VHF low band VHF-low
VHF high band VHF band
UHF band
800 MHz band
- 36.2500 MHz - Oil spill cleanup/interop
- 40.5000 MHz - US Military SAR FM channel - CSQ or 150.0 Hz military CTCSS tone
- 41.7100 MHz - Oil spill cleanup/interop
UHF band
