HF pagers
Revision as of 16:18, 5 July 2018 by R4002 (Talk | contribs)
Frequency Remarks
26.200 MHz UK Paging on-site pager
26.590 MHz UK Paging on-site, non-hospital use
26.815 MHz UK Paging on-site pager
26.975 MHz UK data frequency, UK low-power R/C telemetry (100 mw limit)
27.075 MHz UK data frequency, UK low-power R/C telemetry (100 mw limit)
27.120 MHz ISM center frequency 27120 kHz +/- 163 kHz, often used for Part 15 devices (26.957 to 27.283 MHz)
27.137 MHz New Zealand channel RP7A on-site paging POCSAG
27.162 MHz New Zealand channel RP8A on-site paging POCSAG
27.187 MHz New Zealand channel RP9A on-site paging POCSAG
27.212 MHz New Zealand channel RP10A on-site paging POCSAG
27.225 MHz UK data frequency, UK low-power R/C telemetry (100 mw limit)
27.237 MHz New Zealand channel RP11A on-site paging POCSAG
27.245 MHz UK data frequency, UK low-power R/C telemetry (100 mw limit)
27.255 MHz Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode
27.262 MHz New Zealand channel RP12A on-site paging POCSAG
27.275 MHz UK data frequency, UK low-power R/C telemetry (100 mw limit)
27.412 MHz Republic of Korea / South Korea on-site paging frequency allocation (offset frequency)
27.422 MHz Republic of Korea / South Korea on-site paging frequency allocation (offset frequency)
27.510 MHz Paging, German allocation pager 27 MHz
27.650 MHz Data link (US East Coast based), possibly US military
