- 26.995 MHz - 26995 kHz - Brown or Channel 3A
- 27.045 MHz - 27045 kHz - Red or Channel 7A
- 27.095 MHz - 27095 kHz - Orange or Channel 11A
- 27.145 MHz - 27145 kHz - Yellow or Channel 15A
- 27.195 MHz - 27195 kHz - Green or Channel 19A
- 27.255 MHz - 27255 kHz - Blue (shared with CB channel 23)
- 72.01 MHz
- 72.03 MHz
- 72.05 MHz
- 72.07 MHz
- 72.09 MHz
- 72.11 MHz
- 72.13 MHz
- 72.15 MHz
- 72.17 MHz
- 72.19 MHz
- 72.21 MHz
- 72.23 MHz
- 72.25 MHz
- 72.27 MHz
- 72.29 MHz
- 72.31 MHz
- 72.33 MHz
- 72.35 MHz
- 72.37 MHz
- 72.39 MHz
- 72.41 MHz
- 72.43 MHz
- 72.45 MHz
- 72.47 MHz
- 72.49 MHz
- 72.51 MHz
- 72.53 MHz
- 72.55 MHz
- 72.57 MHz
- 72.59 MHz
- 72.61 MHz
- 72.63 MHz
- 72.65 MHz
- 72.67 MHz
- 72.69 MHz
- 72.71 MHz
- 75.41 MHz
- 75.43 MHz
- 75.45 MHz
- 75.47 MHz
- 75.49 MHz
- 75.51 MHz
- 75.53 MHz
- 75.55 MHz
- 75.57 MHz
- 75.59 MHz
- 75.61 MHz
- 75.63 MHz
- 75.65 MHz
- 75.67 MHz
- 75.69 MHz
- 75.71 MHz
- 75.73 MHz
- 75.75 MHz
- 75.77 MHz
- 75.79 MHz
- 75.81 MHz
- 75.83 MHz
- 75.85 MHz
- 75.87 MHz
- 75.89 MHz
- 75.91 MHz
- 75.93 MHz
- 75.95 MHz
- 75.97 MHz
- 75.99 MHz
- 34.950 MHz - Channel 55
- 34.960 MHz - Channel 56
- 34.970 MHz - Channel 57
- 34.980 MHz - Channel 58
- 34.990 MHz - Channel 59
- 35.000 MHz - Channel 60
- 35.010 MHz - Channel 61
- 35.020 MHz - Channel 62
- 35.030 MHz - Channel 63
- 35.040 MHz - Channel 64
- 35.050 MHz - Channel 65
- 35.060 MHz - Channel 66
- 35.070 MHz - Channel 67
- 35.080 MHz - Channel 68
- 35.090 MHz - Channel 69
- 35.100 MHz - Channel 70
- 35.110 MHz - Channel 71
- 35.120 MHz - Channel 72
- 35.130 MHz - Channel 73
- 35.140 MHz - Channel 74
- 35.150 MHz - Channel 75
- 35.160 MHz - Channel 76
- 35.170 MHz - Channel 77
- 35.180 MHz - Channel 78
- 35.190 MHz - Channel 79
- 35.200 MHz - Channel 80
- 35.210 MHz - Channel 81
- 35.220 MHz - Channel 82
- 35.230 MHz - Channel 83
- 35.240 MHz - Channel 84
- 35.250 MHz - Channel 85
- 35.260 MHz - Channel 86
- 35.270 MHz - Channel 87
- 35.280 MHz - Channel 88
- 35.290 MHz - Channel 89
- 35.300 MHz - Channel 90
- 40.665 MHz - Channel 665
- 40.675 MHz - Channel 675
- 40.685 MHz - Channel 685
- 40.695 MHz - Channel 695
- 40.705 MHz - Channel 705
- 40.715 MHz - Channel 715
- 40.725 MHz - Channel 715
- 40.735 MHz - Channel 735
- 40.745 MHz - Channel 745
- 40.755 MHz - Channel 755
- 40.785 MHz - Channel 785
- 40.795 MHz - Channel 795
- 40.805 MHz - Channel 805
- 40.815 MHz - Channel 815
- 40.825 MHz - Channel 825
- 40.835 MHz - Channel 835
- 40.845 MHz - Channel 845
- 40.855 MHz - Channel 855
- 40.865 MHz - Channel 865
- 40.875 MHz - Channel 875
- 40.885 MHz - Channel 885
- 40.895 MHz - Channel 895
- 40.905 MHz - Channel 905
- 40.915 MHz - Channel 915
- 40.925 MHz - Channel 925
- 40.935 MHz - Channel 935
- 40.945 MHz - Channel 945
- 40.955 MHz - Channel 955
- 40.965 MHz - Channel 965
- 40.975 MHz - Channel 975
- 40.985 MHz - Channel 985
- 40.995 MHz - Channel 995
- 27.095 MHz - 27095 kHz - European CEPT designator A3 - European standardized use for the Eurobalise railroad/train transponder system
- 35 MHz band - placeholder
- 36 MHz band - placeholder
- 40 MHz band - placeholder
- 72 MHz band - placeholder
- 36.010 MHz - RC Channel 601
- 36.590 MHz - RC Channel 659
- 40.665 MHz - RC Channel 50
- 40.675 MHz - RC Channel 51
- 40.685 MHz - RC Channel 52
- 40.695 MHz - RC Channel 53
