Hz FRS 18 Sounds like a catering company? 464.5000 465 DCS Brown Dot """cable run"" " 467.8750 229.1 Hz Gold Star Crane control, active in the evening 467.9125 021 DCS TV or film crew 469.5625 021 DCS TV or film crew 462.6125 74.4 Hz FRS 03 Possible surveillance or radio training 469.5125 021 DCS TV or film crew...active, but weak 467.8375 712 DCS Construction or crane control 464.5125 021 DCS TV or film crew 464.5625 85.4 Hz Hotel or hospitality - customer service and room cleaning/repair crew and engineering 462.5500 123.0 Hz FRS 15 Spanish language, fair to poor signals 462.7625 021 DCS Coordinating shuttles or pick up and drop off vans/buses (poor signal) 464.5625 021 DCS TV or film crew...active, but weak 467.7625 229.1 Hz """J"" Dot" Crane control 469.5375 021 DCS TV or film crew...active, but weak 451.8125 466 DCS Construction crew 4/27/2021 462.5875 97.4 Hz FRS 02 Crane control, very active at several points 467.8750 229.1 Hz Gold Star Crane coordination 462.4250 103.5 Hz Local school or daycare (simplex, portables) 467.6625 67.0 Hz FRS 12 Elevator floor requests 469.5500 114.8 Hz Crane coordination 466.0875 506 DCS """okay well you can move it all up there and just pull the truck up...""" 154.4900 67.0 Hz Highway maintenance crew (portables) - same user previously monitored using this frequency and CTCSS tone combination 462.5750 165.5 Hz FRS 16 UNID user - solid CTCSS tone decode (tone noted in use on this channel previously) 462.7125 159.8 Hz FRS 07 Usual users of this tone and frequency 464.8250 026 DCS Crane control 154.5700 244 DCS MURS 4 Contractor or construction user (portables) 464.5500 627 DCS Yellow Dot Crane control and construction 154.5700 371 DCS MURS 4 Usual group on this channel - stronger than other group heard using different DCS code 457.5250 315 DCS Local school 462.6875 85.4 Hz FRS 06 "Unreadable voice, followed by FRS ""Roger Beep"" - this CTCSS tone previously monitored on this channel " 467.9250 67.0 Hz Blue Star """bring it back towards the left...no...yes...left...about 3 feet"" " 158.4075 065 DCS FLIGHTCOM dispatch - base station to aircraft (Medevac) 151.6250 065 DCS Red Dot FLIGHTCOM dispatch - base station to aircraft (Medevac) 462.6750 606 DCS FRS 20 Retail store 469.5500 165 DCS """pickup on level 6 please"" ""okay so you want me to load it...?"" ""alright""" 462.5625 77.0 Hz FRS 01 Spanish language chatter - seems to be the same users previously monitored using this tone 467.6125 743 DCS FRS 10 Spanish language, very informal chatter (weak/fair signals) 151.5125 136.5 Hz Tower crane control, usual users of this frequency and tone 462.6375 CSQ FRS 04 Kids playing on FRS radios - weak to fair signals - no tones or codes in use 469.5000 165 DCS Construction chatter 151.6250 167.9 Hz Red Dot Crane Master truck to truck - confirmed user - primary frequency 462.6875 141.3 Hz FRS 06 Filipe, are you all ready? - discussion about appointment times, etc. presumed COVID vaccination site or testing site 469.5125 021 DCS TV or film crew 462.6750 136.5 Hz FRS 20 Local school - sporadic interference from retail store users on same frequency 462.7625 021 DCS TV or film crew 467.6125 364 DCS FRS 10 Background audio (weak) 466.3125 156.7 Hz Crane control 158.4000 167.9 Hz Construction related chatter - possibly Crane Master based on CTCSS tone 466.0875 97.4 Hz Construction - fair to weak signals 462.5875 118.8 Hz FRS 02 """following up on that appointment"" " 462.5250 114.8 Hz Talking about lunch buffet.. 469.5000 205 DCS Construction and crane control 462.6625 67.0 Hz FRS 05 UNID user, caught tail end of transmission 462.7625 205 DCS Construction - Spanish and English 464.5000 165 DCS Brown Dot Construction, sporadic signals 462.6625 136.5 Hz FRS 05 COVID-19 vaccination or testing site (active on other FRS frequencies as well) 456.8125 205 DCS Construction crew, talking about weather forecasts 467.5625 371 DCS FRS 08 FRS call tones heard 464.5500 165 DCS Yellow Dot Construction, weak and strong signals, with interference from other stations on frequency 466.1125 021 DCS TV or film crew 462.5625 023 DCS FRS 01 Spanish language, weak poor signal 466.2625 205 DCS Construction 462.6250 127.3 Hz FRS 18 Local school or daycare (weak to fair signal, portables) 462.9125 88.5 Hz Crane coordination (can hear other radios in the background audio of some transmissions) 154.5275 136.5 Hz Tower crane control, usual users of this frequency and tone 467.6875 CSQ FRS 13 Local school - active in morning and mid-afternoon... 451.8125 506 DCS Construction crew, fair to weak signals 151.8200 103.5 Hz MURS 1 Contractor or construction - presumably the same group previously monitored using this tone on MURS 462.6625 023 DCS FRS 05 """you are clear...you are visible on the monitor..you are clear keep it going..."" (FRS Roger Beeps heard) " 462.8250 162.2 Hz Local school or daycare? Poor copy 462.7250 136.5 Hz FRS 22 Catering company? 464.4875 021 DCS TV or film crew 462.6125 97.4 Hz FRS 03 Crane control and general informal chatter (poor to fair signals) 467.9000 225.7 Hz Red Star Retail operations 467.8750 94.8 Hz Gold Star Retail operations 467.5875 032 DCS FRS 09 "Heard female voice, weak to fair signal...no ""Roger Beep"" heard " 467.7750 072 DCS Retail operations - likely Target (known frequency and DCS code combination, heard near Willow Lawn) 467.9250 225.7 Hz Blue Star Retail operations 467.7500 115 DCS Retail operations - likely Target (known frequency and DCS code combination, heard near Willow Lawn) 464.5000 162.2 Hz Brown Dot """50 pound bag"" ""check order""" 456.8125 432 DCS Weak signal, was able to copy DCS code and not much else 462.6125 CSQ FRS 03 """no, that's not...."" ""copy"" (strong signals, received around 7:15PM) " 4/28/2021 469.5500 205 DCS Construction 469.5000 165 DCS Construction and general informal chatter 469.5000 205 DCS Construction, mixing with other signals on frequency 466.0875 506 DCS Crane control/construction (sporadic use) 462.6750 606 DCS FRS 20 Local retail store - previously logged using this frequency and code combination 469.5500 165 DCS Construction and general informal chatter 469.5500 114.8 Hz Crane coordination 467.8750 229.1 Hz Gold Star Active - crane control (busy during morning and evening hours) 469.5500 506 DCS Construction - English and Spanish 467.5625 243 DCS FRS 08 School or daycare operations? - portables...fair to poor signal strength 462.9125 192.8 Hz Crane coordination 467.6625 053 DCS FRS 12 "Possibly local school - """"""I'm actually going to need your help taking the paper back down as well"" and similar traffic " 151.5125 136.5 Hz Tower crane control, usual users of this frequency and tone 464.8250 026 DCS Crane control 462.6750 136.5 Hz FRS 20 Local school - some interference from retail store on same frequency 464.5500 627 DCS Yellow Dot Crane control and construction 467.6625 67.0 Hz FRS 12 Elevator floor requests 466.3125 156.7 Hz Crane control 462.6250 127.3 Hz FRS 18 Spanish and English, presumed construction crew 462.5625 67.0 Hz FRS 01 Very weak signals around 8:15AM - 8:30AM...was able to decode CTCSS and thats about it...heard some Spanish language chatter again at 8:45AM... 462.7125 159.8 Hz FRS 07 Usual users of this tone and frequency - very active at points with strong to fair signals (coming from the downtown area) 158.4075 065 DCS FLIGHTCOM dispatch - base station to aircraft (Medevac) 467.9250 67.0 Hz Blue Star Crane control or construction 154.5700 371 DCS MURS 4 Usual group on this channel - stronger than other group heard using different DCS code 462.8125 627 DCS "Construction crew, appears to be alternate channel or general chat, tactical or ""talkaround"" " 462.6875 85.4 Hz FRS 06 Short transmission, presumed same group or user previously monitored using this tone on this channel 462.6625 023 DCS FRS 05 Coordinating loading equipment, installing ??? unknown - active throughout the day (sporadic interference) 151.7000 141.3 Hz Utility or road contractor - possibly truck to truck comms 462.7000 155 DCS FRS 21 """bring that back up...."" ""okay 10 feet...."" " 462.7875 021 DCS TV or film crew 462.6375 032 DCS FRS 04 Sounds like traffic control 462.7625 021 DCS TV or film crew 462.5875 97.4 Hz FRS 02 Crane control 464.4875 226 DCS Supply or equipment delivery coordination? portables 462.6375 131.8 Hz FRS 04 School or daycare - weak and sporadic signals 464.5375 85.4 Hz Repair or engineering crew? weak to fair signals 462.7250 136.5 Hz FRS 22 Catering company 462.8375 021 DCS Film crew, shuttles 462.7125 146.2 Hz FRS 07 """they're ready for lunch now too so you can send the next group over""" 457.5250 315 DCS Local school 464.5000 136.5 Hz Brown Dot """hey we have another question for you..."" " 462.5875 118.8 Hz FRS 02 """okay drop it down...drop it down.."" " 154.4900 162.2 Hz Luck Stone quarry and crushed stone - truck to truck and truck to base channel (dispatcher talking to mobile unit(s)) 469.5625 021 DCS TV or film crew 464.5500 146.2 Hz Yellow Dot Security or inspection crew (portables) 467.6875 CSQ FRS 13 "Local school - strong signals with FRS ""Roger Beeps""" 462.8250 162.2 Hz School or daycare 462.6625 88.5 Hz FRS 05 """Justin"" and another, unidentified person - probably construction-related chatter " 154.5700 043 DCS MURS 4 Crane control, portables 4/29/2021 151.9550 127.3 Hz Purple Dot Security for warehouse or distribution center 464.5500 156.7 Hz Yellow Dot "Base to ""unit 21"" ""can you open the roof access gate please?"" - base and mobiles with good signals " 151.6250 065 DCS Red Dot AIRCARE EAGLE and FLIGHTCOM doing a radio check at 7:45AM 451.8000 023 DCS Talking about concrete 469.5500 114.8 Hz Crane coordination - very active at points 151.5125 136.5 Hz Crane control - usual users of this frequency and tone combination 462.5625 97.4 Hz FRS 01 """gonna be checking your brakes"" ""okay"" " 467.8750 229.1 Hz Gold Star Crane coordination 469.5000 205 DCS """another company is taking a delivery on the south side of the building....what do we got?!"" ""oh boy"" - general construction related comms " 469.5500 165 DCS Construction - interfering with other users on same frequency 467.6625 67.0 Hz FRS 12 Elevator floor requests 469.5500 732 DCS """well you've got that truck to your right...what do you think he'll do?"" (heavy interference from other users on frequency)" 462.5625 67.0 Hz FRS 01 """Hey Amber...there are more than 5 flats but they all seem like they're the same"" ""okay yeah I would just dump all of those"" " 464.5000 67.0 Hz Brown Dot Very weak signal - caught just enough to decode CTCSS - unable to ID user 464.8250 026 DCS Crane control 154.5700 371 DCS MURS 4 Usual users on this frequency and DCS code combination - portable radios 464.5500 627 DCS Yellow Dot Crane control and construction 462.7250 252 DCS FRS 22 Spanish language, construction noises heard in background 462.1250 69.3 Hz Spanish language, sporadic signals - weak with heavy interference from DMR digital voice signals on frequency 462.7625 021 DCS TV or film crew 154.4900 67.0 Hz Highway maintenance or repair contractor 462.6750 606 DCS FRS 20 Local retail user 466.0875 506 DCS Crane control 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 2 466.3125 156.7 Hz Crane control/construction 467.6625 053 DCS FRS 12 School - possibly same group monitored using this channel and DCS combination 462.5875 023 DCS FRS 02 Inspection crew or HVAC techs 469.5500 506 DCS Construction - general business related comms 462.6750 136.5 Hz FRS 20 Local school - some minor interference from retail users on same frequency 457.5250 315 DCS Local school 462.6500 CSQ FRS 19 Highway construction or repair crew, possibly active on other FRS channels as well 462.6625 464 DCS FRS 05 """bring the diapers"" (low audio) " 462.8875 021 DCS TV or film crew 462.6125 103.5 Hz FRS 03 """that group should be...[unreadable]"" - FRS ""Roger Beeps"" noted in use " 464.4875 021 DCS TV or film crew 462.7125 159.8 Hz FRS 07 Usual users of this frequency and tone combination - downtown activity 462.6125 023 DCS FRS 03 Inspection crew or HVAC techs 467.9250 67.0 Hz Blue Star Crane control or construction (fair to poor signal) 461.1875 67.0 Hz Construction 469.5000 165 DCS Construction 462.6875 85.4 Hz FRS 06 "previously monitored using this tone....heard ""password is G O D 1"" " 151.6250 67.0 Hz Red Dot Road or highway repair crew - sounds like portable radios 462.6000 146.2 Hz FRS 17 Car to car comms, likely a group traveling on the interstate 469.5125 115 DCS "heard ""West"" and nothing else - quick DCS decode though...unsure if related to other users logged on this frequency " 469.9500 203.5 Hz """lane 2"" ""check for obstruction"" ""copy that"" (portables, simplex)" 462.7000 CSQ FRS 21 """Bobcat"" ""maybe we need to double check the voltage?"" ""okay standby"" ""it goes back down into one lane as it merges back into 64..."" - active, possibly highway construction crews? good signals, possibly running higher power mobile radios - ""turn around and take another route"" ""turn around, then we'll go north towards...195"" - very active at points " 466.0875 97.4 Hz """we need two 6-footers or 8-footers would work...and a 7/8ths feed wrench"" (maybe ""speed wrench"") " 467.6375 CSQ FRS 11 Car to car chatter...fair to weak signals 462.7875 023 DCS """just doing a radio check"" - at 12:52 PM - strong signal " 462.6375 77.0 Hz FRS 04 """we need to get that footage"" ""yes, okay...going down...down...okay"" " 462.5875 67.0 Hz FRS 02 "School or day care - ""bring them to the activity room now""" 469.5500 205 DCS Construction chatter 154.5700 043 DCS MURS 4 Crane control, portables 462.6625 136.5 Hz FRS 05 COVID vaccination or testing site operations 467.6875 CSQ FRS 13 Local school - good signals with Roger Beeps - most active in mid-afternoon 456.8125 165 DCS Construction and delivery coordination chatter 151.8200 67.0 Hz MURS 1 "Female voices talking about ""elevator 2""" 464.5375 85.4 Hz Engineering or repair crew (portables, poor to fair signal) 462.5625 77.0 Hz FRS 01 Spanish language, weak with unique style Roger Beep 462.6250 127.3 Hz FRS 18 """area 3"" ""check for Liam's mom she should be here to pick him up now"" " 462.8125 627 DCS Construction and general casual chatter 461.2125 67.0 Hz Hotel or hospitality service (portables, fair to weak signal) 464.5000 179.9 Hz Brown Dot """circuit 2 is showing open"" ""10-4""" 461.1625 67.0 Hz """room 201"" ""clogged""" 462.7250 67.0 Hz FRS 22 Crane control, poor signal 456.8000 023 DCS Possibly construction - talking about rain and forecasted weather 464.5500 114.8 Hz Yellow Dot Tail end of a transmission...heard construction noises in background 4/30/2021 467.8125 506 DCS """K"" Dot" Materials delivery discussion - likely construction site related 461.0875 244 DCS "Construction - mention of ""outriggers"" " 467.6625 67.0 Hz FRS 12 Elevator floor requests 466.3125 156.7 Hz Construction - very busy at points 467.5875 371 DCS FRS 09 Tail end of possible VOX or room audio transmission 151.5125 136.5 Hz Crane control - usual users of this frequency and tone combination 462.7125 79.7 Hz FRS 07 """point one"" ""yes...point one"" (in Spanish) with FRS Roger Beeps - fair to poor signals heard at 8:33AM" 464.5500 244 DCS Yellow Dot Construction - fair signal strength 466.2625 156.7 Hz """yeah I got you, hang on a second"" " 467.6625 053 DCS FRS 12 Local school - previously monitored using this DCS code on this frequency 469.5000 165 DCS Construction 462.7125 159.8 Hz FRS 07 Usual users of this frequency and tone combination - with some interference from the Spanish-speaking group using same channel (different CTCSS tone) 469.5500 114.8 Hz Crane coordination 464.5500 627 DCS Yellow Dot Construction - very active at points as usual 462.6625 023 DCS FRS 05 """we should be able to reuse 2 per second..."" ""both sides of the..."" - likely same group heard previously " 457.5250 315 DCS Local school 462.5875 97.4 Hz FRS 02 Crane control/construction - busy at points 469.5500 712 DCS UNID user - caught this code for a moment on an active frequency 467.8750 229.1 Hz Gold Star Crane coordination - often very active 154.5700 043 DCS MURS 4 Crane control (portables) 462.6375 77.0 Hz FRS 04 Spanish language, presumed construction 158.4075 065 DCS FLIGHTCOM working medevac helicopters 461.1875 79.7 Hz """get those lines up here!"" ""thank you"" " 467.8500 100.0 Hz Silver Star Retail operations - low power portables 462.6750 606 DCS FRS 20 Local retail use 151.6250 065 DCS Red Dot FLIGHTCOM working medevac helicopters 462.5250 114.8 Hz School or day care - portables 456.8125 654 DCS """Customer service"" ""back area"" (poor signal - likely low power portable radios) " 467.8125 103.5 Hz """K"" Dot" Hotel valet coordinationn 462.5500 162.2 Hz FRS 15 """loaders are loading the second truck"" " 462.6500 503 DCS FRS 19 Car to car comms - likely a group on the interstates nearby - heard mention of exit numbers 469.5500 732 DCS Construction chatter - including service elevator requests 462.6250 127.3 Hz FRS 18 """bring that class back up to the..."" - presumed school use " 469.5500 165 DCS """give me five buckets...then we'll hit the horn and see what happens"" - additional chatter, crane operators or similar - this is a very busy frequency with multiple groups on during the day and often transmitting at the same time " 462.6125 225.7 Hz FRS 03 """next group is good"" - with FRS style Roger Beeps " 462.4250 103.5 Hz Local school or day care? or...catering company - portables low power with heavy interference from DMR digital signals on frequency 462.7000 CSQ FRS 21 Highway repair or inspection crew - appears to be the same guys heard on this frequency (and also using carrier squelch) yesterday 461.1875 67.0 Hz """is she leaving? she told me she's a late checkout"" - presumably hotel operator - fair to good signals" 154.5700 371 DCS MURS 4 Road repair crew or contractor 462.6125 127.3 Hz FRS 03 """we'll come back that way"" - UNID users possibly school? " 462.9125 192.8 Hz Crane coordination - one of several frequencies logged on a daily or nearly-daily basis 462.6750 136.5 Hz FRS 20 "Local school - some interference from retail store using same frequency - heard mention of ""7th grade"" as well as numerous specific student's names " 462.8625 88.5 Hz Crane coordination - one of several active frequencies used by multiple cranes 462.6000 CSQ FRS 17 """next time"" ""gray Toyota"" - poor signal " 462.6875 85.4 Hz FRS 06 Weak signal, activity noted on this channel and CTCSS tone previously - see older logs 466.0625 244 DCS Construction - fair signal strength 462.6375 114.8 Hz FRS 04 Two stations talking about traffic conditions 462.5875 118.8 Hz FRS 02 """3:45 appointment"" " 469.5000 205 DCS Crane control 151.8200 103.5 Hz MURS 1 Construction or road repair crew, portables 462.6625 203.5 Hz FRS 05 """oh yeah! she can..."" " 469.5500 654 DCS Construction - sometimes with severe interference 462.5625 77.0 Hz FRS 01 Very faint signal - sounded like Spanish language 151.6250 023 DCS Red Dot Two or more mobiles - talking about traffic and signs, possible highway maintenance or traffic directors 467.6875 CSQ FRS 13 Local school - very good signals - previously monitored using this and other FRS channels without CTCSS tones or DCS codes 151.8200 67.0 Hz MURS 1 """do you have me?"" ""yeah I'm on the elevator now sorry"" " 462.5500 123.0 Hz FRS 15 """bring it back to the number 1 lane"" - portables " 151.9550 023 DCS Purple Dot Traffic sign maintenance or highway repair crew 154.6000 103.5 Hz MURS 5 Repair crew or contractor 5/1/2021 464.5000 131.8 Hz Brown Dot Construction or maybe landscaping maintenance crew? 464.5500 627 DCS Yellow Dot Construction - very active at points 154.4900 67.0 Hz Repair crew or road maintenance crew (portable radios) 462.6750 172 DCS FRS 20 Construction - likely crane control as well 158.4075 065 DCS FLIGHTCOM working several aircraft 469.5500 114.8 Hz Crane coordination and (at times) informal chatter 467.8750 229.1 Hz Gold Star Crane coordination 151.6250 023 DCS Red Dot Traffic sign maintenance or highway repair crew 154.5700 043 DCS MURS 4 Crane control 464.8250 026 DCS Crane control 466.0875 97.4 Hz Construction - poor to fair signal 151.8200 67.0 Hz MURS 1 Hospitality or similar - catering business? 466.3125 156.7 Hz Construction/crane control 461.2375 67.0 Hz Construction 462.6375 032 DCS FRS 04 Traffic control - heard FRS Roger Beeps 467.8750 114.8 Hz Gold Star Second group mixing in with crane control activity running different CTCSS tone 462.5875 67.0 Hz FRS 02 """also want a roll"" ""okay"" - kids playing on FRS walkie talkies " 467.5625 371 DCS FRS 08 Background audio, sounds like part of a wireless intercom system 462.4250 103.5 Hz """next order, lemonade please""" 462.7250 136.5 Hz FRS 22 """elevator 2"" - other traffic, weak signals and poor copy " 151.6250 065 DCS Red Dot FLIGHTCOM dispatch - tone burst - scene request information to AIRCARE EAGLE aircraft, loud and clear signal 154.5700 371 DCS MURS 4 Repair crew or road maintenance crew (portable radios) 462.6750 606 DCS FRS 20 Retail user 154.5275 023 DCS Traffic sign maintenance or highway repair crew 464.5500 223 DCS Yellow Dot Construction crew, talking about drywall and prefabricated building materials 462.9125 192.8 Hz Crane coordination and general chatter - not as busy as the other coordination channels today 151.5125 136.5 Hz Crane control - usual users of this frequency and tone combination 462.5625 CSQ FRS 01 """Eddie needs to prepare..."" ""got it!"" - no CTCSS or DCS in use, typical FRS Roger Beeps...weak signals at 5:17PM" 462.7625 165 DCS """123 remaining"" - unknown user " 5/2/2021 151.6250 065 DCS Red Dot FLIGHTCOM dispatch - loud and clear 462.8125 627 DCS Construction 462.6250 127.3 Hz FRS 18 Day care or similar operation? presumed daycare since it's Sunday 151.5125 136.5 Hz Crane control - usual users of this frequency and tone combination 466.0875 97.4 Hz Construction - poor to fair signal 462.5500 123.0 Hz FRS 15 Spanish language - fair signal 464.5500 627 DCS Yellow Dot Construction and crane control - appears to be primary channel 158.4075 065 DCS FLIGHTCOM dispatching LIFE EVAC 1 for an inter-facility transfer - South Hill Medical to VCU Main Hospital 154.5700 88.5 Hz MURS 4 Tail end of a voice transmission - heavy interference from FSK data bursts or telemetry on frequency (9:20-9:30AM) 469.5500 114.8 Hz Crane coordination - sometimes with very informal chatter mixed in 462.7250 67.0 Hz FRS 22 Weak signal, UNID users 467.7875 110.9 Hz Spanish language, poor copy 154.5700 371 DCS MURS 4 Road repair crew or contractor 466.1375 103.5 Hz """do you have me on 16?"" " 5/3/2021 466.3125 156.7 Hz Construction and crane control 467.6625 67.0 Hz FRS 12 Elevator floor requests 462.8625 88.5 Hz Construction - Spanish/English (appears to only be active in mornings and late evenings) 469.5500 165 DCS Construction and crane control 457.5250 315 DCS Local school - portables 462.6750 136.5 Hz FRS 20 Local school, roughly the same signal strength as the retail users often heard on this same frequency 466.0875 506 DCS Construction - fair signal strength - one of two or three groups using this frequency 151.6250 065 DCS Red Dot FLIGHTCOM dispatch - morning radio check and chatter at 8:00AM 462.6250 67.0 Hz FRS 18 Weak signals...possibly car to car comms 464.5000 165 DCS Brown Dot Construction 462.5625 67.0 Hz FRS 01 """bed 1 is hooked to the other hydrant...so the hydrant that it comes from so...left to right"" ""copy that, I got it now"" - very good signals at 8:06AM" 469.5000 205 DCS Construction and crane control 151.5125 136.5 Hz Crane control - usual group of users heard on this frequency and tone 464.5500 627 DCS Yellow Dot Usual groups heard on this frequency and DCS code - appears to be a primary job site (construction site) channel 462.7125 159.8 Hz FRS 07 Usual downtown building maintenance or security users heard on this frequency and CTCSS tone - note use of non-standard tone 469.5500 114.8 Hz Crane coordination - also informal CB-like chatter at times 158.4075 065 DCS FLIGHTCOM dispatch and radio comms with medevac aircraft 467.8750 229.1 Hz Gold Star Crane coordination 462.6750 606 DCS FRS 20 Retail use 464.3250 546 DCS Event management 466.0875 97.4 Hz Construction or crane control - weak signals 467.9250 67.0 Hz Blue Star Security or building management 462.5500 123.0 Hz FRS 15 "Poor copy - heard ""Jean"" ""tomorrow"" and ""flip"" " 154.5700 371 DCS MURS 4 Road repair crew or contractor 461.2625 67.0 Hz Hotel or hospitality - room maintenance or engineering 151.6250 167.9 Hz Red Dot Crane Master (confirmed user) truck to truck chatter and informal comms...talking about impending thunderstorms 462.5875 118.8 Hz FRS 02 Auto repair shop or somilarV 467.9250 100.0 Hz Blue Star """wrap up"" - talking about a delivery truck, possibly Kroger (retail) based on frequency and CTCSS tone " 467.8500 67.0 Hz Silver Star """I want to see if we can manually check in a guest...last name is Nelson"" " 158.4000 167.9 Hz Truck to truck comms - presumed CRANE MASTER based on type of traffic heard and CTCSS tone 467.6875 CSQ FRS 13 Local school - FRS portables (no tone or code in use) 464.5500 67.0 Hz Yellow Dot """Customer service call on channel 1"" " 464.5000 100.0 Hz Brown Dot """we'll do a little turn"" ""okay right...turn right here"" ""Barry"" and another OM" 462.6375 151.4 Hz FRS 04 Sounds like car to car comms - possibly a group going up or down 95 or 64 467.7125 116 DCS FRS 14 Weak signal, was able to decode DCS code in use (portables) 152.3000 023 DCS Yellow Cab - dispatcher (half duplex system, taxi mobile radios transmit on 157.5600 MHz so other drivers can only hear dispatcher and not other mobiles) - VERY high power transmitter with high-elevation antenna 467.6375 051 DCS FRS 11 Construction traffic control or similar 462.6250 127.3 Hz FRS 18 Weak signal - sounds like a school 151.7600 67.0 Hz Traffic control or flag men - portables, fair signal 152.9075 074 DCS Richmond Public Schools - confirmed user (repeater) 152.9000 205 DCS Maggie Walker Governor's School - confirmed user (repeater) 467.5875 032 DCS FRS 09 School or day care? portable radios 464.5000 77.0 Hz Brown Dot "Security or facilities management - heard a reference to ""unit 3"" " 5/4/2021 158.4075 065 DCS FLIGHTCOM dispatch doing morning radio checks, etc. loud and clear 462.6125 74.4 Hz FRS 03 "Weak - ""I can see you but..."" [faded out] heard around 8:50AM - heard additional transmissions, sound like kids on FRS handhelds " 154.5700 043 DCS MURS 4 Crane control - variable signal strengths 151.5125 136.5 Hz Crane control - usual user of this frequency and code combination 467.6625 67.0 Hz FRS 12 Elevator floor pickup requests - usual traffic for this frequency and tone 466.3125 156.7 Hz Crane control/construction 467.7875 506 DCS "Construction - appears to be secondary or ""talkaround""" 467.5875 CSQ FRS 09 Several guys talking about trucks coming, mud (??) - fair to poor copy, no CTCSS or DCS noted 469.5500 712 DCS Crane control 467.8750 229.1 Hz Gold Star Crane coordination 457.5250 315 DCS Local school, portables (usual user of this frequency and DCS code) 462.7250 67.0 Hz FRS 22 """Sean"" and another first name heard, usual FRS Roger Beeps...plus call tones, possibly mixing with another user on same channel / frequency " 154.4900 67.0 Hz Contractor or highway repair - vehicle to vehicle comms 462.7125 79.7 Hz FRS 07 English and Spanish - sounds like construction site or similar chatter, good signals 462.6625 023 DCS FRS 05 """don't forget to grab a couple waters out of the cooler"" ""Hospital"" - presumably same group heard using this DCS code on this and other FRS channels " 466.0875 97.4 Hz Construction or crane control - weak signals 462.5625 67.0 Hz FRS 01 Coordinating tent or other temporary setup - discussion of stakes, adjusting the line, etc. 464.8250 026 DCS Crane control - usual user of this frequency and code combination 469.5500 165 DCS """I didn't want to have to listen to that alarm go off for the rest of the day"" - active frequency with numerous groups / users " 462.7125 159.8 Hz FRS 07 Usual group using this tone on this channel - active with elevator floor or pick up requests and other facilities maintenance traffic 464.5500 627 DCS Yellow Dot Construction - appears to be primary or command channel 154.5275 136.5 Hz Crane control, same users with this CTCSS tone, or at least same company 462.6750 136.5 Hz FRS 20 School, sporadic interference from the retail user on same frequency 464.5500 346 DCS Yellow Dot """man, I don't know where Scotty ran off to..."" - fair to poor copy, weaker than the other group active on this frequency this morning " 464.5000 88.5 Hz Brown Dot Talking about fire alarms or smoke detectors / heat detectors 469.5500 114.8 Hz Crane control / coordination...mixing with other signals at point 462.6125 210.7 Hz FRS 03 """next two cars are good to go"" - possibly flag men or traffic control " 462.5875 97.4 Hz FRS 02 Crane control - sporadic activity - Spanish/English 461.1875 67.0 Hz """check the..."" ""thank you Manny"" " 462.6500 CSQ FRS 19 """right, security is gonna come take a look at the camera in a second"" " 469.5125 82.5 Hz """Bruto!"" - Spanish language chatter " 462.5750 165.5 Hz FRS 16 """Guys I need the elevator back to 1...I got a couple roofers that need to make it back up to 14"" - strong signal at 1:39PM" 462.6625 136.5 Hz FRS 05 """is that the one with the cone on it?"" ""I dunno"" " 158.4000 67.0 Hz Road repair or maintenance contractor - portable radios 462.6000 455 DCS FRS 17 Sounds like kids playing with walkie talkies - confirmed DCS code in use 466.0875 506 DCS Construction or crane control - very good signals at points 467.8500 67.0 Hz Silver Star Security or similar 462.5625 97.4 Hz FRS 01 Spanish language, weak signals 462.6750 606 DCS FRS 20 Retail user - previously monitored using this frequency and DCS code 461.0625 67.0 Hz """do you have me on channel 5?"" ""10-4""" 467.5625 243 DCS FRS 08 Spanish language, presumed construction site or job site comms 464.5000 023 DCS Brown Dot UNID user - sounded like car to car comms - only caught a few seconds of chatter before signals faded out 469.5000 165 DCS """is it going to rain this time too?"" ""better get some more gas"" " 462.9125 192.8 Hz Crane coordination - can hear other radio chatter in background at points 467.6875 CSQ FRS 13 Local school - strong signals...as usual, no CTCSS tone or DCS code in use 466.2625 023 DCS "Linda - radio checks ""just want to make sure you're on 2"" " 467.5625 026 DCS FRS 08 Catering service or events management? weak signal 5/5/2021 462.8125 627 DCS Crane control and construction - appears to be alternate channel 462.5625 77.0 Hz FRS 01 "Spanish language, unique style ""Roger Beep"" " 469.5000 165 DCS Construction - fair to poor signals 469.5500 114.8 Hz Crane coordination and general informal chatter - mostly English language with some Spanish and Spanglish 462.6250 127.3 Hz FRS 18 Catering service or room service coordination 464.5500 627 DCS Yellow Dot Crane control and construction - appears to be primary 469.5500 165 DCS Construction, fair signal..busy at times but also suffering interference due to other users on frequency 467.6625 67.0 Hz FRS 12 Elevator floor requests 466.0875 97.4 Hz Construction or facilities management 464.5500 67.0 Hz Yellow Dot """what was going on there?"" ""450"" " 464.3250 546 DCS RMC Events - events management 469.5500 343 DCS Elevator floor requests 462.6625 79.7 Hz FRS 05 FRS call tones heard 457.5250 315 DCS Local school - portable radios, strong to good signal strength 462.7125 159.8 Hz FRS 07 Building maintenance and facilities management - downtown - usual user of this frequency and tone combination..heard basically daily 151.5125 136.5 Hz Crane control - usual users 462.6500 632 DCS FRS 19 Radio checks 466.3125 156.7 Hz Construction and crane control 462.6625 023 DCS FRS 05 """wait for..."" ""to come through"" " 462.5875 67.0 Hz FRS 02 Coordinating takedown of tents or tables/chairs 462.9125 192.8 Hz Crane coordination channel - including some informal chatter 466.2625 023 DCS """that group is with Tracey, right"" ""yes ma'am"" ""go ahead"" ""walk up towards the big parking lot"" " 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 4 467.6875 CSQ FRS 13 Local school - strong signals...as usual, no CTCSS tone or DCS code in use 5/6/2021 469.5500 165 DCS """Go-man's on 64"" - other similar traffic " 462.7875 023 DCS """go next"" ""one guy is almost done with the first row and halfway done with the second"" - weak signal, heavy fading " 464.5000 432 DCS Brown Dot Weak signal, unable to ID 151.5125 136.5 Hz Crane control - usual users 464.5500 627 DCS Yellow Dot Crane control and construction - appears to be primary 464.8250 026 DCS Crane control - usual users of this frequency and tone with sporadic interference from high-powered repeater on same frequency 457.5250 315 DCS Local school 158.4075 065 DCS FLIGHTCOM dispatch 467.6625 67.0 Hz FRS 12 Elevator floor requests - the usual traffic heard on this frequency and tone 466.3125 156.7 Hz Construction and similar chatter - same users heard basically daily 466.2625 023 DCS Events management, possibly RMC Events 462.7125 159.8 Hz FRS 07 Building maintenance and facilities management - downtown - usual user of this frequency and tone combination..heard basically daily 469.5500 732 DCS """I need a ride from Massey first floor...up to 6"" - heard names ""Travis"" and ""Lindsey"" or similar " 461.1875 67.0 Hz """contact"" ""check"" - poor signal " 151.6250 167.9 Hz Red Dot Crane Master truck to truck and primary operations channel - loud and clear signals 466.0875 97.4 Hz """back up on..."" weak signals " 467.8750 229.1 Hz Gold Star Crane coordination 467.8375 432 DCS """yeah....it says...4 9 9 4....again that's forty-nine ninety four...4994, copy?"" " 154.5700 043 DCS MURS 4 Crane control - portable radios 462.6625 023 DCS FRS 05 Building maintenance, facilities management or similar - heard one station referred to as BIG DOG - FRS-style Roger Beeps noted in use 469.5500 114.8 Hz Crane coordination 154.4900 67.0 Hz Road repair or maintenance contractor - portable radios 151.6250 065 DCS Red Dot FLIGHTCOM medevac dispatch 464.3250 546 DCS RMC Events - events management 462.6750 606 DCS FRS 20 Retail user 469.5500 506 DCS """car"" ""level"" ""basket"" - very poor copy " 158.4000 67.0 Hz Road repair or maintenance contractor - portable radios 461.3625 023 DCS Events management, possibly RMC Events 462.9125 192.8 Hz Crane coordination 467.6875 CSQ FRS 13 Local school - strong signals...as usual, no CTCSS tone or DCS code in use 461.3125 023 DCS Events management, possibly RMC Events 462.5500 123.0 Hz FRS 15 Somebody keyed a mic for a few seconds - very strong signal...no audio - heard around 8:33PM 5/7/2021 466.0875 97.4 Hz Facilities management or similar 469.5500 114.8 Hz "Crane coordination and informal chatter - ""I already have 5 radios up here man I don't want another one"" - talking about installing a CB radio and listening to the various other companies (heard reference to Miller and Long) talk shit to each other on the CB. also mentioned how a CB was required for a previous job site " 151.6250 167.9 Hz Red Dot Crane Master - confirmed 466.3125 156.7 Hz Construction and similar - very active at points 467.8750 229.1 Hz Gold Star Crane coordination net 158.4075 065 DCS FLIGHTCOM dispatcher 469.5500 732 DCS "Elevator floor requests - ""pickup on 4 please""" 469.5500 165 DCS Crane control and coordination 464.5500 627 DCS Yellow Dot "Construction - primary coordination channel, heard ""Justin"" and other stations " 464.5000 88.5 Hz Brown Dot """303"" - other measurements (??) " 464.8250 026 DCS Crane control 467.6625 67.0 Hz FRS 12 "Elevator floor requests - usual group/users with FRS ""Roger Beeps"" on most, but not all transmissions " 469.5000 205 DCS """don't forget me on level 4"" - sounds like elevator floor requests or service elevator pick up requests - later, heard ""do they want us to get all the Port-o-Johns out the building now?"" ""yes that's right"" " 462.5625 77.0 Hz FRS 01 Spanish language - appears to be the same guys previously heard using this tone but impossible to be 100% sure 461.1875 225 DCS """I want to start on the end of West Franklin Street and work my way up..."" ""check it on that point...hold me on that point and see if I can see you from there"" ""alright we're gonna have to cut that tree"" - possibly survey crew " 469.5000 732 DCS UNID user, weak signal 457.5250 315 DCS Local school 462.9125 192.8 Hz Crane coordination 464.5500 165 DCS Yellow Dot Construction chatter, sporadic signal 462.5750 165.5 Hz FRS 16 """ask him how many TVs he has! [laughter]"" - non-standard CTCSS tone noted in use " 466.2625 023 DCS Event management company - portable radios 469.5500 506 DCS """that might be a problem"" - talking about weather forecast " 462.5625 67.0 Hz FRS 01 "Talking about ""breaking it down"" - presumed similar traffic re: taking temporary tents, tables, etc. down " 5/8/2021 466.2625 023 DCS Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game 151.5125 136.5 Hz Crane control - usual users of this frequency and CTCSS tone 466.3125 156.7 Hz Construction and similar - very active at points 464.5500 627 DCS Yellow Dot Construction - appears to be primary 466.3625 023 DCS Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game 158.4075 065 DCS FLIGHTCOM dispatching medevac aircraft 461.3125 023 DCS Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game 462.6125 225.7 Hz FRS 03 Talking about parking 461.2625 023 DCS Events management - probably RMC Events - simplex / portable radios at Richmond Flying Squirrels game 469.5500 114.8 Hz Crane coordination and informal CB-like chatter 462.6375 CSQ FRS 04 """how close is he?"" ""he's hot"" ""okay keep your eye on the next guy"" ""10-4"" - could be radio operations training or surveillance or??? - FRS ""Roger Beeps"" noted " 5/9/2021 469.5000 732 DCS Construction - fair signal 462.5500 123.0 Hz FRS 15 """copy"" and ""10-4"" heard - short transmissions, strong signals" 158.4075 065 DCS FLIGHTCOM dispatch - loud and clear as usual 461.1875 67.0 Hz Hotel or hospitality comms - also some friendly banter and informal chatter 464.8250 026 DCS Crane control - usual users of this frequency and DCS code - simplex 464.5500 627 DCS Yellow Dot Construction and crane control 466.2625 023 DCS Talking about setting up cones and other similar chatter - presumably event management? 5/10/2021 462.8625 88.5 Hz Crane control and construction - strong signals loud and clear 469.5500 506 DCS Construction and similar comms - Spanish and English 462.6250 127.3 Hz FRS 18 """move 2 feet to the right...I mean your left...your left!"" - fair to poor signal " 467.5875 CSQ FRS 09 """radio check"" ""hello radio check?"" - FRS style Roger Beeps heard, strong signal - ""we got plenty of length in the cargo line"" ""Roger that"" " 158.4075 065 DCS FLIGHTCOM working several medevac helicopters - strong signal as usual 467.6625 67.0 Hz FRS 12 Elevator floor pick up requests 469.5500 165 DCS Construction - similar to previously heard signals using this DCS code 462.5625 67.0 Hz FRS 01 Crane control - very active after 10:30 or 11:00 in the morning - fair to good signals with FRS Roger Beeps 457.5250 743 DCS """group 2"" - weak signals, NOT the local users of this frequency " 469.5500 073 DCS Security or building management? portables - simplex 464.8250 026 DCS Crane control 151.6250 065 DCS Red Dot AIRCARE EAGLE working FLIGHTCOM at 1:05pm - both the aircraft and the base station were loud and clear with strong signals 462.5500 71.9 Hz FRS 15 Traffic control or flag men - fair signals, some interference 457.5250 315 DCS Local school - good to strong signals, much stronger than other users heard on same frequency earlier 461.1875 67.0 Hz Building management or maybe hotel/hospitality maintenance 464.5375 85.4 Hz Hotel or hospitality - engineering? 462.7125 159.8 Hz FRS 07 Same building maintenance or facilities management traffic heard on this frequency and CTCSS tone combination almost daily 151.5125 136.5 Hz Crane control - usual users of this frequency and CTCSS tone 467.7875 110.9 Hz Spanish language, heard construction noises in background 467.8750 229.1 Hz Gold Star Crane coordination - other similar comms 462.7250 136.5 Hz FRS 22 Weak signal - hearing what sounds like Spanish 469.5500 114.8 Hz Crane coordination (multiple cranes) - can often hear other radios in the background 462.5500 123.0 Hz FRS 15 Heard two people talking, one male and one female...unknown use at this time due to poor signal strength 469.5500 205 DCS """I don't even know if he's taking the machine"" - other similar chatter - as usual, this frequency is very busy " 466.3125 156.7 Hz Construction coordination and control 462.5750 023 DCS FRS 16 """4th grade lunch"" ""okay"" " 469.5000 165 DCS Construction - possibly alternate frequency 462.4250 103.5 Hz School or day care operations - not as local as other similar transmissions heard on other frequencies - including the Baofeng and Retevis default factory freqs 466.0875 506 DCS Crane control 462.7250 67.0 Hz FRS 22 """can you hear me?!"" ""I'm not back there!"" - possibly kids playing with walkie talkies - FRS Roger Beeps noted in use" 469.5000 205 DCS """level 10"" ""okay 10-4"" - some interference due to other groups on frequency at the same time...sounds like high-rise construction comms, service elevator pickup requests, etc. " 154.5700 151.4 Hz MURS 4 Construction and crane control; portable radios 464.5000 67.0 Hz Brown Dot Talking about Port-a-Johns 467.6875 CSQ FRS 13 Local school - usually most active in mornings and early to mid afternoon 462.9125 192.8 Hz Crane control/crane coordination (active most in the late afternoon 467.5625 306 DCS FRS 08 """the next exit"" ""yeah I have you good"" ""yeah yeah 10-4"" - likely vehicle to vehicle comms on the interstate " 462.5250 114.8 Hz School or day care - [child's name] mom is here to pick them up, etc. 464.5500 627 DCS Yellow Dot Construction - primary channel... 462.5875 118.8 Hz FRS 02 """Waiting area"" ""okay another 15 minutes"" " 466.1375 103.5 Hz Building management or maintenance - portable radios 462.6125 127.3 Hz FRS 03 Local school - very good signals 466.0875 97.4 Hz Construction or similar - poor signal 464.5500 94.8 Hz Yellow Dot Parking garage attendants or security - fair to poor signals 5/11/2021 466.3125 156.7 Hz Construction - Spanish language heard with some English - very busy at points 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 2 and LIFE EVAC 4 464.5500 627 DCS Yellow Dot Construction - primary channel... 462.5625 043 DCS FRS 01 """Ms. Jones' group is now in room..."" " 151.6250 167.9 Hz Red Dot Crane Master truck to truck comms - very good to good signals 464.8250 026 DCS Crane control 154.5700 67.0 Hz MURS 4 Spanish language, fair signal with some interference from data bursts (telemetry) on frequency 462.8625 88.5 Hz Crane control and coordination 461.1125 67.0 Hz Hotel operations - portable radios 462.6125 114.8 Hz FRS 03 Catering service or room service - probably hotel related? portable radios 467.6625 67.0 Hz FRS 12 Elevator floor pickup requests - the usual traffic heard on this frequency and CTCSS tone combination - with FRS Roger Beeps 469.5500 165 DCS """elevator pick up on 16"" ""pull those two pieces of steel out like that...that makes me a little nervous...."" " 462.7250 223 DCS FRS 22 Crane control or similar traffic - talking about lines and baskets 462.8875 88.5 Hz Crane control and general informal chatter, possibly alternate frequency or talkaround channel 467.6625 053 DCS FRS 12 School - fair signal - portable radios without Roger Beeps or end of transmission beeps or data bursts 469.5000 205 DCS Crane control - good signal strength 464.5000 023 DCS Brown Dot Talking about supply delivery times, casual and informal chatter, heavy fading 467.6125 047 DCS FRS 10 """got power to the roof"" ""bucket"" " 151.5125 136.5 Hz Crane control - sometimes very busy 464.5500 165 DCS Yellow Dot """realize you can't do it"" - sometimes suffering severe interference due to other groups / users on this frequency " 462.5875 97.4 Hz FRS 02 Spanish language 154.5700 043 DCS MURS 4 Crane control, portable radios 466.0875 506 DCS Weak signals - presumed construction based on previous logs and the DCS code used 462.5750 654 DCS FRS 16 Construction site or work crew 464.5000 179.9 Hz Brown Dot "One side of a conversation...one station is extremely strong, heard ""comeback, I didn't copy that last part"" " 466.1875 506 DCS Construction / crane control 462.6750 606 DCS FRS 20 Retail user - portable radios 154.4900 67.0 Hz Highway maintenance or repair crew 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency and channel (downtown) 466.0875 97.4 Hz Weak construction or similar traffic 469.5500 743 DCS Construction 151.6250 065 DCS Red Dot AIRCARE EAGLE working FLIGHTCOM - both the aircraft and the base station (dispatcher) coming in loud and clear 462.6000 455 DCS FRS 17 Road construction or highway sign installation crew 467.8750 229.1 Hz Gold Star Crane control 464.5500 179.9 Hz Yellow Dot """close up the machine room...I'll go ahead and put the card on the elevator and we'll head down"" " 457.5250 315 DCS Local school - heard teachers talking to each other as well as maintenance staff and facilities management staff using same frequency and DCS code 151.6250 67.0 Hz Red Dot """right there"" ""okay leave it there don't fuck with it""" 462.6875 141.3 Hz FRS 06 Steel girder lengths being read, good to fair signals 462.6250 67.0 Hz FRS 18 """back room"" ""second shelf"" - portables, no Roger Beeps heard " 462.7875 021 DCS Film or TV crew 462.7000 192.8 Hz FRS 21 "Heard mention of ""my DeWalt level"" " 466.2125 97.4 Hz """do you want me to connect the tag line cable to the block and then connect the cable to that?""" 151.5050 145 DCS Crane control or maybe concrete pouring...general construction comms 462.5625 250.3 Hz FRS 01 Crane control or similar 464.5500 156.7 Hz Yellow Dot """base"" ""unit 4"" and other callsigns heard - very good signals....more than likely security company" 467.8500 054 DCS Silver Star """when you bring that to Vanessa up front"" ""meet me in my office"" ""okay, copy"" " 462.6125 100.0 Hz FRS 03 Unmodulated carrier (dead air) for 2-3 seconds...then a FRS call tone / alert tone 151.5125 67.0 Hz """one foot to your right"" ""158.5"" ""138.2"" ""148.2"" - several other values heard, portables...poor to fair signals " 467.9000 118.8 Hz Red Star """303, thank you"" " 154.5700 371 DCS MURS 4 Spanish language, variable signal strength 464.5500 732 DCS Yellow Dot Construction, sporadic signals 461.1125 205 DCS Crane control, fair to weak signals 467.8500 179.9 Hz Silver Star Hotel or hospitality - portable radios 151.6250 145 DCS Red Dot """lower...lower....stay low...stay low....""" 462.6125 127.3 Hz FRS 03 "Local school - heard mention of ""1st graders"" - good signal " 462.5750 143 DCS FRS 16 FRS call tones heard...no voice traffic copied 464.5500 754 DCS Yellow Dot Talking about hand sanitizer 151.8200 103.5 Hz MURS 1 """two Maseratis, man!"" ""3"" ""no, 5!"" " 467.6875 CSQ FRS 13 Local school 466.0625 82.5 Hz Facilities maintenance or engineering 151.9550 67.0 Hz Purple Dot "Caught tail-end of a transmission - strong signal...mention of ""3 feet"" - likely tower crane control or similar type comms " 467.6625 100.0 Hz FRS 12 Road repair crew, flag men or traffic direction 467.8500 627 DCS Silver Star Spanish language 154.5700 145 DCS MURS 4 Crane control, possibly alternate frequency - poor to fair signals...portable radios 469.5500 114.8 Hz Crane coordination and informal chatter 462.5875 71.9 Hz FRS 02 Parking lot attendants or traffic control 467.9125 021 DCS Coordinating lighting - possibly film crew 464.4875 143 DCS Spanish language, poor signals 462.5625 67.0 Hz FRS 01 Spanish language chatter 464.5375 85.4 Hz Hotel or hospitality - customer service and room cleaning/repair crew and engineering 462.8375 021 DCS TV or film crew 462.5875 118.8 Hz FRS 02 School or day care - sporadic signals 469.5000 506 DCS Construction 462.6750 136.5 Hz FRS 20 School - not as local as the other logs...confirmed this is the correct tone 467.7625 627 DCS """J"" Dot" Construction-related comms, mostly Spanish language with some English 462.5875 023 DCS FRS 02 IT or RF engineering or installation team 464.5000 103.5 Hz Security or building maintenance / facilities management 462.6875 85.4 Hz FRS 06 Possible counter-surveillance - reading off license plates and vehicle descriptions...noted use of military phonetic alphabet - NATO phonetic alphabet 461.0625 047 DCS Construction or similar traffic 154.6000 371 DCS MURS 5 "Spanish language chatter - appears to be a secondary channel or ""talkaround""" 462.5500 123.0 Hz FRS 15 Local or semi-local school 462.8125 627 DCS Construction chatter - informal CB-like conversation - likely a secondary or general chat channel 462.6250 127.3 Hz FRS 18 Spanish language, poor signal 462.9125 192.8 Hz Crane coordination and informal chatter 462.7875 754 DCS """delivery zone 3"" ""that should be ready after 4:30"" " 462.7250 67.0 Hz FRS 22 UNID signal, tail end of transmission with FRS Roger Beep heard...strong signal but nothing else heard on frequency (or CTCSS tone) 464.5625 85.4 Hz Hotel or hospitality - customer service and room cleaning/repair crew and engineering 456.8125 023 DCS Concrete construction contractor - portable radios 466.3375 110.9 Hz Talking about steel beams - likely construction materials delivery 467.6375 051 DCS FRS 11 Local school - possibly secondary channel 467.8375 021 DCS TV or film crew 462.7125 79.7 Hz FRS 07 "Spanish language chatter - noted two different types of ""Roger Beeps"" as well as at least one transmitter without a Roger Beep at all" 462.7875 732 DCS Construction or maybe facilities management 467.9250 100.0 Hz Blue Star """loading dock"" ""truck bay 2"" " 451.8125 023 DCS Concrete construction contractor - portable radios 462.5625 97.4 Hz FRS 01 """okay 10 is clear, need to check the equipment room gallery for power"" " 466.3625 023 DCS Caught tail end of transmission, possibly RMC events based on frequency and DCS code used 5/12/2021 469.5000 205 DCS Elevator floor pickup requests, supply delivery requests for fright or service elevator - heard mention of level 17, level 12 464.5500 88.5 Hz Yellow Dot """bring it up"" ""copy that thank you"" " 462.5250 114.8 Hz "Local school or day care - talking about students ""coming upstairs"", going to rooms, etc. portables/simplex " 464.5500 627 DCS Yellow Dot Construction - primary work site channel - very active at points 467.5875 91.5 Hz FRS 09 """in the house?""" 461.0625 67.0 Hz """okay I'll give you a call on 105 in a minute"" " 469.5500 165 DCS Construction or similar, including some informal chatter 469.5000 732 DCS Elevator pickup or delivery requests 462.5750 165.5 Hz FRS 16 "Weak, heard ""okay"" ""16"" and a couple other short transmissions " 151.5125 136.5 Hz Crane control 464.5500 67.0 Hz Yellow Dot talking about delivery times...heavy interference from other signals on freq 464.8250 026 DCS Crane control - simplex (portable radios) 462.6125 74.4 Hz FRS 03 Spanish language, weak signals poor copy 457.5250 315 DCS Local school 462.7125 77.0 Hz FRS 07 """you got me?"" ""okay...let's go..let's go...12"" ""copy that, I'll let you know"" " 464.5000 103.5 Hz Brown Dot Security or facilities management 461.1875 67.0 Hz Hotel or hospitality - sporadic activity 466.3125 156.7 Hz Construction - Spanish language heard with some English - very busy at points 151.6250 065 DCS Red Dot FLIGHTCOM working AIRCARE EAGLE 467.6625 67.0 Hz FRS 12 Elevator floor requests 151.5050 145 DCS Construction or crane control 469.5500 506 DCS Construction or crane control 462.6000 455 DCS FRS 17 """anything?"" ""nothing yet"" ""ugh okay"" " 154.5275 065 DCS "LIFE EVAC 4 calling FLIGHTCOM dispatch ""we're about 4 minutes out from landing"" " 462.5875 118.8 Hz FRS 02 """Miss Sam, come in..."" - probably a local school " 464.5000 67.0 Hz Brown Dot """14 is clear..."" ""okay 18...18..."" ""basement...west corridor"" " 462.9125 192.8 Hz Crane control 154.5700 77.0 Hz MURS 4 """that area is already done"" ""okay copy"" " 467.5625 67.0 Hz FRS 08 Sounds like kids playing with walkie talkies 467.8500 67.0 Hz Silver Star """...customer..."" ""okay sounds good""" 469.5500 732 DCS """level 12, going down"" ""pickup on 6, pickup on 6 please"" - elevator floor requests " 462.6125 210.7 Hz FRS 03 FRS call tones (alert tones) heard 151.6250 67.0 Hz Red Dot """no, that's the shit that you do"" " 462.7125 159.8 Hz FRS 07 Same users usually heard on this frequency and CTCSS combination 467.8750 229.1 Hz Gold Star Crane coordination and crane control 462.7250 136.5 Hz FRS 22 """section 2"" ""tables"" ""appointment for 1:45"" " 158.4075 065 DCS "LIFE EVAC 3 and FLIGHTCOM - FLIGHTCOM advising LIFE EVAC 3 that they are still on ""HANOVER FREQUENCY"" and they need to switch to the STATEWIDE EMS channel " 462.5625 261 DCS FRS 01 "Spanish language, heard construction sounds in the background....no ""Roger Beeps"" " 466.0875 506 DCS Construction or crane control 462.6750 606 DCS FRS 20 Retail users, fair to good signals with some very poor signals (obviously portable radios inside a building given the variations in signal strength) 462.7125 146.2 Hz FRS 07 School or day care facility 466.0875 97.4 Hz Construction or crane control 151.8200 103.5 Hz MURS 1 """did you get that level?"" ""we might have to move that dumpster on Roseneath"" - construction/contractor (portable radios)" 464.5500 506 DCS Brown Dot Crane control or job site command channel 462.7625 023 DCS Construction - Spanish and English heard 467.6625 053 DCS FRS 12 Local school - fair to good signal strength 461.2625 67.0 Hz Hotel/hospitality (portable radios) 154.5700 043 DCS MURS 4 Crane control 462.8625 88.5 Hz Construction and crane control - mixture of English and Spanish 467.5625 77.0 Hz FRS 08 Local school 154.4900 67.0 Hz Construction - highway maintenance or similar crew - portable radios 462.6625 136.5 Hz FRS 05 Weak signal, no FRS call tones noted 462.6125 127.3 Hz FRS 03 Local school - appears to be primary frequency at this time 469.5500 114.8 Hz Crane coordination and informal chatter 464.5000 732 DCS Brown Dot Crane control or construction 467.7125 116 DCS FRS 14 Spanish language 466.1125 79.7 Hz Construction 154.5700 371 DCS MURS 4 Crane control - portable radios 462.8125 627 DCS Construction or job site coordination (secondary or backup channel) 462.6375 131.8 Hz FRS 04 Local school - appears to have switched to this channel 5/13/2021 469.5500 205 DCS Construction crew coordination - good to fair signals 469.5000 506 DCS Crane control, sporadic signals 467.6625 67.0 Hz FRS 12 "Elevator floor pickup requests - ""12 going down"" ""5 going up"", etc. " 469.5500 732 DCS Elevator floor pickup requests - also building materials delivery requests/orders for different floors/levels 151.5125 136.5 Hz Crane control - usual users of this frequency and tone 462.6375 97.4 Hz FRS 04 """stop for gas?"" ""okay 10-4"" " 450.2250 023 DCS discussion about classes going outside for recess, etc. probably daycare or local school 469.5500 165 DCS """grouting"" ""I don't care if it's going that way or not!"" - interfering with other signals on same frequency " 154.5700 88.5 Hz MURS 4 Talking about signs and closing lanes 462.7125 97.4 Hz FRS 07 Weak chatter heard, possibly construction site comms 464.8250 026 DCS Crane control - simplex (portable radios) 462.5750 203.5 Hz FRS 16 Weak signal...sounded like car to car chatter or similar 464.5500 627 DCS Yellow Dot Construction - primary work site channel - very active at points 469.5000 205 DCS Troy and Willie talking about hand wash stations and port-o-johns....probably a sanitary job site service company? 467.5875 CSQ FRS 09 """I can't hear anything but a jackhammer - say that again"" ""okay I got you now...give me a call when you're ready"" " 154.5700 371 DCS MURS 4 Crane control - good to strong signals 467.6125 67.0 Hz FRS 10 """Dad we'll call you when we're coming back in"" ""okay sounds good""" 462.5250 114.8 Hz Local day care or school - strong signals from portable radios 151.9550 179.9 Hz Purple Dot Building or facilities management - portable radios 467.8500 627 DCS Silver Star Construction crew - work site control channel, with some informal chatter 467.6625 053 DCS FRS 12 School - good signals, usually stronger than the downtown (presumed) construction users on this same channel 151.6250 167.9 Hz Red Dot Crane Master truck to truck comms - also on-site (portable radios) 467.5625 67.0 Hz FRS 08 FRS call tones heard 158.4075 065 DCS FLIGHTCOM dispatching Medevac helicopters 462.6875 67.0 Hz FRS 06 Two kids playing with walkie talkies - no CTCSS or DCS tones or codes in use 464.5000 77.0 Hz Brown Dot Sounds like a survey crew 151.5125 67.0 Hz Construction - probably portable radios 457.5250 315 DCS Local school 462.7125 159.8 Hz FRS 07 Downtown building maintenance or facilities management - usual users of this frequency channel and CTCSS tone 466.0875 506 DCS Crane control and construction comms 464.5000 165 DCS Brown Dot Construction comms 467.7625 627 DCS """J"" Dot" Construction-related comms, mostly Spanish language with some English 462.5875 118.8 Hz FRS 02 Local school - appears to be secondary or backup channel 462.8875 88.5 Hz Crane control, mostly Spanish language 464.5375 85.4 Hz Hotel/hospitality front desk dispatcher and room cleaning operations 464.5000 179.9 Hz Brown Dot Room service or repair requests 467.8125 047 DCS """K"" Dot" """tanks 2 and 3 are both empty"" ""copy that"" " 467.8750 229.1 Hz Gold Star Crane coordination and crane control 462.5500 71.9 Hz FRS 15 """take a look around and get back to me"" " 467.8875 205 DCS """I'm on 11 now, coming down"" " 462.6750 606 DCS FRS 20 Retail operations - including loading dock coordination, customer service etc. 151.8200 103.5 Hz MURS 1 Construction site coordination - concrete or general building contractor 462.5875 67.0 Hz FRS 02 Very weak signals, late morning...unable to ID 464.5500 67.0 Hz Yellow Dot Construction equipment delivery or repair coordination 466.0875 97.4 Hz Construction and related comms 462.6750 136.5 Hz FRS 20 School - confirmed this is a separate group from the retail store using the same frequency 462.8625 88.5 Hz Crane control and coordination - mix of Spanish and English traffic 462.8250 162.2 Hz """she wants ham and cheese for lunch"" ""okay got it"" " 462.6125 CSQ FRS 03 """do you hear me on this channel?"" ""how about now?"" ""okay good - take that next one away"" " 464.5500 79.7 Hz Yellow Dot """alright I dropped off the 100A and 100B trolley"" ""okay 10-4"" " 462.6250 127.3 Hz FRS 18 "Heard mention of ""order number"" " 467.9250 67.0 Hz Blue Star Security or facilities management (portable radios) 462.6875 141.3 Hz FRS 06 Local school - appears to be secondary or backup channel 154.4900 67.0 Hz Road repair or maintenance crew - portable radios 469.5000 732 DCS """let me call you back in a moment"" " 467.6375 67.0 Hz FRS 11 """bring that up to 13....drop off on 13...."" " 467.8750 165 DCS Gold Star Construction site equipment and supply delivery coordination 462.5625 77.0 Hz FRS 01 Spanish language, poor signals 151.6250 67.0 Hz Red Dot """good radio check...I'm gonna try my handset, hang on"" - sounded like portable radios...possibly road repair or highway sign installation company - previously monitored using common default factory VHF radio channels - see Motorola RDV5100 and similar radios " 467.7625 506 DCS """J"" Dot" Informal chatter, likely construction site or work site comms 462.6625 116 DCS FRS 05 Sporadic signal - heard vehicle descriptions being read over the air - probably flaggers / flag men or similar 466.3125 156.7 Hz Construction - Spanish language heard with some English - very busy at points 464.5000 732 DCS Brown Dot Construction site comms - fair signals 462.5875 97.4 Hz FRS 02 "Crane control and general construction comms - fair signal with FRS ""Roger Beeps"" " 462.6375 77.0 Hz FRS 04 """bring that back in"" ""okay but the only way to..."" [faded out]" 461.2625 141.3 Hz Coordinating safety inspection of some kind - good signals 467.8125 131.8 Hz """K"" Dot" Materials delivery times chatter 462.6875 85.4 Hz FRS 6 "Reading vehicle descriptions and license plate numbers - fair to poor signal...FRS ""Roger Beeps"" noted " 462.9125 192.8 Hz Crane coordination 461.3125 023 DCS Event management - probably RMC Events 151.8200 67.0 Hz MURS 1 Catering or hospitality - talk about orders being taken on the elevator, etc...fair to poor signals 462.6500 632 DCS FRS 19 """second one"" ""thank you"" ""okay, Roger that."" - good signals around 2:30-2:45PM with FRS ""Roger Beeps"" " 467.6875 065 DCS FRS 13 Heard background noise, sounded like a school playground 467.8625 072 DCS "Talking about materials lots, setting up ""lines""" 469.5500 114.8 Hz Crane coordination with informal chatter 462.7000 67.0 Hz FRS 21 Weak signal - possibly vehicle to vehicle comms on the interstate 466.3625 023 DCS Event management - probably RMC Events 462.6375 131.8 Hz FRS 04 Local school - primary operations 461.2625 023 DCS Event management - probably RMC Events 462.5500 123.0 Hz FRS 15 """on 2! on 2!"" ""come on, on 2!"" ""okay copy that on 2"" " 5/14/2021 469.5000 712 DCS Coordinating materials distribution or delivery 464.8250 026 DCS Crane control 467.6625 67.0 Hz FRS 12 "Elevator floor pickup requests - usual traffic heard on this frequency and CTCSS tone (with FRS ""Roger Beeps"") " 154.5275 065 DCS FLIGHTCOM working other medevac aircraft 466.3125 156.7 Hz Construction 464.5500 627 DCS Yellow Dot """we need that torch on the roof"" ""that truck is gonna be here in about 20 minutes"" ""once you fill all those tanks up"" - Construction work site coordination and operations - likely primary channel " 469.5500 205 DCS Construction crew 462.8625 88.5 Hz Crane coordination and control - appears to be most active in mornings and evenings, possibly associated with a late-night shift crew 154.5700 371 DCS MURS 4 Crane control and construction comms 467.6625 053 DCS FRS 12 Local school 151.6250 065 DCS Red Star FLIGHTCOM and AIRCARE EAGLE doing radio checks 467.8500 179.9 Hz Silver Star Hotel or hospitality operations 151.5125 136.5 Hz Crane control 462.5625 77.0 Hz FRS 01 Spanish language, fair/poor signals....this group has been logged previously using this CTCSS tone 469.5000 205 DCS Chatter about portable toilets and other job site sanitary equipment 467.6625 053 DCS FRS 12 Local school - sporadic activity...most active in morning, around mid day and in early to mid afternoon 462.6750 606 DCS FRS 20 Retail store - primary operations channel (previously monitored numerous times) 461.2125 67.0 Hz Hotel/hospitality operations - portable radios 469.5500 114.8 Hz Crane coordination and informal chatter...often extremely informal 151.5050 167.9 Hz Crane Master - secondary or backup operations channel 464.5000 67.0 Hz Brown Dot """basement corridor"" " 462.5875 97.4 Hz FRS 02 Crane control operations 466.0875 506 DCS Construction operations 462.5625 250.3 Hz FRS 01 """elevator"" ""I'm bringing up order 3"" ""okay thank you"" (weak to fair signal)" 467.8750 229.1 Hz Gold Star Crane coordination and crane control 462.5875 118.8 Hz FRS 02 Catering company or hospitality 451.8000 023 DCS Concrete contractor or similar materials construction company 158.4075 065 DCS FLIGHTCOM doing radio checks 462.6250 127.3 Hz FRS 18 Local school or day care - one of many groups that use this very popular frequency channel and CTCSS tone combination 464.5000 94.8 Hz Brown Dot Fire alarm or security alarm installation crew or facilities management guys 151.6250 167.9 Hz Red Dot Crane Master - primary operations channel 456.8125 703 DCS Spanish language, sporadic signal 154.5700 67.0 Hz MURS 4 Two guys talking about the recent spike in fuel prices 462.6000 455 DCS FRS 17 Caught the tail end of a very strong signal 464.5500 732 DCS Yellow Dot Spanish language - fair signal...but weaker than other transmissions usually heard on this frequency 462.5500 123.0 Hz FRS 15 "heard reference to ""level 3"" and ""basket"" - maybe construction site materials delivery or tower crane control comms " 469.5500 165 DCS Construction 462.9125 192.8 Hz Crane coordination and control 462.6375 131.8 Hz FRS 04 Local school - appears to be primary channel for this group 469.5500 023 DCS Spanish language chatter 467.8750 165 DCS Gold Star Construction site equipment and supply delivery coordination 462.8125 627 DCS Construction site or work site comms - appears to be secondary or backup channel 5/15/2021 466.3125 156.7 Hz """where supposed to report back that...that concrete is blue screen on it this morning...before we leave this floor"" ""yeah 10-4 we got guys that are taking care of that"" " 469.5500 114.8 Hz Crane coordination and informal chatter...often extremely informal - Spanish and English, switching rapidly back and forth between the two at points 464.5500 627 DCS Yellow Dot Construction site coordination - primary channel 462.5875 97.4 Hz FRS 02 Crane control - mix of Spanish and English 464.8250 026 DCS Crane control 456.8125 023 DCS Concrete or other building materials delivery and building contractor coordination 467.6625 67.0 Hz FRS 12 Elevator floor requests 151.5125 136.5 Hz Crane control 469.5500 205 DCS High rise construction - including supply requests for different floors, etc 462.5750 654 DCS FRS 16 Crane control - good strong signal at 9:05AM 467.8500 627 DCS Silver Star Construction crew - work site control channel, with some informal chatter 469.5000 506 DCS Construction crew or similar 467.8750 229.1 Hz Gold Star Crane coordination and crane control 462.6625 97.4 Hz FRS 05 """yeah I'm the next lane over...are we gonna take this exit?"" " 461.2625 023 DCS Event management - probably RMC Events 151.6250 136.5 Hz Red Dot Crane control, heard several measurements being read over the air....likely portable radios going by signal strength 462.6750 606 DCS FRS 20 Retail use 466.3625 023 DCS Event management - probably RMC Events 154.5700 371 DCS MURS 4 Crane control and construction - portable radios with some informal chatter 466.0875 506 DCS Construction crew or similar 464.5000 127.3 Hz Brown Dot Building inspectors or facilities management - fair signal but sporadic activity 151.6250 065 DCS FLIGHTCOM and AIRCARE EAGLE doing radio checks - FLIGHTCOM dispatching 451.8125 023 DCS Concrete or other building materials delivery and building contractor coordination 462.8625 88.5 Hz Crane control and coordination 462.7250 67.0 Hz FRS 22 "Kids playing on radios - heard several FRS call tones or alarm / alert tones in a row...fair signals...followed by 8 or 10 alert tones or call tones in a row and ""HELLO!"" ""I can't hear you on the walkie talkie! hello!!! I can't hear you!"" etc etc " 462.9125 192.8 Hz Crane coordination - can hear other radio chatter in the background at points...similar to the other coordination frequencies 462.6375 CSQ FRS 04 """just watch my rear and make sure everything is okay...we're gonna take a right and then get on the downtown expressway"" - more car to car comms - good signals...no CTCSS or DCS in use (carrier squelch)....about 4-5 minutes after initially heard transmission...signal strengths have decreased significantly, which backs up the vehicle to vehicle or car to car type comms theory " 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 3 - aircraft mission particulars, fuel status, etc. and next mission assignment - very strong signals for both the helicopter and the base station 5/16/2021 464.5000 77.0 Hz Brown Dot """we'll call him back and find out what time those loads of PVC are coming"" " 462.7250 136.5 Hz FRS 22 """okay next one"" - weak signal...able to decode CTCSS and not much else " 469.5000 165 DCS Construction site comms 466.3125 156.7 Hz """where is he going!?"" - typical group heard on this frequency and CTCSS tone combination " 467.8500 179.9 Hz Silver Star "Hotel or hospitality operations - portable low power radios...heard ""front desk"" " 462.5750 023 DCS FRS 16 """can I get a radio check on channel 9?"" ""I have you on here"" ""copy that"" " 466.0875 97.4 Hz Construction or similar 462.6250 67.0 Hz FRS 18 Parking lot operations or traffic direction / flaggers 464.5375 85.4 Hz """red Kia, lot 2"" " 461.1625 67.0 Hz Room cleaning requests - fair to poor signal, likely downtown hotel operations 467.8750 229.1 Hz Gold Star Crane control and coordination 151.5125 136.5 Hz Crane control 462.6875 141.3 Hz FRS 06 """can you zoom in?"" ""yeah just stay on...[unreadable]"" - sounds like security guards or maybe loss prevention? could also be film or TV production crew " 464.5500 627 DCS Yellow Dot "The ""Usual Suspects"" found on this frequency and DCS code combination - sometimes very busy " 462.6375 114.8 Hz FRS 04 talking about parking cars and coordinating traffic 464.5000 103.5 Hz Brown Dot Hotel or hospitality 462.7250 67.0 Hz FRS 22 """did you copy that?"" ""okay 10-4"" - weak signals...does not appear to be the same group heard yesterday using this frequency and tone " 158.4075 065 DCS "LIFE EVAC 4 ""down and secure at Chippenham"" confirmation transmission by FLIGHTCOM dispatch center " 467.6375 77.0 Hz FRS 11 Faint signal...female speaker...but good CTCSS decode 464.5500 67.0 Hz Yellow Dot Spanish language 467.5625 67.0 Hz FRS 08 """okay she's good"" - weak signal " 5/17/2021 466.0875 506 DCS Construction / work site comms 451.8125 732 DCS Construction site/work site coordination comms - portable radios 464.5500 627 DCS Yellow Dot Construction site coordination - primary channel 158.4075 065 DCS LIFE EVAC 1 working FLIGHTCOM doing a training flight in the local area - strong signals from aircraft and dispatch radios 467.6625 67.0 Hz FRS 12 Elevator floor pick up and drop off requests 466.3125 156.7 Hz Construction site operations, sporadic signals 154.5700 043 DCS MURS 4 Construction site or tower crane control operations....noisy channel with interference from data bursts telemetry systems on frequency 469.5000 165 DCS Construction operations...- portable radios 467.5625 243 DCS FRS 08 Local school or similar - fair to good signals 151.6250 145 DCS Red Dot Heard tail end of strong transmission 469.5500 205 DCS Crane control 466.0875 97.4 Hz Construction site coordination comms 151.5125 136.5 Hz Crane control - usual user of this frequency and CTCSS tone 467.6625 053 DCS FRS 12 Local school - appears to be the same group previously monitored using this DCS code on this frequency 467.7875 132 DCS "Voice inversion SCRAMBLED transmission secure mode scrambler with ANI data bursts end of transmission EOT ""squawk"" - first heard at 10:42AM" 467.9250 67.0 Hz Blue Star Security or facilities management 469.5500 165 DCS Weak signal heard on a very active frequency 462.6375 131.8 Hz FRS 04 Local school - appears to (now) be primary channel 467.8125 103.5 Hz """K"" Dot" Hotel or hospitality ops 464.5000 67.0 Hz Brown Dot Heard mention of sanitary equipment, probably for a job site or similar - possibly a different group / company / contractor than previously monitored? 462.5625 CSQ FRS 01 "Spanish language chatter - with ""Roger Beeps"" " 461.1375 506 DCS Construction - weak to fair signals 462.6125 74.4 Hz FRS 03 "traffic control / flaggers / flag men - portable FRS radios with typical FRS-style ""Roger Beeps"" " 467.8750 229.1 Hz Gold Star Crane control and coordination 462.6750 136.5 Hz FRS 20 Local school - further away than the other several schools or similar facilities heard, slightly stronger signals than retail user on same channel 462.8625 88.5 Hz Crane control / coordination 151.6250 065 DCS Red Dot FLIGHTCOM dispatch - base station communicating with airborne units 469.5625 021 DCS TV or film crew - possibly production assistants or transportation coordination 462.7250 136.5 Hz FRS 22 Local school - coordinating pick ups and drop offs 457.5250 315 DCS Local school 464.5500 205 DCS Yellow Dot Construction site comms - talking about weather forecast 467.5625 243 DCS FRS 08 Local school or day care - portable radios 462.6750 606 DCS FRS 20 Retail use 462.5250 114.8 Hz Sounds like a day care facility - can hear children in background - must be pretty local, strong signals...coordinating pick ups of children 461.2375 612 DCS """...528"" ""wooo hoo!"" ""...drone"" - broken signals, only able to copy bits and pieces " 462.9125 192.8 Hz Crane coordination 462.5875 023 DCS FRS 02 """thank you"" - female speaker, strong signal " 467.9125 021 DCS """we're gonna [unreadable] back up again tomorrow...gonna talk to the director"" ""copy that"" - probably film or TV production crew going by DCS code used " 469.5500 114.8 Hz Crane coordination and general informal chatter - other radios heard in background of some transmissions....this frequency is active with numerous different users at points and this user appears to be the strongest signal basically every time 462.5500 123.0 Hz FRS 15 """I'm gonna get a message to her real quick"" - sounded like the same group from the local school, might have switched frequencies again " 466.3625 612 DCS """Don't wanna wait too long..."" - portables " 5/18/2021 464.8250 026 DCS Crane control - portable radios - simplex 467.6625 67.0 Hz FRS 12 "Elevator floor pick up and drop off requests - the usual traffic with FRS ""Roger Beeps""" 457.5250 315 DCS Local school - portable radios - simplex 154.4900 67.0 Hz Highway construction or contractor - possibly the same group previously heard using this frequency and CTCSS tone 464.5500 627 DCS Yellow Dot Construction site coordination - primary channel 462.6875 85.4 Hz FRS 06 Security or surveillance - similar to traffic heard on this channel frequency and CTCSS tone previously 151.5125 136.5 Hz Crane control 466.3125 156.7 Hz Construction site comms - Spanish and English heard 467.6625 053 DCS FRS 12 """before she leaves today...I want to talk to her about Floyd"" - local school, presumably the same one usually heard on this channel / frequency and DCS code combination " 154.5700 371 DCS MURS 4 """well if he wants to go for a ride he needs to get off [unreadable]"" - sounds like the same group previously monitored using this DCS code on this frequency " 462.5625 CSQ FRS 01 Spanish language, weak to fair signal...no CTCSS or DCS tone or code in use - carrier squelch 461.2625 631 DCS """that's my bad...I know it was my idea yesterday but...[unreadable]""" 462.5250 114.8 Hz Local school or day care - must be very local....very strong signal loud and clear - portable radios 464.5000 82.5 Hz Brown Dot Spanish language chatter - strong signals, possibly portable radios being used for car to car comms 158.4075 065 DCS FLIGHTCOM dispatcher working LIFE EVAC 1 and LIFE EVAC 2 airborne units (medevacs) 462.7125 159.8 Hz FRS 07 Same usual group usually heard on this frequency channel and CTCSS tone - downtown building security or facilities management or similar operation 462.8375 631 DCS Possibly coordinating materials delivery 466.0875 506 DCS Construction site coordination - talking about truck supply delivery 464.5000 67.0 Hz Brown Dot Electricians - testing breakers, reset requests, etc. 469.5000 205 DCS Construction site comms 462.7125 79.7 Hz FRS 07 Crane control 462.6375 131.8 Hz FRS 04 School or day care? weaker signal, not (usual) local users that appear to have changed channels frequencies anyway 464.5500 114 DCS Yellow Dot "heard mention of ""traffic"" - no other useful traffic heard using this DCS code - other traffic active on frequency at times very busy with chatter " 466.1875 261 DCS """okay bring it back up...""" 467.5875 91.5 Hz FRS 09 FRS call tones / alert tones heard 462.6250 127.3 Hz FRS 18 Local school - possibly alternate or backup channel - this user has changed channels / frequencies and tones several times 462.8125 021 DCS TV or film crew 464.5000 77.0 Hz Brown Dot """you're coming off the center...you're coming off the center"" (female voice....with interference from other activity on frequency / channel)" 462.7250 136.5 Hz FRS 22 Local school - appears to be new primary channel - this user continues to switch channels and tones 467.7875 132 DCS Voice inversion SCRAMBLED scrambling scrambled transmissions with ANI data burst - automatic transmitter ID bursts at the end of transmissions 461.2625 023 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium 462.6750 606 DCS FRS 20 Warehouse coordination - possibly related to the usual retail store users heard on this channel frequency DCS code combination 466.3625 023 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium 467.8500 054 DCS Silver Star """what is your location?"" ""the fountain"" ""you're in the powder room?"" ""no, I'm at the fountain"" ""okay copy"" " 466.2625 023 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium 469.5500 114.8 Hz Crane coordination 461.3625 023 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium 466.3125 023 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium 151.8200 103.5 Hz MURS 1 Contractor - likely same user previously heard using this CTCSS tone - including general informal chatter 461.2375 631 DCS """okay hold for a minute"" ""check back around"" " 462.9125 192.8 Hz Crane coordination 464.3250 546 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium (simplex) 467.8750 229.1 Hz Gold Star Crane coordination 461.2875 532 DCS """get the video of those....[unreadable]"" ""shorts...""" 467.8625 021 DCS TV or film crew - possibly production company comms 461.2375 612 DCS "Weak/broken up signals - similar to what was monitored yesterday on this frequency and DCS combination - heard ""well, we have a question for him"" " 464.5500 023 DCS Yellow Dot Event management comms - possibly also RMC Events - same signal strength as the RMC Events channels...not 100% sure though 467.9250 229.1 Hz Blue Star Crane control - appears to be alternate channel 469.4875 021 DCS TV or film crew 462.6625 82.5 Hz FRS 05 """can you hear me now?"" ""I can't hear [unreadable] on channel 6"" - pretty standard style FRS ""Roger Beeps"" in use " 461.3375 612 DCS Possibly same group using this as an alternate - see logs for same date and DCS code 154.4900 023 DCS """did you get that last vehicle?""" 466.3625 532 DCS Weak signals, maybe also related to TV or film production or related services? 467.5625 CSQ FRS 08 "Two guys talking about somebody ""being hot"", ""knowing when he's hot"" ""having the next one"" and ""he's in the game!"" - heavy use of ""10-4"" and all transmissions have FRS Roger Beeps...no CTCSS tone or DCS code in use - carrier squelch only " 5/19/2021 461.2375 631 DCS Hearing weak transmissions similar to those heard yesterday on same frequency and DCS code 151.6250 546 DCS Red Dot "Crane control - weak to fair signals...heard the tell-tale ""cable down...cable down..."" ""hold your cable"" etc. " 464.5500 627 DCS Yellow Dot Construction site coordination - primary channel 457.5250 315 DCS Local school 466.3125 156.7 Hz Construction site comms - mix of Spanish and English 462.5875 71.9 Hz FRS 02 """Benny, what's that?"" ""you can't say that on the radio!"" - weak/fair signals with Roger Beeps " 464.5000 67.0 Hz Brown Dot Electricians or engineers checking alarm system circuits 462.6750 606 DCS FRS 20 Store or retail use 464.8250 026 DCS Crane control 467.6625 67.0 Hz FRS 12 "Elevator floor pick up and drop off requests - the usual traffic with FRS ""Roger Beeps""" 461.1625 67.0 Hz Engineering or repair crew - probably a downtown hotel or high rise 462.8125 627 DCS Construction site operations - likely secondary or backup / talkaround channel 462.5625 67.0 Hz FRS 01 10-15 seconds of dead air - unmodulated carrier...no Roger Beeps heard 469.5500 205 DCS Construction site operations 462.5500 162.2 Hz FRS 15 """okay copy"" - two different groups using two different CTCSS tones on at the same time" 151.5125 136.5 Hz Crane control - usual traffic heard on this CTCSS tone on this frequency 151.8200 103.5 Hz MURS 1 """alright 10-4"" - usual users of this frequency and CTCSS tone heard " 462.5500 123.0 Hz FRS 15 """insulator"" - other unreadable transmissions mixing in - later, stronger signals in Spanish and English, presumed construction site comms " 467.6625 053 DCS FRS 12 Local school 466.2875 506 DCS Construction site comms 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations 151.6250 023 DCS Red Dot """level A"" heard loud and clear " 462.6875 85.4 Hz FRS 06 """copy that"" - appears to be the same group or user previously monitored using this CTCSS on this channel " 154.5700 371 DCS MURS 4 Same group previously monitored on this frequency and DCS code combination 158.4075 065 DCS FLIGHTCOM calling LIFE EVAC 4 (only able to copy FLIGHTCOM dispatcher signals at this time...) 462.5625 CSQ FRS 01 "Spanish language comms, unique style FRS ""Roger Beep"" - at time transmissions were first heard, no other active users on same frequency " 469.5500 205 DCS Construction site or crane control comms 151.6250 065 DCS Red Dot FLIGHTCOM dispatch calling LIFE EVAC 4 on alternate frequency - was having issues contacting on previous frequency 462.6500 632 DCS FRS 19 """get a name on the..."" ""do you want me to check him in?"" ""...bulb out..."" ""okay"" - Roger Beeps noted in use " 466.0875 023 DCS Construction materials delivery coordination 461.2125 67.0 Hz Hotel or hospitality operations 154.5700 047 DCS MURS 4 """bring it up now...right now!"" " 462.5250 114.8 Hz Local school or day care - very good signals...must be pretty local 151.6250 67.0 Hz Red Dot """come in, B..."" ""can you hear me man?"" - weak signal...likely portable radios " 464.5000 103.5 Hz Brown Dot Hotel or hospitality operations 466.2625 506 DCS Construction site comms 462.6125 127.3 Hz FRS 03 Local school or day care - possibly secondary or backup channel 464.5375 85.4 Hz Hotel or hospitality operations 151.9400 110.9 Hz MURS 3 "Heard ""okay 3"" and ""take it down"" ""these trees over here where...[unreadable]"" ""there's plenty of shade there"" " 462.6125 210.7 Hz FRS 03 Caught tail end of a FRS transmission...with the usual FRS Roger Beep... 154.5275 065 DCS FLIGHTCOM working several aircraft 469.5000 205 DCS Construction site comms, crane control...sporadic activity 462.6500 351 DCS FRS 19 Spanish language - mixing in with other comms on same frequency 467.5625 CSQ FRS 08 """he's on his way"" ""okay bring up....""" 462.8875 88.5 Hz Crane control - Spanish and English language heard...also some general informal chatter 466.0875 97.4 Hz Weak / fair signals - presumed to be the same users previously heard 462.6250 127.3 Hz FRS 18 School or day care - pretty local based on signal strength 467.6375 051 DCS FRS 11 Local school or similar - not as strong as others but decent considering this is a low-power channel (or it's supposed to be anyway) 151.5125 67.0 Hz Weak signals heard...either low volume levels or unmodulated carrier (dead air) - probably portable radios ) 464.5500 77.0 Hz Yellow Dot Weak signal - but confirmed CTCSS tone decode - frequency currently active with stronger signals 462.5875 97.4 Hz FRS 02 Crane control 467.8750 229.1 Hz Gold Star Crane coordination 466.0875 506 DCS """in the truck driver game they call that falling asleep!"" - construction site comms " 464.5000 346 DCS Brown Dot """put all your shit on there"" ""okay man"" ""....like Lane and all that shit..."" - informal chatter " 467.6125 073 DCS FRS 10 Radio checks - two different UNID unidentified stations, Roger Beeps heard 462.7250 136.5 Hz FRS 22 Local school - appears to be primary channel (at least for now) 461.1375 506 DCS Construction - weak to fair signals 151.6250 371 DCS Red Dot """8"" ""22"" and a couple other numbers heard (in Spanish) " 467.7875 132 DCS "Voice inversion SCRAMBLED transmission secure mode scrambler with ANI data bursts end of transmission EOT ""squawk"" - first heard at 10:42AM" 462.9125 192.8 Hz Crane control 464.5000 432 DCS Brown Dot Tail end of unmodulated carrier (dead air) - strong signal, good DCS code decode 462.6750 136.5 Hz FRS 20 "School - somewhat local...sometimes it's the same signal strength as the retail store on this same channel / frequency, other times one or the other is stronger...the school appears to be using FRS handheld walkie talkies with user-selectable CTCSS / DCS ""sub channels"" or ""privacy codes""" 469.5500 114.8 Hz Crane control / crane coordination and some informal chatter 151.8200 67.0 Hz MURS 1 """maybe wait a second or so after I finish talking and *then* try to talk!"" - female speaker - strong signal " 466.2625 023 DCS RMC Events - heard evening radio checks at 5:21PM and 5:22PM 466.3125 023 DCS RMC Events - radio check heard on this frequency as well 467.9250 67.0 Hz Blue Star Security or facilities management 466.3625 023 DCS RMC Events - parking coordination comms 467.7625 546 DCS """J"" Dot" """sector 121"" ""okay copy that"" " 461.3125 023 DCS RMC Events - parking coordination comms 462.7125 CSQ FRS 07 "Group driving down (or up) 95 - ""I told her we'd be there in about 2 hours"" ""it's a block of rooms...including the corner handicap room"" ""okay I had to let that van in behind you"" - signals faded in rapidly and then faded out just as rapidly...pretty standard FRS Roger Beeps in use, no CTCSS or DCS in use - true carrier squelch " 464.3250 546 DCS RMC Events - event management - active at Richmond Flying Squirrels Stadium (simplex) 462.5500 CSQ FRS 15 """Dugout...dugout...come in..."" ""okay..Bishop is warming up...just wanted to confirm, thank you"" - baseball team comms...verified no CTCSS or DCS tone or code in use " 462.7250 136.5 Hz FRS 22 Different user/group than the daytime (school) user of this frequency and CTCSS tone...sounded like two male speakers whispering into their radios...very strong signals, but difficult copy 462.5875 67.0 Hz FRS 02 """okay copy that, I see the white truck coming around the corner now"" " 469.5500 165 DCS Construction site equipment and supply delivery coordination 5/20/2021 466.1875 506 DCS Construction 464.8250 026 DCS Crane control 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations 466.0875 506 DCS Construction comms 464.5500 627 DCS Yellow Dot Usual construction site - high rise tower - comms heard on this channel and DCS code - very active 467.6625 67.0 Hz FRS 12 Elevator floor requests -'usual traffic for this frequency 154.5700 371 DCS MURS 4 Crane control / construction site comms - portable radios 466.3125 156.7 Hz Construction site comms - sporadic signals...sometimes active for short bursts at a time - Spanish and English heard 469.5500 114.8 Hz Crane coordination 154.4900 67.0 Hz Highway construction or highway sign contractor - portable radios 462.5875 71.9 Hz FRS 02 Weak signals with Roger Beeps....sounds like the same chatter heard yesterday on this channel frequency and CTCSS tone combination 462.6750 606 DCS FRS 20 Retail store and warehouse operations...more or less the same signal strength as the school using the same channel 451.8125 023 DCS Concrete or cement contractor - portable radios 151.5125 136.5 Hz Crane control 467.6625 053 DCS FRS 12 Local school - sporadic signals....most active in morning...middle of day and afternoons 466.1875 261 DCS Construction comms 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 1 and other medevac aircraft 462.5625 77.0 Hz FRS 01 Very weak signals - sounded like Spanish language....was able to decode CTCSS and also heard short 3-tone Roger Beep end of transmission EOT burst 464.5000 67.0 Hz Brown Dot Electricians or engineers checking alarm system circuits 462.5250 114.8 Hz Local school or day care - very good signals...must be pretty local 462.6750 136.5 Hz FRS 20 Heard female voices - sounded like a school or similar...fair to poor signals (mostly) with some stronger ones at points 469.5000 506 DCS Construction site comms - sometimes mixing with other group / user on same frequency 469.5000 205 DCS Talking about trucks arriving late.. 462.6250 127.3 Hz FRS 18 Catering company? poor to fair signals...not super local 456.8125 023 DCS Concrete or cement contractor - portable radios 151.6250 546 DCS Red Dot Crane control and general construction comms 462.5875 118.8 Hz FRS 02 Heard faint Spanish language chatter - presumably low-power portable handheld walkie talkie radios - Retevis or Baofeng radios 466.1875 023 DCS Concrete or cement contractor - portable radios 467.6875 466 DCS FRS 13 Weak signal picked up - possibly car to car chatter...signals rapidly gained strength and then rapidly lost it 462.8125 627 DCS "Construction site / job site comms - probably a secondary or fallback ""talkaround"" channel " 466.1375 103.5 Hz """15 more feet..."" ""rope"" ""line"" and similar heard..""bring that line back...okay there..."" " 466.3125 023 DCS RMC Events - Event Management related comms 469.5500 165 DCS Construction site equipment and supply delivery coordination 467.7125 67.0 Hz FRS 14 Facilities management? unable to really ID due to weak signal and poor copy 457.5250 315 DCS Local school - portable radios 151.6250 77.0 Hz Red Dot """6, number 6 please"" ""can you bring it back up?"" ""come over"" - a couple transmissions had what sounded like a ringing telephone or other alarm or alert going off in the background audio " 469.5000 732 DCS Construction or work site coordination...weak to fair signal 154.5275 065 DCS FLIGHTCOM dispatch working LIFE EVAC 3 466.3625 023 DCS RMC Events - parking/traffic control 462.5875 97.4 Hz FRS 02 Spanish language 462.6500 632 DCS FRS 19 Radio checks 469.5500 732 DCS Construction or work site coordination...weak to fair signal 466.0875 97.4 Hz Construction site coordination comms 464.5000 546 DCS Brown Dot Spanish language - sounds like crane control to me 462.6250 371 DCS FRS 18 """give me 30 more feet"" ""crossbeam"" ""hold your cable"" - possibly a new crane control net frequency and DCS code??" 461.0875 023 DCS Concrete or cement contractor - portable radios 462.6875 141.3 Hz FRS 06 Local school - possibly secondary channel 461.2625 023 DCS RMC Events - parking/traffic control 467.8750 229.1 Hz Gold Star Crane control 462.7250 136.5 Hz FRS 22 Local school - probably primary channel 456.8125 023 DCS Concrete or cement contractor - portable radios 467.6125 CSQ FRS 10 FRS call tones / alert tones heard...fair to weak signals 462.5750 77.0 Hz FRS 16 Caught tail end of a transmission, no Roger Beep or other end of transmission tones or beeps heard 461.1625 67.0 Hz Hotel or hospitality 461.3125 023 DCS RMC Events - parking/traffic control 462.7250 252 DCS FRS 22 """Miss Hendricks"" or ""Miss Hendrix"" doing a radio check " 466.2625 023 DCS "RMC Events - talking about vehicles ""dropping off"" and and such...probably traffic control and/or parking...very active at points - appears to be primary frequency...appears to be the most active of the known RMC Events event management frequencies at this time" 462.5500 CSQ FRS 15 """Dugout"" heard - appears to be the same group heard yesterday evening...likely bullpen / pitching coach or baseball staff comms " 151.6250 065 DCS Red Dot FLIGHTCOM dispatch radio for AIRCARE EAGLE 5/21/2021 464.8250 026 DCS Crane control 461.0875 023 DCS Concrete or cement contractor - portable radios 469.5000 205 DCS Construction site / work site materials delivery coordination 151.5125 136.5 Hz Crane control 467.6125 CSQ FRS 10 Sounds like a parent and a child or children talking on FRS walkie talkies - FRS style Roger Beeps noted 469.5500 023 DCS Concrete or cement contractor - portable radios 154.4900 67.0 Hz Contractor - highway maintenance or sign installation or repair crew - portable radios 462.6750 606 DCS FRS 20 Retail use - in-store comms and warehouse/inventory comms 151.6250 67.0 Hz Red Dot Contractor - highway maintenance or sign installation or repair crew - portable radios 466.1875 023 DCS Concrete or cement contractor - portable radios 462.5625 77.0 Hz FRS 01 Spanish language chatter 154.5700 371 DCS MURS 4 Crane control and construction comms 469.5000 165 DCS "Talking about ""hand sanitizer stations"" " 158.4075 065 DCS FLIGHTCOM dispatch working LIFE EVAC 1 and other medevac aircraft 467.6625 67.0 Hz FRS 12 "Elevator floor pick up and drop off requests - ""pick up on 14"" ""pick up on 11 please"" etc. " 466.0875 023 DCS Concrete or cement contractor - portable radios 464.5000 712 DCS Brown Dot Spanish language - probably construction site comms 464.5500 627 DCS Yellow Dot Usual construction site - high rise tower - comms heard on this channel and DCS code - very active 467.6625 053 DCS FRS 12 Local school - previously monitored using this frequency channel and DCS code combination 466.0875 97.4 Hz Construction site coordination comms 151.6250 065 DCS Red Dot FLIGHTCOM dispatcher talking to AIRCARE EAGLE 469.5500 165 DCS """okay fine well then give him your name"" " 151.5125 67.0 Hz Weak voice traffic...last second of transmission heard, solid CTCSS tone decode 462.5250 114.8 Hz Local day care - coordinating location of teachers, classes, etc. - must be very local due to strong signal strength 469.5000 732 DCS """pickup on 6"" - elevator floor requests " 467.5625 CSQ FRS 08 """Michael..."" - female speaker, FRS Roger Beeps heard " 462.9125 192.8 Hz """crane operator"" ""yeah Roberto came back yesterday"" " 462.5625 67.0 Hz FRS 01 """hey pull in here I found a good spot"" ""okay got it"" ""yeah big pimpin' right?"" - followed by more business-like comms...(same guys) - crane control, sometimes with heavy interference since there's another active tower crane user group on this channel...just using a different CTCSS tone " 466.3125 156.7 Hz Construction site comms 462.8625 88.5 Hz Crane control and construction comms 462.5875 CSQ FRS 02 "two kids talking on FRS walkie talkies - ""these are some strange directions"" - signals came up rapidly and then rapidly faded out...possibly two mobile units or kids riding in cars or a car " 466.0875 506 DCS Construction comms - some interference from the other users / groups on this frequency 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations 469.5500 732 DCS Service elevator coordination and floor pick up and drop off requests 464.5000 546 DCS Brown Dot Spanish language - fair to good/strong signals at points 462.7250 136.5 Hz FRS 22 Local school - appears to be primary channel (for now anyway) 154.5275 065 DCS FLIGHTCOM dispatcher - possibly alternate channel? 462.8875 192.8 Hz """radio check, this is the East crane...how well do you copy me?"" ""okay switching back to my other radio"" " 151.6250 77.0 Hz Red Dot """hey can I get a pick up on level 8?"" " 466.2625 023 DCS RMC Events - parking/traffic control 462.7250 67.0 Hz FRS 22 Weak signals...sounded like kids talking on radios / FRS walkie talkies 467.8750 229.1 Hz Gold Star Crane control 461.3625 023 DCS RMC Events - parking/traffic control 462.6125 67.0 Hz FRS 03 "Construction site comms or similar - familiar FRS ""Roger Beep"" " 5/22/2021 469.5500 732 DCS Construction site comms - including elevator floor requests 151.6250 065 DCS Red Dot "AIRCARE EAGLE working FLIGHTCOM at 8:00AM for ""morning radio check"" - both stations full scale loud and clear excellent signals " 466.0875 023 DCS Concrete or cement contractor - portable radios 464.5500 627 DCS Yellow Dot Usual construction site - high rise tower - comms heard on this channel and DCS code - very active 467.6625 67.0 Hz FRS 12 Elevator floor pickup and drop off requests - usual chatter on this frequency and CTCSS tone 464.8250 026 DCS Crane control - portable radios (simplex) 467.8500 179.9 Hz Silver Star "Hotel or hospitality - heard ""front desk"" " 461.1875 67.0 Hz Facilities management or similar 154.5275 065 DCS FLIGHTCOM doing radio checks 469.5500 114.8 Hz Crane coordination - including lots of informal chatter, Spanish and English 154.5700 371 DCS MURS 4 Construction contractor and crane control....sometimes with very good signals....but usually not so good - variable signals as expected with VHF band - MURS handhelds 456.8125 023 DCS Concrete or cement contractor - portable radios 151.5125 136.5 Hz Crane control - portable radios - primary channel for this particular user / group / company / contractor 467.8125 103.5 Hz """K"" Dot" """Front desk"" - likely hotel or hospitality - portable radios " 151.8200 67.0 Hz MURS 1 Hospitality or catering? portable radios...fair to poor signals, at least one, possibly two of the voices heard were female 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 1 and LIFE EVAC 3 medevac helicopters 466.1875 261 DCS Construction comms 462.6875 85.4 Hz FRS 06 Security or maybe surveillance? could also be parking or similar traffic control...heard vehicle descriptors...license plates 151.6250 025 DCS Red Dot "Somebody asking for ""Rick"" or maybe ""Dick"" - poor copy" 462.9125 192.8 Hz Crane control and crane coordination 461.1625 67.0 Hz Facilities management or engineering crew - portable radios 467.8750 229.1 Hz Gold Star Crane control and crane coordination 464.5000 67.0 Hz Brown Dot Electricians or engineers testing alarm system or fire alarm / smoke or heat detector system network functionality circuit testing, etc. 461.2625 023 DCS RMC Events - parking/traffic control 469.5000 205 DCS Construction site comms - sporadic activity 466.3625 023 DCS RMC Events - parking/traffic control 464.5000 546 DCS Brown Dot Spanish language chatter - likely construction site comms 154.5275 136.5 Hz Crane control - portable radios...probably secondary channel for this user group company contractor etc. 462.6750 606 DCS FRS 20 Retail use - talking about inventory, customer service, etc. low-powered portable walkie talkies - likely Retevis brand 466.2625 023 DCS RMC Events - parking/traffic control - appears to be primary channel - or the most active one at the Richmond Flying Squirrels game / The Diamond 466.1625 506 DCS Construction site comms - portable radios 5/23/2021 464.8250 026 DCS Crane control 462.7250 136.5 Hz FRS 22 Maybe parking garage or parking lot check? fair to good signal strength...but *not* the local school user that recently started using this (very popular) frequency and tone combination 462.9125 192.8 Hz Crane control / coordination comms 462.6750 CSQ FRS 20 """If you wanna go 60 miles an hour you wanna tell me that you wanna go 60 miles an hour"" ""uhhh...can you repeat that?"" [laughing] ""uh, never mind"" - sounded like two vehicles driving up or down the Interstate - no CTCSS or DCS noted " 462.6250 127.3 Hz FRS 18 Parking lot attendants or traffic control - heard several transmissions - all of which appeared to be very local - strong signals...probably related to a local church or similar 151.6250 065 DCS Red Dot AIRCARE EAGLE being dispatched to a crash call by FLIGHTCOM dispatch radio 464.5500 627 DCS Yellow Dot Usual construction site - high rise tower - comms heard on this channel and DCS code - very active 467.7500 115 DCS Retail - Target Stores Channel 1 (main channel plan) 464.5000 074 DCS Brown Dot Caught tail end of a transmission...unknown user 467.7750 072 DCS Retail - Target Stores Channel 2 (main channel plan) 461.1875 172 DCS Unknown user - probably also retail store going by the DCS code in use 154.5700 74.4 Hz MURS 4 Portables - possibly also retail related 467.9000 205 DCS Red Star Retail - Target Stores Channel 4 (main channel plan) 469.5500 114.8 Hz Crane control and coordination 467.9250 67.0 Hz Blue Star Security or facilities management 461.1125 172 DCS Retail store - probably security or loss prevention - portable radios 461.0375 743 DCS Facilities management or similar? some heavy interference from the high-power GRTC DMR digital system on 461.025 MHz 461.3625 172 DCS Security ops - portable radios 462.5625 67.0 Hz FRS 01 Crane control 467.8500 67.0 Hz Silver Star Retail - portables - possibly primary channel 451.8000 664 DCS """customer has a question about..."" - weak to fair signal, almost certainly portable radios " 462.5875 97.4 Hz FRS 02 Crane control - mix of English and Spanish language...FRS Roger Beeps noted 466.0875 506 DCS Construction site comms 469.5500 205 DCS Construction site equipment delivery or repair contractor or subcontractor 467.8750 229.1 Hz Gold Star Crane control and coordination 466.2625 023 DCS RMC Events - parking/traffic control - appears to be primary channel - or the most active one at the Richmond Flying Squirrels game / The Diamond 462.5500 CSQ FRS 15 "Weak signal...heard ""side"" and a couple unreadable transmissions...no indication of any CTCSS tone or DCS code usage " 461.3625 023 DCS RMC Events 158.4075 065 DCS FLIGHTCOM dispatch 466.0875 97.4 Hz Weak signals...bits and pieces coming through but unable to positively ID 151.8200 67.0 Hz MURS 1 """you've got room in the rail"" or ""you've got room on the rail"" " 5/24/2021 461.3625 74.4 Hz Electricians or engineering crew - testing alarm panel or alarm circuit functionality, possibility on a new building project in-progress....portable radios but good signals 151.5050 025 DCS """yeah he's falling behind, he's gonna call when he's caught up"" ""okay just let me know when you want me to load the tractor up""" 462.5875 118.8 Hz FRS 02 """wheel alignment"" ""8:00 appointment"" " 469.5500 114.8 Hz Crane control and coordination also lots of informal chatter 466.0875 023 DCS Construction site materials delivery coordination - concrete and possibly other materials - portable radios 462.7125 146.2 Hz FRS 07 """can you bring it...okay you're right...zero it...zero it..."" - weak to fair signal - portable radios ""once you get that one done...the paperwork is already on the table"" " 462.5625 77.0 Hz FRS 01 Spanish language chatter - probably related to crane control based on previous loggings of this frequency and CTCSS tone combination 466.3125 156.7 Hz Construction site comms and crane control - mixture of Spanish and English 462.7250 252 DCS FRS 22 """okay I see you"" ""I'll run a piece of wire up to the 4th level...and that wire will connect to...."" ""right, I'll get it from the electrician"" " 151.5125 136.5 Hz Crane control 467.6625 67.0 Hz FRS 12 Elevator floor requests - usual traffic heard on this frequency and CTCSS tone combination 457.5250 315 DCS Local school - portable radios - used by teachers and also maintenance staff and facilities management staff 469.5500 732 DCS Talking about supply delivery 467.7125 107.2 Hz FRS 14 "Tail end of a FRS transmission with the usual Motorola ""Roger Beep""" 462.6750 606 DCS FRS 20 Retail comms - warehouse and inventory as well as customer service related chatter 158.4075 065 DCS FLIGHTCOM dispatch morning radio checks 462.5750 114.8 Hz FRS 16 Spanish language 151.6250 025 DCS Red Dot """warehouse 3, ready to go...warehouse 3..."" " 466.0875 506 DCS "Crane control - ""trolley out"" ""cable down..."" ""hold your cable"" - etc..." 464.5500 627 DCS Yellow Dot Construction site / work site comms - primary channel 469.5000 205 DCS Construction site related comms - fair to good signal 462.5250 114.8 Hz Local day care - coordinating location of teachers, classes, etc. - must be very local due to strong signal strength 151.6250 065 DCS Red Dot FLIGHTCOM working AIRCARE EAGLE - dispatch to scenes and radio checks 462.5875 71.9 Hz FRS 02 Crane control - fair to weak signals...mixture of Spanish and English and Spanglish 467.6625 053 DCS FRS 12 Local school - previously monitored using this frequency channel and DCS code combination 467.8500 179.9 Hz Silver Star Hotel or hospitality - portable radios 466.0875 97.4 Hz Construction site coordination comms 462.6125 141.3 Hz FRS 03 Spanish language chatter - possibly also construction site or work site related...FRS radios - noted tell-tale FRS-style Roger Beeps in use 464.5000 179.9 Hz Brown Dot Engineering or facilities maintenance - fair to weak signals, portable radios 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations 461.2625 67.0 Hz Hotel or hospitality operations 464.8250 026 DCS Crane control - usual users of this frequency - simplex portable radios 151.6250 167.9 Hz Red Dot Truck to truck comms - likely Crane Master - confirmed user of this frequency and CTCSS tone combination...good signals, likely from high-power mobile radios...crane service company figuring out how to get to job site 461.1875 023 DCS Construction site materials delivery coordination - concrete and possibly other materials - portable radios 462.6875 141.3 Hz FRS 06 Local school - possibly alternate or secondary frequency - very local, very strong signals 464.5500 546 DCS Yellow Dot Spanish language - fair to good signal 154.5700 371 DCS MURS 4 Crane control and construction site coordination comms 461.2125 67.0 Hz Hotel or hospitality operations 462.6750 136.5 Hz FRS 20 "School - heard reference to ""8th grade"" - fair to good signal - sporadic interference from retail and warehouse comms on same frequency / channel " 462.9125 192.8 Hz Crane control and coordination 151.6250 77.0 Hz Red Dot """pick up on...."" [faded away] - sounds like it could be tower crane or service elevator floor requests - heard ""level 8"" a couple times later as well " 467.8750 229.1 Hz Gold Star Crane control and coordination 461.1625 67.0 Hz Hotel or hospitality operations 462.7250 136.5 Hz FRS 22 Local school - primary channel - very local school 469.5500 165 DCS Elevator floor requests - fair to poor signal strength 466.3125 023 DCS RMC Events - parking and traffic control 462.5625 67.0 Hz FRS 01 Sounds like another crane control or tower crane operations channel...some interference from other user or users on same frequency 466.3625 023 DCS RMC Events - parking and traffic control 462.5875 023 DCS FRS 02 "Engineering crew or RF engineers - talking about ""dishes"" - testing signal strength for different links, probably part of a fixed point-to-point data link or telemetry system...or a WLAN or WiFi system...could be SATCOM also, not 100% sure " 467.6875 103.5 Hz FRS 13 """bring those lines back"" ""okay I'll call you on [unreadable]""" 467.8500 67.0 Hz Silver Star "Retail operations - heard mention of ""bread"" ""customer had a question about wine"" " 466.2625 023 DCS RMC Events - parking and traffic control - appears to be primary channel 5/25/2021 464.5500 627 DCS Yellow Dot Construction site command channel - coordinating several different activities at a job site / construction site - often a very active channel 466.0875 506 DCS Crane control and construction site comms 151.8200 103.5 Hz MURS 1 "Same users previously heard on this channel / CTCSS tone - heard ""okay...okay keep it right there buddy"" - fair signals, as to be expected with VHF handheld radios / MURS handheld walkie talkies " 461.2125 67.0 Hz Hotel or hospitality operations 457.5250 315 DCS Local school 158.4075 065 DCS FLIGHTCOM dispatch 467.6625 053 DCS FRS 12 School - daily operations 469.5500 165 DCS Service elevator floor requests - pickup and drop off requests 469.5000 205 DCS """13, that's correct"" - possibly also elevator pick up requests " 466.3125 156.7 Hz Construction operations - often very active but with long periods of inactivity between spurts of activity - English and Spanish heard 462.6750 136.5 Hz FRS 20 School - middle or high school (possibly) - coordinating lunch schedules, teacher to teacher chatter... 467.6625 67.0 Hz FRS 12 Elevator floor requests - pick up and drop off 464.5000 77.0 Hz Brown Dot Security or facilities management - suffering very heavy interference from GPS RTK data bursts on same frequency 151.6250 065 DCS Red Dot FLIGHTCOM working AIRCARE EAGLE 461.3625 244 DCS Spanish language - sporadic signals 462.7250 77.0 Hz FRS 22 UNID user - very faint signals, was able to decode CTCSS tone in use 469.5500 205 DCS Talking about checking connections on different floors / levels - some interference from other users on frequency 151.5125 136.5 Hz Crane control 462.6750 606 DCS FRS 20 Retail use - some interference from the school on the same channel / frequency 151.6250 167.9 Hz Red Dot Crane Master truck to truck and truck to handheld comms - good strong signals heard 462.6125 141.3 Hz FRS 03 """we need to talk to the captain"" ""okay"" " 462.5500 CSQ FRS 15 """it was supposed to be cut"" ""that is gonna show that it isn't going to work..."" ""I'll call down when I'm ready to send some stuff down"" - unique FRS Roger Beep heard - no CTCSS or DCS in use, appears to be 100% carrier squelch / CSQ " 467.8750 229.1 Hz Gold Dot Crane control and coordination 154.5275 065 DCS FLIGHTCOM dispatcher working medevac helicopter aircraft 462.5625 67.0 Hz FRS 01 Crane control - fair, but readable, signals - possibly same group previously monitored 462.7000 CSQ FRS 21 """three seven"" - other, unreadable transmissions heard...no CTCSS or DCS tone or code decoded...appears to be another carrier squelch FRS net " 461.2625 244 DCS """Charlie side"" ""okay right there"" " 462.8875 88.5 Hz Crane control - portable radios - Spanish and English 154.5700 371 DCS MURS 4 Crane control and construction comms 469.5500 114.8 Hz Crane control and coordination 466.0875 97.4 Hz Construction site / job site comms 462.8625 88.5 Hz Crane control - portable radios - Spanish and English 461.3625 023 DCS RMC Events - secondary - parking and traffic control 462.7250 136.5 Hz FRS 22 Local school - primary channel - very local school 466.2625 023 DCS RMC Events - primary channel - parking and traffic control 462.9125 192.8 Hz Crane control and crane coordination 5/26/2021 469.5500 165 DCS """alright 10-4...I'll get those out of here..."" ""even Richard said that's impossible"" ""once we're done with that we're gonna put pit dirt on top of it"" ""well, we can't say we didn't go far enough...we undercut what they asked us to undercut""" 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations 462.8625 88.5 Hz Crane control, heard about 10 seconds of somebody keying their mic down...could hear Spanish chatter and banging / construction noises in the background during the key down 467.6625 67.0 Hz FRS 12 Elevator floor pickup requests 464.5500 627 DCS Yellow Dot Coordinating outriggers, beam locations...usual traffic here 462.9125 192.8 Hz Crane control and coordination - including some informal chatter, sometimes *very* informal 151.8200 103.5 Hz MURS 1 """do you know where the tow cutter is?"" " 469.5000 732 DCS Construction and crane control - weak/fair signals 466.3125 156.7 Hz Active, as usual, with Spanish and English construction site comms 469.5000 205 DCS Elevator floor pick up and drop off requests - or equipment / supply requests for different levels / floors 151.6250 065 DCS Red Dot Tone burst followed by alternating tones - FLIGHTCOM calling AIRCARE EAGLE for morning radio check - both stations loud and clear good radio check at 8:25AM 457.5250 315 DCS Local school 469.5500 114.8 Hz Crane coordination - same voices heard here as on the other commonly heard (basically daily) crane coordination channels 462.7000 CSQ FRS 21 Caught a couple very weak transmissions 469.5000 165 DCS Construction site comms 462.5250 114.8 Hz "Local day care or school - ""...shoes and Brady needs a mask...""" 464.5000 346 DCS Brown Dot """in 0.3 miles you'll take a right"" ""copy that"" ""obviously, Hunter, you're gonna want to watch out for buses coming up behind you...."" ""okay you're clear homie"" " 462.6125 141.3 Hz FRS 03 Carrier - no modulation or voice heard, this CTCSS tone previously noted on this frequency, active users somewhere in this general area 466.0875 506 DCS Construction site comms - sporadic signals 151.6250 77.0 Hz Red Dot """level 2 please! level 2..."" " 462.6750 136.5 Hz FRS 20 School - middle or high school (possibly) - coordinating lunch schedules, teacher to teacher chatter... 469.5500 732 DCS "Elevator requests - heard ""12 going down"" - busy frequency " 151.6250 145 DCS Red Dot Construction site comms - portable radios 467.6875 445 DCS FRS 13 """bring it down nice and easy"" - probably also crane control " 464.8250 026 DCS Crane control - simplex 464.5000 506 DCS Brown Dot "Weak(er) signals - DCS tone noted in use ""under"" stronger signals on this frequency " 462.5875 77.0 Hz FRS 02 FRS call tone / alert tones heard...no voice transmissions though 461.2625 244 DCS Crane control 464.5000 67.0 Hz Brown Dot Very weak signals - was able to decode CTCSS code tone in use 464.5500 754 DCS Yellow Dot """level 2"" " 151.5050 145 DCS Construction - possibly related to materials delivery 462.6750 606 DCS FRS 20 Retail and warehouse use 462.5750 115 DCS FRS 16 """man, he can also come back up here...."" " 154.6000 114 DCS MURS 5 """check section 2"" ""students"" - possibly a school or similar " 467.9000 100.0 Hz Red Star Caught the tail end of a transmission 462.5625 CSQ FRS 01 Vehicles caravanning - car to car chatter with Motorola FRS Roger Beeps - no CTCSS or DCS in use 151.5125 136.5 Hz Crane control 467.5625 243 DCS FRS 08 """okay send it back up"" ""20 more feet...20 more feet"" ""good...looking good""" 462.5500 073 DCS FRS 15 """check 15...check one five, over"" ""okay""" 464.5500 156.7 Hz Yellow Dot "Security - heard ""unit 21"" ""unit 26"" and other two-digit mobile numbers - very good signals - possibly mobile radios " 461.1875 073 DCS Crane control or construction site control communications - weak to fair signals 151.6250 167.9 Hz Red Dot Crane Master truck to truck - talking about exits on I-64 - very strong signals from high power mobile radios 462.6250 127.3 Hz FRS 18 """Meg"" and another unidentified female speaker, heard reference to ""channel 6"" - indicating that they are likely using Baofeng or Retevis walkie talkie radios " 467.8500 054 DCS Silver Star "Heard ""office"" clearly - maybe some sort of faculties management, security or other office building or maybe hotel or hospitality type business or organization " 462.5875 CSQ FRS 02 """wanna get out...."" [faded away] - no CTCSS tone or DCS code noted in use " 151.9550 77.0 Hz Purple Dot Elevator floor pick up requests - weak to fair signal 158.4075 065 DCS FLIGHTCOM working LIFE EVAC 1 medevac helicopter 461.1875 023 DCS Concrete delivery coordination 462.5750 654 DCS FRS 16 "Caught a couple short transmissions, sounded like Spanish language....no FRS ""Roger Beeps"" noted " 462.7250 136.5 Hz FRS 22 Local school - primary channel - very local school 5/27/2021 469.5000 205 DCS Construction site materials or equipment delivery and coordination 151.5125 136.5 Hz Crane control 462.5250 114.8 Hz Local school or day care - portables, must be pretty local 464.5000 162.2 Hz Brown Dot """did [unreadable] and Willie ever make it back?"" ""hey Charlie, did you copy my last?""" 469.5500 732 DCS Supply drop off requests - elevator pick up floor requests and drop off requests 464.8250 026 DCS Crane control 151.6250 77.0 Hz Red Dot Elevator floor requests - could hear telephone ringing or another type of alarm or alert tone in background at beginning of transmission 469.5500 165 DCS """is he on this channel?"" ""okay take it back..."" ""take it back..."" ""get that bell"" ""looks like they might have...possibly broken the....uh....yeah, you see the cast iron piece? yeah the bottom of it"" " 467.6625 67.0 Hz FRS 12 Elevator floor pickup requests 151.9400 110.9 Hz MURS 3 """okay standby guys...."" " 464.5500 627 DCS Yellow Dot Construction site coordination - primary channel or command channel - talking about water bottles and other supplies 462.7125 159.8 Hz FRS 07 Same group usually heard on this frequency channel and CTCSS tone...downtown building or facilities management or security, possibly also related to parking garage operations 466.3125 156.7 Hz Construction comms - mixture of English and Spanish 469.5500 506 DCS Construction site comms 462.8625 88.5 Hz Crane control / crane coordination 154.5700 371 DCS MURS 4 Crane control and construction comms - some informal chatter as well 462.5875 97.4 Hz FRS 02 Spanish language, heard construction noises in background 469.5000 165 DCS Sporadic signal, presumed to also be construction related 462.6250 118.8 Hz FRS 18 """...back here..."" ""okay"" " 462.7250 67.0 Hz FRS 22 Faint signal heard, Spanish language traffic 464.5500 162.2 Hz Yellow Dot "Construction comms - heard mention of ""Charlie"" - probably the same guys monitored using the same CTCSS tone earlier today " 462.7000 141.3 Hz FRS 21 possibly car to car type comms? faded in rapidly and then faded out just as quickly, characteristic of high-speed mobile to mobile type comms, probably handheld walkie talkies inside vehicles 466.0875 506 DCS Construction site comms 451.8000 754 DCS Crane control / construction site coordination type comms 469.5500 114.8 Hz Crane coordination and informal chatter 462.6750 606 DCS FRS 20 Retail and warehouse comms 158.4075 065 DCS FLIGHTCOM dispatch working helicopters 462.7250 252 DCS FRS 22 """coming down!"" - construction related comms, probably connected with tower crane control - heard ""6th floor"" and other level or floor designations " 462.6750 136.5 Hz FRS 20 "School - heard reference to ""6th grade"" and ""8th grade"" - very active during mid-afternoon " 464.5000 165 DCS Brown Dot """is he gonna come down and meet us or what's the deal?""" 462.7125 CSQ FRS 07 """Tyler...Tossinglight?"" ""Tyler...."" ""okay got it"" - with FRS Roger Beeps, probably Midland or Cobra brand FRS handhelds " 457.5250 315 DCS Local school 469.5500 205 DCS Construction site materials or equipment delivery and coordination 462.5625 77.0 Hz FRS 01 Spanish language - probably construction site related communications, previously logged on same frequency channel and CTCSS tone 469.5500 743 DCS Spanish language chatter 151.6250 065 DCS Red Dot AIRCARE EAGLE working FLIGHTCOM 462.6250 127.3 Hz FRS 18 Catering company or hospitality business comms? portable low power radios 467.8750 229.1 Hz Gold Star Crane control / crane coordination 461.1625 67.0 Hz Hotel / hospitality comms 462.5875 77.0 Hz FRS 02 Crane control and construction site related comms 466.0875 97.4 Hz Weak to fair signal heard, no modulation (voice) 462.9125 192.8 Hz Crane control / crane coordination 464.5500 754 DCS Yellow Dot """come up...okay come up...."" ""I gotta set it on the landing, we can't have this rope rubbing on the pedestal"" " 462.7250 136.5 Hz FRS 22 Local school - very local, extremely strong signals...stronger than all other traffic on frequency....very active in the 3:00 to 5:00 or so range
