VHF LADD
Revision as of 18:10, 21 February 2024 by R4002 (Talk | contribs)
Trucking and Resource Roads Channels Canada Alaska
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth or 16K0F3E emission) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth - also known as 11K3F3E emission, 11K2F3E emission or 11K0F3E emission). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies. Receivers must be set for carrier squelch or CSQ mode.
Channel Frequency Remarks/Usage
LADD 1 154.1000 MHz LADD channel 1 - trucking and logging companies, natural resource agencies
LADD 2 158.9400 MHz LADD channel 2 - trucking and logging companies, natural resource agencies
LADD 3 154.3250 MHz LADD channel 3 - trucking and logging companies, natural resource agencies
LADD 4 173.3700 MHz LADD channel 4 - trucking and logging companies, natural resource agencies
LD-1 151.7000 MHz Loading Channel 1
LD-2 151.7450 MHz Loading Channel 2
LD-3 151.7900 MHz Loading Channel 3
LD-4 151.8050 MHz Loading Channel 4
LD-5 151.8500 MHz Loading Channel 5
LD-6 150.4850 MHz Loading Channel 6
LD-7 153.2150 MHz Loading Channel 7
LD-8 154.6650 MHz Loading Channel 8
LD-9 152.3300 MHz Loading Channel 9
LD-10 153.6350 MHz Loading Channel 10
LD-11 157.5900 MHz Loading Channel 11
LD-12 159.7500 MHz Loading Channel 12
LD-13 164.0100 MHz Loading Channel 13
LD-14 165.9600 MHz Loading Channel 14
RR-01 150.0800 MHz Resource Road channel 1
RR-02 150.1100 MHz Resource Road channel 2
RR-03 150.1400 MHz Resource Road channel 3
RR-04 150.1850 MHz Resource Road channel 4
RR-05 150.2000 MHz Resource Road channel 5
RR-06 150.2450 MHz Resource Road channel 6
RR-07 150.2600 MHz Resource Road channel 7
RR-08 150.3200 MHz Resource Road channel 8
RR-09 150.3650 MHz Resource Road channel 9
RR-10 150.4100 MHz Resource Road channel 10
RR-11 150.4400 MHz Resource Road channel 11
RR-12 150.5000 MHz Resource Road channel 12
RR-13 150.5300 MHz Resource Road channel 13
RR-14 150.5450 MHz Resource Road channel 14
RR-15 150.5600 MHz Resource Road channel 15
RR-16 150.5900 MHz Resource Road channel 16
RR-17 150.6800 MHz Resource Road channel 17
RR-18 150.7100 MHz Resource Road channel 18
RR-19 150.7700 MHz Resource Road channel 19
RR-20 150.8300 MHz Resource Road channel 20
RR-21 151.0100 MHz Resource Road channel 21
RR-22 151.1300 MHz Resource Road channel 22
RR-23 151.1900 MHz Resource Road channel 23
RR-24 151.2200 MHz Resource Road channel 24
RR-25 151.3100 MHz Resource Road channel 25
RR-26 151.3400 MHz Resource Road channel 26
RR-27 151.3700 MHz Resource Road channel 27
RR-28 151.4300 MHz Resource Road channel 28
RR-29 151.4600 MHz Resource Road channel 29
RR-30 151.4900 MHz Resource Road channel 30
RR-31 151.5200 MHz Resource Road channel 31
RR-32 151.5800 MHz Resource Road channel 32
RR-33 151.6100 MHz Resource Road channel 33
RR-34 151.6400 MHz Resource Road channel 34
RR-35 151.6400 MHz Resource Road channel 35
Channel Use Location Information Official Resource Road Channel Allocations
See this official list of Natural Resource Roads LADD LD RR Resource Road VHF Radio Channel Frequency Channel Location Use Maps - kilometer signs with call-in channels are listed on the roads where use of these frequencies are required (link below).
[1]
