Fishnet beacon
Revision as of 18:40, 11 October 2011 by ChrisSmolinski (Talk | contribs)
Fishnet beacons, also known as Drift Nets and Fishing Buoy Transmitters, are low power transmitters which periodically send CW identifiers followed by a carrier. The average repetition rate is about 4 minutes. They are battery powered and use fairly small and inefficient antenna, however they can be heard for hundreds or even thousands of miles. Fishnet beacons are can be found between 1.6 and 4 MHz, and are most often found in and above the 160-meter amateur radio band. They are typically used by fishermen to locate nets, hence the name.
Typical transmit power is in the 3 to 10 watt range. Radio Buoys
| 1715 CB8 |
| 1720 92S115 |
| 1722 93W113 |
| 1730 CF3 |
| 1730 IC514 |
| 1750 PR30 |
| 1752 IC518 |
| 1753 RZ6 |
| 1753 4LJS |
| 1753 4PDU |
| 1761 KW109 |
| 1764 4LJP |
| 1772 4PEC |
| 1776 4OWO |
| 1782 VP2 |
| 1787 97W107 |
| 1792 SG5 |
| 1795 CF9 |
| 1802 PK1 |
| 1812 VH7 |
| 1813 EY9 |
| 1839 4BOB |
| 1856 DA2 |
| 1856 4MSZ |
| 1881 4BNZ |
| 1883 5AJW |
| 1884 CK1 |
| 1894 4OUS |
| 1894 4LKO |
| 1894 4LID |
| 1912 DS89 |
| 1918 IO82 |
| 1942 IC526 |
| 1942 PS3 |
| 1948 4QJA |
| 1953 QU7 |
| 1962 4IGW |
| 1962 RZ6 |
| 1970 4PFK |
| 1972 AB8 |
| 1977 4CMV |
| 1982 HU5E |
| 1988 JE1 |
| 1989 AY7 |
| 1993 4OMZ |
| 1998 4DQX |
| 2003 4JSP |
| 2019 4HVX |
| 2020 BM3 |
| 2041 4CEF |
