Part 15
Revision as of 12:44, 19 October 2018 by R4002 (Talk | contribs)
Part 15 is the section of FCC regulations dealing with unlicensed radio operation. Operation in several bands is allowed:
See also: The RC Radio Service, The CB Radio Service, and high power datalink systems that use 26-27 MHz
