CADS or WPAS 26 MHz 27 MHz church radio parish Irish churches on 27 MHz CB radio - Wireless Public Address Service UK Ireland Northern Ireland
Three "bands" in (legal) use, the regular CB band 26.960 MHz - 27.410 MHz / 26.965-27.405 MHz, the UK FM "27/81" band 27.60125 MHz to 27.99125 MHz (defined under Irish and UK law as 27.596125 MHz to 27.99625 MHz) and the "UW band" 27.605-27.995 MHz (27.6 MHz to 28.0 MHz) Church services have been heard outside these band limits, often in the 27.405 MHz to 27.600 MHz portion and below 26.965 MHz (CB channel 1). Some churches use modified "export radios" which, instead of observing the UK FM offset, transmit on the "zeros" instead (i.e., operating on 27.800 MHz instead of 27.80125 MHz). Since the difference between UK FM offset and the zero offset is only 1.25 kHz and FM is used, this usually makes very little to no difference to the (local) receivers the church transmission is meant for. Examples include 27.729 MHz or 27.730 MHz instead of the 27.73125 MHz center frequency. 27.980 MHz AM is included in logs, even though the UK FM band prohibits use of AM mode, this would indicate use of "export" specification radios or multi-country radios set for "RU" or "Russia" mode.
CADS operates on the 80 UK CB channels (standard CB channels 1-40 and UK FM CB channels 1-40) so 26965-27405 and 27601.25-27991.25 FM mode only. UK law defines the 27/81 UK FM CB band as 27.59625 MHz to 27.99625 MHz (5 kHz down from UK CB channel 1 and 5 kHz up from UK CB channel 40, effectively 27.600 MHz to 28.000 MHz). The mid band CEPT/EU band is defined as 26.960 MHz to 27.410 MHz. Ireland's WPAS service operates on two sets of 40 interleaved channels for a total of 80 channels. Although not technically authorized in Ireland, Churches often use the standard 40 "mid band CB" or "CEPT CB" channels as well. Ireland allows use of AM and FM on all 80 channels as part of the WPAS system, while FM is the only mode allowed in the UK. When added to the 40 mid band CB channels 26.965 to 27.405 a total of 120 channels becomes available. In practice, however, the very small offset between the two overlapping channels means users need to be at least one channel away from each other if they are in the immediate area.
Bands
| Band | Frequencies (channel center frequencies) | Frequencies (band limits) |
| CB Band Mid Band CEPT EU Band | 26.965 MHz - 27.405 MHz | 26.960 MHz - 27.410 MHz |
| UK Band UK FM 27/81 CB LW Band | 27.60125 MHz - 27.99125 MHz | 27.59625 MHz - 27.99625 MHz |
| LW Band | 27.60125 MHz - 27.99125 MHz | 27.600 MHz - 27.995 MHz |
| UW Band (Ireland) | 27.605 MHz - 27.995 MHz | 27.6 MHz - 28 MHz |
Note: Ireland’s ComReg technically allows use of AM mode on the LW frequencies (UK 27/81 FM CB band). AM is not permitted in the U.K. on the UK FM 27/81 CB frequencies.
Mid Band CB UK, Europe, Ireland (used unofficially in Ireland) Defined under UK and Irish law as "26.96 MHz to 27.41 MHz"
| CB Channel | Frequency |
| Channel 01 | 26.965 MHz |
| Channel 02 | 26.975 MHz |
| Channel 03 | 26.985 MHz |
| Channel 04 | 27.005 MHz |
| Channel 05 | 27.015 MHz |
| Channel 06 | 27.025 MHz |
| Channel 07 | 27.035 MHz |
| Channel 08 | 27.055 MHz |
| Channel 09 | 27.065 MHz |
| Channel 10 | 27.075 MHz |
| Channel 11 | 27.085 MHz |
| Channel 12 | 27.105 MHz |
| Channel 13 | 27.115 MHz |
| Channel 14 | 27.125 MHz |
| Channel 15 | 27.135 MHz |
| Channel 16 | 27.155 MHz |
| Channel 17 | 27.165 MHz |
| Channel 18 | 27.185 MHz |
| Channel 19 | 27.185 MHz |
| Channel 20 | 27.205 MHz |
| Channel 21 | 27.215 MHz |
| Channel 22 | 27.225 MHz |
| Channel 23 | 27.255 MHz |
| Channel 24 | 27.235 MHz |
| Channel 25 | 27.245 MHz |
| Channel 26 | 27.265 MHz |
| Channel 27 | 27.275 MHz |
| Channel 28 | 27.285 MHz |
| Channel 29 | 27.295 MHz |
| Channel 30 | 27.305 MHz |
| Channel 31 | 27.315 MHz |
| Channel 32 | 27.325 MHz |
| Channel 33 | 27.335 MHz |
| Channel 34 | 27.345 MHz |
| Channel 35 | 27.355 MHz |
| Channel 36 | 27.365 MHz |
| Channel 37 | 27.375 MHz |
| Channel 38 | 27.385 MHz |
| Channel 39 | 27.395 MHz |
| Channel 40 | 27.405 MHz |
- 26.175 MHz - Begin FIXED/MOBILE band (on-site paging, low power devices, short range devices, remote control, remote broadcast pickup and studio audio links Citizen Band Radio) 26175 - 27500 kHz
- 26.350 MHz - UK begin FIXED/MOBILE band to 27.5 MHz (shared with paging, data, telemetry links, military users, and of course the CEPT/EU and US standard 40 channel "mid band" CB radio channels).
- 26.960 MHz - begin CB band / CADS mid band, same as EU CB band and US FCC CB radio channel plan
- 26.965 MHz - CB01 - CB Radio Channel 1
- 26.975 MHz - CB02 - CB Radio Channel 2
- 26.985 MHz - CB03 - CB Radio Channel 3
- 27.005 MHz - CB04 - CB Radio Channel 4
- 27.015 MHz - CB05 - CB Radio Channel 5
- 27.025 MHz - CB06 - CB Radio Channel 6
- 27.035 MHz - CB07 - CB Radio Channel 7
- 27.055 MHz - CB08 - CB Radio Channel 8
- 27.065 MHz - CB09 - CB Radio Channel 9
- 27.075 MHz - CB10 - CB Radio Channel 10
- 27.085 MHz - CB11 - CB Radio Channel 11
- 27.105 MHz - CB12 - CB Radio Channel 12
- 27.115 MHz - CB13 - CB Radio Channel 13
- 27.125 MHz - CB14 - CB Radio Channel 14
- 27.135 MHz - CB15 - CB Radio Channel 15
- 27.155 MHz - CB16 - CB Radio Channel 16
- 27.165 MHz - CB17 - CB Radio Channel 17
- 27.175 MHz - CB18 - CB Radio Channel 18
- 27.185 MHz - CB19 - CB Radio Channel 19
- 27.205 MHz - CB20 - CB Radio Channel 20
- 27.215 MHz - CB21 - CB Radio Channel 21
- 27.225 MHz - CB22 - CB Radio Channel 22
- 27.235 MHz - CB24 - CB Radio Channel 24
- 27.245 MHz - CB25 - CB Radio Channel 25
- 27.255 MHz - CB23 - CB Radio Channel 23
- 27.265 MHz - CB25 - CB Radio Channel 26
- 27.275 MHz - CB27 - CB Radio Channel 27
- 27.285 MHz - CB28 - CB Radio Channel 28
- 27.295 MHz - CB29 - CB Radio Channel 29
- 27.305 MHz - CB30 - CB Radio Channel 30
- 27.315 MHz - CB31 - CB Radio Channel 31
- 27.325 MHz - CB32 - CB Radio Channel 32
- 27.335 MHz - CB33 - CB Radio Channel 33
- 27.345 MHz - CB34 - CB Radio Channel 34
- 27.355 MHz - CB35 - CB Radio Channel 35
- 27.365 MHz - CB36 - CB Radio Channel 36
- 27.375 MHz - CB37 - CB Radio Channel 37
- 27.385 MHz - CB38 - CB Radio Channel 38
- 27.395 MHz - CB39 - CB Radio Channel 39
- 27.405 MHz - CB40 - CB Radio Channel 40
- 27.410 MHz - end CB band / CADS mid band
- 27.415 MHz - Band E Channel 1 (not a legal CB channel)
- 27.425 MHz - Band E Channel 2 (not a legal CB channel)
- 27.435 MHz - Band E Channel 3 (not a legal CB channel)
- 27.445 MHz - Band E Channel 3A (not a legal CB channel)
- 27.455 MHz - Band E Channel 4 (not a legal CB channel)
- 27.465 MHz - Band E Channel 5 (not a legal CB channel)
- 27.475 MHz - Band E Channel 6 (not a legal CB channel)
- 27.485 MHz - Band E Channel 7 (not a legal CB channel)
- 27.495 MHz - Band E Channel 7A (not a legal CB channel)
- 27.500 MHz - end FIXED/MOBILE band (on-site paging, low power devices, Citizen Band Radio)
- 27.500 MHz - begin METEOROLOGICAL AIDS, FIXED, MOBILE band (on-site paging, fixed/mobile service, WPAS is a FIXED SERVICE)
- 27.505 MHz - Band E Channel 8 (not a legal CB channel)
- 27.515 MHz - Band E Channel 9 (not a legal CB channel)
- 27.525 MHz - Band E Channel 10 (not a legal CB channel)
- 27.535 MHz - Band E Channel 11 (not a legal CB channel)
- 27.545 MHz - Band E Channel 11A (not a legal CB channel)
- 27.555 MHz - Band E Channel 12 (not a legal CB channel)
- 27.565 MHz - Band E Channel 13 (not a legal CB channel)
- 27.575 MHz - Band E Channel 14 (not a legal CB channel)
- 27.585 MHz - Band E Channel 15 (not a legal CB channel)
- 27.595 MHz - Band E Channel 15A (not a legal CB channel)
- 27.59625 MHz - begin 27/81 UK FM CB band per Ofcom frequency allocation
- 27.600 MHz - begin WPAS allocation per ComReg frequency allocation
- 27.60125 MHz - LW01 / UK FM CB Channel 1
- 27.605 MHz - UW01
- 27.61125 MHz - LW02 / UK FM CB Channel 2
- 27.615 MHz - UW02
- 27.62125 MHz - LW03 / UK FM CB Channel 3
- 27.625 MHz - UW03
- 27.63125 MHz - LW04 / UK FM CB Channel 4
- 27.635 MHz - UW04
- 27.64125 MHz - LW05 / UK FM CB Channel 5
- 27.645 MHz - UW05
- 27.65125 MHz - LW06 / UK FM CB Channel 6
- 27.655 MHz - UW06
- 27.66125 MHz - LW07 / UK FM CB Channel 7
- 27.665 MHz - UW07
- 27.67125 MHz - LW08 / UK FM CB Channel 8
- 27.675 MHz - UW08
- 27.68125 MHz - LW09 / UK FM CB Channel 9
- 27.685 MHz - UW09
- 27.69125 MHz - LW10 / UK FM CB Channel 10
- 27.695 MHz - UW10
- 27.70125 MHz - LW11 / UK FM CB Channel 11
- 27.705 MHz - UW11
- 27.71125 MHz - LW12 / UK FM CB Channel 12
- 27.715 MHz - UW12
- 27.72125 MHz - LW13 / UK FM CB Channel 13
- 27.725 MHz - UW13
- 27.73125 MHz - LW14 / UK FM CB Channel 14
- 27.735 MHz - UW14
- 27.74125 MHz - LW15 / UK FM CB Channel 15
- 27.745 MHz - UW15
- 27.75125 MHz - LW16 / UK FM CB Channel 16
- 27.755 MHz - UW16
- 27.76125 MHz - LW17 / UK FM CB Channel 17
- 27.765 MHz - UW17
- 27.77125 MHz - LW18 / UK FM CB Channel 18
- 27.775 MHz - UW18
- 27.78125 MHz - LW19 / UK FM CB Channel 19
- 27.785 MHz - UW19
- 27.79125 MHz - LW20 / UK FM CB Channel 20
- 27.795 MHz - UW20
- 27.80125 MHz - LW21 / UK FM CB Channel 21
- 27.805 MHz - UW21
- 27.81125 MHz - LW22 / UK FM CB Channel 22
- 27.815 MHz - UW22
- 27.82125 MHz - LW23 / UK FM CB Channel 23
- 27.825 MHz - UW23
- 27.83125 MHz - LW24 / UK FM CB Channel 24
- 27.835 MHz - UW24
- 27.84125 MHz - LW25 / UK FM CB Channel 25
- 27.845 MHz - UW25
- 27.85125 MHz - LW26 / UK FM CB Channel 26
- 27.855 MHz - UW26
- 27.86125 MHz - LW27 / UK FM CB Channel 27
- 27.865 MHz - UW27
- 27.87125 MHz - LW28 / UK FM CB Channel 28
- 27.875 MHz - UW28
- 27.88125 MHz - LW29 / UK FM CB Channel 29
- 27.885 MHz - UW29
- 27.89125 MHz - LW30 / UK FM CB Channel 30
- 27.895 MHz - UW30
- 27.90125 MHz - LW31 / UK FM CB Channel 31
- 27.905 MHz - UW31
- 27.91125 MHz - LW32 / UK FM CB Channel 32
- 27.915 MHz - UW32
- 27.92125 MHz - LW33 / UK FM CB Channel 33
- 27.925 MHz - UW33
- 27.93125 MHz - LW34 / UK FM CB Channel 34
- 27.935 MHz - UW34
- 27.94125 MHz - LW35 / UK FM CB Channel 35
- 27.945 MHz - UW35
- 27.95125 MHz - LW36 / UK FM CB Channel 36
- 27.955 MHz - UW36
- 27.96125 MHz - LW37 / UK FM CB Channel 37
- 27.965 MHz - UW37
- 27.97125 MHz - LW38 / UK FM CB Channel 38
- 27.975 MHz - UW38
- 27.98125 MHz - LW39 / UK FM CB Channel 39
- 27.985 MHz - UW39
- 27.990 MHz - end WPAS allocation per ComReg rules
- 27.99125 MHz - LW40 / UK FM CB Channel 40
- 27.995 MHz - UW40
- 27.99625 MHz - end 27/81 UK FM CB band CH40
- 28.000 MHz - end WPAS / CADS from 27.59625 MHz / 27.6 MHz (27.5 MHz to 28.0 MHz FIXED SERVICE band)
- 28.000 MHz - end METEOROLOGICAL AIDS, FIXED, MOBILE band (on-site paging, fixed/mobile service)
- 28.000 MHz - begin 10 meter amateur radio 10m ham radio band
- EN 300 1134 (Radio equipment intended for the transmission of data (and/or speech) using constant or non-constant envelope modulation and having an antenna connector)
- EN 300 1354 (Angle modulated CB radio equipment CEPT PR 27 Radio Equipment) 26.96 MHz - 27.41 MHz
- EN 300 4334 (Double Side Band (DSB) and/or Single Side Band SSB amplitude modulated AM CB radio equipment)
- The following maximum effective Radiated Power (ERP) limits will apply to WPAS systems.
- Base Station equipment using Amplitude Modulation (AM): 1 watt (0dBW)
- Base Station equipment using Frequency Modulation (FM): 4 watts (6dBW)
- Antennas must be non directional and antenna gain must not exceed 3dBd
- Antenna polarization must be vertical
- Antenna height must not exceed 10 metres above local ground level
- 26175 kHz - 27500 kHz 26.175 MHz - 27.5 MHz CEPT/ERC/DEC/(96);19,I.S.ETS300.224 CEPT/ERC/DEC/(96);02,I.S.ETS300.135 Paging (private, on-site) Low Power devices Citizen Band Radio (26.96 - 27.41 MHz.) Model Control 26.995 MHz 27.045 MHz 27.095 MHz 27.145 MHz 27.195 MHz FIXED MOBILE except aeronautical mobile S5.150
- 27500 kHz - 28000 kHz 27.5 MHz - 28.0 MHz CEPT/ERC/DEC/(96)19,I.S./ETS.300.224 METEOROLOGICAL AIDS FIXED MOBILE
- 26350 kHz - 27500 26.35 MHz - 27.5 MHz kHz - FIXED MOBILE - except aeronautical mobile
- 27500 kHz - 28000 27.5 MHz - 28.0 MHz - FIXED MOBILE - except aeronautical mobile
