Part 15
Part 15 is the section of FCC regulations dealing with unlicensed radio operation. Operation in several bands is allowed:
See also: the RC Radio Service, the CB Radio Service, and high power datalink systems that use 26-27 MHz
49 MHz devices, frequencies used and discussion.
49.6 MHz - 50 MHz (49.600 MHz - 49.975 MHz) band (47 CFR 15.235 subband 49.820 MHz - 49.900 MHz) shared with military users and other Part 15 devices, including first-generation analog cordless phones. Cordless phones are covered under a separate section of Part 15 - specifically 15.233 [47 CFR 15.233], but the same 10,000 microvolts/meter at 3 meters field strength limitation applies. Bandwidth limited to 20 kHz (generally FM voice, same deviation as VHF low band).
Even current-generation new production baby monitors are available that use the 49 MHz frequencies. Many models offer 2 channels to avoid interference with other nearby monitors. These devices remain in use despite the availability of 900 MHz/2.4 GHz, WiFi based, DECT 1.9 GHz or 5.8 MHz band audio monitors or audio/video combination devices. Analog baby monitors offer low RF radiation exposure due to their use of the VHF 49 MHz frequencies and excellent audio quality from true FM modulation within their service range.
The Radio Shack and Maxon 49 MHz walkie talkies generally have a communication range of around 1/8 mile [200m] in built-up areas. Simple testing with transmitters located indoors at ground level in a heavily built-up urbanized area produced reliable talk range of 300-400 feet [90-120m]. Considerably better radio talk range of and up to 1/4 mile [400m] or even further is possible with outdoor antennas, no obstructions and favorable noise levels.
This equipment provides preppers and militia types with a unique short-range low probability of intercept (LPI) radio communications capability that higher-power VHF/UHF services like FRS, GMRS, MURS doesn't provide.
- 49.830 MHz - Channel 1/Channel A [cordless phone headset channel 21]
- 49.845 MHz - Channel 2/Channel B [cordless phone headset channel 17]
- 49.860 MHz - Channel 3/Channel C [cordless phone headset channel 18]
- 49.875 MHz - Channel 4/Channel D [cordless phone headset channel 20]
- 49.890 MHz - Channel 5/Channel E [cordless phone headset channel 22]
Other Part 15C equipment using 49.82 MHz - 49.9 MHz or a portion of (for example, 49.86 MHz - 49.89 MHz) use different channel plans - 20 kHz channels instead of 15 kHz steps. FM voice room monitors for continuous transmit around 0.0012 mw. Emissions include 20K0F3E regular FM.
- 49.850 MHz - Channel 2
- 49.870 MHz - Channel 3
- 49.890 MHz - Channel 4
- 49.830 MHz - Channel 1 (standard channel A)
- 49.845 MHz - Channel 2 (standard channel B)
- 49.860 MHz - Channel 3 (standard channel C)
- 49.875 MHZ - Channel 4 (standard channel D)
Some 2 channel transmitters use arbitrary channel labeling, including:
- 49.845 MHz - Channel X
- 49.875 MHz - Channel Y
Other channel plans include
- 49.830 MHz - Channel A
- 49.860 MHz - Channel B
Or,
- 49.845 MHz - Channel A
- 49.890 MHz - Channel B
Or,
- 49.840 MHz - Channel A
- 49.870 MHz - Channel B
Or,
- 49.850 MHz - Channel I
- 49.870 MHz - Channel II
Most 2 channel devices use frequencies that are at least 20 kHz apart from each other. 3 channel equipment often use 30 kHz channel spacing. FCC registration documents indicate that 3-5 kHz deviation ratings are the norm (12 kHz to 20 kHz bandwidth, or 12K0F3E to 20K0F3E emissions). Examples include transmitters on 49.870 MHz and 49.850 MHz rated for 3.5 kHz FM deviation, or 14 kHz bandwidth (14K0F3E emission).
- 49.890 MHz - Channel C
Other equipment use random 10 kHz / 20 kHz channel spacing, with offsets from the standard 15 kHz channel steps.
- 49.870 MHz - Channel 4
- 49.880 MHz - Channel 5
- 49.890 MHz - Channel 6
- 49.835 MHz - Channel A
- 49.850 MHz - Channel B
- 49.865 MHz - Channel C
Covered under FCC Part 15 47 CFR 15.235 Operation within the band 49.82-49.90 MHz. Maximum bandwidth 10 kHz, de facto 15 kHz channel steps for R/C use. Sometimes frequencies may be off by several kHz. For example, 49.845 MHz may be closer to 49.840 MHz, 49.847 MHz or even 49.850 MHz, 49.860 MHz may be closer to 49.855 MHz, 49.865 MHz, etc. Low-cost toys and other devices may purposely use frequencies between channels such as 49.825 MHz, 49.870 MHz, etc.
