VHF LADD
Revision as of 12:43, 26 March 2019 by R4002 (Talk | contribs)
VHF LADD (Logging Administration Dispatch), LD (Loading Channels) RR (Road Resource) channels, standardized for trucking, delivery and use in remote areas for truck-to-truck, truck-to-base and emergency services communications with trucks, loading channels, etc. These frequencies are known by several names, including the Ice Road Channels, Loading Channels, LD channels LAD channels, LADD channels, Resource Road channels, Logging common, VHF trucking channels, Canadian trucking channels and several other combinations of these. In remote areas of Canada, specific sections of roads are assigned specific channels. See this official list:
[1]
While these frequencies were originally intended only for use by logging companies, remote dispatch (think Ice Road Truckers) and other specialized use, the proliferation of inexpensive VHF-FM equipment means their usage has become more widespread. The LADD and RR frequencies are used as an adjunct to CB radio (called General Radio Service in Canada - same frequencies and modes as the USA) in some places, and in others, CB radio is used as an adjunct to the VHF LADD and VHF RR and LD channels. Note that the similar MURS VHF CB frequencies are not permitted in Canada for these purposes. Trucks should still retain regular 27 MHz AM CB radios in addition to a VHF radio with LADD/LD/RR channels programmed into memory.
LADD and Resource Road (RR) Frequencies Channels Canada Trucking VHF List
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
Channel Frequency
LADD 1 154.1000 MHz
LADD 2 158.9400 MHz
LADD 3 154.3250 MHz
LADD 4 173.3700 MHz
LD 1 151.7000 MHz
LD 2 151.7450 MHz
LD 3 151.7900 MHz
LD 4 151.8050 MHz
LD 5 151.8500 MHz
RR-01 150.0800 MHz
RR-02 150.1100 MHz
RR-03 150.1400 MHz
RR-04 150.1850 MHz
RR-05 150.2000 MHz
RR-06 150.2450 MHz
RR-07 150.2600 MHz
RR-08 150.3200 MHz
RR-09 150.3650 MHz
RR-10 150.4100 MHz
RR-11 150.4400 MHz
RR-12 150.5000 MHz
RR-13 150.5300 MHz
RR-14 150.5450 MHz
RR-15 150.5600 MHz
RR-16 150.5900 MHz
RR-17 150.6800 MHz
RR-18 150.7100 MHz
RR-19 150.7700 MHz
RR-20 150.8300 MHz
RR-21 151.0100 MHz
RR-22 151.1300 MHz
RR-23 151.1900 MHz
RR-24 151.2200 MHz
RR-25 151.3100 MHz
RR-26 151.3400 MHz
RR-27 151.3700 MHz
RR-28 151.4300 MHz
RR-29 151.4600 MHz
RR-30 151.4900 MHz
RR-31 151.5200 MHz
RR-32 151.5800 MHz
RR-33 151.6100 MHz
RR-34 151.6400 MHz
RR-35 151.6700 MHz
