Part 15
Revision as of 14:01, 24 September 2019 by R4002 (Talk | contribs)
Part 15 is the section of FCC regulations dealing with unlicensed radio operation. Operation in several bands is allowed:
See also: the RC Radio Service, the CB Radio Service, and high power datalink systems that use 26-27 MHz
R/C transmitters, room monitors, baby monitors, analog FM cordless phones (under another section of Part 15, 43-49 MHz, 10 channel and 25 channel versions), walkie-talkies of various types - ranging from cheap children's toys to higher-grade multi-channel (generally 5-channel) transceivers, VOX headset systems and walkie talkies.
(a) The field strength of any emission within this band shall not exceed 10,000 microvolts/meter at 3 meters. The emission limit in this paragraph is based on measurement instrumentation employing an average detector. The provisions in § 15.35 for limiting peak emissions apply.
(b) The field strength of any emissions appearing between the band edges and up to 10 kHz above and below the band edges shall be attenuated at least 26 dB below the level of the unmodulated carrier or to the general limits in § 15.209, whichever permits the higher emission levels. The field strength of any emissions removed by more than 10 kHz from the band edges shall not exceed the general radiated emission limits in § 15.209. All signals exceeding 20 microvolts/meter at 3 meters shall be reported in the application for certification.
(c) For a home-built intentional radiator, as defined in § 15.23(a), operating within the band 49.82-49.90 MHz, the following standards may be employed:
(1) The RF carrier and modulation products shall be maintained within the band 49.82-49.90 MHz.
(2) The total input power to the device measured at the battery or the power line terminals shall not exceed 100 milliwatts under any condition of modulation.
(3) The antenna shall be a single element, one meter or less in length, permanently mounted on the enclosure containing the device.
(4) Emissions outside of this band shall be attenuated at least 20 dB below the level of the unmodulated carrier.
(5) The regulations contained in § 15.23 of this part apply to intentional radiators constructed under the provisions of this paragraph.
(d) Cordless telephones are not permitted to operate under the provisions of this section.
RC transmitters generally use 49.830 MHz - 49 MHz RC channel 1. Children's RC toys are often offered in two versions, a "49 MHz" version and a "27 MHz" version. The 27 MHz version generally will operate on 27.145 MHz. These devices are usually operating under Part 15, not Part 95 (with some rare exceptions for the 26 / 27 MHz gear. Part 15 power limit is 10,000 microvolts per meter at 3 meters (10,000 microvolts/meter at 3m).
49.800 MHz - 49.975 MHz band shared with military users and other low-power users, including first-generation analog cordless phones, baby monitors and low power 49 MHz walkie-talkies. Cordless phones are covered under a separate section of Part 15 - specifically 15.233 [47 CFR 15.233], but the same 10,000 microvolts/meter at 3 meters field strength limitation applies. Bandwidth limited to 20 kHz (generally FM voice, same deviation as VHF low band).
Even current-generation new production baby monitors are available that use the 49 MHz frequencies. Many models offer 2 channels to avoid interference with other nearby monitors. These devices remain in use despite the availability of 900 MHz/2.4 GHz, WiFi based, DECT 1.9 GHz or 5.8 MHz band audio monitors or audio/video combination devices. Analog baby monitors offer low RF radiation exposure due to their use of the VHF 49 MHz frequencies and excellent audio quality from true FM modulation within their service range.
The Radio Shack and Maxon 49 MHz walkie talkies generally have a communication range of 1/8 mile in built-up areas and up to 1/2 mile or even further with no obstructions and favorable noise levels. This equipment provides preppers and militia types with a unique short-range low probability of intercept (LPI) radio communications capability that higher-power VHF/UHF services like FRS, GMRS, MURS doesn't provide.
  • 49.830 MHz - Channel 1/Channel A [cordless phone headset channel 21]
  • 49.845 MHz - Channel 2/Channel B [cordless phone headset channel 17]
  • 49.860 MHz - Channel 3/Channel C [cordless phone headset channel 18]
  • 49.875 MHz - Channel 4/Channel D [cordless phone headset channel 20]
  • 49.890 MHz - Channel 5/Channel E [cordless phone headset channel 22]
Other Part 15C equipment using 49.82 MHz - 49.9 MHz or a portion of (for example, 49.86 MHz - 49.89 MHz) use different channel plans - 20 kHz channels instead of 15 kHz steps. FM voice room monitors for continuous transmit around 0.0012 mw. Emissions include 16K0F3E or 20K0F3E regular FM 4 kHz deviation/5 kHz deviation.
  • 49.850 MHz - Channel 2
  • 49.870 MHz - Channel 3
  • 49.890 MHz - Channel 4
  • 49.830 MHz - Channel 1 (standard channel A)
  • 49.845 MHz - Channel 2 (standard channel B)
  • 49.860 MHz - Channel 3 (standard channel C)
  • 49.875 MHZ - Channel 4 (standard channel D)
Some 2 channel transmitters use arbitrary channel labeling, including:
  • 49.845 MHz - Channel X
  • 49.875 MHz - Channel Y
Other channel plans include
  • 49.830 MHz or 49.845 Channel A
  • 49.860 MHz or 49.890 Channel B
Or,
  • 49.850 MHz - Channel I
  • 49.870 MHz - Channel II
Most 2 channel devices use frequencies that are at least 20 kHz apart from each other. 3 channel equipment often use 30 kHz channel spacing.
  • 49.830 MHz - Channel A
  • 49.860 MHz - Channel B
  • 49.890 MHz - Channel C
Other equipment use random 10 kHz / 20 kHz channel spacing, with offsets from the standard 15 kHz channel steps.
  • 49.870 MHz - Channel 4
  • 49.880 MHz - Channel 5
  • 49.890 MHz - Channel 6
Covered under FCC Part 15 47 CFR 15.235 Operation within the band 49.82-49.90 MHz. Maximum bandwidth 10 kHz, de facto 15 kHz channel steps for R/C use. Sometimes frequencies may be off by several kHz. For example, 49.845 MHz may be closer to 49.840 MHz, 49.847 MHz or even 49.850 MHz, 49.860 MHz may be closer to 49.855 MHz, 49.865 MHz, etc. Low-cost toys and other devices may purposely use frequencies between channels such as 49.825 MHz, 49.870 MHz, etc.
