Cordless telephone
placeholder for additional info later
Frequencies
- Base Frequency 46.610 MHz - Handset Frequency 49.670 MHz
- Base Frequency 46.630 MHz - Handset Frequency 49.845 MHz
- Base Frequency 46.670 MHz - Handset Frequency 49.860 MHz
- Base Frequency 46.710 MHz - Handset Frequency 49.770 MHz
- Base Frequency 46.730 MHz - Handset Frequency 49.875 MHz
- Base Frequency 46.770 MHz - Handset Frequency 49.830 MHz
- Base Frequency 46.830 MHz - Handset Frequency 49.890 MHz
- Base Frequency 46.870 MHz - Handset Frequency 49.930 MHz
- Base Frequency 46.930 MHz - Handset Frequency 49.990 MHz
- Base Frequency 46.970 MHz - Handset Frequency 49.970 MHz
The "49 MHz" cordless phones were rapidly adopted by consumers, resulting in heavy frequency congestion. The 49.830-49.890 MHz frequencies were and still are heavily used by other devices including baby monitors in continuous transmit mode. 15 frequencies were added bringing the total number of channels to 25.
The FCC quickly moved to authorize additional frequency space for cordless phones. With the 900 MHz ISM band 902-928 MHz becoming available next. 900 MHz cordless phones are still used today. Analog FM, digital voice and various frequency hopping spread-spectrum or FHSS cordless phones became available for the 900MHz band. If FHSS technology is used, base stations may transmit up to 1 watt ERP. This increase in transmitter power combined with the interference rejection capabilities of spread spectrum gave the higher-end 900 MHz cordless phones significant range. Unlike the older-generation models, 900 MHz cordless telephones never had a standardized channel plan or base and handset frequency pair or channel plan. This meant that manufacturers simply created their own, with widely differing channel steps, number of channels and other options. Even cheap analog FM 900 MHz cordless phones usually featured automatic channel selection. In other words, if the first channel pair was busy the system simply switched to the next clear channel. This same technology was (and is) included in digital voice cordless telephones operating in the 900 MHz band, the 2.4 GHz band and the 5.8 GHz band as well as those using modern DECT technology.
The 2.4 GHz band became available shortly after 900 MHz and originally provided excellent results. However, the proliferation of devices operating in the 2.4 GHz band now means that 2.4GHz cordless phones often suffer from (or cause) interference and/or have reduced range compared to the other bands. The 5.8 GHz allocation was opened up to alleviate the congestion on 2.4 GHz. Many 5.8 GHz band cordless phones are sold today. Some "5.8 GHz" phones are actually cross-band and use 5.8 GHz for handset to base but use 900 MHz or 2.4 GHz for base-to-handset.
- Base Frequency: 1642 kHz 1.642 MHz - Handset Frequency: 47.45625 MHz - Channel 1
- Base Frequency: 1662 kHz 1.662 MHz - Handset Frequency: 47.46875 MHz - Channel 2
- Base Frequency: 1682 kHz 1.682 MHz - Handset Frequency: 47.48125 MHz - Channel 3
- Base Frequency: 1702 kHz 1.702 MHz - Handset Frequency: 47.49375 MHz - Channel 4
- Base Frequency: 1722 kHz 1.722 MHz - Handset Frequency: 47.50625 MHz - Channel 5
- Base Frequency: 1742 kHz 1.742 MHz - Handset Frequency: 47.51875 MHz - Channel 6
- Base Frequency: 1762 kHz 1.762 MHz - Handset Frequency: 47.53125 MHz or 47.44375 MHz - Channel 7
- Base Frequency: 1782 kHz 1.782 MHz - Handset Frequency: 47.54375 MHz - Channel 8
CT0 - UK Specification CT0 Extended - Long Range 100mW power output
- Base Frequency: 47.43125 MHz - Handset Frequency: 77.5125 MHz
- Base Frequency: 47.41875 MHz - Handset Frequency: 77.5000 MHz
CT0 - UK Specification CT0 - Current Allocation - 10mW power output, FM mode
- Base Frequency: 31.0625 MHz - Handset Frequency: 39.9375 MHz - Channel 1
- Base Frequency: 31.0875 MHz - Handset Frequency: 39.9625 MHz - Channel 2
- Base Frequency: 31.1125 MHz - Handset Frequency: 39.9875 MHz - Channel 3
- Base Frequency: 31.2125 MHz - Handset Frequency: 40.1125 MHz - Channel 8
