Revision as of 13:37, 17 June 2019 by R4002 (Talk | contribs)
Last updated: June 2019
3390 kHz AM/USB - used by Old Time Radio in February 2019 and March 2019
4015 kHz AM/USB - used by Amphetamine Radio and others
4020 kHz AM/USB
4025 kHz AM/USB
4060 kHz AM/USB
4065 kHz AM/USB
4080 kHz AM/USB
6770 kHz AM - used by Old Time Radio or OTR, considered to be OTR's "home channel"
6840 kHz AM
6850 kHz usually AM
6855 kHz usually AM
6868 kHz AM/USB - noted use by Mix Radio International (May 2019)
6870 kHz AM/USB
6885 kHz AM/USB
6886 kHz AM/USB - used by Mix Radio International in October 2018
6890 kHz AM/USB
6915 kHz AM/USB
6920 kHz AM/USB
6925 kHz most common frequency - virtually all modes have been heard +/- 1-2 kHz Many pirate radio listeners park receivers on 6925 kHz.
6930 kHz AM/USB
6935 kHz AM/USB - Latin American pirates can also be heard here (i.e. AD149 on 6934.8 kHz or 6934.9 kHz AM)
6945 kHz AM/USB
6950 kHz AM/USB
6955 kHz AM/USB
6965 kHz AM/USB
6970 kHz AM
7480 kHz AM - noted use by YHWH religious pirate (May 2019)
Euro-Pirate Radio Frequencies
  • 3920-3950 (75 meters)
  • various other bands, including within the legal shortwave broadcast bands
  • 9500-10200 kHz
  • 7400-8100 kHz
  • 6765-7000 kHz
  • 5000-6300 kHz
  • 8000 kHz - Radio Casa
  • 6925.1 kHz - RCW Chile
  • 6250 - Used in the 1980s
