High Frequency Beacon
Revision as of 07:56, 6 October 2010 by Strange Attractor (Talk | contribs)
High Frequency Beacon is a colloquial term for an unlicensed radio beacon that does not follow government regulations for operation (such as Part 15), and is technically illegal.
Freq (kHz) Station ID Location Operation Notes
3450 OK OK
4077.27 MO Oklahoma Solar 200 mW 118ft end fed wire 24/7
4094.8 W. Virginia Dasher Sputnick - 60 dash/min, night only Reported off air September 2009 due to lack of QSLs
4096 ......_ 6 dots 1 dash
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie')
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie')
4097.2 Dasher Inyo County, Calif. near DVNP 55 dashes per minute with chirp when sun is low; day-only, at 5300 ft. elevation ('Inyo-whooper'), inv. vee., 0.5w
5484 SD San Diego, CA
5499.13 WA Dasher
6626.2 S Inyo COunty, Calif. near DVNP About 60-200 dashes per min., sun-only, ~200 mW ('Rocky')
6815 SV1TEST presumably in Greece no further info. (Source: UDXF)
6852 PRV Preveza, Greece 15 W Op: SW2HMU & SV1BJW (Source: UDXF) [1]
6994.8 - UK "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS
RRR RRR RRR REPORTS TO UKBEACON _ GMAIL.COM"
8001.5 S S.W. Arizona sun-only, 1 watt. strong signal daytimes
8188.7 W Colorado Solar/battery 100 mW dipole daylight /7 Location: Colorado
8211.7 OR
10236.7 FL Dasher
14400.3 UFO Colorado
External Links
