PMR446
Channel | Freq MHz |
1 | 446.00625 |
2 | 446.01875 |
3 | 446.03125 |
4 | 446.04375 |
5 | 446.05625 |
6 | 446.06875 |
7 | 446.08125 |
8 | 446.09375 |
9 | 446.10625 |
10 | 446.11875 |
11 | 446.13125 |
12 | 446.14375 |
13 | 446.15625 |
14 | 446.16875 |
15 | 446.18125 |
16 | 446.19375 |
Digital FDMA
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital DPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
1 | 446.003125 |
2 | 446.009375 |
3 | 446.015625 |
4 | 446.021875 |
5 | 446.028125 |
6 | 446.034375 |
7 | 446.040625 |
8 | 446.046875 |
9 | 446.053125 |
10 | 446.059375 |
11 | 446.065625 |
12 | 446.071875 |
13 | 446.078125 |
14 | 446.084375 |
15 | 446.090625 |
16 | 446.096875 |
17 | 446.103125 |
18 | 446.109375 |
19 | 446.115625 |
20 | 446.121875 |
21 | 446.128125 |
22 | 446.134375 |
23 | 446.140625 |
24 | 446.146875 |
25 | 446.153125 |
26 | 446.159375 |
27 | 446.165625 |
28 | 446.171875 |
29 | 446.178125 |
30 | 446.184375 |
31 | 446.190625 |
32 | 446.196875 |
Authorized PMR446 Countries
- 446.006250 MHz - Analog FM or wideband digital channel 1
- 446.015625
- 446.018750 Analog FM or wideband digital channel 2
- 446.021875
- 446.028125
- 446.031250 Analog FM or wideband digital channel 3
- 446.034375
- 446.040625
- 446.043750 Analog FM or wideband digital channel 4
- 446.046875
- 446.053125
- 446.056250 Analog FM or wideband digital channel 5
- 446.059375
- 446.065625
- 446.068750 Analog FM or wideband digital channel 6
- 446.071875
- 446.078125
- 446.081250 Analog FM or wideband digital channel 7
- 446.084375
- 446.090625
- 446.093750 Analog FM or wideband digital channel 8
- 446.096875
- 446.103125
- 446.106250 Analog FM or wideband digital channel 9
- 446.109375
- 446.115625
- 446.118750 Analog FM or wideband digital channel 10
- 446.121875
- 446.128125
- 446.131250 Analog FM or wideband digital channel 11
- 446.134375
- 446.140625
- 446.143750 Analog FM or wideband digital channel 12
- 446.146875
- 446.153125
- 446.156250 Analog FM or wideband digital channel 13
- 446.159375
- 446.165625
- 446.168750 Analog FM or wideband digital channel 14
- 446.171875
- 446.178125
- 446.181250 Analog FM or wideband digital channel 15
- 446.184375
- 446.190625
- 446.193750 Analog FM or wideband digital channel 16
- 446.196875
