AmRRON
American Redoubt Radio Operators Network also: The American Preparedness Radio Network (TAPRN)
Emergency radio monitoring/frequency plan prepper redoubter patriot militia emergency radio preparedness project for licensed and unlicensed users, following the 3 rule:
Monitor channel 3 for 3 minutes every 15 minutes at the top of the hour (:00), bottom of the hour (:30) and quarter past/quarter to (:15 and :45). Combination of channel 3 on the CB, FRS and MURS unlicensed services with specified frequencies in the various MF, HF, VHF and UHF amateur radio bands as well. Primary VHF amateur frequency is 146.420 MHz.
- CB radio channel 3 - 26.985 MHz
- MURS channel 3 - 151.940 MHz
- FRS channel 3 - 462.6125 MHz
- 2 meter amateur band ham radio - 146.420 MHz
Carrier squelch or CSQ receive is required. Transmitting CTCSS or PL is ok. See the pages for the three respective services for more information.
From the AmRRON website:
Make Contact In 3 – 2 – 1
- 3 (Turn your radio on and set it to Channel 3)
- 2 (Attempt to broadcast for approximately 2 minutes)
- 1 (Attempt again every 1 HOUR, on the hour, to save batteries)
Script: Simply use your ARN or AmRRON call sign, preceded by the word, “AmRRON”. So if your call sign is Tango-67, you would say “This is AmRRON Tango Six Seven.” *If you do not have an ARN Call Sign, then your call sign is “AmRRON…” and the initials of your first and last name (or just your last name).
Example: “This is AmRRON JULIET SIERRA” (if you do not know the phonetic alphabet, you could simply say “This is AmRRON J.S.”) Just get the job done.
If you must communicate “in the blind” (attempt to reach ANY AmRRON member who may be monitoring), then you can use the unknown party (or Hailing) call-sign of “X-Ray.”
Example: “AmRRON X-Ray, this is AmRRON Juliet Sierra. Does anyone copy?”
If there is a real emergency, you could also monitor CH3 to give assistance to others in need. To save batteries, monitor for 5 minutes on each side of the hour, to increase the chances of hearing another “Redoubter” who may be communicating using the “Make Contact In 3-2-1” method.
Remember, when making contact with someone you don’t know, always proceed with caution. You should always assume that all transmissions made are being monitored by other operators who may not transmit or reply back to you - even if you are making a general call.
Frequencies:
- 151.8200 MHz - Militia/Patriot MURS VHF MURS 1 - Tactical and Calling
- 151.8800 MHz - Militia/Patriot MURS VHF MURS 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
- 151.9400 MHz - Militia/Patriot MURS VHF Primary/Calling MURS 3 - AmRRON
- 151.9400 MHz - Militia/Patriot MURS VHF Patriot Nationwide Primary MURS 3 (see also: FRS 3 and CB 3)
- 154.5700 MHz - Militia/Patriot MURS VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
- 154.6000 MHz - Militia/Patriot MURS VHF MURS 5
Alternate VHF militia plans:
- 151.8200 MHz - Channel 1 - Operations MURS 1
- 151.8800 MHz - Channel 2 - Operations MURS 2
- 151.9400 MHz - Channel 3 - Calling Primary / Operations MURS 3
- 154.5700 MHz - Channel 4 - Operations MURS 4
- 154.6000 MHz - Channel 5 - Operations MURS 5
- 151.9100 MHz - Channel 6 - Operations VHF 6 Business Band
- 154.5550 MHz - Channel 7 - Operations VHF 7 Business Band
- 154.6250 MHz - Channel 8 - Operations VHF 8 Business Band
- 151.5950 MHz - Channel 9 - Operations VHF 9 Business Band
- 151.5050 MHz - Channel 10 - Operations 10 VHF Itinerant Business
- 151.5125 MHz - Channel 11 - Operations 11 VHF Itinerant Business
- 151.6250 MHz - Channel 12 - Operations 12 VHF Itinerant Business
- 151.6400 MHz - Channel 13 - Operations 13 VHF Itinerant Business
- 151.7000 MHz - Channel 14 - Operations 14 VHF Itinerant Business
- 151.7600 MHz - Channel 15 - Operations 15 VHF Itinerant Business
- 151.8200 MHz - MURS1 - CALLING / TACTICAL MURS Ch 1
- 151.8800 MHz - MURS2 - SOVEREIGN CITIZEN FREEMEN MURS Ch 2
- 151.9400 MHz - MURS3 - PATRIOT NATIONWIDE PRIMARY MURS Ch 3
- 154.5700 MHz - MURS4 - PATRIOT REGIONAL SECONDARY MURS Ch 4
- 154.6000 MHz - MURS5 - MURS Ch 5
- 151.7000 MHz - BIZ 5
- 151.7600 MHz
- 152.9450 MHz
- 151.8350 MHz
- 151.8050 MHz
- 151.5125 MHz
- 151.6550 MHz - BIZ 11 - BUSINESS 11 / FREEBAND / PATRIOT / MILTIIA
- 151.6850 MHz
- 151.7150 MHz
- 151.7450 MHz
- 151.7750 MHz
- 151.8650 MHz
- 152.7000 MHz - BIZ 18
- 154.4900 MHz
- 154.5150 MHz
- 154.5275 MHz
- 154.5400 MHz
- 153.0050 MHz
- 154.6650 MHz
- 158.4000 MHz
- 158.4075 MHz
- 146.4850 MHz - HAMV48 - 2 meter amateur radio ham channel 146.485 MHz Patriot/Militia
Links:
- [1] AmRRON Channel 3 Project
- [2] AmRRON/TAPRN About Page
- [3] AmRRON and TAPRN Local Prepper Redoubt Radio Nets and Frequencies
- [4] AmRRON and TAPRN Subregional Prepper Redoubt Radio Nets and Frequencies
- [5] AmRRON and TAPRN Regional and National Prepper Redoubt Radio Nets and Frequencies
