HF marine
Fisheries, fishing boats, and other commercial marine users will often use frequencies in the HF aeronautical or aircraft bands (including the 6525 kHz to 6685 kHz R and 6685 kHz to 6765 kHz "OR" or military aircraft 6 MHz subbands 6525 kHz to 6765 kHz), other HF aircraft bands, fixed/mobile band (including 43 meters - 6765-7000 kHz) clear frequencies in the shortwave broadcast bands or even amateur frequencies for "out of band" communications to reduce the chance of radio interception by their competition. Out of band frequencies are also used in other ITU regions for marine fax transmissions.
See also: VHF marine band
| Band | Frequency Range |
| 405-525 kHz | MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz (600 meters) was the original CW Morse code calling frequency |
| 2450-2850 kHz | MF 2 MHz marine band |
| 4000-4063 kHz | 4 MHz fixed/mobile band, shared with marine for simplex purposes |
| 8000-8195 kHz | 8 MHz fixed/mobile band, shared with marine for simplex purposes |
| 16460-17360 kHz | HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz |
| 26175-28000 kHz | Various CB-like marine allocations found in this region (many HF-marine radios stop at 27500 kHz or 27.5 MHz) |
