Revision as of 18:51, 30 August 2018 by R4002 (Talk | contribs)
CB is one of the most commonly used two-way and land mobile radio services worldwide, although for handheld walkie-talkie purposes it has mostly been depreciated in favor of VHF/UHF services such as FRS/GMRS and MURS. CB is still heavily used by trucking companies, hunting clubs, farmers, rednecks, doomsday preppers, for local and/or unlicensed paging or data link/telemetry systems,etc and as an inexpensive short-range alternative to licensed services such as the licensed Business Radio Services. Hunters are such a prolific user of CB equipment that export radio companies such as RCI/Ranger have produced radios designed specifically for hunters, such as the Connex Deer Hunter (26.065-27.405 MHz), Connex Coyote Hunter (25.615-27.405 MHz) and Superstar 121 (26.515-27.855 MHz) which cover the lower freeband frequencies often used by hunters. See also JAKT Radio 31MHz
Team MX-10, a typical multi-norm European AM/FM CB radio. Using the radio's menu, the user selects the country they intend to operate the radio in, and the radio loads the appropriate channel plan. Like many multi-norm radios, the MX-10 can be programmed for "RU" or Russian band plan, which is both 25.610 MHz to 30.110 MHz and 25.615 to 30.105 MHz
Galaxy DX 959, a typical AM/SSB "American style" CB radio, easily modifiable to cover 26.695 MHz to 27.965 MHz without any additional boards, or the 120 channel lower/mid/upper freeband plan 26.515 to 27.855 MHz with easy-to-install channel frequency expansion boards.
Superstar 121 AM/FM 26.515-27.855 MHz hunting radio 3 bands (LOW/MID/HIGH) or (C/D/E) of 40 channels for a total of 120 channels. On this radio, the mid band or D band is the legal CB band - all three of these radios are marketed towards the hunter CB radio market - they are simple radios with access to additional frequencies. The Connex Deer Hunter and Coyote Hunter radios offer access to the lower channels, which are popular with hunting clubs in the United States. The Superstar 121 is a very popular hunting radio even though it also provides access to the high band of 27.415-27.855 MHz in addition to the low band of 26.515-26.955 MHz and the regular CB band 26.965-27.405 MHz. The Deer Hunter and Coyote Hunter radios have the CB band as the highest band available.
CB is generally license free worldwide, although frequency allocations, modes and power limits vary from country to country. However, these limits are often ignored and enforcement is extremely lax. Use of "10-meter" or "export" radios is common. These radios offer the user the option of 40 channels plus a band switch, the band switch going up or down 450 kHz (0.450 MHz, or 45 channels). Common export radio frequency coverage includes 25.615-28.305 MHz (standard 6-band export plan), 25.165 MHz - 28.755 MHz (Galaxy DX radios 8-band plan), 25.615 MHz - 30.105 MHz ("RU" or "export" plan, often included in European radios and Chinese 10 meter rigs such as the Anytone AT-5555 and its various clones), and 24.265 MHz - 29.655 MHz (12 meter/10 meter coverage radios such as the Superstar SS-158EDX and its various clones). Others include 25.165 MHz - 30.105 MHz, 25.615 MHz - 30.555 MHz, 26.000 MHz - 32.000 MHz (RCI-2950 and RCI-2970 series radios) and the "three band" or "uppers and lowers" coverage of 26.515 MHz - 27.855 MHz (see discussion regarding "hunting radios" above). Most exports at least have access to the high band of 27.415 MHz to 27.855 MHz and the low band of 26.515 MHz to 26.955 MHz, so the majority of out-of-band communications take place between 26.515 MHz and 27.855 MHz.
25.070 MHz to 25.121 MHz HF-SSB marine (maritime mobile radio service, 3 kHz steps) - shared with 25020-25320 kHz 25.020 MHz to 25.320 MHz Business/Industrial Radio Service (FM mode, shared with 25070-25121 kHz marine HF SSB) 25.550 MHz to 25.670 MHz Radio Astronomy and is supposed to be clear of stations 25.600 MHz to 26.100 MHz 11 meter shortwave broadcast band SWBC or HFBC band. Rarely used. Some DRM tests done here. 26.145 MHz to 26.175 MHz HF-SSB marine (maritime mobile radio service, 3 kHz steps) 25.870 MHz to 26.470 MHz Remote Broadcast Pickup (Studio Transmitter Link or STL) service 27.430 MHz to 27.530 MHz Business/Industrial Radio Service (20 kHz steps, FM mode) 27.555, 27.615, 27.635, 27.655, 27.765, and 27.860 MHz Forest Products Radio Service on a secondary basis (only in certain areas, with maximum 150 watts output power) 29.710 MHz to 29.790 MHz Business/Industrial Radio Service (20 kHz steps, FM mode)
Frequency Range Remarks
Frequency Remarks
25.950 MHz 5 active licenses
25.200 MHz 0 active licenses
25.160 MHz 0 active licenses
25.120 MHz 0 active licenses
See the bottom of this page for R/C, radio control, remote control, RC, telecommand, telemetry, etc frequencies.
CB Channel Frequency
Channel 1 26.965 MHz
Channel 2 26.975 MHz
Channel 3 26.985 MHz
Channel 4 27.005 MHz
Channel 5 27.015 MHz
Channel 6 27.025 MHz
Channel 7 27.035 MHz
Channel 8 27.055 MHz
Channel 9 27.065 MHz
Channel 10 27.075 MHz
Channel 11 27.085 MHz
Channel 12 27.105 MHz
Channel 13 27.115 MHz
Channel 14 27.125 MHz
Channel 15 27.135 MHz
Channel 16 27.155 MHz
Channel 17 27.165 MHz
Channel 18 27.175 MHz
Channel 19 27.185 MHz
Channel 20 27.205 MHz
Channel 21 27.215 MHz
Channel 22 27.225 MHz
Channel 23 27.255 MHz
Channel 24 27.235 MHz
Channel 25 27.245 MHz
Channel 26 27.265 MHz
Channel 27 27.275 MHz
Channel 28 27.285 MHz
Channel 29 27.295 MHz
Channel 30 27.305 MHz
Channel 31 27.315 MHz
Channel 32 27.325 MHz
Channel 33 27.335 MHz
Channel 34 27.345 MHz
Channel 35 27.355 MHz
Channel 36 27.365 MHz
Channel 37 27.375 MHz
Channel 38 27.385 MHz
Channel 39 27.395 MHz
Channel 40 27.405 MHz
FM (Frequency Modulation)
Channel 1 27.60125 MHz
Channel 2 27.61125 MHz
Channel 3 27.62125 MHz
Channel 4 27.63125 MHz
Channel 5 27.64125 MHz
Channel 6 27.65125 MHz
Channel 7 27.66125 MHz
Channel 8 27.67125 MHz
Channel 9 27.68125 MHz
Channel 10 27.69125 MHz
Channel 11 27.70125 MHz
Channel 12 27.71125 MHz
Channel 13 27.72125 MHz
Channel 14 27.73125 MHz
Channel 15 27.74125 MHz
Channel 16 27.75125 MHz
Channel 17 27.76125 MHz
Channel 18 27.77125 MHz
Channel 19 27.78125 MHz
Channel 20 27.79125 MHz
Channel 21 27.80125 MHz
Channel 22 27.81125 MHz
Channel 23 27.82125 MHz
Channel 24 27.83125 MHz
Channel 25 27.84125 MHz
Channel 26 27.85125 MHz
Channel 27 27.86125 MHz
Channel 28 27.87125 MHz
Channel 29 27.88125 MHz
Channel 30 27.89125 MHz
Channel 31 27.90125 MHz
Channel 32 27.91125 MHz
Channel 33 27.92125 MHz
Channel 34 27.93125 MHz
Channel 35 27.94125 MHz
Channel 36 27.95125 MHz
Channel 37 27.96125 MHz
Channel 38 27.97125 MHz
Channel 39 27.98125 MHz
Channel 40 27.99125 MHz
[1]
Channel 41 26.565 MHz
Channel 42 26.575 MHz
Channel 43 26.585 MHz
Channel 44 26.595 MHz
Channel 45 26.605 MHz
Channel 46 26.615 MHz
Channel 47 26.625 MHz
Channel 48 26.635 MHz
Channel 49 26.645 MHz
Channel 50 26.655 MHz
Channel 51 26.665 MHz
Channel 52 26.675 MHz
Channel 53 26.685 MHz
Channel 54 26.695 MHz
Channel 55 26.705 MHz
Channel 56 26.715 MHz
Channel 57 26.725 MHz
Channel 58 26.735 MHz
Channel 59 26.745 MHz
Channel 60 26.755 MHz
Channel 61 26.765 MHz
Channel 62 26.775 MHz
Channel 63 26.785 MHz
Channel 64 26.795 MHz
Channel 65 26.805 MHz
Channel 66 26.815 MHz
Channel 67 26.825 MHz
Channel 68 26.835 MHz
Channel 69 26.845 MHz
Channel 70 26.855 MHz
Channel 71 26.865 MHz
Channel 72 26.875 MHz
Channel 73 26.885 MHz
Channel 74 26.895 MHz
Channel 75 26.905 MHz
Channel 76 26.915 MHz
Channel 77 26.925 MHz
Channel 78 26.935 MHz
Channel 79 26.945 MHz
Channel 80 26.955 MHz
Channel 1 26.330 MHz
Channel 2 26.340 MHz
Channel 3 26.350 MHz
Channel 4 26.370 MHz
Channel 5 26.380 MHz
Channel 6 26.390 MHz
Channel 7 26.400 MHz
Channel 8 26.420 MHz
Channel 9 26.430 MHz
Channel 10 26.440 MHz
Channel 11 26.450 MHz
Channel 12 26.470 MHz
Channel 13 26.480 MHz
Channel 14 26.490 MHz
Channel 15 26.500 MHz
Channel 16 26.520 MHz
Channel 17 26.530 MHz
Channel 18 26.540 MHz
Channel 19 26.550 MHz
Channel 20 26.570 MHz
Channel 21 26.580 MHz
Channel 22 26.590 MHz
Channel 23 26.620 MHz
Channel 24 26.600 MHz
Channel 25 26.610 MHz
Channel 26 26.630 MHz
Channel 27 26.640 MHz
Channel 28 26.650 MHz
Channel 29 26.660 MHz
Channel 30 26.670 MHz
Channel 31 26.680 MHz
Channel 32 26.690 MHz
Channel 33 26.700 MHz
Channel 34 26.710 MHz
Channel 35 26.720 MHz
Channel 36 26.730 MHz
Channel 37 26.740 MHz
Channel 38 26.750 MHz
Channel 39 26.760 MHz
Channel 40 26.770 MHz
Channel 1 26.968 MHz
Channel 2 26.976 MHz
Channel 3 27.040 MHz
Channel 4 27.080 MHz
Channel 5 27.088 MHz
Channel 6 27.112 MHz
Channel 7 27.120 MHz
Channel 8 27.144 MHz
Channel 26760 26.760 MHz
Channel 26768 26.768 MHz
Channel 26776 26.776 MHz
Channel 26824 26.824 MHz
Channel 26840 26.840 MHz
Channel 26848 26.848 MHz
Channel 26856 26.856 MHz
Channel 26864 26.864 MHz
Channel 26872 26.872 MHz
Channel 26880 26.880 MHz
Channel 26888 26.888 MHz
Channel 26896 26.896 MHz
Channel 26912 26.912 MHz
Channel 26920 26.920 MHz
Channel 26928 26.928 MHz
Channel 26936 26.936 MHz
Channel 26944 26.944 MHz
Channel 27016 27.016 MHz
Channel 27524 27.524 MHz
Channel 27532 27.532 MHz
Channel 27540 27.540 MHz
Channel 27548 27.548 MHz
Channel 27556 27.556 MHz
Channel 27572 27.572 MHz
Channel 27580 27.580 MHz
Channel 27628 27.628 MHz
Channel 27636 27.636 MHz
Channel 27644 27.644 MHz
Channel 27652 27.652 MHz
Channel 27660 27.660 MHz
Channel 27668 27.668 MHz
Channel 27676 27.676 MHz
Channel 27724 27.724 MHz
Channel 27732 27.732 MHz
Channel 27740 27.740 MHz
Channel 27748 27.748 MHz
Channel 27756 27.756 MHz
Channel 27764 27.764 MHz
Channel 27772 27.772 MHz
Channel 27780 27.780 MHz
Channel 27828 27.828 MHz
Channel 27836 27.836 MHz
Channel 27852 27.852 MHz
Channel 27860 27.860 MHz
Channel 27884 27.884 MHz
Channel 27892 27.892 MHz
Channel 27908 27.908 MHz
Channel 27916 27.916 MHz
Channel 27932 27.932 MHz
Channel 27940 27.940 MHz
Channel 27956 27.956 MHz
Channel 27964 27.964 MHz
Channel 27980 27.980 MHz
Channel 27988 27.988 MHz
27310.5 kHz 27.3105 MHz
27334.5 kHz 27.3345 MHz
27338.5 kHz 27.3385 MHz
27342.5 kHz 27.3425 MHz
27346.5 kHz 27.3465 MHz
27350.5 kHz 27.3505 MHz
27354.5 kHz 27.3545 MHz
27358.5 kHz 27.3585 MHz
27362.5 kHz 27.3625 MHz
27366.5 kHz 27.3665 MHz
27370.5 kHz 27.3705 MHz
27378.5 kHz 27.3785 MHz
27382.5 kHz 27.3825 MHz
27386.5 kHz 27.3865 MHz
27388.5 kHz 27.3885 MHz
27398.5 kHz 27.3985 MHz
27404.5 kHz 27.4045 MHz
27418.5 kHz 27.4185 MHz
27426.5 kHz 27.4265 MHz
27434.5 kHz 27.4345 MHz
27442.5 kHz 27.4425 MHz
27452.5 kHz 27.4525 MHz
27458.5 kHz 27.4585 MHz
27466.5 kHz 27.4665 MHz
27470.5 kHz 27.4705 MHz
Channel 41 27.415 MHz
Channel 42 27.425 MHz
Channel 43 27.435 MHz
Channel 44 27.455 MHz
Channel 45 27.465 MHz
Channel 46 27.475 MHz
Channel 47 27.485 MHz
Channel 48 27.505 MHz
Channel 49 27.515 MHz
Channel 50 27.525 MHz
Channel 51 27.535 MHz
Channel 52 27.555 MHz
Channel 53 27.565 MHz
Channel 54 27.575 MHz
Channel 55 27.585 MHz
Channel 56 27.605 MHz
Channel 57 27.615 MHz
Channel 58 27.625 MHz
Channel 59 27.635 MHz
Channel 60 27.655 MHz
Channel 61 27.665 MHz
Channel 62 27.675 MHz
Channel 63 27.685 MHz
Channel 64 27.695 MHz
Channel 65 27.705 MHz
Channel 66 27.715 MHz
Channel 67 27.725 MHz
Channel 68 27.735 MHz
Channel 69 27.745 MHz
Channel 70 27.755 MHz
Channel 71 27.765 MHz
Channel 72 27.775 MHz
Channel 73 27.785 MHz
Channel 74 27.795 MHz
Channel 75 27.805 MHz
Channel 76 27.815 MHz
Channel 77 27.825 MHz
Channel 78 27.835 MHz
Channel 79 27.845 MHz
Channel 80 27.855 MHz
26.575 MHz Germany
26.675 MHz
26.685 MHz Western Russia
26.915 MHz
26.925 MHz
26.935 MHz
26.970 MHz Lithuania
26.985 MHz Tver, Russia
27.000 MHz Kiev, Ukraine
27.030 MHz Minsk, Belarus
27.040 MHz Minsk, Belarus
27.060 MHz Kiev, Ukraine
27.070 MHz
27.075 MHz Eastern Russia
27.100 MHz Krasnodar, Russia
27.105 MHz Astana, Kazakhstan
27.110 MHz Poland
27.110 MHz Russia
27.135 MHz Moscow, Russia
27.150 MHz Poland
27.165 MHz Issyk, Kazakhstan
27.170 MHz Poland
27.175 MHz Taraz, Kazakhstan
27.190 MHz
27.200 MHz Zaykova, Russia
27.205 MHz Sweden DTMF-activated playback
27.215 MHz Almaty, Kazakhstan
27.220 MHz
27.230 MHz
27.235 MHz
27.250 MHz Belarus
27.270 MHz Saratov, Russia
27.270 MHz Kiev, Ukraine
27.290 MHz Minsk, Belarus
27.295 MHz Tyumen, Russia
27.300 MHz
27.305 MHz Western Europe
27.325 MHz
27.335 MHz Almaty, Kazakhstan
27.370 MHz Western Russia
27.430 MHz
27.450 MHz
27.470 MHz
27.505 MHz Moscow, Russia
27.580 MHz Moscow, Russia
27.605 MHz Moscow, Russia
27.630 MHz Moscow, Russia
27.635 MHz Moscow, Russia
27.635 MHz St. Petersburg, Russia
27.650 MHz Western Europe
27.675 MHz Russia
27.765 MHz Germany
27.840 MHz Poland
27.875 MHz Rostov, Russia
US "A" or "RC" channels
These frequencies are used throughout the world, often in conjunction with locally authorized frequencies. In the United States, 27.255 MHz (CB Channel 23) is shared with telecommand/telemetry systems in addition to RC. Paging and local telemetry systems often use 27.255 MHz because FCC rules permit high power transmission on this frequency. Ref FCC Rules Part 95 95.207 and 95.210 47CFR95.207 and 47CFR95.210 Local paging systems, on-site telemetry, lightning detector systems, and wireless PA systems have been reported to use 27.255 MHz. During band openings, paging and other FSK signals can often be heard on 27.255MHz. Most of these signals have a bandwidth of 6-8 kHz. FCC rules allow a maximum bandwidth of 8 kHz for data signals on frequencies from 26.995 to 27.255 MHz.
For example, the Linear Systems Xtended Range data transmitter system uses FM-FSK on 27.255 MHz with 10 watts carrier power and 8 kHz bandwidth under Part 95. Radioshack used to sell an on-site paging system that transmitted FM POCSAG on 27.255 MHz with 7 watts carrier power. 27.255 MHz (channel 23) offers surprisingly long range at higher power levels with quality antenna systems. With a 27255 kHz transmitter doing 10-20 watts carrier power and a strategically placed transmitter, one could cover a substantial portion of an urbanized area. Testing with 10 watt carrier power FSK transmitters on 27.255 MHz using base station CB antennas showed ranges of 20+ miles with very little loss in signal strength and no data loss.
FCC rules permit a maximum of 4 watts transmitter power on 26.995 MHz, 27.045 MHz, 27.095 MHz, 27.145 MHz and 27.195 MHz and 25 watts maximum transmitter power on 27.255 MHz FCC rules provide for FSK and FM modes (for data transmission) as well on 27.255 MHz. Due to the higher power allowed on 27.255 MHz, it is often used for unlicensed on-site paging and telemetry systems. FCC rules permit remote monitoring, status alerts, and one-way transmissions on the six RC frequencies, allowing for considerably more flexibility in designing license-free datalink systems that offer impressive range.
CB Channel RC Channel RC Color Code Frequency
Channel "3A" Channel 1 Brown 26.995 MHz
Channel "7A" Channel 2 Red 27.045 MHz
Channel "11A" Channel 3 Orange 27.095 MHz
Channel "15A" Channel 4 Yellow 27.145 MHz
Channel "19A" Channel 5 Green 27.195 MHz
Channel 23 Channel 6 Blue 27.255 MHz
UK RC Channels
Maximum power output 100mW
Black 26.975 MHz
Brown 26.995 MHz
Brown-Red 27.025 MHz
Red 27.045 MHz
Red-Orange 27.075 MHz
Orange 27.095 MHz
Orange-Yellow 27.125 MHz
Yellow 27.145 MHz
Yellow-Green 27.175 MHz
Green 27.195 MHz
Green-Blue 27.225 MHz
Blue 27.245 MHz
White (or Purple) 27.275 MHz
Australian 27 MHz RC and 29 MHz RC Channels
Australia RC Channel Frequency
Channel 1 26.995 MHz
Channel 2 27.045 MHz
Channel 3 27.095 MHz
Channel 4 27.145 MHz
Channel 6 27.195 MHz
Channel 10 29.725 MHz
Channel 11 29.735 MHz
Channel 12 29.745 MHz
Channel 13 29.755 MHz
Channel 14 29.765 MHz
Channel 15 29.775 MHz
Channel 16 29.785 MHz
Channel 17 29.795 MHz
Channel 18 29.805 MHz
Channel 19 29.815 MHz
Channel 20 29.825 MHz
Channel 21 29.835 MHz
Channel 22 29.845 MHz
Channel 23 29.855 MHz
Channel 24 29.865 MHz
Channel 25 29.875 MHz
Channel 26 29.885 MHz
Channel 27 29.895 MHz
Channel 28 29.905 MHz
Channel 29 29.915 MHz
Channel 30 29.925 MHz
Channel 31 29.935 MHz
Channel 32 29.945 MHz
Channel 33 29.955 MHz
Channel 34 29.965 MHz
Channel 35 29.975 MHz
Channel 36 29.985 MHz
New Zealand 27 MHz RC and 29 MHz RC Channels
Similar to American and Australian RC frequency allocations. Different channel numbering system. 26.975-27.280 MHz and 29.725-29.985 MHz. 20 kHz channel steps 29.7-30 MHz instead of 10 kHz steps like the Australian system. 100mW maximum output power under New Zealand law.
NZ RC Channel Frequency
Channel 197 26.975 MHz
Channel 199 26.995 MHz
Channel 102 27.020 MHz
Channel 104 27.045 MHz
Channel 107 27.070 MHz
Channel 109 27.095 MHz
Channel 112 27.120 MHz
Channel 114 27.145 MHz
Channel 117 27.170 MHz
Channel 119 27.195 MHz
Channel 122 27.220 MHz
Channel 124 27.245 MHz
Channel 128 27.280 MHz
Channel 272 29.725 MHz
Channel 274 29.745 MHz
Channel 276 29.765 MHz
Channel 278 29.785 MHz
Channel 280 29.805 MHz
Channel 282 29.825 MHz
Channel 284 29.845 MHz
Channel 286 29.865 MHz
Channel 288 29.885 MHz
Channel 290 29.905 MHz
Channel 292 29.925 MHz
Channel 294 29.945 MHz
Channel 296 29.965 MHz
Channel 298 29.985 MHz
