SINCGARS
Revision as of 14:43, 20 December 2018 by R4002 (Talk | contribs)
Two handheld VHF-FM tactical radios Datron HH7700 30-88 MHz, with no frequency hopping capability, the radio below is a vehicle-mounted VHF-FM military tactical radio
VHF-FM tactical radio system, with frequency-hopping and voice encryption/data encryption capabilities. Operating in the 30.000 to 87.975 MHz frequency band with 25 kHz channel steps. Uses 150.0 Hz CTCSS squelch system. Operates in single-channel (SC) and frequency-hopping (FH) modes for voice and data. Most radios include repeater capability (called RETRANS or retransmit in military usage). Compatible with previous-generation FM radios such as the PRC-25, PRC-77, PRC-1077, HH7700 and dozens of other similar tactical handheld, manpack and vehicle-mounted radios operating in the 30-76 MHz or 30-88 MHz range. NATO military forces and many other military forces use similar frequencies for tactical purposes, almost always with FM voice. The US military fields radios that operate in the 30-174 MHz and 30-512 MHz ranges to support SINCGARS, regular VHF-FM, 136-174 MHz VHF-high band services like VHF marine, aircraft radios, SATCOM and interoperability with other radio systems that use VHF/UHF.
Frequency Band
30.000 MHz to 30.550 MHz
32.000 MHz to 33.000 MHz
34.000 MHz to 35.000 MHz
36.000 MHz to 37.000 MHz
38.000 MHz to 39.000 MHz
40.000 MHz to 42.000 MHz
46.600 MHz to 47.000 MHz
49.600 MHz to 50.000 MHz
Background and History
SINCGARS evolved from basic simplex and duplex military systems operating in the low to mid VHF range (30.00 to 75.95 MHz) starting with the revolutionary PRC-25 radio (using 150.0 Hz CTCSS squelch combined with channelization vs. "tuning" greatly simplified radio operation and made it easy for the average solider to use a radio with minimal training). The US military pioneered the use of FM voice on the battlefield in World War II with the original "three band" system, allocating 20 to 27.9 MHz to armor (100 kHz steps), 27 to 38.9 MHz to artillary (100 kHz steps) and 38 to 54.9 MHz to infantry (100 kHz steps). The famous BC-1000 or SCR-300 backpack radio fielded in WWII operated in the 40 to 48 MHz range using 200 kHz steps and FM voice. Tank radios with FM provided vast improvement over AM-based systems on the battlefield. Improvements with radio technology allowed for all three bands to be combined and moved from 20-55 MHz to 30-76 MHz and eventually 30-88 MHz, reducing channel spacing from 100 kHz to 50 kHz (Vietnam War) to 25 kHz (SINCGARS and present day). With the addition of frequency-hopping and voice encryption the FM radio became the standard battlefield tactical radio for ground and air communications.
