Revision as of 11:01, 21 August 2017 by R4002 (Talk | contribs)
Citizen's Band Radio, or "CB Radio" for short. Known by pejorative names such as "Chicken Band", "Children's Band" and several others. Short-range license free (or simple license requirement) two-way radio service for personal or business purposes in the 25-30 MHz (25000-30000 kHz) range that makes up the shortest wavelength portions of the HF band. De facto standard frequency allocation based on 40 channel American CB band 26.965-27.405 MHz. In radio hobbyist circles, the CB band and adjacent frequencies are often referred to as "11 meters".
The American counterparts (SCR-508 family) provided narrower frequency coverage but higher power output and use of FM which significantly reduced impulse noise interference found in vehicles. The SCR-508 tank radio was rated at 25 watts (communication range of 7 miles or 11 km) and the SCR-608 artillery radio was rated at 35 watts (communication range of 15 miles or 24 km). The American radios provided crystal control and channeling at 100 kHz steps (26400, 26500, 26600, etc). German AM equipment operated at 50 kHz channel steps (27050, 27100, 27150, etc). The US Army also pioneered the concept of using channel numbers in place of frequencies. For example, 25900 kHz would be referred to as "channel 259". American military equipment provided for 10 crystals to be installed at once and selected "on-the-fly" to allow for rapid frequency agility.
The CB service as we know it today started in the United States in the 1950s as a licensed service in the 26.965-27.255 MHz band (23 channels). When the service was created, the original 26.96 - 27.26 MHz band was taken from the 11 meter amateur radio band. Because of this, CB and its adjacent frequencies are often referred to as "11 meters". CB was expanded in 1977 to 40 channels. It is this 40 channel plan that became the "standard" CB plan that most countries have since adopted.
Team MX-10, a typical multi-norm European AM/FM CB radio. Using the radio's menu, the user selects the country they intend to operate the radio in, and the radio loads the appropriate channel plan.
Galaxy DX 959, a typical AM/SSB "American style" CB radio
25.070 MHz to 25.121 MHz HF-SSB marine (maritime mobile radio service, 3 kHz steps) - shared with 25020-25320 kHz 25.020 MHz to 25.320 MHz Business/Industrial Radio Service (FM mode, shared with 25070-25121 kHz marine HF SSB) 25.550 MHz to 25.670 MHz Radio Astronomy and is supposed to be clear of stations 25.600 MHz to 26.100 MHz 11 meter shortwave broadcast band SWBC or HFBC band. Rarely used. Some DRM tests done here. 26.145 MHz to 26.175 MHz HF-SSB marine (maritime mobile radio service, 3 kHz steps) 25.870 MHz to 26.470 MHz Remote Broadcast Pickup (Studio Transmitter Link or STL) service 27.430 MHz to 27.530 MHz Business/Industrial Radio Service (20 kHz steps, FM mode) 27.555, 27.615, 27.635, 27.655, 27.765, and 27.860 MHz Forest Products Radio Service on a secondary basis (only in certain areas, with maximum 150 watts output power) 29.710 MHz to 29.790 MHz Business/Industrial Radio Service (20 kHz steps, FM mode)
Frequency Range Remarks
Frequency Remarks
25.950 MHz 5 active licenses
25.200 MHz 0 active licenses
25.160 MHz 0 active licenses
25.120 MHz 0 active licenses
The so-called "A channels" are also heavily used, especially when a band opening makes finding a clear frequency difficult. The A channels are assigned to R/C and telemetry purposes in most countries (the USA included). These six frequencies fall under a different section of Part 95 of the FCC rules. 27.255 MHz (CB Channel 23) is also one of the R/C channels, but it is shared with CB. FCC rules permit a maximum of 4 watts carrier power on 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz and 27.195 MHz. FCC rules permit a maximum of 25 watts carrier power on 27.255 MHz (this translates to 100 watts PEP at 100% AM modulation). Due to the higher power allowed on 27.255 MHz, it is often used for unlicensed on-site paging and telemetry systems. See the bottom of this page for R/C, radio control, remote control, RC, telecommand, telemetry, etc frequencies.
CB Channel Frequency
Channel 1 26.965 MHz
Channel 2 26.975 MHz
Channel 3 26.985 MHz
Channel 4 27.005 MHz
Channel 5 27.015 MHz
Channel 6 27.025 MHz
Channel 7 27.035 MHz
Channel 8 27.055 MHz
Channel 9 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.175 MHz
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
Channel 28 27.285 MHz
Channel 29 27.295 MHz
Channel 30 27.305 MHz
Channel 31 27.315 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 35 27.355 MHz
Channel 36 27.365 MHz
Channel 37 27.375 MHz
Channel 38 27.385 MHz
Channel 39 27.395 MHz
Channel 40 27.405 MHz
FM (Frequency Modulation)
The UK allows use of the CEPT "mid band" allocation (same as US frequencies) in addition to the frequencies listed below. AM, FM and SSB are allowed on 26.965-27.405 MHz. FM is the only mode allowed on 27.60125-27.99125 MHz. In the UK, these frequencies are shared with the Community Audio Distribution Service (CADS) and the Republic of Ireland's similar service the Wireless Public Address System (WPAS). There does not appear to be specific rules regarding FM deviation or bandwidth. Modern FM CB radios use narrowband FM deviation while older sets may use 5 kHz "wideband" FM.
The 27.6 MHz to 28.0 MHz allocation overlaps with CADS/WPAS and other services in various countries outside the UK.
Channel 1 27.60125 MHz
Channel 2 27.61125 MHz
Channel 3 27.62125 MHz
Channel 4 27.63125 MHz
Channel 5 27.64125 MHz
Channel 6 27.65125 MHz
Channel 7 27.66125 MHz
Channel 8 27.67125 MHz
Channel 9 27.68125 MHz
Channel 10 27.69125 MHz
Channel 11 27.70125 MHz
Channel 12 27.71125 MHz
Channel 13 27.72125 MHz
Channel 14 27.73125 MHz
Channel 15 27.74125 MHz
Channel 16 27.75125 MHz
Channel 17 27.76125 MHz
Channel 18 27.77125 MHz
Channel 19 27.78125 MHz
Channel 20 27.79125 MHz
Channel 21 27.80125 MHz
Channel 22 27.81125 MHz
Channel 23 27.82125 MHz
Channel 24 27.83125 MHz
Channel 25 27.84125 MHz
Channel 26 27.85125 MHz
Channel 27 27.86125 MHz
Channel 28 27.87125 MHz
Channel 29 27.88125 MHz
Channel 30 27.89125 MHz
Channel 31 27.90125 MHz
Channel 32 27.91125 MHz
Channel 33 27.92125 MHz
Channel 34 27.93125 MHz
Channel 35 27.94125 MHz
Channel 36 27.95125 MHz
Channel 37 27.96125 MHz
Channel 38 27.97125 MHz
Channel 39 27.98125 MHz
Channel 40 27.99125 MHz
Channel 41 26.565 MHz
Channel 42 26.575 MHz
Channel 43 26.585 MHz
Channel 44 26.595 MHz
Channel 45 26.605 MHz
Channel 46 26.615 MHz
Channel 47 26.625 MHz
Channel 48 26.635 MHz
Channel 49 26.645 MHz
Channel 50 26.655 MHz
Channel 51 26.665 MHz
Channel 52 26.675 MHz
Channel 53 26.685 MHz
Channel 54 26.695 MHz
Channel 55 26.705 MHz
Channel 56 26.715 MHz
Channel 57 26.725 MHz
Channel 58 26.735 MHz
Channel 59 26.745 MHz
Channel 60 26.755 MHz
Channel 61 26.765 MHz
Channel 62 26.775 MHz
Channel 63 26.785 MHz
Channel 64 26.795 MHz
Channel 65 26.805 MHz
Channel 66 26.815 MHz
Channel 67 26.825 MHz
Channel 68 26.835 MHz
Channel 69 26.845 MHz
Channel 70 26.855 MHz
Channel 71 26.865 MHz
Channel 72 26.875 MHz
Channel 73 26.885 MHz
Channel 74 26.895 MHz
Channel 75 26.905 MHz
Channel 76 26.915 MHz
Channel 77 26.925 MHz
Channel 78 26.935 MHz
Channel 79 26.945 MHz
Channel 80 26.955 MHz
AM mode. 4 watt TX power. Same specifications as AM CB radio. Modern Australian "27 Meg" 27 MHz marine radio equipment usually includes regular US 40-channels in addition to the frequencies below.
27.88 MHz (CH 88) and 27.86 MHz (CH 86) are monitored by coast stations for emergency/distress traffic.
Channel 1 26.330 MHz
Channel 2 26.340 MHz
Channel 3 26.350 MHz
Channel 4 26.370 MHz
Channel 5 26.380 MHz
Channel 6 26.390 MHz
Channel 7 26.400 MHz
Channel 8 26.420 MHz
Channel 9 26.430 MHz
Channel 10 26.440 MHz
Channel 11 26.450 MHz
Channel 12 26.470 MHz
Channel 13 26.480 MHz
Channel 14 26.490 MHz
Channel 15 26.500 MHz
Channel 16 26.520 MHz
Channel 17 26.530 MHz
Channel 18 26.540 MHz
Channel 19 26.550 MHz
Channel 20 26.570 MHz
Channel 21 26.580 MHz
Channel 22 26.590 MHz
Channel 23 26.620 MHz
Channel 24 26.600 MHz
Channel 25 26.610 MHz
Channel 26 26.630 MHz
Channel 27 26.640 MHz
Channel 28 26.650 MHz
Channel 29 26.660 MHz
Channel 30 26.670 MHz
Channel 31 26.680 MHz
Channel 32 26.690 MHz
Channel 33 26.700 MHz
Channel 34 26.710 MHz
Channel 35 26.720 MHz
Channel 36 26.730 MHz
Channel 37 26.740 MHz
Channel 38 26.750 MHz
Channel 39 26.760 MHz
Channel 40 26.770 MHz
Channel 1 26.968 MHz
Channel 2 26.976 MHz
Channel 3 27.040 MHz
Channel 4 27.080 MHz
Channel 5 27.088 MHz
Channel 6 27.112 MHz
Channel 7 27.120 MHz
Channel 8 27.144 MHz
Channel 26760 26.760 MHz
Channel 26768 26.768 MHz
Channel 26776 26.776 MHz
Channel 26824 26.824 MHz
Channel 26840 26.840 MHz
Channel 26848 26.848 MHz
Channel 26856 26.856 MHz
Channel 26864 26.864 MHz
Channel 26872 26.872 MHz
Channel 26880 26.880 MHz
Channel 26888 26.888 MHz
Channel 26896 26.896 MHz
Channel 26912 26.912 MHz
Channel 26920 26.920 MHz
Channel 26928 26.928 MHz
Channel 26936 26.936 MHz
Channel 26944 26.944 MHz
Channel 27016 27.016 MHz
Channel 27524 27.524 MHz
Channel 27532 27.532 MHz
Channel 27540 27.540 MHz
Channel 27548 27.548 MHz
Channel 27556 27.556 MHz
Channel 27572 27.572 MHz
Channel 27580 27.580 MHz
Channel 27628 27.628 MHz
Channel 27636 27.636 MHz
Channel 27644 27.644 MHz
Channel 27652 27.652 MHz
Channel 27660 27.660 MHz
Channel 27668 27.668 MHz
Channel 27676 27.676 MHz
Channel 27724 27.724 MHz
Channel 27732 27.732 MHz
Channel 27740 27.740 MHz
Channel 27748 27.748 MHz
Channel 27756 27.756 MHz
Channel 27764 27.764 MHz
Channel 27772 27.772 MHz
Channel 27780 27.780 MHz
Channel 27828 27.828 MHz
Channel 27836 27.836 MHz
Channel 27852 27.852 MHz
Channel 27860 27.860 MHz
Channel 27884 27.884 MHz
Channel 27892 27.892 MHz
Channel 27908 27.908 MHz
Channel 27916 27.916 MHz
Channel 27932 27.932 MHz
Channel 27940 27.940 MHz
Channel 27956 27.956 MHz
Channel 27964 27.964 MHz
Channel 27980 27.980 MHz
Channel 27988 27.988 MHz
27310.5 kHz 27.3105 MHz
27334.5 kHz 27.3345 MHz
27338.5 kHz 27.3385 MHz
27342.5 kHz 27.3425 MHz
27346.5 kHz 27.3465 MHz
27350.5 kHz 27.3505 MHz
27354.5 kHz 27.3545 MHz
27358.5 kHz 27.3585 MHz
27362.5 kHz 27.3625 MHz
27366.5 kHz 27.3665 MHz
27370.5 kHz 27.3705 MHz
27378.5 kHz 27.3785 MHz
27382.5 kHz 27.3825 MHz
27386.5 kHz 27.3865 MHz
27388.5 kHz 27.3885 MHz
27398.5 kHz 27.3985 MHz
27404.5 kHz 27.4045 MHz
27418.5 kHz 27.4185 MHz
27426.5 kHz 27.4265 MHz
27434.5 kHz 27.4345 MHz
27442.5 kHz 27.4425 MHz
27452.5 kHz 27.4525 MHz
27458.5 kHz 27.4585 MHz
27466.5 kHz 27.4665 MHz
27470.5 kHz 27.4705 MHz
South Korea allows use of the 26.965-27.405 MHz "Citizen Radio" allocation in addition to 27.404 MHz, 27.410 MHz, 27.422 MHz, and 27.440 MHz for paging purposes.
AM on all channels. SSB only allowed on specified channels. 23 channels, 29.710 MHz - 29.985 MHz. 12.5 kHz steps. Some channels have multiple designations depending on their intended use. Used by boating clubs, 4x4 groups, farmers, etc. South African 4x4 groups are starting to migrate to VHF/UHF services but a 29 MHz CB appears to still be required equipment for many of these clubs (much like a 27 MHz CB is required by Jeep and 4x4 clubs in the US and UK)
AM and FM modes allowed. 5 watt maximum transmit power, no limit on antenna gain. Unclear if SSB is permitted. 26.96-27.28 MHz. Several VHF and UHF services are allowed in India for two-way radio, making 26 MHz/27 MHz CB radio a bit of a niche.
Channel 41 27.415 MHz
Channel 42 27.425 MHz
Channel 43 27.435 MHz
Channel 44 27.455 MHz
Channel 45 27.465 MHz
Channel 46 27.475 MHz
Channel 47 27.485 MHz
Channel 48 27.505 MHz
Channel 49 27.515 MHz
Channel 50 27.525 MHz
Channel 51 27.535 MHz
Channel 52 27.555 MHz
Channel 53 27.565 MHz
Channel 54 27.575 MHz
Channel 55 27.585 MHz
Channel 56 27.605 MHz
Channel 57 27.615 MHz
Channel 58 27.625 MHz
Channel 59 27.635 MHz
Channel 60 27.655 MHz
Channel 61 27.665 MHz
Channel 62 27.675 MHz
Channel 63 27.685 MHz
Channel 64 27.695 MHz
Channel 65 27.705 MHz
Channel 66 27.715 MHz
Channel 67 27.725 MHz
Channel 68 27.735 MHz
Channel 69 27.745 MHz
Channel 70 27.755 MHz
Channel 71 27.765 MHz
Channel 72 27.775 MHz
Channel 73 27.785 MHz
Channel 74 27.795 MHz
Channel 75 27.805 MHz
Channel 76 27.815 MHz
Channel 77 27.825 MHz
Channel 78 27.835 MHz
Channel 79 27.845 MHz
Channel 80 27.855 MHz
27.620 MHz 27.820 MHz Jamaica Optional CTCSS tone: 88.5Hz
26.575 MHz Germany
26.675 MHz
26.685 MHz Western Russia
26.915 MHz
26.925 MHz
26.935 MHz
26.970 MHz Lithuania
26.985 MHz Tver, Russia
27.000 MHz Kiev, Ukraine
27.030 MHz Minsk, Belarus
27.040 MHz Minsk, Belarus
27.060 MHz Kiev, Ukraine
27.070 MHz
27.075 MHz Eastern Russia
27.100 MHz Krasnodar, Russia
27.105 MHz Astana, Kazakhstan
27.110 MHz Poland
27.110 MHz Russia
27.135 MHz Moscow, Russia
27.150 MHz Poland
27.165 MHz Issyk, Kazakhstan
27.170 MHz Poland
27.175 MHz Taraz, Kazakhstan
27.190 MHz
27.200 MHz Zaykova, Russia
27.205 MHz Sweden DTMF-activated playback
27.215 MHz Almaty, Kazakhstan
27.220 MHz
27.230 MHz
27.235 MHz
27.250 MHz Belarus
27.270 MHz Saratov, Russia
27.270 MHz Kiev, Ukraine
27.290 MHz Minsk, Belarus
27.295 MHz Tyumen, Russia
27.300 MHz
27.305 MHz Western Europe
27.325 MHz
27.335 MHz Almaty, Kazakhstan
27.370 MHz Western Russia
27.430 MHz
27.450 MHz
27.470 MHz
27.505 MHz Moscow, Russia
27.580 MHz Moscow, Russia
27.605 MHz Moscow, Russia
27.630 MHz Moscow, Russia
27.635 MHz Moscow, Russia
27.635 MHz St. Petersburg, Russia
27.650 MHz Western Europe
27.675 MHz Russia
27.765 MHz Germany
27.840 MHz Poland
27.875 MHz Rostov, Russia
US "A" or "RC" channels
CB Channel RC Channel RC Color Code Frequency
Channel "3A" Channel 1 Brown 26.995 MHz
Channel "7A" Channel 2 Red 27.045 MHz
Channel "11A" Channel 3 Orange 27.095 MHz
Channel "15A" Channel 4 Yellow 27.145 MHz
Channel "19A" Channel 5 Green 27.195 MHz
Channel 23 Channel 6 Blue 27.255 MHz
UK RC Channels
Black 26.975 MHz
Brown 26.995 MHz
Brown-Red 27.025 MHz
Red 27.045 MHz
Red-Orange 27.075 MHz
Orange 27.095 MHz
Orange-Yellow 27.125 MHz
Yellow 27.145 MHz
Yellow-Green 27.175 MHz
Green 27.195 MHz
Green-Blue 27.225 MHz
Blue 27.245 MHz
White (or Purple) 27.275 MHz
Australia RC Channel Frequency
Channel 1 26.995 MHz
Channel 2 27.045 MHz
Channel 3 27.095 MHz
Channel 4 27.145 MHz
Channel 6 27.195 MHz
Channel 10 29.725 MHz
Channel 11 29.735 MHz
Channel 12 29.745 MHz
Channel 13 29.755 MHz
Channel 14 29.765 MHz
Channel 15 29.775 MHz
Channel 16 29.785 MHz
Channel 17 29.795 MHz
Channel 18 29.805 MHz
Channel 19 29.815 MHz
Channel 20 29.825 MHz
Channel 21 29.835 MHz
Channel 22 29.845 MHz
Channel 23 29.855 MHz
Channel 24 29.865 MHz
Channel 25 29.875 MHz
Channel 26 29.885 MHz
Channel 27 29.895 MHz
Channel 28 29.905 MHz
Channel 29 29.915 MHz
Channel 30 29.925 MHz
Channel 31 29.935 MHz
Channel 32 29.945 MHz
Channel 33 29.955 MHz
Channel 34 29.965 MHz
Channel 35 29.975 MHz
Channel 36 29.985 MHz
NZ RC Channel Frequency
Channel 197 26.975 MHz
Channel 199 26.995 MHz
Channel 102 27.020 MHz
Channel 104 27.045 MHz
Channel 107 27.070 MHz
Channel 109 27.095 MHz
Channel 112 27.120 MHz
Channel 114 27.145 MHz
Channel 117 27.170 MHz
Channel 119 27.195 MHz
Channel 122 27.220 MHz
Channel 124 27.245 MHz
Channel 128 27.280 MHz
Channel 272 29.725 MHz
Channel 274 29.745 MHz
Channel 276 29.765 MHz
Channel 278 29.785 MHz
Channel 280 29.805 MHz
Channel 282 29.825 MHz
Channel 284 29.845 MHz
Channel 286 29.865 MHz
Channel 288 29.885 MHz
Channel 290 29.905 MHz
Channel 292 29.925 MHz
Channel 294 29.945 MHz
Channel 296 29.965 MHz
Channel 298 29.985 MHz
