78 MHz VHF CB
Revision as of 21:01, 11 March 2026 by R4002 (Talk | contribs)
Thailand only...known as "78 VHF" "78 CB" CB 78 MHz" "78 MHz CB" or other similar names. Used by truckers and bus services in Thailand. 245 MHz CB is considerably more popular. However, the propagation characteristics offered by mid band VHF (66-88 MHz - although this band is sometimes called "low band" by some radio manufacturers) are ideal for trucking, bus services and other mobile to mobile communications in rural areas. The 66-88 MHz band tends to share propagation characteristics of the VHF high band (136 MHz - 174 MHz, i.e. 2 meters) and VHF low band (25-50 MHz, 10 meter local FM and 6 meter local FM). The 4 meter band 70 MHz band has the same characteristics, but is not available in ITU Region 2.
245 MHz CB has more favorable suburban and urban propagation characteristics and the higher frequency allows for use of handheld radios with reasonable size antennas.
Thailand apparently has regular 40 channel 26-27 MHz CB, 78 MHz CB and the most popular 160 channel 245 MHz CB band.
80 channels 78.0000 to 78.9875 MHz 12.5 kHz steps. FM mode only, narrowband FM deviation required. 10 watt power limit.
Channel Frequency
Channel 1 78.0000 MHz
Channel 2 78.0125 MHz
Channel 3 78.0250 MHz
Channel 4 78.0375 MHz
Channel 5 78.0500 MHz
Channel 6 78.0625 MHz
Channel 7 78.0750 MHz
Channel 8 78.0875 MHz
Channel 9 78.1000 MHz
Channel 10 78.1125 MHz
Channel 11 78.1250 MHz
Channel 12 78.1375 MHz
Channel 13 78.1500 MHz
Channel 14 78.1625 MHz
Channel 15 78.1750 MHz
Channel 16 78.1875 MHz
Channel 17 78.2000 MHz
Channel 18 78.2125 MHz
Channel 19 78.2250 MHz
Channel 20 78.2375 MHz
Channel 21 78.2500 MHz
Channel 22 78.2625 MHz
Channel 23 78.2750 MHz
Channel 24 78.2875 MHz
Channel 25 78.3000 MHz
Channel 26 78.3125 MHz
Channel 27 78.3250 MHz
Channel 28 78.3375 MHz
Channel 29 78.3500 MHz
Channel 30 78.3625 MHz
Channel 31 78.3750 MHz
Channel 32 78.3875 MHz
Channel 33 78.4000 MHz
Channel 34 78.4125 MHz
Channel 35 78.4250 MHz
Channel 36 78.4375 MHz
Channel 37 78.4500 MHz
Channel 38 78.4625 MHz
Channel 39 78.4750 MHz
Channel 40 78.4875 MHz
Channel 41 78.5000 MHz
Channel 42 78.5125 MHz
Channel 43 78.5250 MHz
Channel 44 78.5375 MHz
Channel 45 78.5500 MHz
Channel 46 78.5625 MHz
Channel 47 78.5750 MHz
Channel 48 78.5875 MHz
Channel 49 78.6000 MHz
Channel 50 78.6125 MHz
Channel 51 78.6250 MHz
Channel 52 78.6375 MHz
Channel 53 78.6500 MHz
Channel 54 78.6625 MHz
Channel 55 78.6750 MHz
Channel 56 78.6875 MHz
Channel 57 78.7000 MHz
Channel 58 78.7125 MHz
Channel 59 78.7250 MHz
Channel 60 78.7375 MHz
Channel 61 78.7500 MHz
Channel 62 78.7625 MHz
Channel 63 78.7750 MHz
Channel 64 78.7875 MHz
Channel 65 78.8000 MHz
Channel 66 78.8125 MHz
Channel 67 78.8250 MHz
Channel 68 78.8375 MHz
Channel 69 78.8500 MHz
Channel 70 78.8625 MHz
Channel 71 78.8750 MHz
Channel 72 78.8875 MHz
Channel 73 78.9000 MHz
Channel 74 78.9125 MHz
Channel 75 78.9250 MHz
Channel 76 78.9375 MHz
Channel 77 78.9500 MHz
Channel 78 78.9625 MHz
Channel 79 78.9750 MHz
Channel 80 78.9875 MHz
  • See also:
  • RHA68 - 68 MHz service with similar scope in Finland, Finnish 68 MHz VHF FM
  • 43 MHz VHF CB - Italy - Italian 43 MHz FM CB service
  • 68 MHz VHF CB service (Sweden)
TACTECH TAC-60 T-60 TAC151 5 watt 78 MHz handheld transceiver portable radio walkie talkie 78MHz VHF mid band VHF CB 78 MHz CB walkie talkie - companion transceiver to the TACTECH Convoy mobile transceiver
TACTECH Convoy 78 MHz VHF CB mobile transceiver 78 MHz trucker radio mobile transceiver, note the 78.000 MHz frequency channel on the radio's display. Available with companion 78 MHz VHF mobile truck antenna model HR-78. This transceiver is similar to other VHF mid band 66-88 MHz mobile transceivers such as those used for the 4 meter amateur radio band (70 MHz band) and the RHA68 VHF FM two-way radio service.
