High Frequency Beacon
Revision as of 20:12, 27 November 2008 by XtalCW (Talk | contribs)
2097 A Arizona (15 watts) - 'A' ident or malfunctions as series of dits - 15 watts max., 24/7 (not on air July 08 - needs new battery)
3450 OK OK
4011.8 FL Dasher
4078 W 300-400 mW Inverted L night time only Location: Colorado
4094.8 Dasher Sputnick - 60 dash/min, night only Location: West Virginia
4096 6 dots 1 Dash
4102.3 W... The WIND BEACON - sends 'W' ident and series of dits - each dit correlating to a turn of its anenometer, so if it is windy in the s.e. California desert, it sends lots of dits; and no wind, no dits. 4194 MX Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID.
4608 MXC Xtal controlled milliwatt beacon operated occasionally in europe. Sometimes sends straight carrier instead of ID. Sister beacon to MX.
5454 SD San Diego, CA
5499.13 WA Dasher
7997.7 Dasher Solar/battery dipole 24/7 Location: Colorado "Pike JR"
8211.7 OR
10236.7 FL Dasher
External Links
