This is a work in progress as part of the VHF/UHF radio subpages.
VHF low band VHF-low
VHF high band VHF band
- 155.7525 MHz - VCALL10 - Calling, simplex only (156.7 Hz CTCSS)
- 155.1600 MHz - NATSAR - Search and Rescue - simplex 127.3 Hz or 156.7 Hz (CSQ recommended)
- 155.3400 MHz - HEAR340/VMED28 - Ambulance to Hospital/Hospital to Hospital, medical interop
UHF band
800 MHz band
- 851.0125 MHz - 8CALL90D/8CALL90 - Calling, simplex or repeater (input -45 MHz) both with 156.7 Hz CTCSS
- 851.5125 MHz - 8TAC91D/8TAC91 - Tac 1, simplex or repeater (input -45 MHz) both with 156.7 Hz CTCSS
- 852.0125 MHz - 8TAC92D/8TAC92 - Tac 2, simplex or repeater (input -45 MHz) both with 156.7 Hz CTCSS
- 852.5125 MHz - 8TAC93D/8TAC93 - Tac 3, simplex or repeater (input -45 MHz) both with 156.7 Hz CTCSS
- 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input -45 MHz) both with 156.7 Hz CTCSS
