HF marine
Revision as of 14:24, 15 January 2019 by R4002 (Talk | contribs)
Fisheries, fishing boats, and other commercial marine users will often use frequencies in the HF aeronautical or aircraft bands (including the 6525 kHz to 6685 kHz R and 6685 kHz to 6765 kHz "OR" or military aircraft 6 MHz subbands 6525 kHz to 6765 kHz), other HF aircraft bands, fixed/mobile band (including 43 meters - 6765-7000 kHz) clear frequencies in the shortwave broadcast bands or even amateur frequencies for "out of band" communications to reduce the chance of radio interception by their competition. Out of band frequencies are also used in other ITU regions for marine fax transmissions.
See also: VHF marine band
Band Frequency Range
405-525 kHz MF band, used in some areas for NAVTEX on 490 kHz and/or 518 kHz. 500 kHz (600 meters) was the original CW Morse code calling frequency
2450-2850 kHz MF 2 MHz marine band
4000-4063 kHz 4 MHz fixed/mobile band, shared with marine for simplex purposes
8000-8195 kHz 8 MHz fixed/mobile band, shared with marine for simplex purposes
16460-17360 kHz HF 16 MHz/17 MHz marine band - USB voice calling/distress 16420 kHz, DSC calling/distress 16804.5 kHz
25070-25121 kHz HF 25 MHz marine band
26145-26175 kHz HF 26 MHz marine band
26175-28000 kHz Various CB-like marine allocations found in this region (many HF-marine radios stop at 27500 kHz or 27.5 MHz)
SEA 209 2/4/6/8 MHz MF-SSB/HF-SSB marine transceiver
