HF marine
Revision as of 16:17, 23 January 2019 by R4002 (Talk | contribs)
See also: VHF marine band
Band Frequency Range
405-525 kHz MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz (600 meters) was the original CW Morse code calling frequency
2450-2850 kHz MF 2 MHz marine band
4000-4063 kHz 4 MHz fixed/mobile band, shared with marine for simplex purposes
8000-8195 kHz 8 MHz fixed/mobile band, shared with marine for simplex purposes
16460-17360 kHz HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz
25070-25121 kHz HF 25 MHz marine band
26145-26175 kHz HF 26 MHz marine band
26175-28000 kHz Various CB-like marine allocations found in this region (many HF-marine radios stop at 27500 kHz or 27.5 MHz)
SEA 209 2/4/6/8 MHz MF-SSB/HF-SSB marine transceiver
