HF marine
See also: VHF marine band
| Band | Frequency Range |
| 405-525 kHz | MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz (600 meters) was the original CW Morse code calling frequency |
| 2450-2850 kHz | MF 2 MHz marine band |
| 4000-4063 kHz | 4 MHz fixed/mobile band, shared with marine for simplex purposes |
| 8000-8195 kHz | 8 MHz fixed/mobile band, shared with marine for simplex purposes |
| 16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 26175-28000 kHz | Various CB-like marine allocations found in this region (many HF-marine radios stop at 27500 kHz or 27.5 MHz) |
See also:
- VHF marine band
- 27 MHz Marine CB - 27 Meg Australia marine band
