HF pagers
Revision as of 12:32, 19 October 2018 by R4002 (Talk | contribs)
For information on the RCRS - Remote Control Radio Service in the USA - see the Remote Control FCC Part 95 Class C Page
There is also extensive Part 15 usage of these frequencies for low-power R/C model control. Higher power levels are used by professional grade systems. Most higher-end remote control/radio control devices use the 72 MHz and 75 MHz frequencies (where 0.75 watts is the maximum power output) or the unlicensed 2.4 GHz band. However, there remains considerable use of 26-27 MHz for data link, remote sensor monitoring and other similar purposes due to the high power available for unlicensed users and excellent propagation characteristics for point-to-point data networks.
Frequency Remarks
26.200 MHz UK Paging on-site pager
26.815 MHz UK Paging on-site pager
27.075 MHz UK data frequency, UK low-power R/C "Orange" telemetry (100 mw limit)
27.255 MHz Linear Controls "Xtended Range Wireless" telemetry/control system, 10 watts FSK mode
27.255 MHz RadioShack 7-watt FSK paging system on-site paging system frequency (legal under Part 95 of FCC rules)
27.510 MHz Paging, German allocation pager 27 MHz
27.650 MHz Data link (US East Coast based), possibly US military
Keywords:
26 MHz pager 27MHz paging 27.255 MHz data link 27 MHz data transmitter 27007 kHz 27255 kHz FCC Part 15 Part 95 POCSAG 26.995MHz 27.045MHz 27.095MHz 27.145MHz 27.195MHz 27.225MHz 27.235MHz 27.245MHz 27.255MHz 27.270MHz 27.12 MHz ISM 27MHz band paging Long Range Systems 467.750 MHz
