Emission Designator
Revision as of 14:06, 22 February 2024 by R4002 (Talk | contribs)
See also: Signal Identification
Often just the last 3 characters are used. For example, A3E or A3 to indicate AM voice or AM telephony, F3E or F3 to indicate FM voice or FM telephony. Other sources will omit characters. For example, 8K5F3E instead of 8K50F3E or 20KF3E or 12K F3E instead of 20K0F3E,12K0F3E etc. Some radio communications equipment manufacturers interchange designators for interoperable designators (for example, 16K0F3E and 20K0F3E). 16K0F3E and 16K0G3E are considered interchangeable, FCC licenses often list VHF marine radios as 16K0G3E voice emission mode.
  • Analog voice and data
  • 40K0F3E - military FM 10 kHz deviation - AN/VRC-12, AN/PRC-77 "WIDEBAND" mode for "X-mode" (see 36K0F1D and 40K0F1D)
  • 25K0F3E - 25 kHz wide LPRS 216-217 MHz wide band audio channels
  • 20K0F3E - Regular 5 kHz deviation "wideband" FM voice - used for land mobile systems below 150 MHz, including VHF low band 25-50 MHz
  • 20K0F3E - FM voice - amateur radio standard FM used 29 MHz and up - 25 kHz bandwidth (see also: 16K0F3E, 14K0F3E)
  • 20K0F3D - DMTF and other tone-based signalling systems, including ANI MDC1200 etc. - 5 kHz deviation
  • 18K0F3E - FM voice - 4.5 kHz FM deviation (similar to 16K0F3E 4 kHz FM deviation and 20K0F3E 5 kHz FM deviation) - cf. HTX-202 and HTX-404
  • 16K0F3E - military FM 30-88 MHz Datron HH7700, PRC1077 PRC-1077, PRC1060 PRC1080 25 kHz bandwidth mode - "wide band FM" 25 kHz channel spacing
  • 16K0F3E - 4 kHz deviation FM analog voice - used on the 800/900 MHz bands, VHF marine, VHF/UHF ham radio - 20K “middle band” on many land mobile radios
  • 16K0F3E - 25 kHz "25K" wide FM channel spacing +/- 5kHz deviation FM voice F3E mode - Alinco DR-135LH VHF low band export market radios
  • 16K0G3E - 4 kHz deviation PM analog phase modulation voice (considered identical to FM or 16K0F3E emission - VHF marine band radios)
  • 15K8F3E - MURS mobile radio (154.57 MHz and 154.6 MHz only) FM voice, considered functionally the same as 20K0F3E or 16K0F3E
  • 15K6F3E - 25 kHz channel 25K wideband FM mode (20K or 25K mode) TYT TH-9000D in 25K bandwidth mode - listed as 16K0F3E
  • 14K1F3E - Baofeng and other Chinese handheld and mobile radios "middle band" or "20K" bandwidth - MURS, GMRS
  • 14K0F3E - 20 kHz "20K" medium FM channel spacing +/- 4kHz deviation FM voice (per Alinco land mobile literature)
  • 12K0F3E - 3 kHz deviation, narrow FM voice - cf. HH7700, PRC1077, PRC1060, PRC1080 and other more modern military FM tactical radios
  • 11K5F3E - Narrow mode or NFM on Alinco DR-138 VHF Part 90 land mobile radio
  • 11K3F3D - Audio tone based selective calling or SELCALL systems - narrow band FM NFM
  • 11K3F3D - Audio frequency shift keying within a narrow band "12.5 kHz" channel
  • 11K2F3D - Audio tone based selective calling or SELCALL systems - narrow band FM NFM
  • 11K0F3E - 12.5 kHz "12K" or 12.5K narrow FM channel spacing +/- 2.5kHz deviation FM voice (per Alinco land mobile literature)
  • 11K0F3D - Audio tone based selective calling or SELCALL systems - narrow band FM NFM
  • 10K6F3E - Portable GMRS walkie talkies (Baofeng) based on the UV-82 and UV-5R radios - 10.59 kHz bandwidth, called 11K0F3E by manufacturer
  • 10K4F3E - Narrow 12K mode (12.5 kHz mode) Midland 40 watt GMRS mobile, TYT TH-9000D in 12K bandwidth mode - listed as 11K0F3E
  • 10K4F3E - Midland MXT400 emission on GMRS and FRS frequencies - modified version of TYT TH-9000D UHF mobile transceiver
  • 9K90F3E - Narrow FM voice, 9.9 kHz bandwidth - FRS wireless FM intercom systems NFM voice (compatible with 11K0F3E, 8K50F3E, etc.)
  • 9K84F3E - Narrow FM voice, 9.84 kHz bandwidth - FRS wireless FM intercom systems NFM voice (compatible with 11K0F3E, 8K50F3E, etc.)
  • 9K80F3D - Narrow FM NFM 9.8 kHz bandwidth 9.9 kHz bandwidth - Motorola FRS walkie talkies
  • 9K20F3E - Baofeng (and other Chinese radios) narrow FM mode (NFM mode or "NARR" deviation setting)
  • 9K20F3D - Baofeng (and other Chinese radios) narrow FM mode ANI, DTMF, tone burst 2-Tone, 5-Tone and other audio frequency selective calling systems
  • 9K10F3E - Baofeng (and other Chinese radios) narrow FM mode (NFM mode or "NARR" deviation setting)
  • 9K10F3D - Baofeng (and other Chinese radios) narrow FM mode ANI, DTMF, tone burst 2-Tone, 5-Tone and other audio frequency selective calling systems
  • 9K00F3E - FM mode on some modern CB radios (with FM mode capability, not legal bandwidth in USA per FCC rules)
  • 8K50F3E - Narrow mode on Alinco VHF and UHF FM transceivers (NFM, compliant with 11K0F3E/11K3F3E NFM 2.5 kHz deviation systems)
  • 8K00A3E - AM voice, double side band AM with carrier (8 kHz bandwidth) - maximum AM mode bandwidth permitted on MURS
  • 8K00A3E - Widest AM voice mode bandwidth permitted on 27 MHz CB per FCC Part 95 regulations
  • 8K00F3E - Widest FM voice mode bandwidth permitted on 27 MHz CB per FCC Part 95 regulations
  • 7K50F3E - Super narrow FM voice, narrow FM (not compliant with 6 kHz or 6.25 kHz bandwidth requirements)
  • 7K00F3E - Narrow FM, used on the 11 meter CB band where FM is legal on CB radio
  • 6K00A2D - Tone-modulated AM
  • 6K00A3D - Audio tone based selective calling or SELCALL systems over AM based systems
  • 6K00A3E - AM voice, double side band with carrier (6 kHz bandwidth) - used for CB and VHF aircraft band airband
  • 5K75F3E - FM voice, FM CB radio FM mode, dual AM FM mode radios eg. Cobra 29 LTD FM, Uniden PC78LTXFM
  • 5K58A3E - AM voice, indicated emission on Cobra mobile CB radio Cobra Mini 19 mobile CB radio AM CB
  • 4K00F3E - 4 kHz wide LPRS 216-217 MHz narrow band audio channels
  • 4K00H3E - Widest SSB voice (with full AM carrier) permitted on 27 MHz CB per FCC Part 95 regulations
  • 4K00R3E - Widest SSB voice (with reduced AM carrier, see also: H3E emission and J3E emission) permitted on 27MHz CB
  • 4K00J3E - Widest SSB voice mode bandwidth permitted on 27 MHz CB per FCC Part 95 regulations
  • 3K00R3E - SSB AC-SSB Amplitude Compandored Sideband (pilot tone or reduced carrier) voice (3 kHz)
  • 33M1D1D - 802.11a/b/g/n WiFi
  • 22M0G1D - 802.11a/b/g/n WiFi
  • 17M9GXW - 802.11n XBee WiFi OFDM modulation
  • 16M8GXW - 802.11g XBee WiFi OFDM modulation DSSS
  • 16M0D1D - 802.11a/b/g/n WiFi
  • 12M2GXW - 802.11b XBee Wi-Fi 802.11b DSSS digital spread spectrum modulation
  • 3M35F7W - XBee-PRO 900 900MHz band data radio Digi RF data radio 900MHz 902-928 MHz FSK
  • 478KK1D - Or 478K0K1D - 900 MHz vehicle transponders - Smart Tags 902-928 MHz band 902-928 MHz Location Narrowband (Non-multilateration)
  • 426KK1D - Or 478K0K1D - 900 MHz vehicle transponders - Smart Tags 902-928 MHz band 902-928 MHz Location Narrowband (Non-multilateration)
  • 350KF1D - or 350K0F1D - MaxStream 9XTend-PKG Wireless Modem 120kbps frequency hopping 902-928 MHz 900MHz band wireless modem
  • 293KF1D - or 293K0F1D - Digi XBee-PRO XSC QPSK modulation Digi RF data radio link
  • 250KF1D - or 250K0F1D - Itron Streetlight Network Interface Card (NIC) NIC 450 mesh network data transceiver SCADA 300kbps streetlamp control and telemetry system (902-928 MHz band)
  • 110KNON - or 110K0N0N TransCore transponder (902-928 MHz band) uplink 110 kHz wide signal - specific frequencies within the 900 MHz band
  • 40K0F1D - military FM 10 kHz secure voice X-MODE AN/VRC-12, AN/PRC-77 "WIDEBAND" mode for "X-mode" (see 36K0F3E and 40K0F3E)
  • 37K9F1D - Digi XBee-PRO 868 Digi RF data radio - FSK modulation
  • 37K5G1D - Wireless utility metering systems - including repeaters (frequency hopping)
  • 36K0F1D - military FM 8 kHz secure voice X-MODE AN/VRC-12, AN/PRC-77 "WIDEBAND" mode for "X-mode" (see 36K0F3E and 40K0F3E)
  • 25K0F2D - Wideband "FM" paging systems 26/27 MHz and 40 MHz bands - UK and European wideband on-site pagers
  • 25K0F2D - Digital PM - phase modulation (phase shift keying / frequency shift keying FSK)
  • 25K0F2E - Digital audio-frequency tone modulation (non voice)
  • 25K0G2D - Digital PM - phase modulation (phase shift keying PSK)
  • 25K0A2D - Digital amplitude-shift keying mixed PM (wideband) per Rockwell Collins aircraft radio experimental license literature
  • 24K0F1D - VHF/UHF Radio modems (radiomodems) for European market 169 MHz VHF/868 MHz UHF, 19200bps 19.2kbps (50 kHz bandwidth)
  • 22K0D1D - TETRA data
  • 22K0D7D - TETRA data
  • 20K0N0N - 900 MHz GPS telemetry links - 902-928 MHz Location Narrowband (Non-multilateration) licensed systems on specific frequencies
  • 20K0F7W - Referenced as the emission for Yaesu System Fusion C4FM Digital Voice YSF see also: 12K5F7W
  • 20K0F1D - 25 kHz bandwidth GMSK 19.2
  • 20K0F1D - FSK data, regular 5 kHz deviation - used for 72 MHz wireless clock systems, callboxes and other operational fixed purposes
  • 20K0F1D - Teledesign Systems Radio Modem (MURS channels 154.570 MHz and 154.600 MHz only)
  • 20K0F1D - wireless control and telemetry systems operating on the 154 MHz MURS channels 154.57 MHz or 154.6 MHz
  • 20K0F1D - 72-76 MHz VHF "mid band" licensed business on-site control, remote control, wireless control systems, etc.
  • 20K0F2D - general use for packet data - on amateur radio VHF/UHF bands for example
  • 20K0G3D - PSK - phase shift keying, 20 kHz bandwidth remote control RC radio control systems, various VHF/UHF bands
  • 20K0G1D - GPS RTK Data Radios - Wide mode
  • 20K0D1D - 902-928 MHz and 935-960 MHz Unlicensed and licensed fixed data link radios (wideband mode)
  • 20K0D1D - 64QAM data radio (regular 20 kHz bandwidth mode)
  • 19K6F1D - GPS RTK Data Radios - Wide mode
  • 19K6F1D - FFSK - GMSK data link radios, including Maxon VHF 136-174 MHz and UHF 450-490 MHz data radios telemetry radios
  • 19K0F1D - 4-level FSK data 4FSK data link radios (VHF/UHF bands, wide band setting)
  • 19K0D1W - P25 Project 25 2-slot TDMA P25 Phase II true TDMA, appearing on Phase II P25 licenses
  • 18K0F1D - VHF/UHF Radio modems (radiomodems) for European market 169 MHz VHF/868 MHz UHF, 9600bps 9.6kbps (25 kHz bandwidth)
  • 17K9F1D - GPS RTK Data Radios - Wide mode
  • 17K8F1D - GPS RTK Data Radios - Wide mode
  • 17K7D7D - Motorola "Astro 25" data - Motorola High Performance data Air Interface - wideband 25 kHz channel
  • 16K0F3D - Regular "wide"'5 kHz deviation FM audio frequency shift keying AFSK and DTMF signaling (Alinco literature)
  • 16K0F2D - Yaesu System Fusion Data ("Analog Data")
  • 16K0F2D - Regular "wide" 5 kHz deviation FM packet radio NFM mode packet radio mode (Alinco radio literature)
  • 16K0F1D - Regular "wide" 5 kHz deviation
  • 16K0F1D - Yaesu System Fusion Data ("Analog Data")
  • 16K0F1D - FSK telemetry, telecommand and data links (used on various VHF/UHF bands, including RC services in Europe
  • 16K0G2D - AIS on VHF marine band 161.975 MHz and 162.025 MHz
  • 16K0F3A - Tone-modulated CW (MCW) Morse code ID over regular 4 kHz deviation FM voice systems (most amateur radio VHF/UHF repeaters)
  • 15K0F1D - 20 kHz / 25 kHz wide RC links and telemetry (specialized systems operating below 150 MHz)
  • 14K5F1D - GPS RTK Data Radios - Wide mode
  • 14K4F1D - 25 kHz bandwidth GMSK 9.6
  • 12K5F7W - Yaesu System Fusion YSF C4FM Digital Voice + Data F7W emission see also: 11K2F7W, 9K36F7W and 9K36F1E
  • 12K0F1D - 26MHz band 27MHz band 29MHz band on-site paging systems (Europe)
  • 11K5F3D - Narrow FM audio frequency shift keying AFSK and DTMF signaling (Alinco literature)
  • 11K5F2D - Narrow FM packet radio NFM mode packet radio mode (Alinco radio literature)
  • 11K5F1D - Narrow FM packet radio NFM mode packet FSK mode (Alinco radio literature)
  • 11K3G3D - GPS RTK Data Radios - Narrow mode (12.5 kHz channel FCC narrowband compliant)
  • 11K3F2D - Data links on VHF/UHF land mobile bands, including IFLOWS fixed point to point hydrologic data systems and MURS
  • 11K2F7W - Yaesu System Fusion C4FM digital voice DV YSF C4FM DV 4FSK modified P25 vocoder
  • 11K2F1D - Teledesign Radio Modem (146-174 MHz Part 90, also MURS frequencies 151.820 MHz, 151.880 MHz and 151.940 MHz)
  • 11K2F2B - Data link, telemetry, datalink and other data modes emission on MURS frequencies 151.820, 151.880 and 151.940 MHz
  • 11K0F2D - GPS location data packets and/or text message or group chat messages over FRS and/or GMRS radios (narrow band mode)
  • 11K0F2D - Data links on VHF/UHF land mobile bands, including IFLOWS fixed point to point hydrologic data systems
  • 11K0F1D - 4-level FSK data 4FSK data link radios (VHF/UHF bands, narrow band 12.5 kHz setting)
  • 11K0F1D - GPS location data packets and/or text message or group chat messages over FRS and/or GMRS radios (narrow band mode)
  • 11K0F3A - Tone-modulated CW (MCW) Morse code ID over narrowband FM voice radio system (land mobile systems above 150 MHz)
  • 10K4F2D - SCADA link telemetry radios (narrowband radio links) 146-174 MHz, 154-174 MHz, 406-470 MHz (CW ID 10K4F3E or 10K4F3A)
  • 10K0F1D - FSK remote control FM RC systems, 10 kHz bandwidth
  • 10K0D1D - 902-928 MHz and 935-960 MHz Unlicensed and licensed fixed data link radios (narrowband mode)
  • 10K0D1D - 64QAM data radio (narrow 12.5 kHz bandwidth mode)
  • 9K80D7W - P25 Project 25 2-slot TDMA P25 Phase II - see also: 8K70D1W
  • 9K80F1D - GPS RTK Data Radios - Narrow mode (12.5 kHz channel FCC narrowband compliant)
  • 9K75F1D - GPS RTK Data Radios - Narrow mode (12.5 kHz channel FCC narrowband compliant)
  • 9K84F2D - Motorola FRS walkie talkies with GPS location transmission and/or text message or group chat capability (FSK signals, narrowband)
  • 9K80F1D - Locomotive data link and wireless control (telecommand) telemetry transceiver UHF emission 450-470 MHz
  • 9K50F2D - FSK data, digital link, data, telemetry, telecommand (noted on public safety licenses)
  • 9K50F1D - FSK data, digital link, data, telemetry, telecommand (noted on public safety licenses)
  • 9K36F7W - Yaesu System Fusion YSF combined Yaesu C4FM (Voice Wide * Voice Narrow + Data * Data Wide) - see: 12K5F7W
  • 9K36F1E - Yaesu System Fusion YSF Yaesu C4FM digital voice
  • 9K30F1D - EOD Robot Remote control
  • 9K20F3D - DTMF selective calling, ANI - automatic number identification, including end of transmission DTMF bursts
  • 9K20F1D - EOD Robot Remote control
  • 9K10F3D - DTMF selective calling, ANI - automatic number identification, including end of transmission DTMF bursts
  • 9K00F1D - GPS RTK data links, GPS dog tracking transmitters
  • 9K00F1D - VHF/UHF Radio modems (radiomodems) for European market 169 MHz VHF/868 MHz UHF, 4800bps 4.8kbps (12.5 kHz bandwidth)
  • 8K84F1D - MURS VHF dog collar GPS transmitters - FSK F1D data mode
  • 8K80F1D - MURS VHF dog collar GPS transmitters dog training wireless FSK F1D emission
  • 8K70D1W - P25 Project 25 Linear Simulcast Modulation ASTRO (9.6 kbps in 12.5 kHz channelspace)
  • 8K60F1D - GPS RTK Data Radios - Narrow mode (12.5 kHz channel FCC narrowband compliant)
  • 8K50F3D - Narrow FM audio frequency shift keying AFSK and DTMF signaling (Alinco literature)
  • 8K50F2D - Narrow FM packet radio NFM mode packet radio mode (Alinco radio literature)
  • 8K50F2D - Packet radio - narrow band mode per Alinco amateur radio documentation (8K50F3E data mode)
  • 8K50F1D - Narrow FM packet radio NFM mode packet FSK mode (Alinco radio literature)
  • 8K50F1D - Locomotive data link and wireless control (telecommand) telemetry transceiver VHF 217-222 MHz band 1.85 kHz FSK deviation
  • 8K40F1E - P25 Project 25 Voice - P25 Phase I C4FM voice (per APCO)
  • 8K40F1D - P25 Project 25 Data - P25 Phase I C4FM data (per APCO)
  • 8K34F1D - GPS RTK Data Radios - Narrow mode (12.5 kHz channel FCC narrowband compliant)
  • 8K30F1W - NXDN, IDAS or NEXEDGE Wideband 12.5 kHz - Digital voice + data combined
  • 8K00G1D - BPSK data
  • 8K00A1D - 8 kHz AFSK - AM remote control, 26-28 MHz band, 72-76 MHz band, 49 MHz band/27 MHz band
  • 7K90F1D - GPS RTK Data Radios - Narrow mode (12.5 kHz channel FCC narrowband compliant)
  • 7K75F1D - Wireless dog training collar remote control transmitter (27 MHz - 27.145 MHz / 27.195 MHz)
  • 7K64F1D - Wireless dog training remote transmitter (510mW output) on 27.195 MHz (Part 95 Subpart C RCRS)
  • 7K00F1D - GPS data link for radio collars / GPS collars (MURS frequencies 151.82 MHz, 151.88 MHz, 151.94 MHz, 154.57 MHz and 154.6 MHz)
  • 6K50A2D - AM mode amplitude frequency shift keying (audio frequency shift using AM modulation) - 6.5 kHz bandwidth, may be used on Part 95 Subpart C RCRS radio control systems
  • 6K50A1D - AM mode telemetry - including amplitude shift keying (ASK)
  • 6K40F1D - 3.2 kHz deviation FSK radio-on-a-chip (used for many 26 MHz/27 MHz low power Part 15 devices with FSK modulation)
  • 6K00F7W - Mixed analog/digital use, technically incorrect per FCC rules, but widely found on licenses 6.0 kHz bandwidth
  • 6K00F7W - Icom D-STAR digital voice D-STAR DSTAR 6.25 kHz bandwidth DV amateur radio ham radio digital voice GMSK modulation AMBE vocoder with FEC
  • 6K00F2A - D-STAR ID transmissions (per Icom literature) - Tone-modulated CW ID over FM voice channel
  • 6K00F1D - SCADA, data links, carrier FSK, telecommand (R/C, remote control and radio control systems 25 MHz and above)
  • 6K00F2D - Frequency modulated digital data (FSK) without modulating sub-carrier (6 kHz bandwidth)
  • 6K00A2D - Amplitude shift keying (AM) R/C systems - including those operating in the 26-28 MHz band
  • 6K00D2D - Amplitude shift keying combined with frequency shift keying subcarrier (amplitude and phase/frequency are both modulated)
  • 6K00D1D - Amplitude shift keying combined with frequency shift keying (amplitude and phase/frequency are both modulated)
  • 5K00D1D - 64QAM data radio (super narrow 6 kHz bandwidth mode)
  • 5K00F1D - VHF and UHF narrow band FSK, data link and paging
  • 4K34F1D - VHF MURS based dog training and tracking devices
  • 4K25F1D - VHF MURS based dog training and tracking devices
  • 4K00F7W - NDXN, IDAS or NEXEDGE Narrowband 6.25 kHz - Digital voice + data combined
  • 4K00F2D - NDXN, IDAS or NEXEDGE Narrowband 6.25 kHz
  • 4K00F1D - 4 kHz wide LPRS 216-217 MHz narrow band law enforcement vehicle tracking and data link systems
  • 4K00F1W - NXDN, IDAS or NEXEDGE Narrowband 6.25 kHz - Digital voice + data combined (may be used incorrectly, some sources indicate 4K00F7W should be used)
  • 3K00J2D - Narrowband amplitude shift keying (used for specialty datalink systems)
  • 3K00N0N - 3 kHz OOK on off keying remote control
  • 3K00F1D - Narrow band FSK signals (noted use on HF)
  • 2K80J2D - PACTOR-III
  • 2K50F1D - Narrow band FSK data link, noted use in the 26-28 MHz band during band openings
