Part 15 Beacons
Overview
There are three below-30 MHz bands available to hobbyists for Part 15 transmitters:
- 160 - 190 kHz
- 13553 - 13567 kHz (often referred to as 13560 kHz, 13.56 MHz or 22 meters, shared with ISM)
- 26960 - 27280 kHz (11 meters, shared with CB, RC, data links/telemetry and ISM from 26957 - 27283 kHz)
160-190 kHz Part 15 Beacons
- 167.180 LC Sacramento CA
- 181.818 JH Florence SC
- 182.448 R Keeler CA
- 183.500 WD2XFJ Burbank CA
- 185.100 22A Baraga MI
- 185.185 SIW Oswego IL
- 185.290 KT Oswego KS
- 185.297 TAG Raymond ME
- 185.299 SIW Oswego IL
- 185.303 SJ East Haven CT
- 185.650 WE2XEB Penn Yan NY
- 186.204 MLS Massilon OH
- 187.015 J La Crescenta CA
- 187.507 WI Aiken SC
- 188.830 EAR Saltford, ON
13560 kHz Part 15 Beacons
13553 kHz - 13567 kHz
- 13554.000 AZ Oro Valley AZ
- 13555.414 TAG Holden MA
- 13555.420 JIM Dallas TX
- 13555.430 SIW Elgin IL
- 13555.440 SIW Elgin IL
- 13555.450 MP London ON
- 13555.462 EH East Haven CT
- 13555.472 7P Ajo AZ
- 13555.500 NC Stanfield NC
- 13555.528 EDJ Monroe GA
- 13555.920 WV Richwood, WV
- 13555.98 TSN
- 13556.20 NOM NOM (not 24/7)
- 13556.600 OH Findlay OH
- 13557.50 PBJ Tracey City TN
- 13557.800 PLM [UNKNOWN]
- 13558.2 PVC
- 13558.510 AJO Ajo AZ
- 13558.98 NHVT
- 13561.100 17331PA Hanover, PA
- 13562.080 NDB
- 13562.35 IPA Sandwich,MA
- 13562.950 SZX Macomb IL
- 13563.000 RR
- 13563.55 PCO Colorado
- 13564.280 T Sun City CA
- 13561.55 WMD (not 24/7)
- 13562.80 GNK Madison WI
- 13564.72 ABBY
- 13564.965 RF Grid EM96 NC
- 13565.04 K6FRC Patterson CA
- 13565.69 MR.X Parts Unknown
- 13566.07 KAH
- 13566.20 AMA Hamilton ON
- 13566.22 WAS North Carolina
- 13566.40 RVA Richmond, VA
- 13566.50 ODX
26960 - 27280 kHz Part 15 Beacons
No Part 15 compliant 27MHz beacons reported.
See the 11 meter / 27 MHz CB beacons page, HF beacons and the 26-28 MHz RCRS remote control pages for additional information on beacons in this band. Numerous Part 15 devices operating in this band may act as de facto beacons.
22 meter band beacon kit
FCC Regulations
160 - 190 kHz
13560 kHz
26960 - 27280 kHz
- Radio beacons - general topic
- Radio propagation beacons
- LowFER
- HiFER
- High Frequency Beacon
- Part 15 Beacons
- Letter beacon
- Fishnet beacon
