High Frequency Beacon
Revision as of 20:29, 14 October 2008 by ChrisSmolinski (Talk | contribs)
2097 A Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 (not on air July 08 - needs new battery)
3450 OK OK
4011.8 FL Dasher
4069 WT 300-400 mW Inverted L night time only Location: Colorado
4096 6 dots 1 Dash
4102.3 W... The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the s.e. California desert, it sends lots of dits; and no wind, no dits.
4915 Dasher Sputnick - 60 dash/min, night only Location: West Virginia
5499.13 WA Dasher
7997.7 Dasher Solar/battery dipole 24/7 Location: Colorado "Pike JR"
8211.7 OR
10236.7 FL Dasher
External Links
