Radio beacon
DARC beacons DRA5 and DK0WCY
Radio navigation beacons
There are also marine beacons, based on the same techonlogy and installed at coastal areas, for use by ships at sea.(1) Most of them, especially in the western world, are no longer in service, while some have been converted to telemetry transmitters for differential GPS. Chains of radio navigation beacons for marine use are still active around the Russian and Ukrainian coastline.(2)
NDB technical
Monitoring NDBs
A PFC QSL card from an NDB
The beacons that are between 510 kHz and 530 kHz can sometimes be heard on AM radios that can tune below the beginning of the AM broadcast band. (For example, the "HEH" beacon in Newark, OH at 524 kHz is within the bandwidth of most AM radios, and the "OS" beacon in Columbus, OH at 515 kHz can also be heard on some AM radios). Some beacons can also be heard on 530 kHz, although from the adjacent frequencies such as "LYQ" at 529 kHz in Manchester, TN but for the most part, reception of NDBs requires a radio receiver that can receive frequencies below 530 kHz (the longwave band). Many so-called "shortwave" radios can receive all frequencies from 150 kHz to 30 MHz, which makes them ideal for listening to NDBs. Whilst this type of receiver is adequate for reception of local beacons, specialized techniques (receiver preselectors, noise limiters and filters) are required for the reception of very weak signals from remote beacons.(9)
ILS marker beacons
Radio propagation beacons
See Radio propagation beacon
Single letter HF beacons
See: Letter beacon
Beacons are also used in both geostationary and inclined orbit satellites. Any satellite will emit one or more beacons (normally on fixed frequencies) whose purpose is twofold; as well as containing modulated houskeeping information (telemetry), the beacons are also used to locate the satellite (determine its azimuth and elevation) in the sky. Many satellites transmit two distinct beacons, the general beacon, which transmits limited information in CW or FSK and is used for locating and identifying the satellite and the engineering beacon, which transmits telemetry data in FSK or PSK.
Driftnet buoy radio beacons
Distress radiobeacons
IEEE 802.11 Wi-Fi beacons
In the field of Wi-Fi (wireless local area networks using the IEEE 802.11b and 802.11g specification), the term beacon signifies a specific data transmission from the wireless access point (AP), which carries the SSID, the channel number and security protocols such as WEP (Wired Equivalent Protection) or WPA (Wi-Fi Protected Access). This transmission does not contain the link layer address of another Wi-Fi device, therefore it can be received by any LAN client. (6)
AX.25 packet radio beacons
  5. Robert Connolly: "Greyline DXing, Fishing NDBs and NOTAM software", Radio User, 5(6), pages 35–36, ISSN 1748-8117, June 2010.
WP
