VHF airband
Revision as of 14:25, 26 October 2018 by R4002 (Talk | contribs)
Military aircraft retain the capability to transmit and receive on the VHF-AM aircraft band, with US military aircraft radios covering up to 150 MHz in AM mode. Military aircraft also make extensive use of the UHF-AM aircraft band 225-400 MHz.
Frequency Purpose/Use
121.500 MHz Emergency Frequency known as Guard, see also 243.0 MHz - UHF Guard
122.900 MHz Common SAR (Search and Rescue) aircraft frequency)
123.100 MHz Common SAR (Search and Rescue) aircraft frequency)
123.450 MHz Unofficial air-to-air pilot chit-chat frequency
123.475 MHz Unofficial air-to-air pilot chit-chat frequency
