SINCGARS
| Frequency Band |
| 30.000 MHz to 30.550 MHz |
| 32.000 MHz to 33.000 MHz |
| 34.000 MHz to 35.000 MHz |
| 36.000 MHz to 37.000 MHz |
| 38.000 MHz to 39.000 MHz |
| 40.000 MHz to 42.000 MHz |
| 46.600 MHz to 47.000 MHz |
| 49.600 MHz to 50.000 MHz |
Background and History
The SCR-300 and similar high-HF/low-VHF radios developed in WWII and the Korean War revolutionized small unit tactics. First the capability for a platoon or similar level unit to communicate with its headquarters or commanding elements and then the capability for each man in a squad for fireteam to communicate with each other in addition to the longer-range communications capability for platoon-to-commander and platoon-to-platoon communications using FM radio have changed the battlespace forever. The basic military backpack radio (and now handheld radio) concept has been copied endlessly, to the point where even militias and guerrilla forces use similar VHF/UHF radios for similar purposes. For example, see Ukraine militia forces using Baofengs (UV-5R, UV-82 and similar VHF/UHF handheld Chinese radios) and fighters in Afghanistan using Icom IC-V8s and other 2 meter / VHF handheld radios for battlefield tactical purposes, often in conjunction with 26-28 MHz CB type equipment or other similar radios/bands.
Communist Bloc countries, including the Soviet Union (and former Soviet Union, now Russia), Poland, as well as Western and Central European military forces also use similar frequency ranges (for example, 26 MHz - 70 MHz is/was a popular frequency split for tactical radios, instead of 30-76 MHz). Various handheld and manpack radios covering these bands have been manufactured and used in various countries.
As discussed in previous paragraphs, there is a move to COTS equipment, including non-standard radios such as amateur radios, VHF marine band radios, CB/11 meter radios and other land mobile radios in the VHF/UHF band for tactical purposes. Unfortunately, VHF low and VHF mid band does not work well in heavily built up areas (i.e. urban warfare radios). High band VHF and UHF work considerably better in these environments. It is because of this that the modern PRC-148 and PRC-152 radios cover 30-512 MHz instead of just 30-76 MHz or 30-88 MHz.
Evolution of military FM radio tactical radio bands: World War II, Korea and Beginning of Vietnam War (roughly 1940-1965)
| 20.000 MHz to 27.900 MHz | Armor Band (tank radio, tank destroyers, tank command nets) | 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc |
| 27.000 MHz to 38.900 MHz | Artillery Band | 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628 |
| 38.000 MHz to 54.900 MHz | Infantry Band | 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only) |
| 40.000 MHz to 48.000 MHz | Infantry Band (partial) | 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio |
Most of Vietnam War and Cold War (roughly 1965-1980s)
| 30.000 MHz to 75.950 MHz | Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control | 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 and dozens of others |
1980s-present
| 30.000 MHz to 87.975 MHz | Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode |
| 30 MHz to 512 MHz | Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps |
| 380-430 MHz | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes used for short range communications within squads/fireteams |
| 2400-2500 MHz (2.4 GHz) | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams |
