Part 15 Beacons
Revision as of 13:40, 11 June 2019 by R4002 (Talk | contribs)
Overview
  • 160 - 190 kHz
  • 49820 - 49900 kHz (49.82 - 49.90 MHz)
160-190 kHz Part 15 Beacons
  • 167.180 LC Sacramento CA
  • 181.818 JH Florence SC
  • 182.448 R Keeler CA
  • 183.500 WD2XFJ Burbank CA
  • 185.100 22A Baraga MI
  • 185.185 SIW Oswego IL
  • 185.290 KT Oswego KS
  • 185.297 TAG Raymond ME
  • 185.299 SIW Oswego IL
  • 185.303 SJ East Haven CT
  • 185.650 WE2XEB Penn Yan NY
  • 186.204 MLS Massilon OH
  • 187.015 J La Crescenta CA
  • 187.507 WI Aiken SC
  • 188.830 EAR Saltford, ON
13560 kHz Part 15 Beacons
  • 13554.000 AZ Oro Valley AZ
  • 13555.414 TAG Holden MA
  • 13555.420 JIM Dallas TX
  • 13555.430 SIW Elgin IL
  • 13555.440 SIW Elgin IL
  • 13555.450 MP London ON
  • 13555.462 EH East Haven CT
  • 13555.472 7P Ajo AZ
  • 13555.500 NC Stanfield NC
  • 13555.528 EDJ Monroe GA
  • 13555.920 WV Richwood, WV
  • 13555.98 TSN
  • 13556.200 HHH CT/MA Border (testing, may not be 24/7)
  • 13556.600 OH Findlay OH
  • 13557.50 PBJ Tracey City TN
  • 13557.800 PLM [UNKNOWN]
  • 13558.2 PVC
  • 13558.510 AJO Ajo AZ
  • 13562.080 NDB
  • 13562.950 SZX Macomb IL
  • 13563.000 RR
  • 13563.55 PCO Colorado
  • 13564.280 T Sun City CA
  • 13562.80 GNK Madison WI
  • 13564.20 RF Grid EM96 NC
  • 13565.04 K6FRC Patterson CA
  • 13566.20 AMA Hamilton ON
Pending beacons:
  • Freq TBD VVV CT/MA Border (Vertical dipole, solar powered)
  • Freq TBD WOO Worcester, MA (Solar powered)
None reported
22 meter band beacon kit
FCC Regulations
160 - 190 kHz
  emissions.
13560 kHz
  meters.
  meters.
  limits in §  15.209.
  device.
26960 - 27280 kHz
See also: Remote Control - 49 MHz R/C Frequencies
(b) The field strength of any emissions appearing between the band edges and up to 10 kHz above and below the band edges shall be attenuated at least 26 dB below the level of the unmodulated carrier or to the general limits in § 15.209, whichever permits the higher emission levels. The field strength of any emissions removed by more than 10 kHz from the band edges shall not exceed the general radiated emission limits in § 15.209. All signals exceeding 20 microvolts/meter at 3 meters shall be reported in the application for certification. (c) For a home-built intentional radiator, as defined in § 15.23(a), operating within the band 49.82-49.90 MHz, the following standards may be employed: (1) The RF carrier and modulation products shall be maintained within the band 49.82-49.90 MHz. (2) The total input power to the device measured at the battery or the power line terminals shall not exceed 100 milliwatts under any condition of modulation. (3) The antenna shall be a single element, one meter or less in length, permanently mounted on the enclosure containing the device. (4) Emissions outside of this band shall be attenuated at least 20 dB below the level of the unmodulated carrier. (5) The regulations contained in § 15.23 of this part apply to intentional radiators constructed under the provisions of this paragraph. (d) Cordless telephones are not permitted to operate under the provisions of this section.
