FRS
Family Radio Service
UHF replacement (or rather supplement) to the CB service. Created in the late 1990s by the FCC after intense lobbying by RadioShack.
Ch | Freq MHz | - Notes - |
1 | 462.5625 | Shared with GMRS - FRS Calling Channel 2 watts maximum TX power |
2 | 462.5875 | Shared with GMRS 2 watts maximum TX power |
3 | 462.6125 | Shared with GMRS 2 watts maximum TX power |
4 | 462.6375 | Shared with GMRS 2 watts maximum TX power |
5 | 462.6625 | Shared with GMRS 2 watts maximum TX power |
6 | 462.6875 | Shared with GMRS 2 watts maximum TX power |
7 | 462.7125 | Shared with GMRS 2 watts maximum TX power |
8 | 467.5625 | FRS only 0.5 watt 500mw maximum TX power |
9 | 467.5875 | FRS only 0.5 watt 500mw maximum TX power |
10 | 467.6125 | FRS only 0.5 watt 500mw maximum TX power |
11 | 467.6375 | FRS only 0.5 watt 500mw maximum TX power |
12 | 467.6625 | FRS only 0.5 watt 500mw maximum TX power |
13 | 467.6875 | FRS only 0.5 watt 500mw maximum TX power |
14 | 467.7125 | FRS only 0.5 watt 500mw maximum TX power |
15 | 462.5500 | Shared with GMRS 2 watts maximum TX power |
16 | 462.5750 | Shared with GMRS 2 watts maximum TX power |
17 | 462.6000 | Shared with GMRS 2 watts maximum TX power |
18 | 462.6250 | Shared with GMRS 2 watts maximum TX power |
19 | 462.6500 | Shared with GMRS 2 watts maximum TX power |
20 | 462.6750 | Shared with GMRS - GMRS Calling Channel 2 watts maximum TX power |
21 | 462.7000 | Shared with GMRS 2 watts maximum TX power |
22 | 462.7250 | Shared with GMRS 2 watts maximum TX power |
- FRS channel 3 (462.6125 MHz) is the recommend "prepper" or emergency preparedness/response channel with MURS channel 3 and CB channel 3 as part of the AmRRON CH3 Project
- FRS channel 1 (462.5625 MHz) is the recommended "calling" frequency, along it is often the busiest calling
- FRS channel 20 (462.6750 MHz) is the recommended GMRS calling/travel channel, with CTCSS or PL tone 141.3 Hz
- Crossband repeaters, patching FRS/GMRS with CB or MURS, is becoming more and more popular. Use of PL tones 156.7 Hz and 167.9 Hz is recommended. use of 67.0 Hz (the default tone for many radios) is not recommended. The GMRS "default" tone is 141.3 Hz.
