Revision as of 13:43, 12 August 2019 by R4002 (Talk | contribs)
Most of the transmissions you'll hear on these frequencies are from portable handheld radios - walkie-talkies, but sometimes high powered mobile radios or even portable repeaters are heard. Portable or temporary repeater output frequencies may be any of the VHF low or VHF high frequencies. On the UHF band, input frequency is 5 MHz above output frequency. In many situations all frequencies are used for simplex only. The 457 MHz, 462 MHz and 467 MHz frequencies are simplex use only and are often used for on-site communications using portable handheld radios. Note the Motorola RDX, CLS and XTN series default channels - these are not FRS/GMRS frequencies. Motorola FRS and GMRS radios use the standard 14 or 22 FRS channels. The default channels listed below only apply to Motorola business band radios in the RDX, CLS, XTN and similar series/variants sold in the United States
  • 151.6400 MHz - Itinerant - narrowband only, maximum bandwidth 6.25 kHz (generally 6K00F3E emission)
  • 152.9000 MHz - Motorola RDX default channel 19
  • 154.6250 MHz - Mobile or base (sometimes used for paging)
  • 154.6400 MHz - Mobile or base (154.6475 MHz/154.650 MHz/154.655 MHz start Public Safety frequency allocations)
35.180 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
154.45625 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.46375 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.47125 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.47875 MHz Operational fixed (SCADA, data links, telemetry, etc) only
154.505 MHz
154.5275 MHz Mobiles only
154.585 MHz
154.610 MHz
154.625 MHz
154.640 MHz
157.470-157.725 MHz 7.5 kHz steps, 157.5225 MHz to 157.725 MHz mobile/input freqs from old Taxicab Radio Service
173.20375 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.210 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.390 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
173.39625 MHz Operational fixed (SCADA, data links, etc) only - narrowband 6.25 kHz channel spacing
