High Frequency Beacon
Revision as of 17:47, 21 January 2011 by Strange Attractor (Talk | contribs)
Freq (kHz) Station ID Location Operation Notes
3450 OK OK (Youtube video)
4096 ......_ VA 6 dots 1 dash
4096.25 Dasher Joshua Tree N.P. 1 sec dash (about 30 per min.), 400 mW to inverted vee, 24/7 ('Hexie')
4096.6 Dasher Mojave Nat. Preserve 2 sec. dash (about 16 per minute) 400 mW to inverted vee, 24/7 ('Kelsie')
4097.2 Dasher Inyo County, CA
near DVNP
5484 SD San Diego, CA
5499.13 WA Dasher
6626.2 S Inyo County, CA,
near DVNP
6815 SV1TEST presumably in Greece no further info. (Source: UDXF)
6852 PRV Preveza, Greece 15 W Op: SW2HMU (Source: UDXF) [1]. Defunct?
6994.8 - Norfolk, UK "RRR RRR RRR UK BEACON PROJECT 0.8E 52.8N 0.1 WATTS
8001.5 S S.W. Arizona sun-only, 1 watt. strong signal daytimes
8188.7 W Colorado Solar/battery 100 mW dipole daylight /7 Location: Colorado
8211.7 OR
8350 Dasher North Carolina
10236.7 FL Dasher
14400.3 UFO Colorado
External Links
