Revision as of 11:57, 26 October 2017 by R4002 (Talk | contribs)
high HF and VHF / UHF RadioLand mobile radio service authorized under Part 90 (Land Mobile Radio Services) of the FCC rules. FCC eligibility verbage states (FCC Part 90.35): Persons primarily engaged in any of the following activities are eligible to hold authorizations in the Industrial/Business Pool to provide commercial mobile radio service as defined in part 20 of this chapter or to operate stations for transmission of communications necessary to such activities of the licensee: (1) The operation commercial of business activity; (2) The operation of educational, philanthropic, or ecclesiastical institutions; (3) Clergy activities; or (4) The operation of hospitals, clinics, or medical associations.
The FCC has allocated a massive amount of frequencies for the Business/Industrial Radio Service (commonly referred to as "Business Radio" or "Business Radio Service"). The FCC allows use of frequencies in the 2000 to 25000 kHz (2-25 MHz) band for business purposes, only if frequencies above 25 MHz will not satisfy the requirements of the user, in other words, in special cases only.
VHF Low Band
25.020 MHz Oil companies, oil spill cleanup operations
27.430 MHz
27.450 MHz
27.470 MHz
27.490 MHz Itinerant use only
29.710 MHz
29.710 MHz
31.0600 MHz Shared with Public Safety Radio Pool
35.0200 MHz Mobile use only, 2 watts maximum power, shared with Public Safety Radio Pool
35.180 MHz
36.250 MHz Oil companies, oil spill cleanup operations
41.710 MHz Oil companies, oil spill cleanup operations
43.720 MHz
43.740 MHz
43.820 MHz
43.840 MHz
43.920 MHz
43.960 MHz
44.100 MHz
44.120 MHz
44.160 MHz
44.180 MHz
44.200 MHz
44.320 MHz
44.360 MHz
44.400 MHz
44.420 MHz
44.460 MHz
44.480 MHz
44.580 MHz
