Radio beacon
Revision as of 03:27, 20 July 2010 by Strange Attractor (Talk | contribs)
Radio beacons have many applications, including air and sea navigation, propagation research, robotic mapping, radio frequency identification (radio-frequency identification, RFID) and indoor guidance as with real time locating systems (RTLS) like Syledis.
Radio navigation beacons
A most basic aviation radio navigational aid is the NDB or Non-directional Beacon. These are simple low frequency and medium frequency transmitters and they are used to locate airways intersections, airports and to conduct instrument approaches, with the use of a radio direction finder located on the aircraft. The aviation NDBs, especially the ones marking airways intersections, are gradually decommissioned, as they are replaced with other navigational aids based on newer technologies. Due to relatively low purchase, maintenance and calibration cost, they are still used to mark locations of smaller aerodromes and important helicopter landing sites.
There are also marine beacons, based on the same techonlogy and installed at coastal areas, for use by ships at sea.<ref>Template:Cite book</ref> Most of them, especially in the western world, are no longer in service, while some have been converted to telemetry transmitters for differential GPS. Chains of radio navigation beacons for marine use are still active around the Russian and Ukrainian coastline.<ref>Template:Cite journal</ref>
In addition to dedicated radio beacons, any AM, VHF, or UHF radio station at a known location can also be used as a beacon with direction finding equipment.
ILS marker beacons
Template:Main A marker beacon is a specialized beacon used in aviation in conjunction with an instrument landing system (ILS), to give pilots a means to determine distance to the runway. Marker beacons transmit on the dedicated frequency of 75 MHz. This type of beacon is slowly phased-out and most new ILS installations have no marker beacons.
Radio propagation beacons
Template:Main A radio propagation beacon is specifically used to study the propagation of radio signals. Nearly all of them are part of the amateur radio service.
Single letter HF beacons
See: Letter beacon
A group of radio beacons with single-letter identifiers ("C", "D", "M", "S", "P", etc) transmitting in morse code have been regularly reported on various HF frequencies. There is no official information available about these transmitters and they are not registered with the ITU. Some investigators suggest that some of these beacons (the so called "cluster beacons") are actually radio propagation beacons for naval use.
Beacons are also used in both geostationary and inclined orbit satellites. Any satellite will emit one or more beacons (normally on a fixed frequency) whose purpose is twofold; as well as containing modulated station keeping information (telemetry), the beacon is also used to locate the satellite (determine its azimuth and elevation) in the sky.
A beacon was left on the moon by the last Apollo mission, transmitting FSK telemetry on 2276.0 MHz<ref>Template:Cite book</ref>
Driftnet buoy radio beacons
Template:Expand section
Driftnet radio buoys are extensively used by fishing boats operating in open seas and oceans.<ref>Template:Cite web</ref> They are useful for collecting long fishing lines or fishing nets, with the assistance of a radio direction finder. According to product information released by manufacturer Kato Electronics Co, Ltd., these buoys transmit on 1600–2850 kHz with a power of 4-15 W.
Some types of driftnet buoys, called "SelCall buoys", answer only when they are called by their own ships. Using this technique the buoy prevents nets and fishing gears from being carried away by other ships, while the battery power consumption remains low.<ref>Template:Cite journal</ref>
Distress radiobeacons
Template:Main
Distress radiobeacons, also collectively known as distress beacons, emergency beacons, or simply, beacons, are those tracking transmitters that operate as part of the international Cospas-Sarsat Search and Rescue satellite system. When activated, these beacons send out a distress signal that, when detected by non-geostationary satellites, can be located by triangulation. In the case of 406 MHz beacons which transmit digital signals, the beacons can be uniquely identified almost instantly (via GEOSAR), and furthermore, a GPS position can be encoded into the signal (thus providing both instantaneous identification & position.) distress signals from the beacons are homed by Search and Rescue (SAR) aircraft and ground search parties who can in turn come to the aid of the concerned boat, aircraft, and/or persons.
  • EPIRBs (Emergency Position Indicating Radio Beacons) signal maritime distress,
  • ELTs (Emergency Locator Transmitters) signal aircraft distress
  • PLBs (Personal Locator Beacons) are for personal use and are intended to indicate a person in distress who is away from normal emergency response capabilities (i.e. 911)
The basic purpose of distress radiobeacons is to get people rescued within the so-called "golden day" [1] (the first 24 hours following a traumatic event) when the majority of survivors can still be saved.
IEEE 802.11 Wi-Fi beacons
In the field of Wi-Fi (wireless local area networks using the IEEE 802.11b and 802.11g specification), the term beacon signifies a specific data transmission from the wireless access point (AP), which carries the SSID, the channel number and security protocols such as WEP (Wired Equivalent Protection) or WPA (Wi-Fi Protected Access). This transmission does not contain the link layer address of another Wi-Fi device, therefore it can be received by any LAN client.<ref>Template:Cite book</ref>
AX.25 packet radio beacons
Stations participating in packet radio networks based on the AX.25 link layer protocol also use beacon transmissions to identify themselves and broadcast brief information about operational status. The beacon transmissions use special UI or Unnumbered Information frames, which are not part of a connection and can be displayed by any station.<ref>Template:Cite web</ref><ref>Template:Cite book</ref> Beacons in traditional AX.25 amateur packet radio networks contain free format information text, readable by human operators.
This mode of AX.25 operation, using a formal machine-readable beacon text specification developed by Bob Bruninga, WB4APR, became the basis of the APRS networks.
Template:Reflist
  • Klawitter, G.: "Funk-Baken und Indikatorstationen" (in German), Siebel Verlag, ISBN 3-89632-055-6 (2001)
  • Beaconworld on-line resources list by Alan Gale, G4TMV
  • Godfrey Manning: "Sky High: ADF and NDBs", Radio User, 2(12), pp. 25, ISSN 1748-8117, December 2007
Template:Refend
