VHF airband
Revision as of 14:18, 13 December 2018 by R4002 (Talk | contribs)
Military aircraft retain the capability to transmit and receive on the VHF-AM aircraft band, with US military aircraft radios covering up to 150 MHz in AM mode. Military aircraft also make extensive use of the UHF-AM aircraft band 225-400 MHz, often with ECCM systems such as HAVE QUICK, HAVE QUICK II and SATURN frequency hopping modes. The 225-400 MHz band is also extensively used for SATCOM and other purposes outside the scope of air-to-air communications. 380-400 MHz is shared with land mobile radio systems used by the US military in the United States.
Icom IC-A210E VHF-AM airband transceiver, designed for installation in aircraft, this version of the IC-A210 supports the 8.33 kHz narrowband channel spacing required in Europe. Frequency coverage is 118.000 MHz to 136.975 MHz in 25 kHz or 8.33 kHz steps with 6 watts AM carrier power.
Frequency Purpose/Use
121.500 MHz Emergency Frequency known as Guard, see also 243.0 MHz - UHF Guard
122.900 MHz Common SAR (Search and Rescue) aircraft frequency)
123.100 MHz Common SAR (Search and Rescue) aircraft frequency)
123.450 MHz Unofficial air-to-air pilot chit-chat frequency
123.475 MHz Unofficial air-to-air pilot chit-chat frequency
