HF marine
See also: VHF marine band
| Band | Frequency Range |
| 2450-2850 kHz | MF 2 MHz marine band, USB voice and FSK modes, some AM voice heard here in Russia, Eastern Europe and Asia (older-generation trawler radios 2-3 MHz) |
| 16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 26175-30000 kHz | Various CB-like marine allocations found in this region (many SSB marine radios stop at 27500 kHz or 27.5 MHz) |
- 2003.0 kHz
- 2065.0 kHz
- 2079.0 kHz
- 2082.5 kHz
- 2086.0 kHz
- 2093.0 kHz
- 2096.5 kHz
- 2142.0 kHz
- 2203.0 kHz
- 2214.0 kHz
- 2635.0 kHz
- 2638.0 kHz
- 2738.0 kHz
- 2782.0 kHz
- 2830.0 kHz
- 4146.0 kHz
- 4149.0 kHz
- 4417.0 kHz
- 6224.0 kHz
- 6227.0 kHz
- 6230.0 kHz
- 6516.0 kHz
- 8294.0 kHz
- 8297.0 kHz
- 12353.0 kHz
- 12356.0 kHz
- 12359.0 kHz
- 12362.0 kHz
- 12365.0 kHz
- 16528.0 kHz
- 16531.0 kHz
- 16534.0 kHz
- 16537.0 kHz
- 16540.0 kHz
- 16543.0 kHz
- 16546.0 kHz
- 18825.0 kHz
- 18828.0 kHz
- 18831.0 kHz
- 18834.0 kHz
- 18837.0 kHz
- 18840.0 kHz
- 18843.0 kHz
- 22159.0 kHz
- 22162.0 kHz
- 22165.0 kHz
- 22168.0 kHz
- 22171.0 kHz
- 22174.0 kHz
- 22177.0 kHz
- 25100.0 kHz
- 25103.0 kHz
- 25106.0 kHz
- 25109.0 kHz
- 25112.0 kHz
- 25115.0 kHz
- 25118.0 kHz
| ITU Channel | Ship Transmit / Coast Receive | Coast Transmit / Ship Receive |
| 401 | 4065 kHz | 4357 kHz |
| 402 | 4068 kHz | 4360 kHz |
| 403 | 4065 kHz | 4357 kHz |
| 404 | 4065 kHz | 4357 kHz |
| 405 | 4065 kHz | 4357 kHz |
| 406 | 4065 kHz | 4357 kHz |
| 407 | 4065 kHz | 4357 kHz |
| 408 | 4065 kHz | 4357 kHz |
| 409 | 4065 kHz | 4357 kHz |
| 410 | 4065 kHz | 4357 kHz |
| 411 | 4065 kHz | 4357 kHz |
| 412 | 4065 kHz | 4357 kHz |
| 413 | 4065 kHz | 4357 kHz |
| 414 | 4065 kHz | 4357 kHz |
| 415 | 4065 kHz | 4357 kHz |
| 416 | 4065 kHz | 4357 kHz |
| 417 | 4065 kHz | 4357 kHz |
| 418 | 4065 kHz | 4357 kHz |
| 419 | 4065 kHz | 4357 kHz |
| 420 | 4065 kHz | 4357 kHz |
| 421 | 4065 kHz | 4357 kHz |
| 422 | 4065 kHz | 4357 kHz |
| 423 | 4065 kHz | 4357 kHz |
| 424 | 4065 kHz | 4357 kHz |
| 425 | 4065 kHz | 4357 kHz |
| 426 | 4065 kHz | 4357 kHz |
| 427 | 4065 kHz | 4357 kHz |
| 428 | 4065 kHz | 4357 kHz |
| 429 | 4065 kHz | 4357 kHz |
See also:
- VHF marine band
- Maritime Fax Transmissions
